PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99
  1. Radial recommendations...
  2. QS 150 Needle Settings
  3. Super Tiger dispalcement numbers?
  4. Exhaust ports on DA 100 and 3W-100
  5. Hanging by the stab??
  6. G-45 Stock Muffler has vents!
  7. helllcat exhaust
  8. 3W Side carb/Rear induction??
  9. fail safe
  10. new 41 breaking in
  11. zenoah source coil specs
  12. What in Your Gas Field Setup?
  13. battery voltage for falkon ignition on ZDZ80
  14. Brison Website Down
  15. ZDZ50 how much does it weigh?
  16. Bent crank. You'll never guess how
  17. Name that engine part two
  18. Spark Plug for FPE 2.4 Engine
  19. Prop size for zdz40
  20. Help!! Need Advice On Gas Engine
  21. Name that engine
  22. just got my zdz 80
  23. BME 100 Twin
  24. RCS 140 ignition plug
  25. 30 degree V 2stroke twin-Possible
  26. 7.5 HP = what engine? Fuel consumption?
  27. Zdz 50
  28. Weedie twin.
  29. Ryobi 725r Report
  30. Pica 1/5 Spitfire - Engine Recommendations?
  31. Fuchs props. How are they??
  32. 80" H9 Cap 232: Moki 2.10 or 3.2 Gas?
  33. after run oils
  34. mag vs electronic ignition
  35. 3W with DA ignition...
  36. Gasoline Tank Vent Problem
  37. The different characteristics of prop brands?
  38. ZDZ-50...Walbro Carb WT-76=1
  39. Engine cleaner
  40. How big a tank do I need for my Brison 3.2 ?
  41. 1/4 x 32 spark plugs--good/bad idea?
  42. Tuning 2 stroke gassers?
  43. zdz 80 single 50lbs thrust? REALLY?
  44. ZDZ 40 Spinner Bolt
  45. B&B Remington 38, who has one
  46. What is the correct gas tank setup for my 3W100B2
  47. Homelite Twin
  48. fuel tank stuff
  49. ZDZ 40 RE muffler (please help !!)
  50. Fuel Mixing Strategy
  51. magneto vs electronic ignition
  52. zdz 80 on h-9 33%
  53. Zenoah G26 glow
  54. 2-blade & 3-blade comparison
  55. best 3 bladed prop?
  56. New conversion projects help needed
  57. 3W-75 w canister muffler?
  58. Zenoah G38 vs Homelite 33cc
  59. Big Bore Carb ?
  60. Poulan 50CC conversion
  61. old OS 46 SF
  62. Need Help With Moki Needle Settings
  63. Please help me design a mount for this Engine
  64. Smallest Gasser Available??
  65. Zenoah G26 - Performance Issue
  66. Is my Mac 3227 engine 32 cc's?
  67. 10 mm hole on prop for 5/24 crank....
  68. Twin YS engine
  69. Brison/Sachs 5.8............. any good?
  70. NEED HELP WITH MCculloch engine
  71. Quick question about gas.....
  72. Re: Da
  73. Spears Engines
  74. muffler pipe coming off
  75. Side-Load Bad for Crankshaft Bearings?
  76. McCulloch 32cc question/info
  77. BME 44 & 3 blade prop on warbird
  78. saito 120 vs. 100
  79. Brison website??
  80. Spinner for Taurus 52??
  81. G 62 and RC Ignition
  82. Bad transition on Brisson 3.2?
  83. twin gas conversion?
  84. Poulan Conversion 42CC or 46CC?
  85. Cutting carbon spinner
  86. US 41 won't start, pop, anything
  87. Fuji 64
  88. DA50 is Here!
  89. BGX or similar Muffler
  90. Any Informatiion on new FPE 1.3?
  91. Anyone had interference with metal throttle and choke rods?
  92. Need some help with a Brison 3.2
  93. Homey vs Zenoah
  94. Headers cracking???
  95. zdz 40 question
  96. J-tech mufflers
  97. ZDZ 80 Single What prop?
  98. Saito 182 td
  99. Any experiences with the FPE 3.2????
  100. Zdz60 Prop Size And Rpm?
  101. Has anyone put a G38 in a Hanger 9 T Craft??
  102. Where can I get a starting spring for my G-38?
  103. Quadra 35 no spark, Help!
  104. DA 100...anyone else waiting?
  105. Best price for new OS 160?
  106. HOW RELIABLE IS A MOKI 1.35 is it worth the $$$
  107. What size prop are you using on your gas engine?
  108. prop for Quadra 65
  109. muffler for OS 160?
  110. ? for rcign
  111. Starting a ZDZ
  112. "New" 80cc gas Engine
  113. Anybody heard of Precision Eagle 4.2 c.i.?
  114. huge gas conversion?
  115. homelite or mcCulloch ??
