View Full Version : Gas Engines
- MAN OS GGT10 review, picture captions in what language ?
- Some progress with the GT80, but still a couple of concerns.
- B25-Engines?
- Rcs44b2
- Changing from 20:1 to 32:1 gas to oil ratio
- Adding a 12" ext to the pick up lead??????? DLE 35 RA
- NGH 30cc 4 stroke
- At a complete loss with GT80...........
- Can I use A123s with this G-62 ignition?
- Sticky gas review
- choke dont close
- Six bolt hubs
- OS Muffler on Evolution 15GX2..?
- Bennett muffler repair
- Tuning your Gas Engine made easy....
- Zenoah-62 reduction drive starting
- Brison 52 bearings
- DLE 35ra fuel consumption rate
- gas engine surging
- G-23
- Need larger cup
- SPE 26 Parts
- Zenoah gt80 problems
- DLE 20 muffler question...again; Sheeeh.... let's try it with PICTURES this time.
- Sachs 4.2 engine
- DLE 55 ignition modules
- 1.20 glow versus 30cc gas
- Need strange muffler for DLE 20 in this strange position....
- DLE 120 / 111 bolt pattern
- weigh and size Dle 50 and DLe55
- BCMA 26cc AND BCMA eXL auto advance ignition MANUAL SEARCH
- new to zdz 80 super, hints & tips?
- Is this too rich?
- DLE Carb Rebuild Kits
- Os gt10
- Gas Engine Fuel Line
- Lift Meister - engine for?
- G-45 rpm?
- RC 35cc Gas engine Plane Cooling
- Need help identifying mystery twin?
- Bowman's Rings
- quadra , wont start ?
- G38 On Coleman Fuel
- Plug cap falling off
- Zenoah G62 oil mix question
- HS needle setting for Evolution 15GX2?
- Engine will not fire..15cc
- Gas/oil mix and ring replacement
- Is This Safe for Gas??
- Dle 35 carburator
- ATT. Gas engine Gurus OS Max GGT10 CC or 15 CC
- AGM warranty beware
- Fuji 64 cuts out in midrange
- Valley View Props?
- dle 20ra
- Is it possible to cut the insulator block on the carb of a G 62 for more clearance?
- Prop size for Saito 150 gas
- ZDZ 80 twin---wanted
- Composition of Stihl HP oil
- Carb flooding
- G-38 diaphram--oops
- DLE ENGINES going to exclusive USA dealer.
- mineral oil
- gas/oil ratio for Saito 150 coversion
- Homelite 30cc
- ASP fs 400 radial engine
- G-38 spring starter
- DLE 40 CC Twin Cylinder Engine
- What size Glow engine is the power equivalent to 30cc gas engine?
- C&H module for a Brison 50cc
- JC 30 Evo Gas Engine
- the $2 boat motor
- Rcxel 2.0
- DLE 55 runs great in the morning, won't run at all in the afternoon
- small gas engines
- Throttle curve OSgt33
- G26 running but??
- Brison 2.4,, parts??
- Help with rcgf 15cc
- carb setting
- G 26 help
- DLE55 RA Performance w/ Bowman Ring and timing at 28 degrees BTDC
- Gas Engine - Choke Push Rods: Need Some Suggestions
- Please identify this 20cc gas engine
- - identify - What gas engine is this ?
- 3w120
- New 11mm carb for a good price
- Engine Backfires and Kicks Back
- BME 44 carb replacement?
- DLE engines and Valley View RC
- O.S. GT 55 gas engine
- DA 50cc
- Loop in gas tank vent line?
- Help Identify these Engines
- Sensor Pick-up Lead Extension - ZDZ Ignition
- prop cutter
- Saito fog-84-r3 won't start
- troubleshooting a G26
- Evolution 33cc GX
- G 62 carb question
- power for engine and recvier
- Gas Engine running temperatures
- Old Timer engine. Does anyone know anything about it?
- DLE-55RA Battery Voltage Question
- Old DL-50 questions
- Mounting the carb on DLE20
- Evolution 15GX2 Throttle Barrel binding....again
- 30cc prop question
- Servo activated kill switch location for magneto g38
- DLE-30 Experts HELP
- Dle 120 prop extension
- How do you tell the difference between a G 62 and a G 45??
- evo 10gx issues
- Glow-Gas engines
- Stating ZDZ 50/60 with electric starter
- RCGF USA Warehouse and Service Center is available !
- DLE 30 Question
- 1/4" copper washer for glow/spark plug
- Gas Engines RPM
- First gas engine question
- Saito 82 b vs Evolution 10gx -feeling stumped and need to make a decision ...
- Prop size for stol airplanes...
- Help with walbro carb
- RCGF 15cc will not run!
