PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 [42] 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. How is your generic chinese engine so far ?
  2. plug reading on DL
  3. DA-85 Question or TWo...
  4. Rotary valve engines
  5. how do i move the timing on a gasser?
  6. Cermark 26cc Gas Engine anyone?
  7. Another Glowing Recommendation for Brillelli!!!
  8. Static Thrust of ZDZ 100cc B2NG Engine
  9. 3W80Xi OR ZDZ80RV-J
  10. single cell lipo for ignition
  11. Lightweight engine for 90inch 30% Carden?
  12. Zen G26EI Sensor Assembly - Question
  13. Identification of R/C gas motor.
  14. Back to Amsoil?
  15. Fuelers and Kill Switches.
  16. Carb Kit - Where do the screens go?
  17. Large Prop Balancing
  18. Should I replace them or not ??
  19. Why change what is fine ?
  20. FUJI BT-34B?
  21. 3W 100 Running Issues
  22. RCGF 100cc Petrol Engine
  23. Ignition Module Replacement
  24. Humble Homelite 25cc Needs Help
  25. Missing engine standoffs for a DA-50:help
  26. DA needle settings
  27. DA-100 Owners help please?
  28. Tatan Twin
  29. 3W 80 will not throttle up.
  30. G-38 carb. mounting hole?I noticed
  31. NYLON MOUNT & EVO 35GT
  32. Thoughts about all the new engines and their prices?
  33. shell advance 2/c oil.....your thoughts
  34. 50cc = 29 lbs thrust- Flight video added
  35. 50cc 4-stroke
  36. Gas Engines
  37. Need help with a Tartan Twin
  38. Do most ignition systems work the same?
  39. which is best? 4.8v or 6v ?
  40. DA85 or ZDZ super 80
  41. Zenoah G20ei
  42. g38 airframe suggestion
  43. SMOKE MUFFLER CONVERSION HELP
  44. magnum 91 rfs gas
  45. DL question
  46. MOVED: Question - YS 140 Sport or RCV 120 for CMP F4U Corsair?
  47. BT50SA/B/EI differences
  48. Switching from 100LL to 93 octane gas
  49. The best 50cc class import engine ???
  50. Quadra questions
  51. GAS MOTOR FOR HANGER9 taylor craft
  52. MVVS ICU-S ignition V 2.0
  53. Walbro Carb
  54. DIY Ignition System - Most simple
  55. Jamara V Desert aircraft
  56. Saito Gasser Airframes
  57. FTL 45 CC ENGINE SPARE PARTS IN UK?
  58. FPE1.3 21cc
  59. 3w-85xi iddle help
  60. Small gas engine question
  61. xy 50 cc
  62. Engine Templates
  63. fuji 43 prop
  64. FTL45 distance to front of prop shaft.
  65. Quadra 50/52 muffler needed
  66. ZDZ 100R2 (anyone have one in use?)
  67. Zenoah G26 in H9 1/4 Cub
  68. WHAT MODEL TILLOTSON???
  69. RCS 150 radial indo
  70. Exhause coupler for Evolution 26
  71. Another CH question.
  72. Gas Engines?
  73. Fast idle on DA100
  74. Sachs inline twins
  75. MOKI 1.80 Gasser and FSI-03 ignition
  76. Roto 35Vi engine
  77. Help me find appropriate mounting bolts for zdz80 plz...
  78. Quadra 35 gas to oil ratio
  79. Securing cannisters?
  80. Nwe to gas--help!
  81. New Engine Break In
  82. DA100 performance
  83. G-23 fuel consumption?
  84. contact with ch-ignitions ?
  85. Gas to Alcohol conversions ?REVERSIBLE?
  86. Help me identify this boat engine?
  87. QQ 86" Yak - Need reasonably priced 50cc Gasser!
  88. Fuji gasoline kill switch
  89. 5/8" Flex pipe for gas engine
  90. Fouled Plug ?
  91. DA 50 Factory Settings
  92. BME 50 owners advice needed
  93. 1.10 size gas engine?
  94. Need engine mounting template, Where to get??
  95. ZDZ 100NG Carb
  96. Fuji BT-24A?
  97. h9 Extra 260 with 3W 85Xi.
  98. MT50cc ?
  99. Engine identification needed?
  100. MVVS-45 crankshaft design change
  101. Carb stack? on a Zenoah, is it beneficial?
  102. Tartan ST77 twin engine
  103. Fuel Fill Setup - Advice
  104. Advice? Best engine for EF 88" Yak/Extra
  105. Motor mount problems
  106. Ethanol in gasoline
  107. Slimline Boxxer pump for gas?
  108. Smaller prop for G62
  109. GT-80 Mounting Question
  110. engine side and down thrust
  111. 42 Percent Products Opti-Kill opinions??
