PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. new to gas question
  2. Gas wont fire
  3. Gas plane and CG
  4. A-cubed
  5. Make A DA-50 As Quite As Possible
  6. 3W 55i starting problems
  7. Name this Gas engine!
  8. Saito Radial Glo driver
  9. clunk question
  10. Zenoah 26cc
  11. The spark plug of the world's most MINI
  12. MOVED: glow engines
  13. evolution 45
  14. Engine technology, how far have we come
  15. CHT
  16. Old G-38 questions
  17. DA50 ignition sensor position?
  18. EI question
  19. INFORMATION FUJI BT64IE
  20. MOVED: INFORMATION FUJI BT64IE
  21. Evolution 26 throttle linkage - H9 Cessna - any pics?
  22. Which do you own DA 50 or G-62?
  23. Fuel tank question
  24. Mounting gas engine need help
  25. Dynamite 12s Help!!
  26. DA50R Fuel Question
  27. Any one want to trade a Slimline for a DA muffler?
  28. What Is The Actual Weight Of A BME-105?
  29. Homelite flex shaft.----- Many questions
  30. tach engine problem
  31. Break in time coming up!
  32. Moki questions.
  33. racing gas (110 octane) + Zenoah G-23, what will happen?
  34. Muffler sugg. for brison 3.2
  35. Chip hyde's Quite Pipe
  36. fine tuning 26cc fg mt5 engine
  37. Aeroworks Yak Battery Question
  38. fuel lines
  39. Fuji 50BT
  40. Extra 260 and G38
  41. Is there a left and right ignition lead on a twin?
  42. ZDZ 50
  43. Evoltuion 26 GT: and best oil
  44. PT 27x10 prop and DA100 rpm?
  45. Quadra 35
  46. 3W-50I w Keleo Exhaust props/thrust
  47. Why is the fuel not being sucked into my engine?
  48. BME 110 -vs- DA 100
  49. Ralph's G-26 (Rcign1)
  50. fuel tubes, material type for gas
  51. Three blade prop on a 100cc engine
  52. SPE 26cc With Yak54
  53. 25cc homie
  54. DA 50 Crash - spare parts???
  55. Extra 260 27% ?????
  56. Wjhat is a reasonable flying speed for sport aerobatics.
  57. Small gasoline fuel injected engines
  58. 3W-200 vs 3W-212
  59. Twin Engines
  60. RE 52 settings
  61. Desert Aircraft - Super!!
  62. resistor in plug cap
  63. Where is Evolution 45GX made in?
  64. Questions regarding DA 50 muffler options
  65. RCS 140 experience
  66. US 41 questions
  67. Quadra 35
  68. 39% Engine choice?!?!
  69. Brillelli Logo Contest
  70. DA50 ignition trouble - intermittent connection?
  71. Will Your Gas Engine do This ????
  72. help on 3w 50 install
  73. I need a custom muffler for Fuji BT-43EIS
  74. Has anyone installed a power generator to the gas engine on your plane?
  75. where to find MVVS .15 diesel in US?
  76. DA50 VS G62
  77. Dynatron geared starter for gas??
  78. Hayes for gas?
  79. Voltwatch Question
  80. pressure
  81. Ignition Interference Problems
  82. Onboard Starters for Gas Engines
  83. help, wierd G23 running problem
  84. Fuji 43 EI tuning question
  85. Brillelli 40cc carb question *Updated Photo*
  86. Futaba Switch for E.I.
  87. DA50 Slowing when Inverted
  88. Q42 static thrust
  89. What is the best engine in the 100cc market?
  90. bme 110 and carb problem
  91. Let's talk PROPS
  92. Evolution 58GX-2 throttle sticking
  93. reed valves for M&R 100
  94. XOAR Props: Where do you guy them?
  95. Evolution 26GT Information
  96. 3w80Xi on canister very peaky
  97. fuel
  98. Evolution 58 problems?
  99. Taurus 52 Manual
  100. mig 27
  101. DA 100 IGN PROBLEM???
  102. will this exhaust mount work?
  103. homelite 25cc gearbox?
  104. DA 100 and 3W 106 W/Muffler Weights
  105. Good Idle, won't transition
  106. Should I install the ignition regulator before or after the switch??
  107. BME 50- rough idle
  108. G230 PORTING FOR TORQUE
  109. how long will it run
  110. really bad radio glitches while running...
  111. HITEC EQUIPMENT ARE POOR FOR GAS ENGINES
  112. Giant Big Stick and BCMA SPE 40 Build
  113. Engine ID for Experts Only
  114. fule tank mount
  115. electronic ignition
  116. Fuel Line Size
  117. Fuji 32 IS IT ANY GOOD?
  118. velocity stack/ G38 "what angle ??"
