PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Small hole in the carb's choke plate.
  2. SPE 40 weak spark
  3. straight exhaust pipe on engine?
  4. Need help....Have you guys heard of this???
  5. Old Falcon Engines
  6. FTL45
  7. 4s/2s power?
  8. DA-85 prop balance question
  9. Fuji 32EI RFI problems
  10. Very very quiet DA50 setup?
  11. 3W How strong?
  12. How can I tell if I remembered to add oil to my fuel?
  13. One battery for ignition and RX.
  14. DA-85 muffler install
  15. Spring sreel reeds
  16. 3.2 Twin problems
  17. Air in line between tank and engine
  18. Any body tached their spe 26 yet?
  19. Very happy with my ZDZ engines, Thanks to RCshowcase
  20. Fuel Tank ?
  21. Do I need a starter?
  22. MVVS 116 42% AUSTARS EDGE 540
  23. 4.8 ignition for crrc 45 engine
  24. Help Engine dont running right
  25. Which Brillelli to buy!??
  26. Maloney 100
  27. ZENOAH G38 Kill Switch "how to" ???
  28. MOVED: .049 gas engine needed for the Guillows F4U-4 Corsair Balsa wood Giant
  29. 20X6 wood for 26cc
  30. 120" Clipped Wing Cub-World Models
  31. DA 100 Set Ups
  32. xyz lspro or crrc 26cc. which one????
  33. MVVS 26 ignition question
  34. Hanger9 Extra 260 Motor Mount
  35. Stupidest Question DA-50 Ignition
  36. Stupid Tuning Question
  37. Fuji BT-34 vs. Zenoah G38
  38. RCS 215 RADIAL HELP WANTED
  39. MVVS Ignition
  40. RE:ZDZ IGNITION ON A123 BATTERY
  41. MT57cc gasser ?????
  42. Flexible Gas Tubing
  43. Zenoah 26 Quit
  44. Brillelli is busy - so
  45. Quadra 100 wanted
  46. My experience with Cactus Aviation
  47. 50 cc twin tank size?
