View Full Version : Gas Engines
- Ignition question?
- ZDZ plug cap
- xyz or unitedhobbies engine 26cc (FTL)
- gas engine reversal - is it possible ?
- Any idea which engine this is?
- 100cc plug distance, Getting it closer
- WHAT IS THE BEST GAS ENGINE?
- crrc 26 help needed
- nx props, any good and where to get at ?
- Something bigger than a fiddy
- US 41 Engine Question
- DL50 in a TFGS Mustang
- Battery help!
- MOVED: BT-50SB Flywheel Scrape
- BT-50SB Flywheel Scrape
- THRUST SPECS..HELP
- Brillelli 46gt more silent exhaust/muffler?
- DL 50? good? bad?
- Is this a Quadra 75?
- What type of engine is this? Someone said it might be an Zenoah G-26?
- Help me ! What spinner dimension is recomanded for BT-24 Fuji Imvac ?
- Brison 2.4
- 3W106 at wide open throttle stopped instantly
- crrc 45 flew the coop
- Brillelli Motors ????
- MLD-28 gasoline engine
- RCexl Ignitions on BME50
- gas tank pluming
- Walbro carb, how to make it behave?
- Evolution 40 GX vs 35 GT
- Homelite engine mystery with pictures
- Benifits of gas over nitro
- 3 1/2 precut spinner
- SD Yak 54 33% which engine without
- What's the best prop, Menz or 3W??
- DA or 3W
- US 41 Foaming
- Zenoah G38 on Giant Big Stick?
- BME 115 fixes
- help me !! DL 50 rpm are not here !!!!! ? why ?
- Engine chart
- SPE-28cc, Is it true?
- Zenoah G-62 Starting Coil
- Zenoah G-26 Carb
- autogyro plans
- BME 50 Carb
- BME 102
- Problem with BME 110?
- MALONEY-100
- Happy Father's Day
- Fuji 46.5 interference
- Good sport aircraft for a Brillelli 36GT needed
- electric props and gas props
- MOVED: Saito 80
- Zenoah G-26 Mixture Adjustment
- Zenoah 23
- saito 220 reduction prop?
- MT 57 engine Header offer
- How to remove a G45 crankshaft????
- Which motor for my for my Hanger 9 Yak 54
- Help EVO 45GT!
- Zenoah G20 prop and rpm numbers?
- Moki radial 250
- What size battery for G-26 ignition?
- How many RPM,S for a Brison 3.2?
- Pennzoil air cooled, what percentage?
- JC Engines AREA 51, AeroWorks 29% Katana S
- ZDZ 80 RV-J eng template on Comp ARF extra 330L 2.3m
- Gas engine equivalent to OS 160 2 stroke?
- Zenoah G20EI and Rubber Mounts
- Share some info of MT-57CN
- ccrc 45 pro
- Name that noise!
- RayAracing head button reconditioning service?
- Is there any power to be gained?
- BLACK SLABBER
- HELP WITH J TEC PITTS
- Smallest Gasoline engine available??
- 50cc engine "missing" at low RPM, HELP!
- OIL GAS RATIO
- Brillelli 46GT Tank size
- Electronic Glitch - 45cc RCGF range issues
- ZDZ 80 OR BME 102 BETTER?
- DL 50 Muffler is JUNK!!!
- DL 50cc Muffler is JUNK!!!
- Brillelli 46GT oil recomendations
- 3.2 Twin fuel problems
- what settings for SPE26, please
- MOVED: cox chainsaw
- Dubro prop balancer
- where can i get this water jacket for g62pu?
- G 230 RC
- Fuji BT-24EI Kill Switch
- Engine Advice for my 30% SD/TOC Extra 260 87"
- 3W advice
- old fuel, worst idelinG?
- Cleaning up and restarting old engine
- OPS 60 Twin Maxi: what is modern equivalent?
- ZDZ 50 NG
- G20ei won't start....
- G-38 Carb Screw Size
- Need to quiet down my DL 50
- xyz26 engine
- Zenoah G38 for 1/4 Super Cub
- DA-85 with MTW-90 Canister use a Throttle Curve??
- Ethanol-free gas?
- SPE 26 Bent crankshaft
- Do I need a reed block
- Sachs A&M ignition timing
- GrPro engine support
- Aera 51cc Recall
- G62 What RPM With Zinger 22-10
- Does this look right for a CHRCEXL ignition on a Fuji BT50EI?
- How do I tell if I have a MkI or MkII????
- MTW Muffler system
- Would the pick up magnet (hall sensor) decay?
- Best DA 50 in cowl muff?
- Carb Spring: Use it or lose it?