  119. DA50 question
  120. throtle servo
  121. MacC engines
  122. 3W80Xi spinner bolt size
  123. Need Advice
  124. Newby Needs Advice
  125. Sullivan SkyWriter smokepump??
  126. G-62 spinner adapter
  127. Zenoah brand synthetic oil - shelf life?
  128. Fuji 32EI
  129. As engine run in, which needle to reset?
  130. Giant Bug Stick Mount
  131. BME 110 mounting dimensions
  132. Brillelli 54/60
  133. BT-43 EI fuel tank size
  134. New to gas HELP!
  135. smoke on quadra 42
  136. E.M.I. interferance ???
  137. Walbro Source
  138. Evolution 26 out of tune
  139. New CDI ignition system
  140. DA spark plug
  141. Old A&M 4.2
  142. Q-75 coil
  143. Sachs 3.2
  144. Zenoah G23 info?
  145. SIRIO .12 evo 3 motor question
  146. Evolution 45GX and 58GX starting backwards
  147. what prop for quadra 42?
  148. Changing Angle of Carb Fuel Inlet-BT32
  149. Fuel boils back out of carburetor.
  150. starter question
  151. 3W 157 low end not steady
  152. THOR 45CC CDI GAS MOTOR
  153. Evolution Ignition Shorted
  154. Wanted: HomeLite 25cc blower engine shaft
  155. DA service is hard to beat!
  156. Which engine prop combo
  157. IPONE 2 STKE OIL RIGHT MIX RATIO?
  158. G26 Checkup?
  159. DA Manual Conflicts - Telecon
  160. G26/644 bulb type carb
  161. 3W-75i STILL won't draw fuel
  162. ZDZ Super 160 dimensions?
  163. Replacing a Brison 3.2 with an RCIgn G62
  164. Sachs 3.2 spark plug
  165. ZDZ 50 NG ignition setup
  166. Evolution 58 GX-2 Ign question
  167. Bi plane
  168. help compare engines for me please
  169. Velocity Stack ???
  170. Velocity Stack ???
  171. Zenoah G20EI ignition on single LiPo cell
  172. gp extra 300 patty zenoah muffler
  173. Brison 2.4 Muffler Recommendations please
  174. DA 150 plug gap
  175. Evolution 26GT muffler
  176. Copperhead Venom Motors
  177. Where to buy GOOD synthetic 2 Cycle oil ???
  178. MVVS/EVO 26 carb
  179. What's the story with Ethanol effecting carbs ? >
  180. 3 line fuel tank
  181. Reed valve
  182. Walbro WT-76B Carb Kit
  183. Brison 3.2/ SUDDEN problem!
  184. Oil for G-38
  185. Fuji 32 EI and possible RF Interference
  186. Ignitions
  187. Electroinc Ign Mod. Testing
  188. Kroma 50cc-Anybody got one?
  189. Zanoah G45 Problem
  190. Hard Starting DA50 - (Not Starting)
  191. BCMA SPE26 vs Brillelli 26SS
  192. ZDZ 80 rv tuning
  193. Evolution 26GT quitting......
  194. Replacement probe on Vlach EZM 1 TI?
  195. 3W-75i fuel draw problem
  196. Plane for a Zenoah G45
  197. Electronic Ignition Conversion on US 41cc????
  198. Fugi BT 32
  199. BT64A No Spark at The Plug
  200. zdz/walbro pain and sorrow
  201. DA 50 Muffler Options?
  202. Quadra Engines
  203. DA 100 - starting drill?
  204. 3W 106 engine tuning issues
  205. zenoah g-62 w/electronic ignition
  206. Hard starting ZDZ
  207. Evolution 45GX2 LOVE IT OR HATE IT
  208. Aluminum or CF Wing Tube Suppliers.......
  209. Ignition
  210. Fuel Proof Paint for gas planes
  211. What other Engines are directly compatible with the traxxas pro .15 engine?
  212. Which to decide 3W55i or DA50r??
  213. BCMA-SPE26 - 26cc Engine
  214. 3W 85B2 Feedback?
  215. LOOKING FOR A GASSER BUT WHICH ONE??
  216. Engine runs different during K.E. flight
  217. "help" McCulloch Mac 2181 (PRO MAC) "28cc"
  218. XOAR Vs MENZ 27x10 comparison?
  219. Read my plugs!!!
  220. EVO 26 cc engines: opinions
  221. Why won't my FPE 4.2 transition?
  222. Cant find Lawn Boy in San Fernando Valley
  223. Zenoah 62 please help
  224. Tartan Twin
  225. Need heavy spinner - Suggestions.
  226. da50 problem
  227. Engine makes loud intermitent pop noise in flight?
  228. Gasoline tank to smoke oil tank?
  229. ZDZ50 Ignition work on ZDZ80 (Falkon)?
  230. choke vs throttle position
  231. Electric Starting Zenoah G-62
  232. New style 3W Ignition running on Lith-Ion vs NiMH
  233. Anybody using carbon fiber for the throttle pushrod?
  234. brisson 3.2
  235. G-38 Mufflers
  236. Hopping up a Q35
  237. G-62 jug
  238. ZDZ50NG problems
  239. DA50r guestion
  240. Air filters for Zenoa engines
  241. Smoke system making a mess inside my plane
  242. How much fuel does a G26 use up in 10min.?
  243. NB! 3W QS CYLINDER HEAD BOLT FAULT
  244. Help me Quiet down my airplane!!
  245. 26GT caused fire
  246. kroma carb
  247. Chicken stick for gas engines
  248. MOVED: Fantom Engines
  249. Brison Manufacture moved to Ontario
  250. Brisk Spark plug alternative for MVVS/Evolution?
