View Full Version : Gas Engines
- MVVS IGNITION
- odd G-26 problem
- G26 Surging at high RPM
- 100 cc plus engines?
- Help, no response from other forums on Cirrus servos
- Need Help With break-in/ Tunning of BT-43IE
- Felt clunks
- Need suggestion on muffer for MVVS58
- DA 50
- Where to buy a Honda GX35
- Honda GX25 exhaust question
- Spinner for ~60cc
- Three props and a Brison..
- 3W85xi First Look
- what prop to use
- all prop screw broken in my ZDZ 100(what can I do)
- 3W engined C-ARF P 51 Mustang
- Teflon tape/prop bushing?
- Spark plug color?
- Quadra 65 silencer/muffler
- Evolution 58 Problems - Part 2
- g62 throttle arm
- ZENOAH 23 COIL NEEDED
- DA50 and tuned pipe throttle linearity
- 50SB Surrender
- g-62 mods to lighten engine
- Gas Engine for the QuiQue 73" Yak
- Puzzled by my Evo 26, need advice!
- g62 starting problems
- My first twin.....DA 100
- BME 50 Overheating?????????
- Best fuel line and tank stoppers
- Eliminating glitches
- Throttle Servo HELP!! Weird problem
- What motor is this
- ZDZ 210 & T-80 Tuned silencer help?
- Prop Guru's!!...Need Help??
- engine will not start hot
- spark plug cap placement
- 3w 150 mounting template
- knox hobbies
- 4.2
- DA 50 warning
- peak 26, help
- G-62 Choke doesn't choke enough.
- G62 CARB REBUILD
- No power for hovering in my ZDZ 100 ??
- New Zenoah G260 PU- EI
- DA 50 bog at high G's
- Weight of DA50
- Gas Engine
- How hot is too hot?
- Unknown Engine
- Fuji 50 muffler
- Ch Jump start for Zenoah 45cc
- bme 115 headers
- How long may I run a gasser inverted?
- Stihl HP oil.....your comments please.
- zenoah oil mix
- Walbro 610 carb
- Unable to access Pe's prop-power-calculator site.
- 3 blade prop 22x10 source?
- Fuji 32B with Broken Case
- Funtana100x on Gas?
- AvioMac engines
- Zenoah G20 Muffler and Senior Telemaster
- CF props for 20cc engines
- quaddra 100 conversion
- evolution 35GT carb problem
- KROMA 100I?
- Air Hobbies Sachs Dolmar 3.2
- Anyone know this engine ? (UK eBay site)
- 3W 80XI Carb query?????
- zenoah g38 problems
- G-62 starts but won't run
- G-38 question
- Muffler
- engine runs perfect on ground, horrible in air
- Easy start system fo ZG-62
- Low end adjustment on new Fuji 43EI
- Bambula or Xoar prop question?
- BT64EI settings
- What is this and what are the specs?
- Carb on BME 50 & Base Spacer Leaking Air
- *Top Flite Power Point 22X6X10 Prop*
- Smoke Oil Rate of Consumption
- Who makes this muffler?
- Fuji 64 electrical interference
- WHat size fuel line for a Brillelli 46?
- Walker 3.2 CI Qeustions.
- Positioning the prop
- G-38 sheering woodruff keys
- Brillelli 36GT is going to fit just fine
- G38 with Walbro KT6 Carb issue...
- Piston material
- 3W28i OS 140RX or Saito 180
- Muffler, firewall clearance
- Fuji 32
- Leaving the elec ignition switch on.....problems ??
- Magneto and Electronic Ignition.
- quiet props
- Header tank? ? ?
- header tank for gas????
- problems with brison 2.4?
- Adjusting throttle sensitivity.
- Cheap propellers?
- New 100cc twin?
- Revolution 52 Ignition Module Failures
- 3W 50i Full RPM Problem
- US ENGINE
- 3W70 engine problem
- DX7 help with ignition kill switch? No open servo slots
- 1st GAS power for GP Cap 232 27%
- Taurus TS-52 tuned pipe setup?
- spark plug to hot to touch ?
- 45cc questions - first time gas
- Prop for RCS 140?
- AMSOIL - HOW MUCH?
- G-20 with pipe
- CONVERTING TO GAS - SIZES OF GAS VS. NITRO
- How much fuel does a G62 use per minute??
- Gas engine Mount
- Choke really needed?
