View Full Version : Gas Engines
- I have
- New ZDZ-210 will not idle - lean
- MOVED: hi all
- Spark Plugs
- Mejzlik Repairs...
- 3w 42 and what prop / rpm ???
- zdz 80 heats to over 428 degrees???
- Evolution 35GT muffler??
- zdz80 vs evo 58 ?
- Sachs engine problem..need help !
- 3W-75 Engine
- 3W 70 Whats Wrong ??
- Trying to get mix right on Zenoah G-23...Bolts coming loose in flight.
- Patty W Extra 300 1/4 scale - Engine selection
- Taurus Engines
- Brand New 3w 106 Cactus SS, what kind of RPM should i get
- BME-100 kickback issues
- Walbro fuel draw problem
- MOVED: what fuel to use for my ENYA 4c?
- Zenoah G62 Inquiry
- ZDZ 80 header for MVVS 58
- Plane for Zenoah GT-80?
- zdz 50 ng ignition interference ??
- How to get mix right on a G-32...it doesn't sound like my OS..
- gas planes
- Any experience on Chip Hyde QuitePipe & BME 110?
- What Sparkplug for A&M 2.0?
- EMI problem
- Power box and 3W ignition
- Wierd ZDZ40 starting problem-Please Help
- Tank Position
- MVVS/Evolution 58GX, what muffler?
- DA50- Is this enough cowl cutout for cooling?
- Bill Morrison Custom In Cowl Cannisters - Where are you???
- adjusting the needles.
- Four Star & G38
- AHHH, Where are all the props!!!
- LiPo Ignition battery??
- What Size?
- ZDZ 50 RV vs ZDZ 50 NG
- Walbro carb kit help needed,please
- fuji 32b plug gap and fuel tube ?'s
- Another Beginer Gas user with a ?.
- zdz 80 fuel draw problem at startup only
- HELP!!! DA50 Tuning
- 3W 150Qs-need help
- rcign G-26
- glow engine to gas conversion????
- ZDZ Inverted
- Crankshaft Bent ????
- Usl 120, Brison,3W,roto?
- Zenoah 45 Choke/Throttle directions?
- RCIGN1
- Trouble balancing G-32 flywheel...saga continues.
- engine interference
- New Roto RM70 boxer
- Is spray brake cleaner OK for a Zenoah g-31?
- ARRG! Can't get flywheel off g-31. Nut and pulley off...
- How to keep bottom of flywheel from getting tore up on g-31... ps. you guys are great!
- BME 110
- How do you lock a Zenoah g-23? Want to remove flywheel...
- What is "RPP stage #2"? engraved on a used Zenoah g-23.
- I have a Zenoah g-23, but can't find the manual...anyone have a link?
- *G26 & Plane Combo*
- Gas Line setup help needed please
- YW engines
- best way to refuel/pump gas?
- G62 Throttle Plate Screw Orientation
- how sells these type of mufflers for 50-60 cc?
- Anyone try using a larger carb on a US41 for improved POWER?
- ZDZ 160B2 Champion on pipes
- The best 50 CC class gas engine for doing 3d?
- 3w75IUS enginge drill guide
- New 3W-157
- 3w24 muffler
- Quadra 48? piston rings
- 28 ounce fuel tank
- MOVED: WEED EATER PROP SIZE???
- BME 110x
- BME 50 Exhaust Dimensions
- Walbro (Roto 35) Needle Valve Help Please
- Questions about tuned canisters
- Quick Rx Battery Placement Question
- Roto 25 carb Gasket
- DA 100
- MOVED: professional home build ignition
- twin cranking on one cylinder
- When is Desert Aircraft coming out with a 75cc motor???
- Any BME 110 Extreme Users Using a Biela 3 Blade???
- Best gasser in the 40-45 CC range
- Big Problem with Roto 25 Needle
- How do you rate these budget priced props.
- Amsoil Saber
- ROTO 25...yeah or nay?
- da100 stand off mounts
- BME 50
- G62 exhaust
- thunder tiger 120
- RCS-ZDZ Service
- Zenoah G-26 Set Up Question
- MOVED: MDS 1.48 W/New Carb
- 3W 140 vs. DA 150 mounting holes
- Another prop question
- What prop on 2.0 A&M?
- Broken prop stud - Zenoah G-26
- Radio interference
- Spinner size for 22x10 prop?
- Ignition Battery Types
- fuji50
- Zenoha G45 / Zenoha G62 ?
- MAS Classic props
- 3w 120 canisters
- fuji 50 ignition
- quadra 50 muffler question... help
- ZDZ-80 I'm at a dead end.
- Fuel pressure problem
- Prop spacer on DA-50
- what engine to use?
- g-62 muffler problems
- Do u unload the gas from the gastank?
- Zenoah G-45 Prop and RPM
- MOVED: Carburetor question for 25cc Homelite
- DA150 Real World Numbers
- 50cc engines - which is quieter?
