View Full Version : Gas Engines
- WANTED: Walbro WA144 - unavailable at B&B
- Which 3D plane for MVVS 2.1 (35cc) ?
- Quadra 28 ???
- Had a blow out on a JMB can
- Funtana 90 w/small gasser setup tips
- BME 110 Extreme Prop etc...
- BME 110 starting problem
- bisson vs supersonic
- Help!!!...G26 Carb' problems???
- G-62 Prop
- G-62 Prop
- M&R 100 engine help
- Ebay G62's, new, deal or not?
- Plug Reading Question
- 70cc-80cc Engine Opinions
- DA 50 Mount Pattern
- DA-150
- ZDZ 80 Quits after a few seconds.
- Gas newbie G26/G38?
- 30cc Homelite conversion??? HELP !!!!
- ZDZ 50 problems ??? anyone ????
- DA 50R - Carb position reversible?
- Zenoah G26 vs US Q25
- Recommendations/Comments on 20cc Series Gas engines
- BME 110 extreme
- Brillelli Engines SEC Engines
- zdz 80 rv rpm
- BME-105 Headers and canisters
- Setups for quiet dB on big engines ?
- Brison engine with a 400 ml tank
- Walbro Carb
- About funtana .90 box size
- On board electric starters?
- Crankshaft pointing down...
- Gas Tank Vent ?
- 3W-157 Prop?
- Rings
- props for a brison 3.2
- DA 50 - engine cut / dead stick
- [b]"TAURUS OWNERS ONLY"[/b]
- Header question.
- 3W106 Need Help!!!
- Brison 3.2 Plug Alternative ?
- Quadra 42?
- Help me sort out my 3W 50i
- zinger pro vs msc or menz
- Crankshafts
- NEW!!! Taurus T-52
- da 100 vs 3w 106
- BT32 Engine Mount
- DA150 misfire
- J&A 3.2 Sachs??????????
- G-62 prop hub roll pins
- KROMA 100 or 3W 106
- DA-50 and KS 1060 Tuned Pipe
- Engine Mounting Plate
- Piped exhaust for a G23.
- ZDZ 100 NG
- Inverted Wraparound Muffler for New ZDZ 80 RV-J ?
- DA 75
- props
- World Model Extra 330L 28%
- ZENOAH STILL not pulling fuel ????
- parts for zdz 80
- DA-50r Substitute
- Newbie help. What size should I get ?
- U Can Do 60 with an Evolution 26GT petrol
- Super Tartan 22, is it any good????
- radial engines
- opinions about BME engines
- Ignition setup for DA 50
- BME 50 Question
- Fuji BT-64EIS
- Any word on any NEW DA ENGINES<<<
- ZDZ 160 vs DA 150 ????
- MVVS 116 Updates?
- DA-50-R
- 3W 157 OR DA150
- Winter Storage
- Bisson or Slimline for DA-50
- Canister Mufflers-How do they Work?
- Dose anyone have C&H ignitions email address?
- Engine choice, plz help?
- 3W 56B2
- prop, what one to use?
- G-62
- Prop Shaft Extension
- Gasser Smoke Muffler Question
- *GCBM 25cc(1.5 c.i.) Gas Engine*
- New Mejzlik Owner Has Questions
- da 50 rpms
- Lawn Boy Ashless
- mvvs 45 & DA 50 actual weights
- G-62 and Ralph???
- 3W 140 B2 starting question
- Roto 35 silencer
- Spinner from the box for DA 50 R ?
- DA 50R FUEL LINE SYSTEM
- Where to buy a ZDZ or DA engine
- MVVS 45 vs. DA50
- Engine Break In
- Do velocity stacks lessen power.
- US 25cc
- ZENOAH Not pulling fuel????
- Break-In
- KILL SWITCH ON ZENOAH G 38!!!!!!
- New Canister Mufflers
- 3W 157...who has one?
- what do I use for the clunk line in a petrol plane
- Help Starting ZENOAH !!!
- da 50 props
- Crashing gas engine planes
- radio interference
- Evolution gassers, Any good?
- ZDZ Owners, Need help
- MOVED: engine help
- EQUIVALENT GAS ENGINE TO GLOW ENGINE?
- USQ (Quadra) Engines - Customer Service
- I need a spinner
- ZDZ 60 vs MVVS 58
- Quadra 65cc starting problem
- G-62 safely adjusting the carb
- MVVS 58 vs ZDZ 60
- which gas engine for funtana 90??
- Gas engines from China??
- DA 150 Cans or stock mufflers?
