View Full Version : Gas Engines
- 80 cc Twin DOHC
- Weber 70cc twin / Germany
- Besides the engine, what else is needed for a Gasser set up?
- Reduce vibration
- Engine timing question
- RCIGN1 - G62
- Tillotson on a 106..... funked up???
- DA 50 MUFFLER QUESTION
- MVVS 58cc How much power???
- altering the Zenoah stock muffler??
- Is there a single bolt adapter for the ZDZ 40?
- Need info on DA 50 spark plug
- Information needed!!3.7 Sachs engine
- Quadra 35 Troubles and Questions
- ZDZ-50 set screw help
- ZDZ 160 ??
- Balsa USA 1/4 scale Gas Engines
- idle change after inspection??
- Sachs Engine with Walbro Carb
- Ignition Battery
- f.p.e. & glitches
- da 50 - BEST 3-d AIRCRAFT for it
- DA Guru's
- Rear Carb engines
- gas engine info ?
- Mounting a 3W 24
- Worth it to convert to new style spark plug cap?
- 5.8 Pitts muffler?
- My Sincere Apologies!
- G-62 and Slimline Pitts Muffler
- SMALLEST GAS ENGINE ??????????
- BME 55 Extreme status??
- Brison Revo 52
- FUGI 50
- Need ZDZ40 Tips and Tricks
- MAKING FROM SCRATCH AN EXHAUST SYSTEM FOR A ZDZ 60
- ZDZ Nose Bleed ?
- RC Showcase?
- Quadra 75M props used.
- KS Exhaust on Brison engines
- DA 150 vs. ZDZ 160
- Best oil for "break-in"
- Taurus Engines
- Brison 2.4 Muffler Recommendation
- looking 4 part
- rv king gas motor 100cc twin
- Diaphram gasket goes bad in less that 1 hour?
- Who makes the most Powerful 25-30cc Gasser
- twin gasser
- Cand H Ignition Problem
- Oil percentage of DA100?????,
- 50 as strong as a 62
- 3W-24i Vibration
- G26 Prop Shaft Repair Question
- ZDZ50 vs DA50 ????
- FBE 1.3 info
- 3W-24 ignition problem ?
- Zenoah g-38A vs G-38B
- G-62 cuts out on vertical
- Which Walbro on BME 102?
- zdz timing
- Switching to gas engine
- Sachs engines
- G23..... too much prop??
- 3W 28 i
- Getting the mixture right?
- Glow To Gas Power
- G62 carb configuratin
- Gas engine
- Home made pitts muffler for a ZDZ40 side exhaust engine
- DA-50 carb number
- prop hole diameter???
- unknown engine
- Royal Purple 2 cycle oil?
- DA 50 clicking noise and backlash........
- Quadra Q75 vrs. G62 how do they compare?
- NIB Maloney 125 thoughts
- Running in a DA 100
- Needle setting for dummies?
- gas/oil mixture
- Need to silence Roto 35
- rebuild of walboro carb - how to
- tartan twin 77
- BME 110Xtreme?
- EIS Conversion Compatible with BT-50SA
- 3W 100 Running Strange
- Strange occurance?
- BME 110 cylinder temps
- ZDZ 40RV and 40B model question
- Zenoah G62 Muffler Bolts???
- Spinner Bolt for 3w 50i
- Engine for 40% yak
- How do I keep the muffler tight?
- Thank You Cactus
- Where in Fort Lauderdale is Bel Ray available.
- Quadra 35 electronic ignition help
- Painting Propeller White
- Any interest in a hi tech 4-stroke gasser?
- Props for counter-rotating DA-50's
- Best Buy in Gas engines
- Horizon-Zenoah support-outstanding!
- Roto 25
- Long term storage
- Roto 25
- What engine for a 33% GP Extra 330L
- Prop Confusion with Bambula Propellers
- ZDZ 160 With cannisters
- Zenoah 62 crank end float
- Easiest mounting 50cc for Patty Wagstaff?
- sensor too far away??
- Which gas engine???
- Ignition
- First gas engine
- Ignition battery voltage ??
- Roto 35 Gas/Oil Mix
- Ignition module and heat
- Getting Started in Gas
- Quadra 50s Help needed.
- DA 50 in Dave P Extra 330
- Gas Engine Identification Help Needed
- Soft Mounts ZDZ80 V?
- Echo (Kioritz) 61cc twin won't start
- MVVS 1.6 crankcase fitting
- 3W 256 Radial. When???
- G62 Muffler
- Afraid to buy another gasser
- RCS140
- g23 bogging down
- bme engine mount ?
