- Best Engine for Petrolcar?
- help identify this engine
- ignition??
- Quiet muffler for a Sachs 5.2 gasser
- Kioritz 2.4 - Starting Method
- ZDZ80RV won't start, help.
- G 26 MISFIRES
- Mejlik props
- gas engine for ziroli p-40?"
- flooding inverted ST2500
- A couple things...
- Pitts Muffler for Fuji 50?
- G26 with tuned pipe
- DA-75...anyone heard anything?
- Tell me about your ZDZ 60 powered Giant Stinger
- US Source for 3.5" Engine Standoffs
- Zenoah GT-80 Power???
- receiver battery location and ignition battery location
- ZDZ-160 Champion
- Roto 35
- 4.2 Pitts exhaust?
- Quadra 52 Carb Upside Down
- ZDZ 80 Engine Test Stand-Dick Hanson
- Best Prop for Reno Racer G62??
- DA 50 choke setup
- Slimline Showtime
- Newbee Gas Engine Install Question
- Q52 prop size
- 3W-200
- Fuji 32A on Creek Hobbies 540 Edge need help!!
- Equivelent Petrol to Glow
- Question about First Place 2.4 muffler
- Muffler that fits ZDZ80 to a 30% Lanier Edge 540t???
- G-26 won't idle, help
- Im new to petrol please help
- Seidel ST 770 Radial: Help Needed Please
- maloney engine???
- Crashed caused by possible ignition inteference?
- prop size for 3w 100
- G62 Engine question
- Large engines/ fuel lines
- Mounting a Brison 3.2
- Oil Syringe
- Gas Engine Vibration between brands
- Best prop position for hand-starting?
- Lock Washers on Prop Bolts?
- Tartan Twin
- Giant Engine Starter - How to hook up a solenoid for counterclockwise rotation
- CH ignition & spark plug question
- D and B 5.1 Twin
- About this forum
- My Fix for Hangar 9 Super Cub Problem
- US 41 Timing
- Sachs 3.2, problem setting it up.
- G38 Carb squirting gas
- Webra Bully Ignition
- What capacity pack for the electronic ignition on gassers?
- US41 carburetor adjustment
- Difference between Fuji 50-SA & 50-SB?
- ZDZ 40 - throttle servo - Your Comments?
- Zenoah GT-80 rotor nut
- DA 50R manual?
- Low end problem, Taurus 2.6
- Need help with EVRA engine
- Need help with my Zenoah G230 rc engine
- G-62 for the H9 CAP 232
- ZDZ baffling in CAP
- Small gasser?
- ZDZ question for Dick Hanson.
- Biela 27x10 or 28x10 for DA100?
- How-to-manual for gas engines
- ST 3000
- Plug wrench size BME 50cc
- Sachs Dolmar 3.2 Crankshaft
- NEW 35CC Gasser for 120-140 size planes!!!!
- Question on propping a Brison 3.2
- DA50 Engine Owners Plane Weight Question
- 3W 120 vs 106
- 50cc Gasoline Engine with rear exhaust?
- Isolating Rx battery from Ignition module for RF noise
- G26 Throttle Arm?
- Gasoline engine surges at full throttle.
- 3W100 vs 3W106B2
- Where to purchase Amsoil oil
- Pefa Mufflers
- 50-60cc Gas engines
- BME 50
- Popular engines
- Need the REAL width of a Fuji 50????? PLEASE!!!!
- Fuji 50
- 3W100
- DA50 and ignition battery - Engine quit
- Zenoah G 62
- ZDZ 80 prop sizes
- Remove Choke Plate from G26 Carb
- Gas vs Glow
- Kill Switch?
- XF props
- Walbro WJ-64 Carb. -Where to find a Repair Kit?
- Best IMAC Prop for a Brison 3.2
- Any reason not to remove metal backplate on G-26 to save weight?
- 3w 106 Fuel consumption
- US41 wont shut off
- ZDZ 40 strange idle
- The write prop
- Prop for Kioritz 2.4
- 3w 106
- zdz 40 prop size
- Bme 50 Prop size
- What's more powerful a 3W 24cc or MVVS 26cc?
- Prop Question
- unknown motor
- Roto Motor - New Engines
- Brison 3.2 Prop ?
- Brison 3.2 vs G62 need power?
- BME Propellers
- BME 110Xtreme?
- 3W-106QS Overheating Question
- gas carb to glow carb?
- help me.... 3w 100 b2
- BME 110 performance data.
