PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. DA Engine Mods
  2. Walbro Carb
  3. DA-50 Carb Change
  4. Brison 3.2 carb needed.
  5. Brison 2.4 weight & prop/rpm
  6. SPE 40cc
  7. Gas Engine for Funtana S90
  8. compagnucci gas carb settings ?????
  9. what plane for zenoah 45
  10. U. S. Q Quadra Aero
  11. The new Fuji Imvac BT-43
  12. BME 50/ GP Mount
  13. walbro carb
  14. MOVED: Bipe recommendation for a Ryobi 31cc
  15. Winter Storage of G-62
  16. zdz 50 Is there a problem with it?
  17. what engine for a yellow aircraft spitfire???
  18. check-out this site
  19. 3W 80 Xi
  20. 3W 150 rear-intake problem
  21. help!!! Brison 3.2 dies on down lines
  22. DA 50 engine: Comments please
  23. MVVS 45 or Revolution 52
  24. Zenoah GT-80 need some advice.
  25. ZDZ 80 Encouragement
  26. Noise question
  27. Ignition Batteries
  28. MOVED: OPS 30cc on Bridi Big Bee
  29. ROTO company site?
  30. Best 50 cc class engine
  31. MOKI FLOODING CURE
  32. New DA engines ??
  33. Question about fuel flow
  34. FC 3.5 ON SIDE OF MOTOR
  35. Need help with first twin
  36. Need help with first twin
  37. Brison-BME-Taurus 50cc Differences
  38. BME 50 Prop Question
  39. King 95 experience
  40. silicone tube, need help
  41. Another direct comparison ?...
  42. ROTO 35 engine and airscrew
  43. Zenoah Z445
  44. Mvvs 1.60 gas header question
  45. G62 Power on 81" Sukhoi 29
  46. Battery for RCIGN Ignition
  47. APC 22x10 or Wood Prop?
  48. FPE 2.4 or Brison 2.4 ?
  49. What is my ZDZ60 worth!!!
  50. A new 36mm billet head option for Zenoah and Chung Yang motors
  51. Excessive ring/piston groove clearances
  52. HELP with Quadra 200RSS Timing ? ? ?
  53. Techie ? for RCIGN1
  54. Moki 2.10 Crankcase back cover
  55. Comparing Gas Engine Weight
  56. DA 50 fade with outside manuvers
  57. What plane to choose for a MVVS 45 -58cc engine
  58. A few general questions
  59. Breaking in DA 50
  60. Mark 180 gas versus RCS,ZDZ,etc.
  61. What have I done ? Is the YW 48 good or bad?
  62. starter spring problem?
  63. MVVS 58 versus DA-50
  64. Other DA engine?
  65. Choke servo for Da-50
  66. Zenoah 45 EI from RCIGN1
  67. MOVED: Poulan Chainsaw reference need one!!
  68. MVVS Exhaust option
  69. Ignition Placement
  70. MOVED: using an old Enya 35 in a rc car
  71. ZDZ 80 RV needle settings
  72. Surefire Bisson Loose Muffler Fix
  73. GT-80 wont draw fuel
  74. More power from Kawasaki TH48 engine?
  75. Newbie to petrol power... "white" gas questions.
  76. DA 50 spinner bolt broken/stuck
  77. Silencer for Brison 3.2
  78. BME 110 Ignition Problem
  79. RCS 140 silencing
  80. Variable Advance/Retard: How I Found Out
  81. Quadra 42 muffler and exhust pipes
  82. Another G26 carb block cracked!!
  83. Throttle transition -- Sachs
  84. Bennett pitt muffler
  85. M180 gas engine quality
  86. MOVED: IS IT POSSIBLE TO CONVERT A WEED WACKER INTO A PLANE ENGINE?
  87. Will the real EVO engines please stand up! NEW ENGINES!
  88. I can't find WAE 342!!
  89. G62, any simple power hop ups???
  90. Amsoil 80:1/leaf blower??
  91. MOVED: Metal noise from tailwheel
  92. zenoah g38 or quadra 35? what is this thing?
  93. zenoah g62 carb problem can anyone help
  94. Honing Cylinders--Re-ring Job
  95. small AMT tuned pipes
  96. new 3W-55ius
  97. DA 50R manual
  98. Break in a DA 50R question
  99. shielding spark plug cap & wire
  100. MVVS Gassers in Stock!
  101. Which fuel line for gas: Tygon or Neoprene ?
  102. Have 3w 80 twin. Tool question.
  103. MVVS 1.60 = YS 1.10?
  104. Fuji 64EI spark plug cap
  105. Do modern electronic ignitions generate much heat?
  106. ***FLASH*** "TAURUS" INTRODUCES NEW "BEEMER"***
  107. zdz60 front bearing leak
  108. Zenoah G26 reliability??
  109. Holy Cow! When did DA release the 75CC?!!!
  110. Smoke muffler on a Gasser????
  111. Prop Shaft Adapter for Fuji 50
  112. throttle and choke???
  113. Gasoline line T's
  114. Do Gas Engine Bearings Rust like Glow Engines?
  115. zenoah G62, please help!!!