  116. T-Maxx Engines
  117. Gasser Newbie Engine Starting (Not!)
  118. G38 Crankshaft Straightening
  119. Just Got My Taurus TS-52......WOW!!!
  120. AW 31% Edge engine???
  121. Carb Spacer
  122. Us 41
  123. Rcs 180
  124. tru-turn back plates
  125. Homey hopups
  126. BME 50 vs DA 50 vs 3W50 vs Taurus 52 Pros and Cons??
  127. Us 25
  128. ZDZ 80 prop bolts
  129. 3w 60 Side exhaust Side Carb
  130. B.m.e 50 Exhaust
  131. Joss Stik
  132. Walbro Parts Needed
  133. Rcs 215 Help
  134. bme 3.5?
  135. Fuji 86cc twin
  136. Perry Pump Plumbing
  137. Advise: throttle linkage at right angle & on forward side?
  138. 3W Ignition Sensor
  139. new zdz80 props
  140. How bad is a prop strike
  141. Big Saito 4-strokes on gasoline
  142. Engine help!
  143. BME 100: Shake maker
  144. 3W100 3 Blade Prop
  145. Moki 2.1 fuel & starter?
  146. ZDZ 40B any good?
  147. Prop Reamer for a Moki 2.1
  148. Ryan weed eater (Ryobi?)
  149. fuji 32 on a stinger 120
  150. ZDZ 80 throttle management
  151. Moki 1.80 - FPE 2.4 how do they compare
  152. Adding smoke to JMB can
  153. Ignition and Muffler on US .41
  154. 160FX, best prop?
  155. Evra (Phelon) 190-old gasser?
  156. Fuel tank plumbing/ lean on downlines
  157. More Weedwacker
  158. Balancing a US41
  159. BME 100 Twin
  160. 3W 78B2 - is it good?
  161. Ryobi/Zama carb needles setting
  162. Flywheel cracks
  163. us 25
  164. Rear exhaust on big gas twin?
  165. Fuel Pump and OS160FX
  166. us engine 25 muffler needed
  167. gas engines HELP
  168. Do Bisson mufflers restrict performance?
  169. oil/gas mix ratio
  170. 160 FX woes
  171. ZDZ 80 (purchase)
  172. Brison 2.4
  173. tinker
  174. Feb. 2, Anyone got their DA 50 yet?
  175. 160FX Weight
  176. Fuji BT-32A dimensions
  177. best suited gas engine for the nosen p-51?????????
  178. supertigre 2000
  179. Pre-Igntion hot spots wanted (hot tube ignition)
  180. BME choke question
  181. saito mixture screw question
  182. ace big bingo
  183. ZDZ, BME, or ??? to Launch a Giant Glider
  184. China-Supertiger 2300 is in
  185. St 2300
  186. submit error
  187. B&B G-38 Mount - Questions
  188. Drilling props for Taurus 52
  189. disregard
  190. Sachs 3.2
  191. Gasser for AW 25% Edge 540?
  192. ZDZ 80 newbie questions
  193. Can a connecting rod be stretched?
  194. Moki 180 Break In
  195. ZDZ50 Got Yours Yet
  196. Break in Oil
  197. ZDZ60 WOn't start. My first gas engine
  198. RCIgn Where are you?
  199. Sachs 5.8 has gas pooling at idle
  200. Kill Switch for Taurus TS-52, What to use?
  201. Walbro carb for ZDZ 60
  202. Ether When Starting
  203. Homelite XL12
  204. Anyone know the weight of a Quadra 35 ?
  205. Ran my new OS 1.60 fx
  206. Any cooling issues with side mounted ZDZ80 in H9 Cap?
  207. which one should I sell?
  208. gas 4 stroke
  209. Lazer Motors
  210. Muffler restriction.
  211. Anyone running the RCS .44 twin?
  212. P & W 985 engine
  213. Krumscheid Dealer in the USA?
  214. Zdz 80
  215. Gas Engines Performance 25-41 cc
  216. 3-Blade Prop for G-38 HELP!!
  217. Big glow Engine
  218. Desert Aircraft....
  219. Going nuts. Saito 1.80 and BME 44 Mount?
  220. BME 102 evo shaft size - Not 7/16"
  221. Anyone flown an RCS 44 B2???
  222. Muffler dimnesions
  223. Can someone identify this engine ?
  224. 3w24 an Joss stick?
  225. Delete post
  226. Engine For Cap 232 25%
  227. 3W-50 thrust?
  228. Gumed up carbs
  229. weed eater featherlite 25cc
  230. Exhaust system--can you identify?
  231. Any new news MDS2.18?
  232. Big K&b Engine
  233. US-41 the newer version
  234. Is this too much prop???
  235. Need help with High Speed
  236. Brison/ A&M 2.0 engine
  237. Conversion Engine
  238. Which Engine ? see pictures
  239. Engine Recommendation
  240. zenoah GT 447
  241. Where To Bye Mejlick Prop
  242. Firewall Forward
  243. re: rcign Ignition
  244. Ignition-Magneto 5.8 only sparks when turned over extremly fast. Can't hand start .
  245. Easiest Conversion Homelite45 or Poulan46cc?
  246. MVVS 1.60 muffler
  247. Newbie Needs Advice from the Experts - Some Basic Questions
  248. 3 Blade prop on ZDZ 50