- Gas Engine for 15# Plane
- 3W-75 or Q-75 posts
- A big "Thanks!" to Ralph at R/C Ignition
- Quadra 52 Electronic Ignition
- Is it necessary to store inverted gasser - right side up?
- Lil gasser
- 3W-75 Fuel Rate
- G62 carb settings
- 3W100 Back Fires...?
- New G-26
- BME 50 motor mount?
- You can link car products directly to our product guide and other posts now!
- ZDZ 40 Fuel consumption
- Brison 3.2 and Amsoil 100:1
- g26 acts strange
- Z-445 w/ very weak spark
- Fox 3.2 and muffler problem
- How to set up ZDZ80RV throttle linkage?
- mvvs 35cc (2,15ci)
- zdz40 sportsman
- Sachs 3.2 Need help in starting this thing
- Gas Engine For A 60 Size Airplane?
- Rcv-90/ Tf P-39
- DA-50 Carb won't richen
- How warm to the touch does your cowl get?
- Can a G-26 be hand started ?
- BME Engine Timing
- Need help to start my Zenoah'sG62
- Loose ZDZ spark plugs
- need for speed
- How do you tune a 3W-100
- anyone used a soft mount on ZDZ 80
- Low Pitch Props for gassers?
- Fox 80cc twin
- Walbo carb + "tank pressure"
- Need help identifying engine
- J-Tech Snuffler System
- NEW G-26 Won't Start
- BME vs DA
- Finally figured out problem with DA50!
- smoke system
- Where to find Moki Props ?
- Which 50 Cc To Use?
- First gas engine?
- Zdz50 Ng
- Zdz 100 B2 Ng?
- Zenoah G26 Lightening
- Lightweight Zenoah Engine Mount
- ZDZ40 vibration dampening.
- problem trying to choke the ZDZ 40cc
- MVVS 58cc Gasser - 9.25HP?!?!?
- zdz 80 single metallic sound
- ZINGER PRO or ZINGER square tip
- Zenoah vs Quadra - Is it comparing apples and apples?
- MVVS 3.50 (!) 8,2 hP and 1630 gr. wtoumuff
- G26
- Looking for ZDZ 210 RPM numbers....
- Mvvs 3.50 (!)
- 24 volt starters
- ZAMA Carb
- G-23 or G-26 ?
- Web site Info
- Muffler options for a G-23
- Aftermarket muffler
- Cannister Silencers for DA 100
- ZDZ 80 twin with side mount carb??
- G-62 ignition and hard starting
- Purr Power
- Walbro - Throttle curve required ?
- Sauch 4.8
- Identify
- fuel tank air inlet
- G-Force props?
- Which brand of prop is loudest?
- Zdz 60 Fire Hazard
- Duralite Plus + Ignition = Problems?
- AI 3w150...HELP
- Quadra 52 questions
- Exra 330l
- ZDZ80 Piston Failure
- Q35, new crankshaft
- ZDZ40B & 3 bladed prop.
- New to gas, G23 help...
- Any one with a well tuned 3W-60
- DA 50 Mounting question G.P. Pitts
- engine for dp extra330l
- Zdz80b2rv
- Rcs
- Is G-23 and G-38 mount bolt pattern the same?
- Need Help - RCS 1.4 Gas Leak
- First gasser model..
- Supplier of Super Tigre G3250?
- Newbie Gas question
- what plug for mcculloch
- will g23 muffler fit g26?
- DA 50 static thrust figures
- Light Engine mount for MVVS1.6
- BEST MUFFLER FOR 3W70i + ANY TIPS
- Q-35 carb question
- prop sizes
- Will a Bambula 24x8 work on a DA50?
- 3W106 crank failures
- Fuel tank set up & stopper help
- US engines 41cc? Worth it?
- Bisson Muffler Mfgr defect?????
- ignition battery 4.8 or 6vlt
- Anyone make a shaft extender/adapter for DA-100 (for spinner)?
- velocity stacks???
- sachs 4.2 question where can you .....
- Where do I put the extra wire?...
- pitts Mulffer
- ZDZ to 3W/DA comparison
- the right prop for a bme102 on an extra
- Need rear crankcase for G-23
- clean engine
- engine comparisons 100cc twins
- Us 25
- Ryan(Ryobi) Conversion ?
- ZDZ40...need manual
- Does anyone recognize this Sachs conversion??
- walbro carb question
- Us-35
- Glow to gas transition ...
- Walbro carb type
- prop size for quadra on 1/3 cub?
- G62 parts....
- Quadra crankshaft
- wankel?
- Help with timing Help
