PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Which Motor?
  2. 3W 50cc....
  3. DA, BME, ZDZ, Prop bolts
  4. Where's CH Ignitions?
  5. Sears 2-Cycle Synthetic Oil
  6. Newbie question
  7. 3W 70 Twin slightly mis-firing
  8. Does anyone recognize this engine?
  9. Da-100 Vs. Bme-105 Evo
  10. carbs
  11. Slimline Pitts style muffler for the DA 100
  12. The Reichmuth Ignition
  13. Need "stripped" Super Cyclone ign eng
  14. Crankshaft for Bunch Tiger Aero 45
  15. Zenoah g26 not starting
  16. 3W50RI.........not starting
  17. 3W-75ius muffler
  18. Would a MVVS 35cc be enough for a GP 1/3 scale Pitts Special ARF?
  19. zdz 80 twin... slow to rev up
  20. 3W50 rotten transition, erratic idle
  21. Q75xl starting problems- Help fast please???
  22. 3W-100 issues
  23. Clunk/pickup line question
  24. One Way Bearing
  25. G62 Prop Hub Diameter?
  26. US 41 Loads Up?
  27. FPE 1.3 - Anyone use one yet?
  28. BME,3W, or DA?
  29. CH Electronics Syncro Spark Temperature Tolerance
  30. BCM muffler question
  31. Source needed for inverted pitts J&A muffler for ZDZ80
  32. carb cowl spacing
  33. 4 Star 120 Gas Engine ?
  34. Help with choking the DA50
  35. SlimLine Muffler Measurements for a 4.2 Sachs
  36. prop for Quadra Q-400B engine
  37. Spark plug for a Q75xl
  38. Hot Summer Days With A G38
  39. Fuel mixtures for a G-62 and a Q75XL
  40. Whats the right engine size????
  41. Hard Starting BME 44(help)
  42. Quadra?
  43. broken tap in prop shaft,"what to do" ??
  44. What is your preferred prop for your gasser?
  45. What Can for a BME44?
  46. Gas Engine Suggestions - 1/5 scale PICA P-51
  47. How Hot Is To Hot
  48. G23 Fuel Mixture?????
  49. Break In MDS .58
  50. spark plug adapters
  51. 3w 212 4 Cylinder
  52. Idle problem
  53. 3W 140 Muffler ID/Repair
  54. cleaning a walbro carb.
  55. How to Kill a G38
  56. moki 135 genesis pipe
  57. What rpm from a Taurus 62?
  58. Stihl 031AV
  59. Canister Header Length Question
  60. New engine
  61. DA-50 break in prop
  62. Gas can/pump setup needed
  63. Can you fix a fouled plug?
  64. 80cc Comparison?
  65. Motor box failure
  66. Hard Time Finding Oil
  67. Quadra 42 problem
  68. G38 smoke system
  69. Hanger 9 Supercub & G26
  70. Soft mount for 3W75i
  71. MVVS 160 in a D.P Ultimate. Will it pull??
  72. mvvs 1.60 gasser
  73. Proper Engine & Ignition Grounding - How do you do it ?
  74. ZENOAH G26 Performance Problem Solved
  75. Cup Mount for G45?
  76. MVVS 1.6 gas engine
  77. 3D Prop for 3W-75 US
  78. ZDZ 80 B2 slop?
  79. Blue or Red loc tite on DA50 standoffs?
  80. G62?
  81. Fiberglass or Wood prop, 22x8?
  82. Spark plug for Brison 3.2?
  83. engine for kyosho 7.5 sport
  84. BME 50 Question
  85. zdc 80 single idle rpm
  86. Help! Need info on Zenoah G-23
  87. Gas Engine-Throttle Connection?
  88. What size brass tubing for smoke tank?
  89. Best Prop for heavy load Using G45
  90. Want a gasser to replace Saito 180
  91. Are Hitec servos as good as JR
  92. Byron Purr Power Mount for G 62
  93. Help: Newbie with G62 !!!!
  94. Anyone using the Airwild props
  95. A conundrum of an enigma of a puzzle...
  96. YS 91 gaskets/pumper
  97. BME 50 or Brison 3.2 Which One?
  98. New Zenoah GT-80 with crooked prop shaft
  99. smoke oil
  100. New engine
  101. 3W-100ib2
  102. Engines with Cannister Mufflers
  103. sachs engine question
  104. Zenoah G 26 Walbro Carb Problem
  105. Oil fouls gas ?
  106. Help! Zdz80
  107. Talon Chainsaws??
  108. 3W 75 question
  109. Anyone have any experience with the 3W carbon props?
  110. C.H. Ignition
  111. WALBRO CARBS, need one
  112. Slim muffler G- 62
  113. BME50 or Fuji BT-50SB 46.5cc Gas w/Butterfly Carburetor
  114. Gas Twin For Meister Corsair?
  115. Zenoah G 26 Performance Problem
  116. Sachs 4.2 Engine
  117. G-62/Davis Diesel Muffler?
  118. G-62 with reduction drive.....HELP
  119. Air hobbies 11.6
  120. RCS 140 Carb Orientation problem!
  121. Electric Start
  122. Smoke on a twin cylinder
  123. G38 Old vs. New?
  124. Oill For DA-50R
  125. Plug color
  126. ZDZ-80 Rocks, hard to start
  127. 3W 75, 85 B2, or BME 102/105 for the H9 Sukhoi??
