PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 [47] 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Brillelli 40 Ignition Troubles
  2. P-51 D 60 Which Gasser for this One?
  3. Starting Problems
  4. Dumb Question for a gasser newbe
  5. SPE Engines
  6. What engines should I be looking at?
  7. Spec' of the thread , DA muffler pressure fitting
  8. Fuji BT43EI Broke crank in flight
  9. 75cc Yak 54 cooling baffles
  10. Any videos of the RCS 50VT 4st ?
  11. Tight spark plug on 50ng
  12. how to install new ignition on spe 26 (magnet repositioning)
  13. Evolution 35GT Muffler Keeps Falling Off!!!
  14. G-45 Pitts Muffler choices?
  15. Zenoah G45 Weight Reduction
  16. 4-stroke gas engines for 1/3 scale
  17. MOVED: Ryobi 31 cc Conversion
  18. Brison 2.4 cuts out in transition
  19. Creative choke levers for walbro WT carb
  20. Evo 35, Elec Ignition & Spektrum
  21. where to buy walbro carb parts?????
  22. MOVED: Question about removing the primer bulb
  23. G62 performance questions
  24. walbro carb for 100cc
  25. 50ng airframe vibration...is this normal
  26. Fuji BT 32B or Zenoah 38?
  27. DA 50 or 3W motor??
  28. Fuji 43EI end play
  29. New to gas engines...can I pick your brains!!
  30. oil question
  31. g-26 stud broke
  32. Good way to store an engine
  33. zdz 50ng transmitter question.
  34. How much gas should a G62 burn for a 30 lbs warbird
  35. DA-100
  36. Need some help with my 3W80B2
  37. carb trouble
  38. Roto 25V - Throttle linkages?
  39. Standoff Length
  40. Ignitions on A123 Cells??
  41. High End Tuning Question
  42. defective prop from Troy Built Models
  43. USE Engines- Need help
  44. Fuji 43ei performance question
  45. HH100cc twin
  46. Converting GMS 120 to Gas
  47. 3W 60i no spark
  48. DA-100
  49. Brillelli 25 GT v2
  50. Starting Options for Magneto Gas Engines
  51. MVVS 45 Canister inconsistant runs
  52. Sources for Penzoil Air Cooled 2 cycle oil?
  53. BCMA SPE 40 tuning problems
  54. Gasser Throttle Servo???
  55. 26cc gas motor, having some problems
  56. Where's BME?
  57. Pump Gas Ina NitroModels P-51D 60?
  58. Carb linkage for Evol. gt-35 (or any gasser)
  59. Locktite on muffler bolts 3W 60
  60. ANY ONE USING AMSOIL ..2/CYCLE OIL?
  61. oops
  62. Fuji BT 50 want to convert it to Electronic ingition
  63. MOVED: 1/4 SCALE 16lb Cub, What engine?
  64. G38 in a SIGs Extra
  65. Cooling Baffles...How 2??
  66. Solo 4 Blade prop on a Brison 4.2?
  67. CF tuned pipes feedback please
  68. Neoprene Question
  69. Evolution 26GT in a Dynaflite 81" Spitfire
  70. spark plug cap (metal or rubber) ?
  71. Best non-carbon prop for a DA-50 in a QQ Yak 54
  72. Looking for info on a DA 50 on a GP Christen Eagle
  73. Cans for DA-100
  74. G-26 & Zinger prop issue/need help
  75. K&S Header question
  76. Zenoha G-45 top end problem
  77. Engine Mounting
  78. DA 50 Surges at high throttle
  79. 3W-157 carb and choke linkage set up
  80. ENGINE WILL NOT IDLE
  81. Gear drive starter attachment?
  82. teflon coupler burn-through prevention
  83. TF corsair, G62 and propeller
  84. NEW Dumb Question about gas fuel tanks
  85. Idle level on a Fuji 43EI
  86. Dl 50
  87. Best fuel line size
  88. NGK CM6
  89. Help me tune the carb!
  90. DUMB ROOKIE QUESTION
  91. *G62 Overheating Or Not*
  92. Fuji 32
  93. Fuji front Bearing
  94. RCIGN1
  95. THOR 45 UPDATE!!!!!
  96. Brison 2.4
  97. MOVED: Saito 150 Problem Please help
  98. How long does it take?
  99. ENGINE TROUBLE
  100. Best Fuel Line for inside gas tank
  101. MOVED: I've searched....I can't find.......
  102. GF26I & Special 71inch Wingspan 3A/3D Plane
  103. G-62 Question
  104. cylinder or round fuel tanks
  105. 3W 55i Engine_Pros & Cons
  106. Taurus 52c engine worth $679??????
  107. Best source for a TNC tach
  108. What came first? Oil or the Engine?
  109. Thor 45cc Might be of interest!!!!
  110. 87, 89, or 91 octain
  111. GAS 45CC 18X6 PROP ?????
  112. Six to one prop adp.
  113. YW 48 twin
  114. Need Help! Timing a Quadra RSS-200 with C&H Syncro Spark
  115. New DA-50 tuning questions.
  116. BME 115 RPM
  117. *WH Extra 300LX Dual Elevators Different*
  118. (part 2) mounting the throttle servo on the motor/fire wall
  119. zdz 210 tuned pipe length
  120. Please HELP! Need a 1/4-28 Pressure Fitting w/Nipple
  121. WHAT OIL FOR OLDER ZDZ 160?
  122. mounting the throttle servo on the motor/fire wall
  123. ZENOATH 38CC ENOUGH POWER???
  124. WILL AN ELECTRIC STARTER START A GAS ENGINE?
  125. WHERE IN UK CAN I BUY A ZENOAH ENGINE?
  126. ZENOAH G45 high end power loss problem
  127. Taurus 52 for Midwest SuperStinker
  128. DA 50 or 3w 55i cowl baffels: Yes or NO?
  129. Zenoah GT-80 Twin
  130. Carbon Fiber Prop Drilling and Balance
  131. Muffler for side mounted G62
  132. Ethanol in Gasoline
  133. need advise..i want to buy my first gas engine but!!