  112. 80cc gasser
  113. da 150 timing
  114. Whats the bottom line on 3&4 blades ?
  115. Timing on small gassers
  116. MT 62cc clone any reports
  117. Side by side Photo's..DA & DL....
  118. DA-100 starting
  119. Inline Fuel Filter Options...
  120. Fuel Tubing/Spark Plugs for DA100 ???'s..
  121. Received WT-201-1 Gasket kit - confused
  122. 3W vs DA 150 class
  123. Found a Good Source for NGK BPMR6F Plug
  124. Zen G26ei Throttle Arm Removal - Help
  125. DA 100 operating temp?
  126. CMPRo gile 202 best gas engine to use
  127. 2.4 FOX-Muffler
  128. MOVED: how to build a muffler
  129. MOVED: Short spinner bolt on Fuji 43cc EI
  130. CH Ignition on a123?? for TKG
  131. Zenoah G-62 90 degree intake...
  132. G26ei Mounting - Is backplate needed ?
  133. Water cooled weed wackers?
  134. DA 100 Issues
  135. Short spinner bolt on Fuji 43cc EI
  136. New SV100cc Twin From United Hobbies
  137. Gas Engine mounting
  138. DL50 Prop Hub--please help
  139. Koit 45cc
  140. BME Service - Disgusting
  141. brison 5.8 engine
  142. Need heavy prop and spinner!
  143. Tank size for Brillelli 36GT
  144. Fuel tank for a 4.2
  145. what prop for g62
  146. MVVS 45 Bearings
  147. 45cc engine.
  148. Where can I purchase a Walbro Carburetor?
  149. Kill Switch - Servo and Manual Operation
  150. G38 on a Tuned Pipe
  151. Slimline DA50 Inverted Pitts Question
  152. Gas Tank Setup for G-62
  153. DA50 and RCEXL Ignition
  154. MOVED: OS 1.60 gas conversion
  155. Inverted pitts for DA50
  156. thanks DA
  157. Thanks B&B!
  158. MOVED: Losing The Experts and Their Knowledge
  159. greater carbon buildup in inverted setups?
  160. general
  161. G-38 carburetor assy.help
  162. ZDZ 50NG Questions
  163. MOVED: MOKI 2.10 Operators Manual
  164. g26 in 72"cap work
  165. is this mount ok?
  166. RCS-140 Idle adjustment help needed
  167. Brillelli crankshaft extension
  168. Ultimate engine test stand
  169. Clunk / filter question
  170. DA 85
  171. Brison Carb question?
  172. EVO 26GT2 , Changed ignition - Reduced performance
  173. KS1060 VS MTW Cans
  174. Engine?
  175. Zenoah G26ei Exhaust
  176. Spring Starters for Zenoah Engines
  177. MOVED: Weed wacker motors?
  178. Jenn Feng Plugs
  179. Homelite engines.
  180. Da 50 starting
  181. changing oil ratios?
  182. where to buy carbs
  183. MOVED: Good Electronic Ignition conversion for Gas
  184. ZDZ Super 160..Who's runnin' em
  185. How good CCRC 45
  186. brillelli 46gt exhaust upgrade
  187. Dusting off unused engine
  188. MOVED: 25 cc homelite
  189. Radial,who makes one for a 50# plane
  190. g-23 carb problems
  191. ZDZ80 RV (silver head) ignition help plz...
  192. 3w 70i
  193. most popular engine
  194. 3.7v li-po for zenoah.?
  195. oops wrong thread.......
  196. somebody fill me in on "bme"?
  197. G-38 and G-26 oil ratio
  198. Hitec 5965 and a gas engine?
  199. Walbro screen filter ?
  200. H9 P-51 60 size, want to go gas, suggestions??
  201. Tuned pipe options for DA 50
  202. G26ei or G26 magneto
  203. Fuji BT64A Magneto Problem
  204. Gas motor starters - 40 - 50 cc
  205. New to gas q's
  206. Fuji gassers
  207. tygon ok for inside of tank??
  208. fuel tubing?
  209. Getting service for your BME.
  210. sv 50cc gas engine
  211. fuji magneto 24cc and 64cc crankshaft
  212. G-38 Prop size
  213. Stuart Mackay gas engine
  214. revolution 100
  215. Nubee needs help with gas engine comparision
  216. HH50S gas engine question
  217. DA 50R Flame out
  218. Walbro WT-644 carb question?
  219. Help with Smartech Traveller
  220. Sachs gas engine
  221. Advise on twin engine please.
  222. Anyone wear out an engine using particular oil at recommended oil ratio?
  223. gas twins
  224. Evolution 26GT2...Good bye you JUNK.
  225. Any reason RC people use different oil than lawncare people?
  226. ZENOAH SPARK PLUG BOOT
  227. specs look OK
  228. Need quart size gasoline container
  229. Throttle SET UP FOR 9 CAP
  230. SPE 26cc prop size in CMP Giles 202 140
  231. ANYONE HAD AN XYZ 50CC? LOOKING FOR MY FIRST GAS ENGINE
  232. what cannister for brillelli 366gt, 60cc
  233. Evo 80 Pitts Muffler
  234. Slimline fueler?
  235. Anyone have parts for a old g38??
  236. G-38 Full throttle ?
  237. how makes the largest gas engines?
  238. G23 conversion. Possible?
  239. Canister for 3MM TOC 53??
  240. Pefa L canisters for 3W157???
  241. Zenoah G-38 Graupner prop bushing
  242. united hobbies 50 cc
  243. Throttle and Choke Setup On a MVVS 160
  244. Saito FG-36
  245. 2.4 , BME vs First Place Engines?
  246. fpe 130
  247. Thor cdi wiring
  248. pitts muffler for G26, is it worth it?
  249. connecting fuel tank
  250. Is there a quite DA-85
