PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Prop Pins - Use them or take them off ???
  2. 3w 32-10 to mejclik 30-10 on zdz160
  3. Which propeller is best for Gassers ????
  4. DA 50 Run-in.
  5. Gas Engine Losing RPM
  6. DA 100 and What Prop/RPM???
  7. BME 110 Motor Mount
  8. DA 100 OR 3W 106 ?????????
  9. ZDZtach accessory
  10. ZDZ 80B2RV
  11. Quadra 40/42
  12. prop information for gasser
  13. Throttle return spring?
  14. priming 3W50
  15. prop on 100
  16. Why not ground the block?
  17. Cant get Fuji 64 EI started
  18. ZDZ80 failure mode!!!
  19. G-38 in a TF GS P-47
  20. ZDZ 50 carb settings and prop size?
  21. fickle Fuji 64EI
  22. MINIMUM PLANE WEIGHT FOR A ZDZ 160
  23. baffling gas engines for cooling
  24. ZDZ Question
  25. Taurus Engines - Comments Please
  26. Hydro Mount
  27. smoke pump
  28. How long is safe for a gasser engine to run inverted?
  29. brison 3.2 ????????
  30. new to gas engines
  31. BME 50vsBME 44
  32. 3W 106B2 Prop Hub Removal
  33. ignition battery interference
  34. reduction gear drive for Sullivan starters
  35. operating temp for genaric zenoah engine?
  36. Can I do this ??
  37. Suitable Exhaust Muffler for 28cc 3W engine
  38. Turn of the engine in the air
  39. Roto25 Needle Settings
  40. Carb problems with Quadra 52
  41. DA 100 / Mobil 2T break-in?
  42. FUJI BT 64 EIS
  43. DA-50R Starting Problems
  44. Best Spark Plug for FPE 3.2?
  45. roto 25 starting problem.
  46. 26cc/Edge 540 Combo?
  47. How to hand-start a Zenoah G-45??
  48. Wolf Predator 3.2???
  49. 3W old style w/ blue dot voltage?
  50. Giant U-Can-Do
  51. WILL A DYNATHRUST PROP RUIN MY ENGINE ???
  52. Prop Balancing ???
  53. Engine storage
  54. MOVED: crappy searching
  55. G62 vs 3w 60cc
  56. Fly gas in a 60 sized airframe
  57. G26 Conversion weight savings
  58. Zenoah G-45 Black Gunk
  59. best prop for a zdz 40 rv is???
  60. Just picked up a plane with a ZDZ 80
  61. FOX 3.2
  62. Tank vent
  63. Stuffed carby. Bing on ZDZ 60
  64. Does Mejzlik make a carbon 24X8 Prop,,,
  65. Is USQ Aero Engines still on the bussiness?
  66. Is USQ Aero Engines still on the bussiness?
  67. Anyone recall the old Byron belt drive quadra?
  68. KS-89 or KS-95 on ZDZ-80 RV?
  69. Cowl cutout for DA 100 carb
  70. Prop to crank relationship
  71. MVVS 116 witness report: WOW!
  72. Aviomac 85cc twin mufflers needed
  73. Propeller thoughts for GASSERS!!!
  74. Roto 25 oil mix
  75. Least width 100cc twin?
  76. Starters
  77. 50 cc Homelite engine
  78. ZDZ 160 prop nut?
  79. 50cc engine
  80. Sheared prop bolts help
  81. BME 110 with tuned pipes
  82. DA 100 ignition wire question
  83. RCS 215 Radial
  84. Zenoah G-62 Bearing Problems !!!
  85. DA 100 bolt size info needed
  86. HELP! Traded for a Sachs 5.8, but it LOOKS like a Sachs 4.2???
  87. Gas Engine Break - In.. Is it needed and how ????
  88. How heavy is your clunk?
  89. engine help please what to do
  90. ZDZ40 - Good or Bad??
  91. gas pump or oil pump
  92. fundamental question on electronic ignition
  93. MOVED: do i buy a new engine or rebuild
  94. CRRC GF45i
  95. Johnson Muffler Phone Number?
  96. News on the BME 55 ?
  97. BME 50 and CH ignition surging
  98. Question on exaust design?
  99. Fuji 64A vibration
  100. Poulan 42cc conversion
  101. MOVED: Please, Help Me!!! Problem With My Car Engine
  102. Baffled by engine - who can help me? All sorted out!
  103. RC Showcase Service
  104. 3w 150 carb question
  105. Anyone know if a DA-150 and 3W-150 have the same bolt pattern
  106. longer reach plug
  107. Engine Manual
  108. MOVED: Problem Locating Needle
  109. BME extreme VS. DA 100???
  110. C & H Ignition Help
  111. Poulan oil
  112. 2blade to 3blade prop
  113. G38 Props
  114. DA 50 problems
  115. Brison 4.2 muffler
  116. G26 needle adustment makes no difference
  117. Looking for a ges engine, recommendations?
  118. Metal spark cap for Zenoah GS260RC?
  119. silicone sleeve doesnt fit header
  120. Klotz?????
  121. DA Engine Repair
  122. Zenoah help
  123. DA 100 cooling
  124. Gas not pumping into carb on Q50
  125. Practical idle rpm.?
  126. New to gas engines....help please
  127. evo 26gt
  128. Muffler choice for DA50
  129. Another DA 50 for me
  130. MVVS 35cc
  131. BME 102 Reed Block
  132. One of repacking suitable for ZENOAH G450PU
  133. Ignition battery voltage
  134. Do I Need More Right Thrust
  135. Muffler on ZDZ question
  136. Mathe Corsa R 35 cc
  137. Smoke Muffler
  138. DA-100 INFO NEEDED
  139. zdz 80 break in
  140. Canister Smoke
  141. Baffling construction help, tips please?
  142. 3WIUS75 Canister muffler which one?
