PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 [63] 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. New to Forum and Gas Engines
  2. G-26 upgrades..?
  3. Fuel Clunk
  4. Gwin Aero Mighty Midget..
  5. 3W 70i Header Length
  6. Evolution/MVVS 45 carb tubing
  7. ZDZ 80 Carbs?
  8. Wich engines???
  9. How do you check for COMPRESSION?
  10. C&H ingition - 6 volts OK???
  11. Is PCM and Elec. Ign. a must? Is PPM OK?
  12. Prop Indexing for hand starting
  13. COMMENTS ON SKOREPA PROPS
  14. 3WSYNTHOIL
  15. How about synthetic 2T oil for G26 or gasser?
  16. Walbro carbs, difference w/wo primer bulb
  17. C&H Ignition on Brison engines no longer
  18. G26 mount??
  19. tillotson carb 3-w 150
  20. Which canister for Evolution/MVVS 45
  21. MVVS 45 MUFFLER
  22. Venting a G26
  23. DA 50 Choke valve strength
  24. A&M Aircraft Motor.(#s mean?)
  25. Fuel pressure
  26. MVVS 1.6 and black goop
  27. Ace 4-120 Bipe
  28. Red Max 50:1 Premix
  29. Need lightweight Gasser to turn 18" prop
  30. G26 Gas Oil Mix??
  31. Help Identify this engine
  32. da 50 problem help me pls
  33. 3W-150
  34. 3-line fuel system
  35. Bing carb on ZDZ80 question:
  36. Da-50 Deadsticks.... any thoughts??
  37. G-26 rebuild publications??
  38. quadra 52 firewall install?
  39. gas fuel dot ?
  40. tachometer
  41. Questions for Roto25 Users
  42. MOVED: compression range for weedie/chainsaw engines
  43. ZDZ 80 rv won't run
  44. Happy New Year gassers as RCU heads into its 5th year and is here to stay for the next 50!
  45. First Place 1.3 engine(corr)
  46. fuji 50 sb - no spark
  47. 3W STARTING PROBLEM
  48. 3W STARTING PROBLEM
  49. Modifying Walbro carbs
  50. Spitfire engine
  51. My First Gas Engine Revolution 52
  52. brison 2.4 setup once and for all!!!!
  53. Sachs 3.2 Header/Pipe
  54. help!DA 50 plug tip
  55. Pictures inside Canister Muffler
  56. RCIGN1
  57. FLYWHEEL putting back on???????
  58. DA 50????
  59. G26 (Zen) Velocity Stack positioning
  60. 28cc McCulloch and GP Giant Big Stik???
  61. spitting back fuel
  62. G62 Lite
  63. Brison 2.4 vs Evolution 35GT
  64. Velocity stacks
  65. Melody Engines
  66. FUJI 50 EI VS 43EI
  67. Carb to Firewall Space?
  68. G-62 hop up and replacement parts.
  69. ZDZ prop drilling?
  70. G-26 cannot get reliable idle for landings
  71. JMB Muffler with a DA 100
  72. Canister muffler for DA 50
  73. EXHAUST MOUNTING HELP REQUIRED
  74. DA 50 All-Up weight question
  75. Mach .15 ?
  76. Ready made fuel jugs
  77. New thread :carbon cannister in composite forum.
  78. 3W 80Xi owners???
  79. Which one? ZDZ 50 VS DA 50 VS MVVS/EVO 45
  80. kill switchs on gas engine ignitions
  81. DA 150 Question
  82. BRISON 3.2 AND PROPER BREAKIN AND OIL
  83. Toni Clark Hydro Mount
  84. G26 with Monocoupe
  85. Bent crank? OR not??
  86. O.T. sites that have used Planes for sale?
  87. Anyone fly with a Aviomac 250 quad engine?
  88. Fuji 43 Connecting rod Unique design?
  89. ZDZ160 ON A 50 POUND PLANE???
  90. Thanks!
  91. DA100 Does this look right to you?
  92. DA 50 question
  93. Throttle Arm Tension Spring on DA 150
  94. More Brison 2.4 ??
  95. Tips for putting a gas engine in long storage.
  96. Brison 2.4 VS ZDZ 40
  97. Propeller for ZDZ 160?
  98. 3W 106 QS running probs- HELP PLEASE
  99. Initial settings for a Fox 3.2????
  100. Which prop for a G45
  101. G-23 Bad Crank Needle Bearing Ahhhh!!!
  102. ZDZ 40 plug wrench?
  103. G-38
  104. walbro carb
  105. Lanier yak engine choice?
  106. HELP !! Settings for 3W 75
  107. RCS 75, any info?
  108. Throttle Coupled Spark Advance System
  109. DA 50 canister?
  110. Da-50 selling advice
  111. Walbro repair kit
  112. The most quiet muffler/pipe for a big gasser???
  113. DA-75 Where are you???
  114. 1.20 size light gas motor...?
  115. How do i setup ignition/switch on Da100?
  116. good 3D plane for G26??
  117. brison 3.2 what prop
  118. 3W 150 or 157?