  134. Is it too small?
  135. Air bubbles in my Gas line
  136. RC IGN website
  137. HELP! zenoah G38 will not flip start but will start with starter or rope
  138. New style 3W ignition on old style engine
  139. PCM Receivers for Gas engines
  140. Zenoah G62 Questions
  141. Throttle & Aux Channel Graph set up for TME smoke
  142. MOVED: Super Tigre 3000 Fuel
  143. Ignition module Cowl installation
  144. THOR 43 CC CDI PETROL.
  145. ZDZ Eats Screw Results
  146. BME 90 gasser problems
  147. Zenoah Questions
  148. Anyone uses Nicd for their RX pack on gasser/giant scale?
  149. DA 170
  150. wild hare 25% yak w/ g-38
  151. plumbing for OS 120 without pump
  152. Evolution 26ccGT Piece of Junk
  153. Simple Carb turning question?
  154. Gas engine
  155. Gas engine selection for A CUB and Taylor craft
  156. ZDZ40RE F3A
  157. engine dies offon the last 1/3 of a outside in verted loop
  158. Cannister cushioning
  159. muffler problems
  160. Desert Aircraft DA-85 ??
  161. Zenoah glow/petrol(gas) power output
  162. DA50 question,kind of....
  163. Brison 2.4 Smoke system
  164. BME 102/HELP
  165. DA-100 or 3W-106
  166. Need Help - Brison 3.2 Smoke Tap
  167. Carb hole in firewall- How big?
  168. Gas engine for a Seagull Super Star?
  169. fuji 50 conversion engine vibration
  170. g-26 props
  171. g-38 on dynaflite decathlon-best prop?
  172. Need help with smoker
  173. prop drilling
  174. My G-26 went south after 4 months
  175. *G62 Just Shut Down*
  176. What is the best clunk inside the gas tank?
  177. spark plug appearence
  178. MOVED: Help.... replacement plans for 68" CG Extra 300.
  179. G26, Abell muffler, poor idle
  180. G62 Lite prop position
  181. Evo 26GT....First gasser!!!!
  182. Leaving Glow, Going To Gas
  183. 3W75 quit in flight (Maybe ignition)
  184. 3W35 problems
  185. Flexible exhaust?
  186. Brisson 2.4 Carb and needle help
  187. 3.3m yak needs best engine
  188. How to convert Glow engine to Ignition gas engine
  189. Head Temp??
  190. Peak 26cc engine
  191. FUJI43EI : Idle is not stable
  192. Kill switch for Evo
  193. Published versus calculated thrust readings
  194. FUJI 24BT PROBLEMS
  195. Do all gas engines seem to get rich after takeoff?
  196. best prop fpr 3w 70cc
  197. Walbro carb spacer
  198. G 26 Zenoah Hand Start - How Hard?
  199. WALBRO CARBURETOR PROBLEMS ?
  200. HELP! zenoah G38 carb problems
  201. 3W 150 TOC
  202. DA50 & Slimline Pitts w/ Smoke - Install FYI
  203. SPE engines
  204. Evolution 26GT...... HELP!
  205. J&A 3.2 Spark Plug
  206. More Smoke On The Ground Than In The Air...
  207. G-62 Low RPMs
  208. Important Evolution 45GX2 cranking info
  209. DA-50 Exost Bolts
  210. JEM fuel dot
  211. Good First Gas engine?
  212. no popping starting procedure
  213. SPE26 Walbro carb tuning problem
  214. A little help with my DA 50
  215. Who make a cannister ready Ultimate
  216. Evolution 26? MVVS 26???
  217. quadra 42 owners manual needed
  218. DZY 48cc FLAT TWIN PETROL ENGINE
  219. ZDZ 80 super problem. Need help!
  220. Chicken Power??
  221. 3W 106 Velocity Stack
  222. Engine recomendation.
  223. Evolution 58 GX2 Ignition mounting
  224. G26 seems to be a little hard to start after it's warmed up
  225. SPE26 throttle linkage help
  226. Zenoah G26 erratic running solved (I think)
  227. Brillelli 25 GT V2
  228. 3W Ignition modual
  229. Fuji 32 ei
  230. DA 50 Possibly Overheating
  231. cmpro Giles 202 (140) with mvvs 35cc gas ??
  232. Exhaust Port Dimensions 3W70 -- 3W85 ?
  233. What type of painting color for muffer
  234. need help is their a mounting template for the DA 50 engine,
  235. BME no longer in engine business?
  236. Zenoah 23
  237. Where should my 50 EI idle?
  238. 3W 75 PROBLEM
  239. Fuji BT24 EI
  240. G- 38 question
  241. Slight play in crankshaft of G26
  242. DA-50 Weight (RTF w/standoffs + Ignition) ?
  243. Evolution 35GT
  244. Zenoah G20 Specs, Need Help
  245. 25cc GAS ENGINE BIRD???
  246. D.A.100 MTW Cans mid range problem!
  247. 3w 200b2 TOC
  248. DL50 props and RPM
  249. Little gasser.
  250. Quadra 42 crankshaft end play. Is .026 excessive?