- *Brillelli 25 GT V2*
- 4.2 Brison
- Extracting the single bolt BM110 hub
- Zenoah Manufacturer Support
- Highpower steam engine and an car with C02-engine
- Noise readings
- unregulated 7.4 for ignition
- Evolution 26 GT VS Zenoah 20 CC for 90 4-cycle replacement
- Evolution 116CC starting
- Prop for max speed g-62 on a TF GS Mustang
- Walbro carb problem on BCMA 26
- US Engines 41
- D&B 3.7 Twin
- 3W 50i RPM problems
- DA 100 ,DA150 Engine mount size ?
- Best Prop for 3W 200 cc
- Gas fuel line replacement?
- Mounting Gas ENGINE
- CRRC Pro 26cc engine
- Moderately priced tach, which would you choose.
- Standard Performance Test For Gassers?
- SLimline Smoke muffler leaking at pre heater..again
- DA-50 Gasser newbie questions
- Found the answer myself
- Da100
- Help with Strange Walbro Carb Problem
- What is the best 100c gas engine?
- SPE 40 Broken Crankshaft?
- Props for gassers question.
- MOVED: Nitro Mix
- DA 50 trouble
- What is the difference between a WT 433 and a WT 811 carb.
- looking for pics..giant 4 stroke , red valve cover's
- How do i setup the gas tank on a 40cc spe gasser
- Help with engine selection
- Glow Resemblance of a Gas Engine
- 3w-50i missing at high speed
- 3MM Engine/Updated Weights Spreadsheet
- Problem with G-26 dying
- 3mmtoc53cc vs dl50
- Tell me about props.
- Engine Vibrations
- Glass Spinner?
- BCMA - Missing in Action??
- Fast idle at end of flight .. wisdom sought
- Piped G62 lite
- Gas Engine Idle Question
- yak 54 3d
- Quadra Q52 had eat the screw of the Throttle Plate I Need replacement
- Video CAP 231 Ex whit 3W80xi
- Troubleshooting BME 44 Problem
- Starter for G-62
- MOVED: Gas engine
- Muffler for Zenoah G45
- RCS 140 surges when the throttle is advanced to full.
- Zenoah G23 and G38
- Zenoah G26 & G38
- On Board Starter fot Big Gassers
- Hauling the mail!
- Quadra 35 startup and needle setting
- Evolution 35GT
- DA 50 Surges at full throttle
- DA 50 Running Problems
- great planes extra 330L fuji bt-86 balancing and prop size new to gas
- FPE 2.4 transition
- engine dies after popping crow
- Carbon Fiber cannisters
- How Do I Wire an Ignition Kill on a DA50?
- oil fuel (zenoah engine)
- Zenoah G26 throttling
- Buying a DA50
- any affordable new gas engines out there?
- Mac Minirelli
- Need advice.....DA header brazing question
- SPE 26 Help
- MOVED: new need help on glow engines for rc cars 1/8 scale
- DA 85, ZDZ super 80 , or 3W 80?
- Contact info for US Engines
- Da 50
- Current draw DA50 Ignition
- G-45 Wont Start
- Need a G-62 Cylinder Head
- Rubber mounts for gas engines - where can I buy them?
- Newbie needs recommendation please
- ignition timing
- any 3w-85's running out there?
- I think I'm in love with my ZDZ :)
- FPE 2.4 spark plug wire pulled out
- What are you using for a servo kill switch on a EI engine?
- please help for engine problems
- MOVED: EI for Ryobi 31 conversion
- 50cc engine light and low cost ?
- Giant Scale Fuel tank size?
- BME 50 gas/oil mixture
- Brisson 5.8 Ignition lead
- Spark Plug Reading
- Webra Bully 35 cc Gas engine parts.
- new F-1 Sundowner...1st gasser...right engine choice?
- GAS with magneto + FM PCM?
- Best wood prop (size & pitch) for a G26
- ZDZ-80 & 26x10 prop @ 6100rpms?
- Need Help on US Engines--35cc
- US-41 manual
- Questions on Fuji 50 SB
- Zenoah g-62
- Gas can/pump combo
- flyinrazorback....quick question BME 115/cannisters
- Overwhelmed New Gasser - Need Input
- Husky Challenger 2.7 smoke muffler?
- New BME 50cc Sport Model Engine
- Ooops
- Bearing part reference number for Brison 3.2
- Spark Plug question
- G38 woes...CH to the rescue
- Byron`s original Pitts Bipe
- What Is this Engine?
- G-45 knife-edge question
- 26GT2 Starting Problem
- please help for carb problems
- MOVED: Fuji BT-24 Marine engine
- CM6 sparkplug
- Homelite 25cc mystery
- Help on 27% Hangar9 Cap 232G
- BME 100 fires, won't start!
- Fuji BT-24 Marine engine
- Gas Engine Fuel Systems (Novice Questions)
