View Full Version : Gas Engines
- Can t start my MVVS 1.60 Gasser, Pe or anyone with experience on electronic ignitions
- Zenoah G-62
- Keeping Muffler Bolts in
- Saito 180
- props
- Tru-Turn Spinner Question
- ZDZ 60 tuning
- Removing Idle Stop on MVVS 1.60 Gasser
- Fuel Filter for Gas Engines
- Walker Sachs
- out of touch for a little while
- zdz 40 runs lean in outside loops
- Zenoah G34L--any good?
- brake in
- High Low needle valve adjustment
- Taurus,Taurus,Taurus.......
- Saito 300 vs. OS 300
- Mds 2.18??
- OT: GP 1/3 scale pitts ARF tech notice
- Resister Plugs Gas Engine
- Ryobi 31 @8000 RPM (18X8)
- Anyone flying Quad 75xl
- Weedeater Engine Conversion
- Good muffler for 50cc ??
- Need line for smoke, tygon melts
- Too Much Muffler Volume?
- moki 2.10which prop?
- ZDZ engines questions.... ???
- da 150 vibration
- Precision Eagle, How would you rate?
- equivelent?
- Brison 4.2 which prop?
- Saito 300 Twin Idle
- ZDZ 60 prop nut size
- Was5.8won't fire Now 5.8a man eater
- Engine repair
- Does anyone have tips on carb adjustments on gas engines?
- engine has little response when in a hover
- Sukhoi Brison Combo
- Mv Vs1.60 Gas/ Pitts Muffler
- Fpe 2.4
- drilling out prop and spinner for moki 2.1?
- Quadra Engines
- I posted this in the ARF forum, but it applies here too
- muffler for rcs 180
- AW 40 Inline Twin (Moki?) gasser
- source for bearings??
- Fox Gassers
- need advice on balancing 32 x 10 prop
- FROMECO fail safe Reliaswitch
- What engine goes by the name of "THE EAGLE" ?
- ignitions
- Quieter Pitts muffler for 3W75?
- Took engine apart
- 19 or 20" Props fror G38?
- What mufflers are you using on your ZDZ 80 single?
- Saito 180 - Loosening muffler and exhaust pipe
- G-38 muffler bolts
- Moki 1.35 ?'s
- mvvs 160 gasser
- Help removing engine with alum. mount with loctite!!!
- How much does the Tauras 3.7 weigh....
- Any experience with YW Engines of Korea ?
- Overheating ????
- Brison Mechanical Advance - any good?
- Can i get parts for this?
- MVVS 1.60 Gasser - A Question or Two? for Pe or anyone
- G62 Low speed vibration
- Strange Problem
- Tuning a G38 or G45
- Gas cans and pumping fuel
- What engine to use?
- Thoughts on FPE 2.4
- G-23 fuel line
- g38 zenoah
- Good News Ryobi Fans
- Prop for Brison 3.2
- anyone running os 160 in fun fly ?
- ZDZ 60 pressure tap ?
- Wolfe gas engines? Where?
- Don Harris Smoke Pumps
- A&M Sachs 2.0 Gas
- Zdz-80 Quick!
- RCS 140? Anyone with experience
- Fuel tank venting (gas) HELP
- G62 prop
- Vibration reducing mounts?
- Tartan Twin info
- 3W 75 single replacement spark plug??
- ST 2500 / Sig Sukhoi
- A must read!
- 32-1 thru 80-1 oil what the difference?
- Bme50
- Where can I get standoff engine mounts?
- What engine for a Lanier 1/3 Extra 300S
- Need Engine Recommendation for 1/7 C-47
- New Saito engine
- Does anyone have or had a Brison 3.2?
- General Carbon Prop Question(s)
- Replacement for APC 20/10
- 5.8 brison
- MOKI 2.10 Problems
- ZDZ 160 question
- Brison 4.2 numbers
- Saito 180 dangerous?
- Know anything about a Kawasaki ??
- custom smoke muffler? (build it myself?)
- Low and High needle settings
- How can I wire in a voltwatch on the ignition side of my MVVS Gasser...
- mvvs 2.1 gasser and H9 1/4 Cap 232
- BME 100 / Aeroworks 33% Edge 540T
- 3W 78B2 - Any comments or problems?
- Moki 360 inline twin
- 3W 100 quits when nose down
- which is better 3w-50i,bisson3.2,FPE 3.2?
- Mount for a BME50?
- Ryobi carb/fuel tank configuration
- Can you identify this gasser ?
- OS 160 Prop size?
