View Full Version : Gas Engines
- Which Bisson muffler would give the best results?
- Ralph's lite G62
- Props for BME 50...
- Gas Engine Weights - 50cc WEIGHT Class
- Block off primer bulb? g26
- DA100 & Menz 27x10 RPM help
- Revolution 52 and tuned pipes
- Compagnucci .39
- Octane rating for MVVS/Evolution 45? (edit: R/C engines in general)
- weed eater motor conversions
- Cleveland Cyclonic Props
- DA 50 - 3 Blade? 2 Blade?
- 3W breakin Question-Good ole Customer Service/ Maybe not
- Should my fuel dot be above the tank?
- Any one running the new 3W-55??
- Best Mufflers for Gas Engines ??
- Ring failure
- How do you set up kill switch for EI engine?
- storing DA50 for 1 year-how?
- G-38 with a bent crank
- Aerotech P51, Husky Challenger gas engine and missing throttle arm
- RCIGN, the races, engines
- Husky Challenger throttle arm
- BCMA-26 & Big Stick 60
- DA 50cc and Oil to be used
- Missing wires on my G-38
- Disposing of old or dirty gas
- Where is Ralph C
- Loud Props
- E-85 fuel and two stroke oil
- Fuji BT-64A starting woes....
- OS 1.60 or 43 Fuji Imvac.??
- Fuel Pump for gas can?
- Dad needs gasser for QQ 73" Yak
- Any idea what's wrong with my DA50
- Should I go with a three line fuel hook up?
- Good choice for gasser vs. )S 1.60
- Super zdz80 hanger9 Edge 33%
- Sachs conversion upgrades
- GP Extra 330L
- Anybody Weld Mufflers??
- What Engine Have I Got ?
- Need engine advice
- RCIGN1 ,,, I have a question,,,
- Walbro WA164 question
- Toooo Lean ! But cant help it !
- Hypothetical: You finish running, and you want to add after-run oil...
- Parts for Dolmar, Makita, Brison gas Engines
- Ryobi Conversion
- MW54 MK3 starter motor
- Fuji 32-A problems
- Carb Question
- What best cleaning agent after flight for the black soot?
- Strange pulse problem witha Fuji 32 (New Info)
- RCI?
- Quadra 35 installation
- zdz 80 rv prop nut thread size.
- Still problems with my ROTO35Vi
- ideas needed for broken flex header??
- Stock Mufflers?
- ZAMA Carb replacing a Walbro
- G 62 Exhaust
- polishing in cowl mufflers
- NEW IMPRESSIVE MVVS IGNITION !!!!!!!
- Adding a cleaning agent to fuel ??
- Evolution 45 ignition trouble
- New electronic ignition Zenoah 62???
- 3W-24 Muffler Source
- WHATS THE BEST CLEANING GUM FROM A PETROL ENGINE
- Where can I get a Menzs prop
- Would you put a KS1090 on a 3W75iUS????
- Evolution 58 carb fittings question
- Prop Bolt Patterns
- Quadra 50 carb help....
- BME 100 gas flow rate
- help - need your opinion on the Fuji BT64A magneto
- Engine Recommendations
- Using the 10mm adapter bolt
- Brillelli Boyz
- FUJI 32 EI Engine ??
- MVVS 35 ?
- Gas rookie alert!
- BME 100
- walbro carbs
- zenoah 20ei . . . any set up/ starting tips? tis' my first gasser
- Shutting the engine using choke?
- ZDZ 80 RV-J New Muffler?
- Question about my Zenoah G26
- Really could use some help on this one.
- Used G-38 Problem
- DA50 engine question
- Engine Cleaning
- What can I get away with??
- 3W 100 with PT prop
- Walbro carbs
- G-45 or ZDZ 40
- which way do you mount the slanted velocity stack?
- DA Engine with a 3W ignition??
- ZDZ 80 & KS header problem
- Mvvs 1.60 Engine priming problem
- Where to buy BME engines?
- ZDZ 160
- Im just about to do it :)
- Mouse Can for Gas?
- Evolution 58 gasket
- Carb leaking?
- BME 110 Questions.
- RCS 75R
- DA100 twin, performance tweaking
- G-62 Best fuel mixture
- Desert Aircraft serviceform needed
- Muffler support...
- Taurus TS 52 Template
- anyone have or know where i can get a muffler for a walker 4.2
- Motul 800 Questions
- Need Valve Dimensions
- DA 50 Template??
- swinging that 20"4-blade variable pitch constant speed prop
- Fuji BT-24 Marine Engine - Broken Pull Starter
- 3W-80XI CS on Aeroworks Yak?
- DA 50 owners - post you needle settings
- Great Planes kill switch question
- RFI choke
- MOVED: RFI choke
- Large Scale Online Store?