- Petrol Engine Drawings
- Hello
- King 100 Ignition Problem?
- gas storage and transport
- DA engine oil
- ZDZ 40 PARTS
- DA50 Prop Strike - Do I need to send in the engine?
- BME-50, spark plug is bad??
- DA100 throttle spring
- Question for RC Ignition
- DA 50 running rich when inverted, problem solved
- DA 150 ZDZ 160 and 3W
- Good supplier for G62 parts???
- reed valves
- Rx Glitches from spark plug?
- Cloud 9?
- carb for Quadra 52 needed
- DA-50 CARB MOUNTING?
- Spark Plugs
- What is this thing? Help
- What's wrong here?
- DA-50 1.25'' STANDOFFS FOR TOC YAK!
- Engine Cooling - Inlet & Exit
- use gas fuel tank for glow?????
- NEW EVOLUTION 116GX TWIN GASSER!!
- 3-W ignition problem
- Best way to kill a 3w60 from transmitter
- DA50 startup and deadstick troubles
- Fuji RF emmission
- DA 50 carb appears to be upside down?
- what 3-blade prop to replace a 28x10?
- how about a MVVS 35cc gasser in this,,,
- da50 mounting template needed
- ZDZ 40 Backplate Gasket Blown
- EVO 58 arrived
- Prop for 3W 106QS
- experience with MVVS 116 IRS ??
- Help with Sachs 4.2!!!
- Has anyone used a AVIOMAC 125 NEED HELP
- Need BME-50 ignition component.
- Your favorite wood props ?
- sig extra 300 w/q50
- RCIGN1. Read this
- G-62 dies in my TP p-51 maiden flight
- ZDZ 40 muffler
- da100 VS zdz100 muffler bolt pattern???
- 2 stroke mix in my 4 stroke engines
- Is this an A&M 2.0?
- 3w crankcae disassembly
- Best prop for G38 in a Spacewalker
- New MVVS gasser magnesium crankcase !
- Desert Aircraft 50 too ritch in inverter flight
- Gas engine GAINING rpm (Brison 2.4 muffler mod)
- ZDZ-210 owners
- Funtana 90 with Evolution 26GT? Crazy?
- Gas and Glo lubrication, an informal look.
- Help!
- Sample Oil
- MVVS 116cc Gasser
- Gas with FM
- FPE 2.4 throttle
- Fuji 32B install for a fokker DVII
- WHOA GAS ENGINE GLITCHES!!!!
- G-62 in a 87" Ziroli Stearman?
- 3W Prop Hub
- Who made this engine?
- Fuel Tank Repair
- I need ZDZ help/advise
- Aerobatic plane for a 31cc Ryobi conversion?
- Fuji BT 43 Ei. Comments please.
- Evolution 58 or ZDZ60 , which is lighter and more powerful?
- Prop Pins - Use them or take them off ???
- 3w 32-10 to mejclik 30-10 on zdz160
- Which propeller is best for Gassers ????
- DA 50 Run-in.
- Gas Engine Losing RPM
- DA 100 and What Prop/RPM???
- BME 110 Motor Mount
- DA 100 OR 3W 106 ?????????
- ZDZtach accessory
- ZDZ 80B2RV
- Quadra 40/42
- prop information for gasser
- Throttle return spring?
- priming 3W50
- prop on 100
- Why not ground the block?
- Cant get Fuji 64 EI started
- ZDZ80 failure mode!!!
- G-38 in a TF GS P-47
- ZDZ 50 carb settings and prop size?
- fickle Fuji 64EI
- MINIMUM PLANE WEIGHT FOR A ZDZ 160
- baffling gas engines for cooling
- ZDZ Question
- Taurus Engines - Comments Please
- Hydro Mount
- smoke pump
- How long is safe for a gasser engine to run inverted?
- brison 3.2 ????????
- new to gas engines
- BME 50vsBME 44
- 3W 106B2 Prop Hub Removal
- ignition battery interference
- reduction gear drive for Sullivan starters
- operating temp for genaric zenoah engine?
- Can I do this ??
- Suitable Exhaust Muffler for 28cc 3W engine
- Turn of the engine in the air
- Roto25 Needle Settings
- Carb problems with Quadra 52
- DA 100 / Mobil 2T break-in?
- FUJI BT 64 EIS
- DA-50R Starting Problems
- Best Spark Plug for FPE 3.2?
- roto 25 starting problem.
- 26cc/Edge 540 Combo?
- How to hand-start a Zenoah G-45??
- Wolf Predator 3.2???
- 3W old style w/ blue dot voltage?
- Giant U-Can-Do
- WILL A DYNATHRUST PROP RUIN MY ENGINE ???
- Prop Balancing ???
- Engine storage
- MOVED: crappy searching
- G62 vs 3w 60cc