  48. Mini v8 gas engines
  49. Hots plans
  50. Best Smoke System
  51. BME 58 Extreme
  52. Bolt Pattern for 3W and DA 150
  53. Restrictive muffler fix ?
  54. THROTTLD ARM ON G-26
  55. Two Iron Bay fuel regulators needed
  56. Fuji-Imvac BT-50SB
  57. Problems with Evolution 45GX (not gx2)
  58. Which One Would You Buy? G20 vs. BT24
  59. G-26ie
  60. MTW Canisters
  61. DA100 Walbro Vented Diaphram Covers
  62. Brison 6.4
  63. Echo Gt 1000 16cc Gas Engine Compression
  64. crrc 26 cc 3 or 4 blade prop
  65. Gas Engine Tuning - WHY?
  66. What can be done to a Zenoah G26.......
  67. g-45 muffler problem
  68. DL50 v G62
  69. HobbyCity xyz engines
  70. New ignition
  71. Brillelli Engines
  72. Shortning the stack on a side dump muffler.
  73. New G62 Electronic Ignigion Coverson
  74. Containing gas odor
  75. Kits for 26 XYZ gas & 50 DL gas
  76. Evolution 26GX questions
  77. Has anyone ever heard of this?
  78. Sachs 4.2 Won't Start-HELP!
  79. Country of manufacture
  80. Help dialing in a 3W?
  81. Carden 40% Edge/DA150 sags in rolls
  82. Why is this happening? Can someone help??
  83. GOOD DEPENDABLE 26CC GAS ENGINE ?
  84. DA 100 running on one cyl?????
  85. G260 question?
  86. G260 question?
  87. Oil burners
  88. Tillotson Carb Spitting Fuel - Need Advice
  89. GRPRO GAS ENGINES MEASUREMENTS
  90. SV-26 From H.C. Review
  91. Used G-38 running worse
  92. Zenoah GT 80 spraying fuel from carb
  93. SPE 26cc prop size question?
  94. 50cc Exhaust System
  95. Magneto troubleshooting
  96. 40cc crankcase smoke system
  97. DL50's exhaust pipe
  98. large displacement single cylinder engines
  99. DA 50 drill set up for a yak 54
  100. Correct 46 cc Poulan Sparkplug
  101. US41cc muffler comes loose
  102. DA-85 throotle and choke hookups
  103. Gas Engine FAQs
  104. Convert 45ccm nitro to gas?
  105. Fuji 50EI and GP Patty Wagstaff
  106. Fox 2.4 Pitts muffler
  107. New RC Showcase 26cc question.
  108. Red Line or Royal Purple 2 cycle oil
  109. RC Extreme Power welcomes Extreme Flight RC
  110. Who sells the lightest 50cc engine???
  111. G20 ir needs aerobatic plane
  112. 2.4 GHz and ignition interference
  113. ignition voltage
  114. Two smaller gas tanks in giant-scale?
  115. Mounting a DA-85
  116. Dessert Aircraft decals?
  117. A123 VPX
  118. Convert Quadra 52 to cdi
  119. two 3W 80s, same problem,,
  120. XYZ 26cc First Impressions
  121. Please help with timing??
  122. SPE 26 problem??
  123. Zenoah G45- Switching to Synthetic Oil
  124. G26 Help.....
  125. Need help with a Battery....
  126. How to Set Timing with XYZ CDI Ignition?
  127. Zenoah G-62 Tuned Pipe???????
  128. Engine choice question.
  129. Building and tuning, Bud Bottle Mufflers.
  130. Zenoah G-20 set-up questions
  131. RCGF 100 Revisited
  132. RCEXL V2 Ignition - OK On 6.5 Volts ??
  133. Grpro 100cc twin. or?
  134. Where's Ralph??
  135. Mounting the tank in a gasser
  136. XYZ Engine Website
  137. other considerations for G-26
  138. ZDZ 40 Manual
  139. Tuning tips needed for canisters
  140. US engines webstite? Anyone know it?
  141. satio carb
  142. Gas engine for 8' Unionville Turbo beaver?
  143. To Bench Test or Not?
  144. Fuji 43EI Sheered Crank and RPM readings
  145. Reversing the cylinder on a Zenoah G20
  146. DA 85 Mid range burble?
  147. Heat and Space
  148. DL50 pitts
  149. reformulated gas and time
  150. Antique Engine
  151. Sachs Dolmar
  152. Is the da50 and da85 th same ignition?
  153. New to Gas engine tuning question
  154. Not a gas engine post,but need specs for a gas starter
  155. Ethanol in gas
  156. Fuji 43 ESI Sheered Crank
  157. GIANT SUPER SPORTSTER NO FUJI?????
  158. ZDZ 80 RV Parts
  159. 64a vibration
  160. Gas battery,shutoff switch scematic
  161. OPS gas conversion
  162. DL50: exhaust question
  163. Help w/ Zenoah 20
  164. Quadra 65
  165. What chainsaw used the Quadra engine again??
  166. Quadra 74cc engine
  167. What engine runs best...?
  168. Where do OS engines get made?
  169. called Walbro Engineering today
  170. 50cc smoke system setup??
  171. DL-50 Which header and muffler for SD extra?
  172. What kind of gas engine is this?
  173. Making propellers
  174. Coleman fuel instead of Gasoline
  175. Methanol vs Gasoline
  176. DL 50 Bearing
  177. wiring kill switch for fuji 86
  178. Fuel Supply Problems
  179. e read on the Gas engine for a 120 Four Star
  180. AREA 51 and Extreme Flight 88" Extra (Vedio added) Plus one more
  181. Convertion to Gas for Giles G-202
  182. mineral based 2 stroke oil
  183. Folded Wave / Tuned Muffler Style Pipes?
  184. DL-50 carb question??
  185. 3 blade props
  186. inverted gasser
  187. Help with 50cc misfire/pop and flame out,Final vid added
  188. SPE26 and rcexl ign with cm6 plug
  189. "break-in" props
  190. 3MM engine
  191. KS Tuned Pipes vs AMT Tuned Pipes
  192. Is there anything wrong with a DL 50 on a 3D plane?
  193. Two Mystery Engines
  194. Question about 3w 60 ignition wire
  195. Remote starter G26
  196. Help needed with a ZDZ 210
  197. DA-170 is here
  198. Torch Engines
  199. Giant Sportster ARF Engine?????????
  200. BME 50 Engine How good of a engine?
  201. 3W 75i AND WILDHARE GILES 202 35%
  202. Spinner problems
  203. Exhaust gas temperature and pressure questions
  204. Evolution Gets some New gassers
  205. A word about Keith Baker and BME Engines
  206. What sealer for Quadra engines??
  207. Evolution 35 mounting options ??
  208. Walbro Carb Fuel Lines
  209. Help identifying engine
  210. 3w75i won't start after trying everything...service???
  211. velocity stack or not?
  212. SPE26 Prop mounting
  213. Zenoah G38 aftermarket exhausts
  214. Zenoah G26 Question
  215. Need Help With Fuji BT-86
  216. Fuel line
  217. Hodges Hobbies now stocking the AREA 51 Gas Engine
  218. What To Do With Old Gas?
  219. what makes a smoke muffler?
  220. LS PRO ENGINES Welcomes BCMA ENGINES
  221. Quadra ignition parts available in a small engine shop?
  222. CRRC-PRO 50cc review
  223. where to buy a walbro carb for the BME 110
  224. Z 62 easy start ?
  225. Home made scale muffler extensions ????
  226. Ready to GIVE UP on my G-45
  227. Pick for Chinese 26cc Engine?
  228. zenoah g26ei running trouble
  229. Problem starting a G38
  230. Evolution 26 problems
  231. DZY 48 twin, cast case Chinese YW clone
  232. Help! G-38, taxis way too fast!
  233. Engine choice for Rascal 110
  234. DL 50 or mt 57
  235. GLITCHES
  236. NIMH batteries on ignition
  237. Electric to Gas convert
  238. enging mount template
  239. Reduction drive for 50cc to 85cc singles
  240. MT57cn rpm,prop,thrust readings.
  241. MOVED: please tell me what the c of g should b for my 28%xtra 300l
  242. evolution engine question
  243. zenoah g-62 90 deg intake manifold.
  244. AVIO 70 CC GAS ENGINE
  245. MVVS 58 Pro Power
  246. MVVS/EVO 160 GAS Choke Linkage
  247. MOVED: Large Saito 300's
  248. gas engine.
  249. Review, RCGF 100 rear induction twin
  250. BT-64A issues...already?
