View Full Version : Gas Engines
- Gas engine experience
- Evo 26GT + Seamaster 120 combo?
- TORCH 60 CC
- How much power???????????
- zenoah transfer to husqvarna
- Evolution 45 carb number
- SAITO FG 36 (220) Gas Four Stroke - Anyone Got One?
- WHICH VESS PROP ON A DA-50 FOR 3D???
- Brillelli 366Gt on a UltraRC 29% Giles-202
- Ebay G62
- G45
- Mastang 50
- SPE Petrol Engine; Throttle Linkage
- Evolution 26GT and Greatplanes Venus 2 ARF?
- Teflon Burning Through
- Skorepa Prop for DA50
- gas fuel tank question
- TYGON
- Oil Mixing Chart
- MVVS 26 cc gas inverted assembly.head low
- YW 48cc Boxer, flange size
- torch 180cc
- Fuel/Oil ratio
- DA50 - No Fire
- Pitts for a Zenoah G-20?
- DA 50 help....
- Taurus 52 experiences
- Throw some light
- Ignition Battery on top of Rx Battery?
- Manifold length formula?
- I have an Evolution 45GX2 engine and I need another choke shaft.
- Good engine for WW1 fighters - 1/4 scale
- Help with 3W-24 idle
- Volk Props - Are they any good?
- BME 105 vs DA 100??
- direct comparison
- Tapping a Quadra 42 for Smoke
- Prop rpm's
- zenoah G-23 midrange
- Bold Muffler
- Smoke system question
- runing gas in a glow engine
- BCMA 62, Real Zenoah or Clone?
- Help needed with Zenoah 62 Carb ???
- Prop for old 3W 150
- 50 cc 4-stroke.... anyone got one ?
- SPE and BCMA same engines?
- 3W-75 Info Please Chime in!
- Lathe for Gas engine work
- Power + reliability + bang for the buck = ???
- DA50 temperature reading after landing
- Baffling a Gasoline Engine
- My DA-100 IN COOL AIR
- Need engine for Piper Cub
- Which is best tuned pipe fo ZDZ-50NG ??
- Differences in Brison 2.4?
- Zenoah Diesel conversion?
- Spinner on a Zenoah G-26?
- 3w 55cs
- 50cc class Engine for Iron Bay Cessna 195
- DA50 Muffler Bolts
- GF45
- how to make smoke oil for a 3w 100 twin
- ZDZ 40 RV-RE
- G-62 on a Hyde Mount?
- zenoah g26
- THOR 45 CDI at Hobby People Comments
- Fuji BT43EI good as a first gas engine?
- Kroma 50 Any actual Users
- Winter time in upstate NY, time to design a better bug trap
- g62 piston
- Gas engine mods
- Walbro WT76A
- OK to cut stacks on Pitts Muffler?
- Mick Reeves Torquemaster
- airplane and engine knock offs, knockoffs
- DA 50 overheating
- Starting a Zenoah G62
- Best Gas Engine? A Nitro Guy Needs Help
- Alpina gas engines, what do you know?
- Ch ignition setup confusion
- What's happened to Aerotrend...
- XTREME COMPOSITE EDGE 540T 2X2
- How many props Have you or do you break on average?
- glow to gas for large supertigre's
- Fuel line that won't get hard? Is there any?
- Brison 3.2 crank play
- wae 342 prop?
- WALBRO FUEL FILTER/CLUNK??
- New Fuji BT24
- Anyone know any info on this Cloned DA?!
- 50cc engine choice
- Gas Oil Mixture
- suggestion on gass engine to sukhoi
- zdz 80rv difficult to start up
- DA 50 quits in blenders
- connected headers on twins?
- Choke setup DA-50 H9 Extra 260 27%
- Zenoah G26 or Evolution 26GT?
- Spring Starter Lubrication
- Meeting 94 dB Noise threshold at 3 meters
- WH plane and Brillelli engine combo
- Engine for 18lb plane
- Walbro Winter Storage
- 3W 55 CS
- super tigre 90 on gas
- U.S.41-on a___?
- DA 50 problem
- Ran the BME 115
- MOVED: marine conversion Craftsman 32 CC weedeater
- 3W or ZDZ
- Zenoah Help
- ZDZ 160 Carb????
- Centering the Carb Butterfly?
- DA-50 DA 50 Whats your carb settings?
- Gas engine fo 68" EF Yak
- SPE 40cc engine experiences
- What size of motor for a 60lbs plane?
- where can i learn about carbs?
- who sells airworld radial engines?
- Help on starting a Quadra 42 gas engine.
- 3W Casting Imperfections
- Da-100 Ignition
- What does GAS stand for?
- New G62 Question
- Which engine between these?
