PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 [80] 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. ZDZ-80RV on a cannister help
  2. Brison Service?
  3. Toledo
  4. Do I need a gasket??
  5. Converted Zenoah G26 performance
  6. Contacting BME Engines
  7. Increasing Fuel Efficiency
  8. 4-Stroke Gassers?
  9. Flew my G-26 powered Chipmunk fully cowled in, with the muffler I built. Success.
  10. Picture of Hydemount for large gas engines
  11. NEW BIE to gas setting up DA 50
  12. G62 Mixture problem
  13. newbie - please explain types of ignition?
  14. Pipe length between engine and muffer
  15. BME 55 Extreme
  16. is my G2D just worn out?
  17. Proper Static RPM's for a Small Gasser
  18. Brison Ordering Information
  19. Zenoah G-26 and Amsoil 100:1
  20. need engine advice.
  21. WILL IT WORK
  22. muffler for a RCS 140 R/E
  23. Loocking for kalt kg 22 parts!!!
  24. MVVS 160 engine ignition
  25. RB1004-WS7
  26. G-38 Walbro Carb Rebuild Kit Part #?
  27. DA 50-R Igintion Kill Switch
  28. Cannister muffler
  29. Pinch test on Gas Engines
  30. Fuji 64 Problems
  31. WHAT SIZE GAS ENGINE
  32. Prop shaft diameter for a G23?
  33. G62 Zenoah vs ZDZ 60
  34. PK props
  35. GT-80 IS THIS A GOOD ENGINE
  36. BME 44 & 50 Same mount Dimensions???
  37. Zenoah G26 Answer About Conversion Weight Savings
  38. idle problems
  39. us 41 on 77" extra
  40. G38 Question
  41. Spark plug??
  42. Regular muffler to smoke??
  43. Homelite 25cc fuel oil mixture???
  44. Kudos to Brison
  45. who makes this engine? help?
  46. gas engines
  47. BME 110 CC pressure tap
  48. Power requirements for DA-50
  49. Where to buy aftermarket mufflers for G23?
  50. Mixture rule of thumb???
  51. G23 CARB SETTINGS??
  52. Pitt's style Muffler for O.S. 91 Four-Stroke
  53. Fuji 50SA plus GP Christen Eagle II
  54. 3W 100QS or ZDZ 120 for 35%'er
  55. K&S or Pefa mufflers
  56. Mounting the DA 50??
  57. Considering Zenoah G26
  58. YW Engines- Anybody using one?
  59. FPE 5.8
  60. Fuel Tank Question
  61. Poulan 46 rcignition
  62. Request for comments on A&M 2.0
  63. How long do i need to wait to 3D a ZDZ 160 champion?
  64. Elongated crankshaft with ballbearing
  65. DA-100 RPM's
  66. DA50 with Slimline Muffler Dimentions
  67. Zenoah G-62 engine mount.
  68. Need info on the 3W-75I
  69. zenoah g 26
  70. Which is the stronger engine? DA 150 or ZDZ 160 champ?
  71. zenoah g26 help!!!
  72. DA-50 video
  73. B&B contact
  74. 3W150ss needs tuning help... VID
  75. Desert Aircraft Engines
  76. FPE 5.8
  77. Throttle movement resolution
  78. nova power trap
  79. BRISON 2.4 VS FPE 2.4 ?????
  80. DA_100 Idling Problem?????
  81. Fuji BT-50Sa + Zinger Pro 22x6 ???
  82. G-62 fuel consumption
  83. A big gift to RCSHOWCASE!! (those who like the products and service, come on in)
  84. Mechanical advance ignition
  85. Dale Abell muffler
  86. 3w break in
  87. Electronic Ignition for Mac Minarelli 85cc twin
  88. Brison 4.2
  89. 3W-106 - Prop Choice
  90. Taurus engine
  91. Educate Me Please.
  92. ZDZ 80, H9 33% Cap, what size fuel tank?
  93. Tell me about your YW Engine
  94. Pro Spark Ignitions HELP !!!
  95. Headers for ZDZ 160 Champion
  96. Help...I Need Carb for 3.5 BME
  97. Check these out New DA fuel dots
  98. ROTO 35
  99. Exhaust flange
  100. FPE 5.8
  101. Fuji BT-50SA + GP Christen Eagle II + Spinner
  102. US 35 and 41
  103. Need Starter Spring for TRD Gas Engine
  104. I need options (50cc options!)
  105. bolt prop into hub what torque? Help!!!
  106. DA50 and slimline muff. mount
  107. Twin troubles
  108. 4.2 Ignition
  109. ZDZ100 vs BME102
  110. Curiosity is killing me...
  111. DA 150 Canaster mufflers
  112. Electronic ignition for a G23
  113. J & A "Peace Keeper" Mufflers?
  114. walboro wt 603
  115. Brison 4.2
  116. Brison 4.2 Question
  117. Fuji 50SA vs 50SB ???
  118. Does conversion roughen an engine?
  119. ZDZ 80
  120. Question 3W vers DA vers CH
  121. DA-50?????????PROPS?????PROPS??????
  122. Is this going to be a problem with my DA100?
  123. Brison 2.4 vs prop
  124. G23 Walbro fuel flow problem
  125. ZDZ 60 Question ????
  126. Brison 2.4 throttle/timing advance is stiff
  127. New Brison 100 twin
  128. Drilling Props for the DA 50
  129. Old Gas Engine????What Kind???? Help Identify???
  130. bme102
  131. Walbro needle valves How do you tell the difference?
  132. RCS 1.40 ignition box
  133. G-62 problem
  134. Q35
  135. Maybe a silly gas engine ?????
  136. Header and canister?
  137. Problems With Zenoah G-26
  138. RCS44B2 spark plug problem
  139. Quadra 42
  140. Quadra 75XL Info
  141. fuel tank tubing
  142. New Pricing
  143. which gas engine for...