- 1.60 Glow to Gas Question
- Ignition Switch Setup
- DLE 20cc Very High RPM
- Fortitude gas tanks
- New OS GGT10 just came in
- Syssa Mounting Template
- DLA 58 won't idle down or reliably
- Muffler for Sig T Clips 70
- engine for aeroworks extra 260 35cc QB
- Agm-30?
- Throttle Servo
- NEW RCGF 10 cc engine
- 20-26 cc gas engine -recommendation?
- Saito 82 ( 14 cc)
- Welch Plug Installation Tool
- Mini V-12 RC Model Aircraft Engine that Actually Runs
- NGH 26GT muffler bolts?
- carb overhaul
- Moki 250
- DLE-30 RPM lead to Hitec Optima???
- Saturday's Stupid Size Question
- Bme44
- HELP air in fuel line!
- Need Assistance With Gas And Glow Engines In North Atlanta Area
- Correct carb for older 3W-75
- PTE 36 r engine
- DA150 problem
- The Hangar 9® P-51 Mustang S 8cc gas trainer
- DLE 30 problem
- VVRC 40 Twin
- 4 Cycle RC engines
- Looping vent line on top of fuel tank?....
- Engines
- Rear exaust DLE 55 vs side exaust....
- DLE and others DRY Carbs?
- Need engine for my Spitfire
- First dual carb engine - fueling question
- OS GT15, Initial Impressions
- Muffler
- Da50 aluminum bolts torque
- eme 60cc mounting problem
- canister muffler for twin cylinder engines
- DLE 60 Twin
- Canister exhaust rear dump for RCGF 60cc twin cyl and Saito 57TS 4 stroke
- Need Some help With a Wankel Engine
- Throttle cable flexing (binding) 15cc Evolution.
- MLD 35 ... anyone selling parts for these in the USA...?
- Need help identifying this large scale engine
- Quieting a DLE 60 on a 30% Raven
- Question for the gasoline engine gurus
- Identification help
- NGH GT25B ON Hobby King MXS-R
- Help! Need parts for gas motor
- Quadra 35
- Walbro wt-433 substitute
- 2 Stroke gas/oil exhaust temperature
- Reuse nitro fuel can for gasoline?
- High Temp Loctite 5770?
- bolts for aluminum stand off
- Gas engine Storage?
- 3 w ignition plug wire?
- How do you set up a gas engine fuel tank?
- Evolution 10cc drive key (Woodruff key) size
- Evolution GX33
- Motor Mount for Saito gas Conversion
- Zenoah GT-80 interrupter
- 3MM 53cc engine owners?
- Tuning Moki 250
- 12v electric starter for 80cc gas engine
- zdz super 80, need ideas
- DLE 20 fuel consumption
- DLE 55 w/ 16 Oz. tank - how long will it fly ?
- EGT probe install
- OS 120AX gas conversion?
- Telemetry for gas engine temps(inline twin)
- NGH GT25 Thrust ?
- Help 3MM 53 prop washer
- RCEXEL opo w/BEC
- Caution dealing with syssa aircraft!
- WANTED Thor 45 muffler
- HF 3 bladed c/f prop
- G62
- Need some advice: DA50 overheated and crashed
- DLA 116 in-line twin
- Need engine advice
- Which is the smallest gas engine 2 and 4 stroke?
- Zenoah timing
- Quadra 52 Carb
- Quadra 40 and a Big Stik
- Help engine air hobbies
- venting gaser?
- roto motor 85 fsi
- Evolution TPS .45 engine dead sticking.....
- Valley View XYZ 20cc choke help please!!
- DA 60 Prop Size
- U.S. 41cc gas engine
- Clunk/Filter?
- Rcgf 30 Twin
- Gas or Glow ?
- os gg15 a runner!!
- DLE-40 Twin
- Roto 25V
- Quadra 35 Specs?
- Custom ZDZ 120 BRV2 Enige Trouble
- Av8tor's "storage fuel"
- Walbro carb supplier?
- Dle 30 side carb
- Old Berlelli 26 needs shaft repair
- Which engine to use???
- dl-50 prop drilling templete
- US 40cc gas engine
- Least Vibration
- Anyone know if the DA150 carb fits on the DA120?
- Conversion - DLE 20 to 20RA - question
- question for antique
- 60cc twin JC EVO
- DLE 20 vs Valley View 20cc
- Brison 3.2 Gas engine (52cc), question regarding prop?
- A question about the DLE 30- How to shut it down?
- NGH 17cc
- zdz 60CC CARB PROBLEM
- DLE 55 hard to start
- mintor 22 info needed
- A complete guide to Saito model 4/strokes
- What Engine