- Questions about ZDZ 60 RV
- B48 twin Overheating
- Engine started but no throttle response at all????
- Evolution 26gt Any good?
- what a difference a prop makes - DA50
- Rebuild Instructions for Walbro
- DA 150-3W140 measurements
- Gas or 4-stroke?
- Engine Cowl Cut Out??
- G38 starting problems
- CH ignition, HELP!!!!!!
- MOVED: os 40 asp 46
- US41 engine
- New Trailer
- BT43EI hall sensor issue solved
- HELP! Something not right after crash. Engine won't start
- Copperhead Mfg. Co.
- radio servo chatter ( CDI)
- MOVED: Help the challenged. Please Identify this converted weed whacker
- First Place Engines 3.2 ??????
- Saito Gasser
- ZDZ-50 Problem! Please chime in if u can help!!
- Brillelli 26cc or Zenoah 23cc
- 3W75 Radio Interference
- 3W Service?
- Smoke System - need Help!
- brillelli 40 vs fpe 2.4
- stand offs for a da 50
- *QQ 73 YAK"/Brillelli 40cc GT*
- DA150 Header length for Greves Pipes
- WANTED:Walbro 167 carb
- 27x8 Propeller
- Walbro ????
- Christian Eaglewith fuji 50 NEED HELP
- New Taurus 3.2
- Nagging G62 Problem
- Impromtu Vess props comparison
- ch ign for g20...?
- g20&h9 p-47..?
- Roto engines
- New crank or call RCIGN
- Evolution 45GX2 prop bolts
- Need Feedback on BME 90 (ST on gas)
- DA-50 And 1/4 scale 300
- DA 50 Throttle linkage reversed?!?
- Opinion of the Fuji-Imvac BT-43EI
- is it ok to run a T between the tank and carb 3W?
- What prop size??
- Slimline Excel Fueler
- BME 50cc problems
- evolution 26 gasser
- BME 76
- NEED Ideas
- Help me ID this 3W engine ?
- Brillelli 23SS
- muffler question
- What engine is this ?
- Walker Sachs 3.2 Repair
- Airworld 60 problems
- Need crankcase seals for Q100
- Da 50 8 MIN flight
- Yet another tuning question...
- Quadra 42 Help!
- Revolution 52 dimensions???
- Gas versus glow engine
- 50-100cc Comparison - Need HELP!
- RCIGN, Is this Your Work?
- ZENOAH GT 80
- 3W and ZDZ (80xi, 80xics, 80rv and 80rvj)
- Breaking in the DA50R
- need some advise please
- MPG on a G 62
- DA50 sensor wire question
- Difference between BCMA and Brillelli
- H9 33% Edge 540 and 100cc Engine
- Constant Speed Prop Test
- Mysterious 3W engine (pics added)
- 2 cycle oil debate
- MVVS/EVO 45gx2 spinner backplate
- SPE 26 CC CARB.?
- DA-50 Deadstick on Inverted
- 3W Ignition - Ch Ignition ... ??
- Brison 2.4 engine missing parts
- G62 and Mejzlic 22 X 10 prop RPM?
- G62 vs. DA-50 real comparison
- DA 50 wont start
- Needing to make my own header pipe for my G26, any ideas or help?
- Super Tigre Twin Info Needed
- KROMA 100cc ENGINE MOUNT DIMENSIONS HEIGHT AND WIDTH
- Wing Loading and Cubic Wing Loading
- yea or nea on evo/mvvs 1.6
- DA100 acting strange
- Brillelli 366GT *60cc*
- Maloney 1.25
- UAV Operators.
- BIG Problem with US41, Please help
- BCMA-SPE40
- help with engine size
- UnusalCox Engine
- old 3W 80B2(twin cylinder)
- ZDZ-60 -vs- MVVS/EVO 58
- Zdz 80 or BME 110/115
- Gas Engines from AK Models
- Wood 22 X 6 Prop
- Evolution 58 Spark Plug
- Quadra Engines by Dick Bennett
- Fuji BT-64A vs BT-64EI vs G62
- Seagull Edge 540 & gasser
- MOVED: Featherlite help
- Does Bennett do fax and phone ordering only?
- G38 by Ralph
- Brison 2.4 high throttle problem
- i need help with a magnum motro
- Byrons Originals Mustang 50 Engine
- Ignition interference
- 3BLADE prop on a DA50???
- Prop for ZDZ 80?
- DA50 Dieing & Prop Question
- Where to buy G-38 Ign Module
- G26 gasket problem?
- Zenoah G-38 G380PU
- Gas octane and 2 stroke oil mix in a ZDZ?
- Need help with installing a Kill Switch on Zenoah G-38
- DA 50 ignition test