- need a wizard for my zenoha 62
- anybody running a zdz-60?
- Fuel Tank Help
- Another Purpose Made 4 Stroke!
- Zenoah G-62 Prop hub extension...
- Where can I get my MVVS 35cc Gas serviced???
- Rebuild G-62
- cleaning dusty carb
- 3w 100 lite.
- EI Battery Location
- DA 50 intermittant
- Header for a ZDZ 80 Inline Twin
- Prop For 40cc Gasser
- Gasser on Stinger 120
- Zenoah G-38 stops in idle
- New DA 50 Hard to Start
- ZDZ 50
- 3w 24 tuned pipe
- Another radio glitch question with a gasser..
- Evolution Muffler Woes
- So I'm hooked on gas engines, what's next?
- How long will a 1.400 mAh run a 3w 42
- BCMA Engines - EXCELLENT guy!!!
- Walbro carb ID
- Walbro Carburator rebuild
- mvvs 1.60 gas tuned pipe mounting
- My first 50 cc engine
- ignition noise
- DA50 R will not richen up
- Carbon fiber plate for carb, well it help?
- MVVS 116 Prosport
- 3W 106 adjusment issues -- "balsa box?" -- RTK?
- DA50r PROBLEMS<, thoughts needed!!!!!!!!!!!!!
- DZY 48 T GAS ENGINE
- 3w eng 4.8 what mah
- 3W Hall sensor cable question
- evolution 45 problems
- Kill Switch
- DZY Engines
- Need Large Diameter Tubing for Exhaust Extensions
- MOVED: Pull start not Retracting
- Would You Use This Oil For Break-In If You Had It Lying Around?
- Electronic ignition troubble
- can i cut a da 50R muffler shorter
- 3W 684i B4 TS??????????? For what????????
- DA 50cc problems
- Quadra 50 Timing ? ? ?
- Stuttering Sachs
- BelRay H1R
- Zenoah G62 Power
- Ethanol additive in gas
- 26CC 4-Stroke for $75.00!!!!!!
- Looking for a 3D plane
- Pulse Jet
- where to purchase a new MVVS 58
- New cyl/piston - new running in??
- DA 100 and others - Stopping the Engine
- 2.1 MOKI for the H9 P-51 1.50 ????????
- What brand wood prop is best for 54cc break-in
- q50!! need case or parts engine!!!
- What engine is made for an 18-19 lbs 3d plane.
- 32cc weed eater converson
- Can I use Li-ion cells on my Fuji?
- trouble starting G-38
- BCMA-engines
- DA-50 and Evolution58 Octane ?
- 50 CC props?
- Quadra 42 Help!
- Bme 90/u-can-do combo ??
- Tillitson RK-23-HS carb replacement or needle 3W70ius
- G26 throttle arraingment
- What's up with my DA 50?
- da-100 RPM
- counter rotating engine g38 size
- exhaust problem for mvvs 45 mg
- MVVS 45 MG
- 3W 55i at Cactus Aviation. Help.
- Zenoha G-42
- gas engine very hard to start(3w???)
- Brison 2.4 Cranshaft Play
- Fuel dots?
- DA 50 hard to start
- remote control compatibility to different brand servos
- new zenaoah G20..
- 3W Not Starting!
- Elec. Advance versus Mech advance
- DA 150 Header length
- noise reduction
- Which gas engine for 1/4 scale cub?
- Break In?
- Aeroworks Extra 260QB and DA100!!!
- Turns MVVS/Evolution 45IRS/MG....
- ZDZ160 Strange increase in power.
- 16 oz tank for DA50?
- Evolution 26 GT
- G38 shaft size ??
- Anybody have 3W 240 experience?
- gas to glow
- Walbro Carb Setting
- FYI CMP 50CC extra 330l
- SACHS
- 3W carb replacement
- gas on hanger 9
- Maloney 100 problem
- G62 of Fuji BT-64A
- Need help with gas engine glitching problem
- 3W-200B2-TSCS comparison ZDZ210
- RCIGN's
- Carbon props
- G62 Spark Plug Coming Loose
- 36% katana world models/aero works/bme 110 extream?
- need info on 3W 80b2 TOC
- 28x10 MSC vs. Mejzlik 28x10
- Gas engine for Top Flite Warbirds?
- Zenoah flywheel magnet gap spec?
- DA100 standard Mufflers?
- G-62 easy link adapter
- ignition
- Inverted Blues
- DA fuel spots in Australia.
- Amsoil 100:1 vs Saber
- RCS 1.40 throttle question
- New to gas engines
- Brillelli 40GT anyone running one?
- Smoke pump next to ignition?