- moki distributor
- MOVED: Sticky piston ring on Super Tigre
- A&M Sachs prop size recommendations
- zdz 80 rv rpm in yak54
- Engine test stand pictures
- prop thrust testing
- Evolution 58 GX-2 crankshaft end play?
- spe 26 tunepipe ??
- Re-engine Byron reduction drive - help req'd
- Zenoah G26 trouble
- Muffler
- MOVED: Fuji 24 ei RFI
- Fuji 24 ei RFI
- Zama carb problem
- Zenoah G26 EFI
- KS MTW for less noise
- 3w-55i or 3w-56
- SV 100cc twin engine
- Menzs 27x10 SPLIT while in flight......
- exhaust
- Zenoah G26 questions.
- MOVED: Homelite 25 cc
- Brillelli
- 3W Ignition Module Voltage
- Moki Radial Synthetics?
- 3W 100 hard starting.....any tips/advice...
- Zenoah G26 EFI operation ??
- Does 2-stroke oil get old
- Question on carburetor regulator plate venting
- Scratchs on cynlinder wall of DL50?
- prop size
- engine trouble
- Best pitts for DA-50
- Engine for my new plane
- DL50 magnet and sensor position
- Curious to know what the resistance is on an RCJGY?
- DA-100 and TBM Silent Beauty mufflers
- RCU marketplace crook!! Help!!!
- Anyone using Area51 motor??
- Idle Problems
- Trying to decide on engine
- ? about DL-50
- JMB T70 Cans
- Concerning TORQUEMASTER reduction unit.
- Great Planes kill switch
- MOVED: HELP PLEASE____1989 46SF-S ABC
- Walbro carburetor parts where?
- Pre-cut aluminum spinners
- Reading piston tops.
- BME parts and service
- How do U cool your inverted 50cc?
- Help with fuel filter
- Zenoah G38 and G62 same problem
- Brillelli Engines No Response
- MOVED: Redmax engine
- Fuji 50 prop bolt question
- Gas fuel stopper question
- Da 50 Prop Question
- Zenoah 26 Electric Ign Batteries??
- BT-86
- BME 115 - Reed travel / clearance
- Saito FG-36 Gasser
- HOW CAN I UPGRADE MY FUJI 32B?
- R870 radial, who's using it?
- 3w 140 engine problem
- Evolution 45 GX vs. 45 GX2
- wich engine to a cap 232 27% alitalia
- My G-45 wants a home
- CRRC 45
- Carb / Firewall Spacing (DA50)
- Search came up with nothing, US Engines gone?
- Airframe for RCS-180
- New DA85 vs DA100
- G20 with which plane?
- Evolution 35 gas carb adjustment
- BME 3.5
- gas tank setup
- Did I get a deal?
- SPE 26CC poping?
- DZY 48 Twin problems.
- Evolution 26 and 35cc carb linkage
- mvvs a123 batery problems
- Da 50 S.O.S.
- Quiet muffler needed G-38
- How long exhaust for a MVVS 45cc
- MOVED: old model t maxx dies after fuel tank is less then half
- I need help tunning. what temp should i be at.
- Brillelli 46 issue
- G-62 carb block
- Ultra Stick 1.2 Lite Zenoah 26 help
- Mounting DA-100 mufflers backwards
- where to buy g62pu crankshaft?
- MUFFLER EXHAUST OUTLET MODS
- Which engine to purchase for 35% aircraft
- Zen G26 Carb Adjustments - Help
- DL 100 - New Twin on the Block!!
- cutting out when throttled up quickly
- Burbles During Inverted Flight
- Ignition question
- G38 CF Prop
- Stopping glitches mod...and spark advance question
- Spark Plugs for PeakModel 26cc
- Tartan twin (77G0
- Test stands for break in (not good)
- G20 ei won't start anymore
- Radio Interference
- Brass clunk in gas fuel.
- Fuji-Imvac 50EIS low rpm's?
- A little help for this gas newbie
- Fuel filter for DA-85
- 3w ignition swap to pirate
- looking for CF 3B 22 X 10 PROPS for 3w 60
- Quadra 40 Decibel level?
- G26 Throttle Plate removal
- Zenoah G23 Capabilities
- Byron Purr Power Muffler System
- NO LIMITZ SPINNERS
- Coleman fuel
- G-38 Carb Replacement
- domler sachs enigne
- Question about DA 50 ing.
- After market ign on G-62
- Alternator / Generator on a 50cc Gas engine.
- parts diagram for Quadra 100M (magneto)
- 3MM TOC53 engine
- 1" ID Silicone Tubing
- Missing at full throttle
- Ralph Cunningham converted G-26 Problem
- Help pulling Brillelli 26 apart
- Any good 26cc engines
- Zenoah G-62
- Small hole in the carb's choke plate.