  143. Proper propeller position when starting electronic ignition gas engine
  144. GP 1?4 Patty and fuji 64
  145. Kangke Monocoupe with Ryobi conversion
  146. DA50 and Hyde mount
  147. zenoah g26 won't idle in the air?
  148. ZENOAH G26 WON'T IDLE IN THE AIR
  149. Has anyone received their Evolution 26GT gasser yet ?
  150. DA-50: can't get it pop w/ choke closed.
  151. Need an exhaust header for ZDZ 50RV
  152. ZDZ60 Help with Props,,,,,,
  153. How to brake-in a DA100
  154. My Engine mounting skills Suck HELP please
  155. ZDZ 80 Temp
  156. Fuji BT32-b Cracking Crankcases
  157. What Casting #s VS What Engine Size for Sachs?
  158. BT-32b Crankcases Cracking
  159. ZDZ 100 Tuning
  160. DA 50 not running good!!!
  161. BT-32B Crankcase Crack
  162. Header/Cannister for BME 44?
  163. Electronic ignition question...
  164. ZDZ-40 info
  165. G26 will not maintain full throttle!
  166. Brison 3.2 starting problems Help ASAP
  167. da 50 wont draw fuel
  168. Using two tanks to increase fuel capacity
  169. zdz 80 gas engine
  170. can't find a DA-50 muffler
  171. Evolution Gas Engines
  172. spark plug gap for Brison 3.2
  173. *****G26*****
  174. Locking throttle carb screw in inlet?
  175. unknown engine ?
  176. Smart-Fly
  177. interesting
  178. Carb Bolts- Aluminum, brass
  179. Aviomac 125 question
  180. ZDZ 40 RV-L Electronic ignition
  181. hall efect sensor mount on BME
  182. Throttle servo?
  183. Recommended ARF's for 25cc gas conv.
  184. Newbie DA50 questions
  185. 3W 200 Prop
  186. conversion question
  187. where to buy lawnboy or Amsoil synthetic?
  188. max. timing on G62
  189. What prop for G-62?
  190. ignition interference
  191. Issues with BME
  192. c&h ignition
  193. GAS LINE FILTERS
  194. THE CHOKE LEVER??????????
  195. Cleaning needle valve ports Walbro Carb
  196. BME
  197. G-26 Muffler
  198. 1st gasser -- couple questions
  199. BME100 : is it a good engine?
  200. Tachometer Placement on Gas Engine
  201. ZDZ-80 Low Speed Needle... and High for that matter
  202. MOVED: partner 72cc
  203. gotta clean the dirt out--anything to watch out for?
  204. Zenoah G62 flying muffler!!
  205. DA 50 with Cannister
  206. Rx & 2 battery packs conection
  207. Gas Engine for Great Planes Extra 300S 1.60 ARF and 80" midwest Cap???
  208. Is this A&M any good?
  209. DA100..
  210. G26 owners,, answer please...
  211. giant scale prop pitch gage?
  212. Moving to Gas...How to for dummies???
  213. MOVED: Is this repairable?
  214. 100CC new engine?
  215. Zenoah engine mods
  216. G38 Coil High Tension wire
  217. 3W Canisters
  218. Couple questions
  219. Mechanical or electronic Brison 3.2 Your opinion please
  220. Composite Arf Cross-over header installation
  221. amsoil in ct
  222. BME RPM Range
  223. ZDZ 80 retap exhaust with 5/8 BSW
  224. Exhaust extensions
  225. DA100 3-blade prop
  226. Brison 5.8 or a twin
  227. G-26 / Needles factory settings
  228. Brison 3.2 Sparkplug
  229. 3W 150QS Prop??
  230. MOVED: engine quitting
  231. First really hot day/Brison 3.2
  232. Where can I find a longer propshaft for a Quadra 35?
  233. MOVED: Differences of the Saito Golden Knight
  234. Butterfly position on G-26 must be correct!
  235. G45 Prop and Throttle Servo Location Question
  236. Just can't seem to get the setting of my G23 carb right.
  237. Carb to Engine- Heat Blocking Material
  238. In need of oil for Fuji 4-stroke
  239. Prop selection for MVVS 1.60 & MVVS 2.15?
  240. tank size
  241. Need a DA50 manual!
  242. 3W-QQ106 Fuel Leak
  243. 3W Tuning procedure for engine with 2 carburettors?
  244. conversion of gas heli engine to aircraft?
  245. Gas engine idle stop screw
  246. Quadra 100 Engine??????????
  247. G-26 will not run Ralph need help
  248. What engine is this?
  249. lowend needle tuning for the air ???,,,
  250. need tuning help!!!