  119. Moki 210 versus 40 cc gassers
  120. Looking for 32*10 prop
  121. ZDZ Super 80 & torque roll
  122. zenoah g-62
  123. 3W 106 W Chip Hyde Quiet Pipes
  124. What Cannisters?
  125. brison 2.6
  126. Ignition Question
  127. MOVED: recognise my engine please
  128. Evolution 58
  129. Brisson 3.2 smoke tap
  130. Can I use a Menz 30x8 Prop on A DA-100?
  131. G-62 engine
  132. DA 50R Serial #'s
  133. LIGHTENING UP
  134. muffler for G 26
  135. Any advantage with two piston rings?
  136. 3W Ignition Module ??
  137. What are you using for a test stand?
  138. Evolution 58 runs backwards
  139. BME 50 Carburator Choke stuck
  140. Polypropylene Fuel Tubing
  141. Need contact info for Bold Mufflers
  142. MOVED: Homelite Magnum III 3.55 ci power issues
  143. MOVED: Yak 71" & Brillelli 25cc gas , How well they match?
  144. MVVS 1.6 Mufflers
  145. Help Fuel Injectors
  146. Which 5" spinner for g45 ?
  147. Fuji Impression !!
  148. EVO 80 now running
  149. muffler
  150. Brison 3.2 prop not fitting tight
  151. How big of a warbird can G26 handle for scale and mild acro?
  152. Light G62
  153. High Octane in DA 50
  154. G26 enough for Hype Sukhoi?
  155. Is there a resistor plug available in the CM-6 size?
  156. MOVED: Anyone have experience with these conversion engines
  157. Easily reverse your one-way gas pump!
  158. need help with sachs 2.7
  159. Have You Ordered an Engine From Europe?
  160. WHO IS USING KLOTZ KL-100 oil in their 50cc & up Gas engine?
  161. DA-50 Walbro carb issues...
  162. Taking a G45 out of storage.
  163. ZDZ 40 starting tips?
  164. How do you setup gasser fuel tank?
  165. Can I extend/lengthen the magneto red/black lead?
  166. Ignition System for DA 50 R
  167. 26 gt gasser & ohio r/c extra
  168. How long are plugs good for?
  169. Extending probe wire ?
  170. MVVS 58
  171. MVVS-Evolution Issue
  172. Kroma 50
  173. ansoil mix for DA 100
  174. Sorry clicked twice
  175. Pls share pic of your servo/throttle linkage on G26 or similar
  176. ZENOAH G380PU 38
  177. Ok to run Avgas.....
  178. Looking for most powerful RC engine
  179. Spark plug gap for a G 38??
  180. Fuel suppy to U.S. 41 cc engine
  181. cannisters on brison 6.4???
  182. Source for large 3 bladed props?
  183. 4.8v 2100mAh NiMH battery
  184. Blendzall 2 Cycle oil
  185. Mounting a G-26 Upright
  186. Old Engine
  187. ROTO 35VI ????????
  188. Hand starting G26
  189. Am I crazy to fit G26 onto Great Planes PT19?
  190. what battery for 69cc brison? nimh
  191. pipe design
  192. RCS 140
  193. Ignition switch for the DA 50 R
  194. New ZDZ doesn't idle
  195. Fuji 4 Stroke 34cc
  196. How do I set up kill switch on G26? Simultaneous Servo and switch??
  197. Width of Zenoah G-26
  198. Where is the G26 thread on problem to start when new?
  199. first place 2.4 or 3.2?
  200. zenoaoh G-38
  201. Suggestion for Protecting Spark Plug Wire
  202. DA 50 or evoulution 58 ?
  203. Evolution/Mvvs 58
  204. Will it fit???
  205. What Muffler for Evo 1.6?
  206. Carb getting blocked
  207. DA50R Bench Break in
  208. Brison 3.2 mounting template
  209. Sending a DA 150 to Desert Aircraft
  210. 3 W 80 B2 Question
  211. DA 50R repair
  212. Engine Match...Again
  213. Head temperature related to oil content
  214. OS .40SR piston ring
  215. Getting Ready To Buy Zenoah G-26
  216. Real Gas vs Converted Glow Gas Engines
  217. running in new engines
  218. Mounting G26 - soft vs hard?
  219. JMB website
  220. Anyone flown the GP PT 19 on gasser ie zenoah g26 or MVVS 26?
  221. Fuji BT64EI test
  222. BRISON IGNITION VOLTAGE.
  223. My my, how things and times have changed.
  224. Here's one for the 2 cycle oil debate
  225. Planes for 25 cc engines
  226. breaking in DA-100 and problem need help
  227. Cold weather - long time to warm up?
  228. Evolution 26
  229. Engine Breakin
  230. 43 EI & Big stick
  231. Mounting mvvs 1.60 to funtana w/pipe
  232. Piston port vs reed induction
  233. Walbro WT-645 vs WT-644 question
  234. All
  235. Voltage limits for CH ignition
  236. MVVS/Evo 26 with Tuned Pipe
  237. New to Gas
  238. Which size GAS motor for a "WEEKS SOLUTION"?
  239. I am looking for an engine...
  240. Roto 25 Gasser Change in Idle Question
  241. DA 150 tuning
  242. What engine for this plane??? 1/2 scale project!!
  243. Piston Seizure Poll
  244. Help need engine RTF weights
  245. Carbon Fiber Canisters?
  246. MVVS 45 and mtw td50 canister
  247. Someone whit experience of "no name" gas engine
  248. Brisk Spark Plugs
  249. QS150
  250. *Brillelli & GCBM 25 CC Engines*