  128. Gas Engine and prop for 1/3 scale Pup?
  129. Differences between gas and nitro
  130. Ofna 9.5 Pro Engine?
  131. gas/glow conversion table
  132. Rcs 140??
  133. Zdz 80
  134. Da-50
  135. DA50 and vibration questions
  136. Help with kill switch options
  137. G-23 broken prop stud/shaft
  138. Oil Mix for G38 & ZDZ 40
  139. glow vs gas power equivalency table
  140. Fuji Gas Engine?
  141. 3W-100 engine trouble.. please look
  142. Kalt G22 Parts Needed
  143. PCM on gas engines
  144. 3W Carbon fiber 31.5x8x14
  145. Where to run gas vent line overboard?
  146. Question about Brisson 3.2 RPM
  147. Gas Engine Question
  148. old gas engines
  149. Need advice for first smoke system
  150. Bme 105
  151. gas engine for 31% CA Extra
  152. Timing on A 3W??
  153. G38
  154. 33 homey. attaching prop
  155. Desert Aircraft customer service
  156. First Place 1.3 and Dynaflite PT 19
  157. RCS 180 rattling noise
  158. What model for a 3W-35??
  159. Engine response time w.r.t different types & fuel
  160. Getting an MVVS 1.60 gas, what muffler to get?
  161. RCS 180 not drawing fuel
  162. HELP!!! Looking for 1" ID Flex Exhaust Pipe
  163. Quietest 40cc????
  164. 3W 75 throttle arm
  165. Cylinder head and muffler
  166. Engine selection for Midwest Super Stinker
  167. ZDZ 80 single, Bisson pitts muffler. Best prop combo?
  168. Converting a Glow tank in a Gas tank
  169. 3W 75 side carb
  170. Prop Size for Fox 2.4
  171. Amsoil 50:1 and 100:1 Temp diff in BME 102?
  172. DPM Extra 300L- which gas engine best
  173. Os 91 Fx
  174. BT-86 twin gasser
  175. adjusting gas engines
  176. Zdz 40 Re On A Extra 300s Patty Waggstaff?
  177. My G-23 hesitates during turns?
  178. When to switch to synthetic on g62
  179. G 45 Should I put it on Ign. HELP
  180. whats best engine for 1.20 size Funtana
  181. G62 Alky to gas question
  182. Quick gas engine question.
  183. Quadra Q100ss
  184. Small Gas Engines
  185. FPE 2.4 has Black stuff and oil in exhaust
  186. G62 weight savings
  187. ZDZ or 3W?
  188. Spinner for DA50
  189. ZDZ 40 mounting method
  190. Showtime Smoke pump
  191. Menz Ultra 22x12 on a G62?
  192. How much gas does a G62 or 3W 75 use per minute???
  193. No matter how hard I try.......
  194. Brison 2.4 Muffler Needed
  195. U.S. 41 Not Running Right
  196. 3W 75 Idle?
  197. Idle adjustment on 50 cc engine
  198. QS 150 3 blade prop size
  199. correct prop size for a Sachs 4.2 ????
  200. new engine
  201. Magneto ignitions and static fields causing radio interference?
  202. Lawn Boy Ashless
  203. Engine selection
  204. BME 50 running hot.
  205. Walbro Carb Choke Spring?
  206. SE5a, Saito 45 fuel tank height
  207. Msc 25x10 & Zdz80????
  208. Menz Vs. 3w Props
  209. zenoah vs. U.S vs. Fuji vs. other gassers
  210. 3w 70 Single On A Pipe
  211. RCS 1.40 will only run at half throttle. - IT WORKS!!
  212. New engine
  213. G26 vs. RCS 1.40?
  214. ZDZ 80 single
  215. Bme 44
  216. Quadra 52 and oil question
  217. Learn From The Expert: Mr. Clarence Lee
  218. Engine quiting on down lines
  219. G-38 increase power
  220. Need header length for KS can on ZDZ40
  221. 3w 60
  222. 3W 212 4 Cylinder
  223. Spark plug wire
  224. Should I get a DA-50 or a ZDZ 60?
  225. Need opinions on BEST 70-80cc gas engine
  226. Throttle hookup 3W 106 question
  227. soft mount -62 gas
  228. Comments on Engine/Muffler Installation
  229. best gas engine for balsa usa 1/3 super cub?
  230. F.p.e 3.2
  231. 3w 106 Vs 3w 106 QS
  232. web site for kavan elect. gas pump???
  233. Menz and Menz ultra?
  234. G26 Advice
  235. cylinder repair
  236. Spacer on engine to put prop/spinner further forward.
  237. G-38 starting problem
  238. Webra Bully 35cc
  239. Help me decide MVVS 26cc or 35cc vs RCS 140 or 180
  240. broken bolt in prop hub 3w-140
  241. Newbie Question - Tank Placement For Gas Engine?
  242. plugs???
  243. 3W 2 into 1 cannister exhaust
  244. US Engines 41
  245. Zenoah G2D & Walbro 167 Tuning??
  246. Echo 2 stroke oil for break-in
  247. Smoke Fuel Tank?
  248. ZDZ 40 Crank Snapped
  249. Alcohol in fuel