- Moki 2.10 Questions
- help with Zenoah and spinner
- H9 Cap & MVVS 1.60 Gasser: Second Impression - Wow! Things are really looking up.
- Break in question for Zen GT-80
- Us 41 ?
- ZDZ60&27%Cap great!
- Klotz Oil Problem - Very strange
- ZDZ 40 , what props are you using?
- mvvs160 gasser and H9 taylorcraft
- US 41 & H9 Edge 540 ... which prop?
- throttle on zdz 60
- ZDZ40 and J&A Peacekeeper muffler
- Sachs 3.2 prop?
- ZDZ 80 twin
- Six bolt Prop Hub???
- Super Titan Twin???
- Which Engine
- Help With Web site for ZDZ and BME Engines
- Out Of Town Notice
- CH Ignition Voltage
- Gas engine for 16# Sport Plane
- Prop for 3.7 ????????
- Perry oscillating pump on 1.60FX
- Normal RPM Range for 3W 150
- g-62/ j&a peacekeeper muffler coming loose
- tank placement on moki 2.1?
- Large Taurus Engines
- Best gas engine for a H9 cap 1/4
- Please read before posting...........
- ST prop question???
- MVVS 1.60 Pipe/Header Weights
- Carb rotation for US41
- ZDZ 60 or BME 50
- Taurus 2.6 and flexible exhaust down-tubes
- Best Gas Fuel tubing
- Q35 problems
- BME 44 and H9 Edge.
- Timing on zdz 80, Dick Hanson please respond
- Ryobi Conversion
- MVVS 1.60 Gasser & H9 Cap - An Observation
- Did I goof in drilling my prop?
- Os 160 h9 cap 1/4 mounting question
- Bent Crankshaft
- Supertigre 3250
- New Gas Engine $49.99
- Ryobi Conversions
- BME 85cc Single
- Anyone use J'Tec snufflers?
- Question . . tips for operating ST-3000?
- G23 midrange
- MVVS 1.6 gas, any experience?
- Gas engine carbs?
- MDS 1.48 mufflers
- Questions regarding G23 glow engine.
- Tartan twin
- 2 Stroke oil
- Moki 2.1 fuel line?
- Need Help!!!!
- Honda Mini 4 Strokes
- G62 and TF Power Point Question
- Ignition Upgrade for FPE 2.4 ---> Better Performance
- RPM Data on Super Tiger 2300
- unknown engine help!!
- New Saito 300 Twin
- Giles202 engine words of widom
- What have I got ? Please help
- Do you run a Taurus? What prop do you use?
- Prop Torque Specs please
- 2 stroke oil for gas engines
- Brison 2.4 and Klotz
- 3W 80 Weight?
- BME 102 dies after 3 minute flight
- Backwards Moki 1.8
- ZDZ 120 Boxer Carb
- BME 44 quits after long dives towards the ground
- 3w-100B2 Flameout
- fuel line clamps
- RCS Info Received Close site
- Da-100
- Fuji giant scale engines good?
- 3W-Plugs
- Highest RPM's on a 75cc?
- FPE 2.4 info.
- Modifcations of a Big Super Tiger
- Setting Idle
- what is a good sized engine for...
- Question......
- What advantage is there in buying a carbon prop?
- Moki 2.1
- Ordered MVVS 1.60 Gasser - Topmodel..
- FPE 4.2 Carb transition problem
- Moki 3.60 twin
- ZDZ 40 Hard to start
- 3w-100 noise prblem
- Choke assy. for G-23
- ZDZ ignition
- Ayone used an R.C. IGNITION?
- DA 100 prop
- bme 3.7 prop size
- What fuel are you using in the MDS 1.48?
- BME engine mount
- Minimum Cooling Requirements
- Maloney Spark Plugs
- Zdz40
- Cheetah 2.5
- Source for MVVS 1.6 Tuned Pipes?
- Colored Smoke?
- Smoke System for Saito 150 HELP
- Ryobi
- Tru-Turn Spinner Help?
- Prop reamer for BME 44
- ST3000 and nitro % ????????
- Throttle Linkage on 3W Tilotson
- Fuel tubing setup
- Spring Starter on G-62?
- Another choice
- updated MDS Carb on 1.48!
- quadra 35
- WHat to Buy
- Gassers... Fuel Smell
- Engine replacement ST3000-Gas
- Zdz fuel?!?
- Engine Weights??????
- MOKI 2.1 Questions
- Help - MVVS 1.60 Gasser Will Not Run!!! I'm Desperate.
- What size battery do i need for my flight box?
- Ignition PleaseDelet
- Mega Smoke System???
- Supertigre ST-2300
- Black exhaust from a Zenoah G45?