- Vent Question
- BT32 & Giant Stik
- Quadra 52
- Measuring Oil
- FPE 1.3
- BF-34EI parts question
- Oil ratio for run in
- Prop for Evolution 58 at altitude
- MOVED: about 1/6 scale FG monster truck
- ZDZ 50 v/s the DA 50 for a BME Yak
- "Calling All "WALBRO" Experts"
- ZDZ 80 RV in Mick reeves 1/4 spitfire
- WEED EATER 25CC CONVERTION
- replacing 3w igntion
- 3W 100 Tries to die inverted
- Question about the BT43 EI
- How do I mix a music track to fly too????
- ZDZ80B2 Fuel Problem
- BME 105, best prop
- Brison Revolution 50 engine
- Fuji 50EI slim or pitts muffler??
- Your Favorite G62 Options
- When is gas better than glow?
- Thumbs up to ZDZ
- New JMB silencer and cans for ZDZ 80RV-J
- U.S. 41 and 21 pounds of airplane- HELP!!!
- Opti-2 oil
- Flex Cable for Throttle on Gasser?
- Make your own Electric Starter, How to???
- zdz 40 break in question
- ZDZ100NG with mufflers?
- SUPER TIGER 2300 & 3250 needle settings
- 3W carb linkage installation
- CArb, Throttle, Choke questions on DA-50
- Headers for MVVS 45
- PCM vs FM for gas/ignition
- Need weedeater conversion parts
- This Forum Closed
- zdz 160 champ
- EI Conversion for 32
- GP GIANT BIG STIK G26 or G38
- Inline twins 3w or ZDZ?
- QUADRA 100 VS 3W 75
- BME 110
- Engine for Midwest Super Stinker
- G-26 tuned pipe
- Header and pipe for ZDZ 40??
- What carb make and model on you US41 cc? Help!
- carb model type and model number
- Quadra 42 Maintanance and Repair Manual
- Can't get weedeater conversion to run
- NEED WIRING DIAGRAM FOR CH JUMP START
- Fuji 50EI rubber mounts
- RCS 140 Tuned pipe setup
- Dynattron Conversion to Miller Belt Drive
- Price on a used 3W 140 TOC?
- Heat shielding for canister installs
- new BMB canister??
- thrust of DA-50R
- US 41cc engine
- BME 44 Cannister Results!
- What is the procedure for installing a gas engine propeller with center and six outer bolts?
- Wanted DA-50R or equivalant
- Construction of 100cc Extra 300 .
- G-62 On-Board Starter
- 3w 55ius
- Someone please explain the term " thinned oil"
- Quadra 75 spark-plug size
- Does anyone out there have any experience
- Best Gasser Throttle Servo
- piston port induction vs. rotary/reed valve
- Quadra 35
- Fuel tank assembly
- G-26 DIES WHEN INVERTED
- fuel for gasser
- What fuel tank size for 60cc gas
- Brison 3.2 Backfire.... HELP!
- 3W Comparision 80vs 100vs 106
- Brison Rattle
- 100cc glow engine
- gas engine for dynaflite super decathlon
- Walbro replacements ?
- Spark plug color, to rich, lean or correct
- Fuel mixture changing with airspeed?
- Fast fuel drain on a 3W-60?/Problem solved
- problem with DA 50 engine
- Fuji 32, any good??
- zdz 80 idle
- Webra Bully 35cc muffler-can't find one
- Your ideal 40-55cc class gas motors...
- DA 100 All Up Weight
- Gasser air filters
- Kroma 180i
- 3W vs DA
- DA SERVICE
- Zenoah G26 need some advice........
- where to get spark plugs for a zdz 40
- SOOOOO--The G62 Really DOES Run Good
- Why does my ZDZ 60 weigh more than stated
- DA 100 and prince 27x10 prop ?
- Slimline Pitts vs. Stock Muffler on DA50
- Zenoah G-38 throttle linkage
- What fuel tank size for 50cc gas
- Question for RCIGN1
- In need of a set of 3W Mufflers for a 100
- Oil in Atlanta Georgia Area
- FUEL TANK SETUP FOR 41cc US ENGINE
- 3W stock vs TOC vs CS series?
- MOVED: Sullivan model 602 starter torque?
- Airplane for G-62 with CH ignition - recommendation?
- ZDZ 100 NG
- Ringfree in hobby engines
- DA 50 or ZDZ 60 for 3D
- AIRHOBBIES TWIN
- Prop drilling guide orientation?
- broken muffler.
- 2cycle Oil
- identifing engine size
- GP Christen Eagle Help!
- 3W 100 - quits in air if idle set too low
- Amsoil and DA 100 Question
- MVVS 35cc, help w/choke set up
