View Full Version : Gas Engines
- CH Ignition on BME 44 Problem
- g-62 syncro spark ignition
- US 41 cc..... ever use it?
- US41 - more power available?
- O.S.1.6 FX and a Cline Regulator
- ZDZ40 vs. Moki 2.1
- Problem Zenoah GT-80 Please HELP!!!
- mvvs 2.15 gas for a good price
- engine squeel
- FPE 2.4 problem
- Zdz 40
- G 38
- New Saito Engine
- Giant Engines
- Zenoah (Red Max) Engines--any good?
- C&H ignition for G62 & G45
- Super Tiger 2500
- Webra electronic ignition system
- new gas user
- BME Engine
- Honda GX31
- what is everyones take on starting fluid?
- Brisson 3.2 smoke port location
- GT-80 Zenoah and Hangar 9 1/3 Cap
- Throttle Pushrod for Gas Engine
- 3W80 & Tilottsen, Burbles-Gurgles & Sputters
- Pipe For OPS Maxi 30cc
- Any experiences out there with S&W mufflers?
- RCS 140 on 12lb Cap
- DA 50 on the testing blocks
- Saito 2.70 Twin Prop
- G-62
- B&B Smoke system for G-62
- Ryobi problem
- Fuji Engines ????
- ballancing a spinner ???
- Malonney 125
- Moki 1.8 needle settings
- How do you make a gas motor quieter?
- BME 50 Setup Question
- Mounting a U.S. 25cc engine
- Need some help on a G62----UPDATE--IT RUNS!!
- Kolbo Engine
- Giant Aeromaster Help
- H9 Edge BME 44 or Saito 180?
- Brison 5.8 question
- what size props?Q52
- g-62 crankshaft end play & vibration
- G-62 high speed needle
- da 100 ?
- Fuel mix for Zenoah G-23
- So What kind of Gasoline Do you Use?
- ZDZ Germany
- Gas pumps
- 1/4 scale corsair engine?
- Starting MVVS 1.6 gas?
- Please help identify engine and carb...
- OS 1.60fx muffler
- Size fuel tubing for 3.2 gas
- 3W smoke tap
- Mds 1.48
- Zenoah G-62 throttle linkage
- What size tank
- 6 Bolt Prop Dimentions
- Mac Minnerelli engines?
- Experience with TRD glow engine?
- multi-tank installation
- ft-300 questions
- Zenoah G38
- Brison 5.8 Prop?
- ZDZ 160 for Radio Craft 40%
- Engine Recomendations For 91" Hots
- ST3000 Prop Size - "HELP!"
- FPE 3.2 prop?
- Gas conversion that has good performance vs weight?
- Where to find ZDZ engines?
- 3W - What gas works best?
- Mds 2.18 ????
- OS 160 Pinging?
- Inverted ST 3000K in a H9 Cap 1.20
- Exhaust manifold leak???
- Perry Carb on ST2300. HELP!!
- Echo 21cc hop-up Carb?
- Adjusting The High/low Mixture On A Brison 3.2 To Allow A Good Transition???
- Oil mix-Fox 3.2
- Zenoah G-45 Plug Gap?
- Zdz ????
- Where can I find...20" 3 blade PRO ZINGER
- Moki Ignition (same as RCS 1.8) Question
- Anybody know what kind of engine this is???
- Throttle control rod
- Best muffler for ZDZ80/H9 Cap 232?
- On Props
- os 1.60 props for 12 lb edge
- How To Hook Up throttle on MVVS 1.60 Gasser?
- Large size propeller
- OS160 Twin four stroke
- G23 Fuel Flow
- precision eagle 4.2 on glow
- Help! I need parts for my Super Tigre 3000.
- BME 5.8 Twin (What octane?)
- HELP, Prop Size for a 3.2 Sachs?
- G62 Problems
- MDS 1.48-props
- mounts
- Zenoah G38, What pipe??
- H9 Edge 540 and BME 44 What do ya think?
- U.S.41 idle speed problem?
- 2.4 gasser I'm ordering one tomorrow
- Sachs 4.2 Muffler
- Walbro Card Maintenance
- Gas Engine Guide
- 1.60 FX w/Jett Engineering Muffler? What should I expect?
- Gt80
- which gasser for sig Extra 300xs
- 5/32 fuel tubing question
- Perry carb for a SuperTigre 3000
- O.s. 1.60 Fx
- BME 50 rpm and thrust numbers
- ST 3250 problems
- Saito 180 problems!!
- Poulan 30
- What prop should I use on Super Tigre 3250?
- Alternative engines
- Brison Or Zdz 60 ???????