  116. identify this engine
  117. g62 mounting Template
  118. DA 50 question (needle)
  119. what gas eng.for a balsa usa se5
  120. What is going on HERE! MVVS & Evolution engines.
  121. MVVS 45MG
  122. Saito twin on gas with ignition???
  123. Reversing a Zenoah
  124. CALLING ALL "TAURUS" OWNERS.
  125. G26 in a Balsa USA EEA Biplane
  126. Suggested Tank Size for Quadra 75?
  127. Plug Identification?
  128. How much shaft run out is acceptable on a gasser?
  129. Quadra 35 fuel / oil mix
  130. Carb stacks, do they work and how.
  131. DA-150 Carburator P/N
  132. Evolution 35 on Midwest Cap?
  133. Fuji BT-32EI
  134. Best Place to order a DA?
  135. Recommended fuel tank for ZDZ80 ?
  136. 3w igntion trigger switch
  137. USE ENGINES N.Y
  138. 2.4 Gasser that has the reliability and quality if the DA-50?
  139. What do you think of Evolution 1.60 Gas sold by Horizon?
  140. prop size?
  141. I ordered parts, but get no response
  142. zdz 80 plug
  143. Need plane for a Quadra 35cc!!!!!
  144. brison 2.4 broken shaft in mid-air
  145. Zenoah G45 Exhaust header
  146. Need Help with Older Zenoah 62 Engine - Part II
  147. Who has Menz 27x10 in stock?
  148. b&b spinners
  149. soldering muffler tap
  150. 3W 106i B2 looking for people using this engine
  151. What GAS engine To choose DA or 3W???? HELP!!!
  152. radio interference
  153. GT-80 muffler bolt size
  154. Problem with MVVS 2.15 and Bisson Pitts Muffler
  155. Simple Fuel Question
  156. gas/oil mix...
  157. Cermark Pitts Powerplant
  158. Ignition sensor for F.P.E mounting advice
  159. Q65 petrol-oil mix and prop size
  160. "Tuning Extension" for Walbro Carbs?
  161. DA 50 drill bit size
  162. Choke for G38
  163. FPE 1.3 plane
  164. Quadra 75 Help -- Prop Size & Oil Mix
  165. Engine for Protech Giles 202(72")
  166. Rpm for da150 with prince prop 31-11
  167. igntion module??
  168. What prop to use for a ZDZ 40
  169. Redline Oil Ratio?
  170. Several Quadra Q75 Questions
  171. 50cc Gasser Weights
  172. BME 105 questions
  173. Cowl Attachment/ 96" Warbird
  174. 3w-100 Weight, power???
  175. G62 plug boot question
  176. RCIGN G38 Conversion
  177. Amsoil mix ratio for ZDZ 40?
  178. 2 to 4 Blade Propeller Conversion
  179. Need 1/2 inch Engine stand off's DA50
  180. Electric starter for 50cc engine ?
  181. It has dissapeared...
  182. emi bead selection
  183. What carburator
  184. Help needed choosing engine
  185. Quadra 50 power
  186. spinner for BME 110
  187. G26 still not just right,, need suggestions
  188. frustrated with attaching a prop spinner to 3w 60
  189. Where can you buy the MVVS 58CC canister from?
  190. Firewall fuel profing?
  191. Ignition switching for RCIGN conversions
  192. Which Cans for 150cc Motor?
  193. New ZDZ 80 RV-J
  194. Supersonic Mufflers, Any Good?
  195. Quick test on tuned pipe ZDZ 50 RV
  196. Loctite for G-26 Muffler
  197. Looking for Quadra 50 2" prop hub extension
  198. Resistor plugs for G-62
  199. 3w ignition module wiring
  200. Quadra 100Xl what prop
  201. NX prop and brison 3.2
  202. HELP!!! Pulled exhaust threads
  203. Will Brison survive?
  204. FPE 2.4
  205. ZDZ50NG Slimline muffler
  206. Zenoah G-45 question
  207. Fox Service Policies?
  208. Factory Needle Settings for MVVS 2.12 (35cc)
  209. DA50 Carb and Reed Valve Reassembly
  210. Collari .30
  211. 10mm DUBRO STYLE prop nut ?
  212. BME 50 Richening
  213. G38 Kill Switch Help
  214. What size engine for what weight airplane
  215. Seekig coil for US Engines
  216. WHICH WAY GASKET GO ??
  217. G62 engines on E Bay
  218. ZDZ Super 160 Twin
  219. g26: metal clevis on throttle arm safe?
  220. Byron 4.2 prop adapter.
  221. g23
  222. Sachs Dolmer 3.2/ any good?
  223. ZDZ 80 TROUBLE
  224. GT 80 Question
  225. 3W 80i
  226. DA 100 sags in inverted flight. Any idea?
  227. U.S. Engine Order Trouble?
  228. Has anyone used 100LL avgas in their airplane engines?
  229. Revolution Engines
  230. Hej there
  231. ZDZ 80 Twin
  232. Convert G-62 from magneto to Electronic Ignition
  233. Fuji 50SB Surging at Midrange
  234. G38 + Hangar 9 Cessna Skylane
  235. Fuel Tubing Firewall Penetration on CF/Fiberglass Airframes?
  236. Mobil 1 & Motul 800 ratio
  237. MOVED: Ryobi 31cc 3D CAD model
  238. New ZDZ-80
  239. Gas Engine for Stearman
  240. ZDZ 40 header length
  241. Zenoah G-26
  242. Klotz techniplate kl-200 synthetic
  243. Spring-aire Retracts (not Robarts)
  244. Need info. to make a Tuned Pipe for G-62
  245. G26 w/ smoke muffler set-up
  246. need advise on a brison
  247. Correct carb for a G-38?????
  248. RCS 140 gas engine
  249. FIREWALL REINFORCEMENT? FUEL TANK DA 50
  250. 3W engine customer service