- Dave Patrick Extra, is ZDZ 40 enough?
- Zenoah G-26/Abell muffler
- DA 100 mounting spacing
- DA-100 ignition help/switch
- Ignition kill switch question
- velocity stack... angle back, or angle forward?
- Carb adjustment?
- balancing spinners
- Gas Engine Virgin.
- What gas engine to replace an OS 1.60??
- Choice of Airplane/Engine combo please
- 1 Inch Flexible Exhaust Conector
- Advice on component placement please
- G38 - Muffler Modifications
- Digital Fish Scale to Measure Thrust
- Taurus Engines Site?
- DA 50 Choke connector
- BME 110 props
- MVVS tach'ed, some impressive,,,
- Yamalube 2R Oil Question
- ZDZ 80 Twin runs on one cyl.
- ZDZ40 OK for a GP Super Stearman???
- Gasser carb 101
- Mid range problems...mvvs 1.60 gasser
- CH Ignition- Get Well, Bill!!
- What Walbro carb for ZDZ40
- making a gas to glow
- Gas Fuel Line Question
- BME 44 Fuel Consumption (tank size?)
- Getting into Gas
- Opinions on the RCS 180
- Is this Too Risky...?
- metering diagfram cover plate
- Synthetic Oil Exhaust Smell
- Older Brison 3.2
- C.H.Ignition problem??
- ZDZ 80RV Bing or Walbro ??
- 3 Blade Props for Zenoah
- ZDZ/Falcon ignition goin separate ways
- G38 weight
- More amsoil 100:1 in ZDZ 80 RV questions
- Drilling out Carbon Fiber prop
- Welding Aluminum Exhaust
- DA - what is the yellow fuel tube for?
- G62 fuel line hookup question
- After run oil for Gas Engines
- Black resdue from MVVS 1.6
- 3W 100cc ish 4 stroke gasser
- Broken pick-up bracket G 62
- DA Customer Service - the best!
- Death before Quadra
- Quad 35 or 42 ???
- New EIS engines compatibility with magneto version
- Any Updates on the BME Extreme 55
- Brison 100cc, does this engine exist?
- Help w/ spring starter for Fuji 50
- BME 110 question
- G62 fast idle solved.
- ZDZ 40 Sportsman performance
- 3W-100 bolt circle diameter?
- Mvvs 1.60 gas engine
- tunning my MVVS ???
- fuel tank plumbing
- Flexable Ehaust
- plug ????
- Gas engine compared to 2-stroke power
- RCS 215 timing gears
- ZDZ 40 Muffler Attachment problem
- US Gas Engines.
- Engine Noise from 3w-70iUS?
- BME 110 question
- Where to get Amsoil in Indianapolis?
- Zenoah G-45 mounting?
- first gasser for Sig 1/3 Spacewalker?
- fuji 35 where to get new carb
- doesn't anyone els have a MVVS 35cc
- Walker 3.2 vs DA 50,BME 50
- BME prop attach question
- Old Z80
- Hey BAX ....Forget It I fixed it myself!!
- BME 50 Prop Confusion Opinions Wanted
- Korea YW still operate??
- G-62 fast idle, tighten tailwheel? Not!
- Small Gasser
- Contacting BME?
- G62 Idle
- ZDZ 80 rpm and prop choice
- Zenoah G23 Spinners
- Changing crankshaft on G-62.
- Help - Zenoah G-62 won't run
- Muffler Temperature
- Brison Customer Service ???
- YS 1.40 L / YS 1.40 DZ / DA-50
- Need Manual Gas Pump - HELP!
- G 23 spark plug?
- Performance w/ Amsoil 2000 vs Amsoil 100:1, are they the same?
- Best gas/oil ratio for older G23?
- ZDZ 80 spark plug
- Old style G38 kill switch
- first 2 flights with my MVVS 35,,,
- Why No Gas 4-Strokes?
- fuji 50 sb
- Taurus 52 HELP!
- Opinions of MVVS 2.15 and Roto 35cc
- us 41 coil mounting
- coil mounting
- 19.2volt cordless drill/excellent 50cc starter
- da 100 headers
- Sachs 3.2
- Same battery for Rx & Ignition ?
- ZDZ100NG
- Bel Ray H1r
- Prop Thrust
- Zenoah 23cc - Z230 heli
- DA-100 idle speed in flight
- Bad Business Practice - US Engines - Anyone Else?
- Having Problems with DA50 ?
- Replacing the Cylinder, ZDZ 50
- Anyone know who makes these fuel jug caps?
- BME ATTENTION!!!
- Symptoms displayed by over propped gas engine?