  144. BME 110X single bolt prop hub???????
  145. Glad to finally see it!
  146. Brison Engine Support Forum
  147. G-23 header
  148. Please-Need carb help on a Zenoah G-45
  149. Abell mufflers-what is web sitr.
  150. DA 100 Mufflers
  151. 3w/ngk/resistor/rfi...
  152. Need advice about Kavan 50 twin 4 strokes
  153. Quadra 35 info needed
  154. engine ideas for meister corsair?
  155. ZDZ 60 Please help!!!
  156. DA 100 Fuel Consumption
  157. ANYONE HAVE ANY DA-50 Mounting Pictures
  158. Castrol 2 Stroke Oil
  159. Need picture of G-62 carb linkages...
  160. fuel proofing for gas...??
  161. (Linked) Zenoah G26/Four * 120 Questions . . .
  162. Mvvs 2.15 muffler
  163. Voltage for DA-50 ignition
  164. g23 throttle adjustment
  165. Lawnboy substitute ?
  166. Maloney 125 Gas Engine
  167. Quadra 42 v. US 41 v. G-62
  168. Brison 3.2 rpms...props
  169. DA 50 Muffler and other ????
  170. Will props drilled for DA or 3-W fit ZDZ?
  171. ZDZ 80RV canister or pitts muffler?
  172. Questions about 40cc to 60cc engines
  173. QUADRA 40cc any good?
  174. Bullet shaped spinner--Who makes one
  175. Mounting a Fuji 32 on a Ultra Hots
  176. Bisson muffler on DA50
  177. Novarossi RX-21 WMO ?????
  178. No spark ....... ignition problem, checklist??
  179. Zenoah G-62--converting to synchrospark?
  180. New 3w 100
  181. How I have a good start in my quadra 35
  182. BOLD mufflers website
  183. Help me ID this never used 50cc engine
  184. G-38 prop bolt question. Which Truturn adapter bolt fits the steel prop driver?
  185. Please read before posting.
  186. Video, BME110X Comp Arf 40% Extra.
  187. Prop size and make for a ZDZ 50 RV?
  188. Giant Airplanes Fuel Containers
  189. What engine is this???
  190. US 41 vs. Quadra 42
  191. US engines CDI ignition
  192. Walbro carb rebuild
  193. Thrust measurement of G45
  194. G62 spring starter
  195. G38 Muffler Recommendation
  196. What spinner for Zenoah G-45?
  197. Break in question and confusion
  198. Engine for Hangar 9 Cub or Super Cub?
  199. Bing Carb. on a ZDZ80B2
  200. Oil Specifications?
  201. What engine is this?
  202. High-test gas for U.S. Engines 41cc?
  203. Frayed plug wire shielding
  204. MVS 2.15 gas?
  205. smallest gas engine
  206. G45 and B&B Muffler question
  207. How does the propeller effect left thrust?
  208. Wow! No one needs help?
  209. How quiet is the ZDZ 160 champion??
  210. Taurus Engines
  211. Pics of DA 100 installed in the H9 sukhoi
  212. Muffler for a G23
  213. G-23
  214. 3w50i or DA50 in Kangke (SuperKraft) Laser 2000 ?
  215. Walbro Carbs ?
  216. OS 65 LA
  217. ZDZ 50NG and ZDZ 60
  218. Need a plane for a Taurus TS42
  219. DA 100
  220. remote needle valve
  221. Carbon throttle pushrod RF interference ?
  222. Engine size
  223. 3W 106 Break in
  224. Engine Identification Help!
  225. Rookie Questions
  226. MVVS 58cc Gasoline Monster Engine
  227. Matching Engines to Airframes
  228. 3W 106 QS with intake
  229. Zenoah G45 mufflers
  230. BME 110 Extreme Feedback....
  231. 3W 140 prop washer
  232. Brison 3.2
  233. tell me about the Zenoah 45,,,
  234. gt 80
  235. RCS 44 TWIN (First run on test bench or in model)?
  236. YW engines?
  237. question on A&M 2.0
  238. BME 50 help
  239. HP or Torque?.....what do you need to spin the prop
  240. Taurus engines
  241. zdz 120 or 160 info
  242. Selling used 3W's
  243. Go back to using 3W?? (multiple selecttion)
  244. Please, i need some little help w/my 3w106
  245. Engine Thrust stand
  246. What's up with Taurus Engine web site
  247. Fuel tank setup
  248. ZDZ60RV Bearing play
  249. Prop for G-38 ?
  250. DA50...which pitts muffler??