- Brison with Bisson Pitts Style Muffler
- Fuel tank plumbing for Zenoah GT-80
- ZDZ 80 Muffler
- Throttle servo speed for gas engines
- moki 180 carb problem
- Need help with prop selection
- 3W Carb Snorkel
- Fuel Dots
- HELP ME with My ST 4500
- Best way to break-in new engines?
- Stand for running gassers
- Perry Pump ???
- Zdz Availability
- US 25. Is there anything that can be done?
- Backyard converter needed
- Inverted Saito 150 , good or bad?
- Break in
- Use of Fuel Valve or Fuel Dot in Gasser
- Kalt G-22?
- Fuel line in the tank
- Wolf Predator 1.8 Info Needed
- Magnum 1.80 Good? Bad? Ugly?
- mvvs power vs saito or O.S.
- G-23 Glow
- ZDZ Ignition Systems
- What Prop Size for ZDZ 60
- Zenah G45 prop bolt to long????
- Needles on 3W
- HELP! Brison 3,2 with CH Ignition. No Fire
- How much thrust can I get from a Ryobi?
- ST3000-"Run Time"???
- G-62 fuel flow
- Hand Start, Glow or Gas?
- Mds 1.48
- Engine Vibration: Gas vs Glow
- Carb adjustment on 3W 100 or 85
- Moki seized
- Fiber Optic Kill Switch For Gas Engines
- Please delete this message
- RC Showcase 140 Good, Bad, or???
- DA 150 verses ZDZ160
- Advice Regarding A&M/Sachs 3.2
- Engine selection for Weeks Solution...
- Servo amplifiers on long leads?
- RCS 140 Engine--Won't Run Properly
- Koritz gassers ???
- Kawasaki Mod. TA36 3.15ci
- OS 160 Power not all that.
- Remington 2.5 c.i (42cc) conversion
- ZDZ Expanded Warranty
- What Prop Size?
- 2 cycle engine oils
- Clamps on gas fuel lines?
- G-23 Muffler Replacement ?
- Fuel tubing size for big ST's
- Bme100 Vs Zdz 80
- First Place Engines
- Saito 1.20 Thoughts
- Big Apc Props Breaking In Flight
- Fuji BT-50SA
- Gas Engines, Cowls & Switches?
- Synthetic oil
- 3 blade prop for os 1.60 fx
- C&H Ignition
- 3W 75iUS (Side Carb)
- US 41 with Jump Start?
- Who's still waiting on a ZDZ80 single?
- Bme 50
- Pipes and Power
- ZDZ engines???
- H9 ULTRA STICK & US ENGINES 25 cc.
- Anyone using the FROMECO Fail Safe Reliaswitch
- Starting out- engine quality
- NIB Moki 1.8
- Engine Thrust: Is it the only factor?
- A club member asked if I should have a fire extinquisher with this gasser. Should I?
- Syncro Spark
- Mangum 46cc Gas -Data Wanted
- Request Picture of Gas engine installation
- Pitts muffler for G-62 on Giant Aeromaster
- Passing Gas
- Best muffler for Brison 3.2
- Smoke System Your Thoughts
- New to Gas....what do I need? (besides gas?)
- Do you start your OS 160 by hand or by starter?
- Interference, engine on - orientation dependent.
- Brisson 3.2, choked - kicks hard, breaks prop
- Relative smoothness of small gas engines
- Mufflers on a G-62?????????
- Prop size for a G-23
- First Gas engine - I think I'm in over my head!
- BME 44 noise problem
- OS160FX "Starting the Engine question"
- US41 won't run
- BME 102 hard to start!
- G445 idle ??
- 3W ENGINES HELP!!!!!
- Plumbing for gassers??
- Isolation Mounts?
- Best muffler for Zenoah G45???
- Northrop Drone Engine
- Prop 4 Quadra 35
- Taurus?????
- Zenoah G45 & Lanier Edge 540T
- old Quadra?
- U.S. Engines... any good???
- What brand/kind fuel tanks to use?
- air filter
- ZDZ airfilter
- Ever heard of an EVRA engine???
- B M E 50 weight + cost +smoothness
- OS 160 4-Stroke ????
- YS 140L prop choice
- Best Gasser for Giant Aeromaster
- Could someone give me a few website addies for RCS and MVVS??
- Fuji 86T?
- Irvine 1.50 questions
- 3W 100 or Da100?
- Gasser Newbie.. Brison 2.4... Help needed. :)
- OS FT-120 twin
- Props ?
- Glow engines vs. Gas engines
- Wolf Preadator Engine?
- 3W-24 engine
- What kind of oil and oil ratio are you running?
