View Full Version : Gas Engines
- HOBBYKING 26cc PITTS MUFFLER
- glow to gas
- New to gas engine models
- DLE 20 with #4 ignition issues
- RCGF 20cc flat twin and hangar 9 Christen eagle
- Beaver with floats
- Need opinions on AGM gas engines
- Spark Plug color
- RCGF 60 twin won't start?
- Zenoah 45 Backplate Mount
- DLE 35 RA issues
- EMAS 111 Carburetor search
- Choke needed on gasser?
- DLE20RA a couple of questions.
- anderson spitfire
- Custom rcexl ingition hall sensor?
- mt 57 rc engine 57 cc
- Mufflers, DLE111 DA 100
- 366gt brillelli prop bolt
- DLE20RA Prop Choice
- DLE-30 Ignition prolems
- DA100 Props
- 60cc gas tuning NEED HELP!
- dle 20 ra
- Gas engine for Top Flight P-51 9lbs
- 5.8 Precision Eagle motor
- Saito fg 17
- Before I make a mistake
- EME 60 top rpm
- is their a difference in DLE single ignition modules?
- info on 30cc cobra gas engine
- zdz 120 piston rings
- Can a DLE 20 be converted to 20 ra?
- older G38 with no choke
- 50cc headers
- Sad News About Bill Jensen
- About this site (www.kairomame.com)
- Bowman's rings
- ZDZ 80b2 inline help
- Older G38 with newer carb WT-338?
- what gas to use and what are you doing to fasten mufflers
- Ignition module hook-up
- How to get prop hub off the dle35 RA
- 2 stroke oil
- Hard starting DLE 30 cc
- Help identifying ignition
- Mt 57
- Roto Flow Gas Tanks how to empty...
- rookie horsepower question for plane
- Parts for BME?
- Mintor 110
- Ethanol gas issue--but backwards?
- Can't get prop hub off DLE55
- Lean or rich? Video
- H9 Ultra stick 30CC design and component questions.
- Walbro Velocity Stack Source
- WT645 throttle side paly
- NGH 35cc Help please - timing
- Dle 30 or 35
- Need help identifying
- DELE 55 carb
- FG 33R cam gear timing adjustment
- Chinese made Brisons?
- G38 on Backplate Will Not Loosen
- Evolution 15cc
- dle 85
- 3W 85 Twin Cylinder With Unusual Problem.
- Sachs dolmar
- OS GGT10 opinions
- Dle 20 ra
- Tartan Twin 77 gas
- Another RCGF 10CC
- New RCGF 35cc Rear exhaust
- First gas engine
- MOKI 50VT Engine Mount
- Plug Gap for 45cc
- Turnigy 26HP-S 26cc Gas Engine
- H9 Ultra Stick 30cc: Engine selection?
- Help Identifing a converted engine
- Don harris on board charger. This thing is so cool
- Want to convert a Zen G26EI back to mag. ignition.
- Zenoah G-62...Need help replacing Fuel Nipple on Carb?
- rcgf reed valve replacement
- Byrodrive help
- Desert Aircraft
- Info needed on Evolution 10cc Gasser.
- EME 35cc looking for info
- 90 degree carb extension, possible or not?
- New dle 35ra ,,,compression seems lo?????? Best / easy / wat 2 start ????
- DLE 20 choke lever location
- Best WW2-fighter sound from a DLE55?
- Zenoah G45 Carburetor Throttle Pushrod Linkage
- 14mm to 10mm plug conversion
- Evolution Gas Engine - 33cc ( New Gas Engine User )
- My first gas engine DLE 20
- Zenoah G62 Carb Insolator
- twin cylinder exhaust design
- RCGF 26bm on a Funtana 100x good match?
- Please help me identify this engine (make and displacement)
- ROLLING Chicken Stick
- Copyright announcement of algorithm on mini CDI
- Saito 21fg inverted?
- Biela 18x10 Focke Wulf 3 blade scale prop
- Engine make and size
- Byron Glasair/DLE 30
- Brand New DA 60 problems
- DLE 35RA with straight pipe?
- Dle 30
- Any info on the GP 123 gas engines
- Is Da 50 and DLE 55 mufflers interchangeable
- Dle222 fuel tank size
- TorqPro 70 4-Stroke Gas Engine
- Timing question
- DLE 55 Engine Noise
- os120fs vs dle20
- Throttel linkage G38
- Gas vs electric engine mount template?
- Zenoah Twin 2850 ?
- O/S gas glow plug
- Replacement ignition module for BME 44
- DLE 111 crankshaft woodruff key size
- What Engine
- Need help with engine ID
- early XYZ 50cc. I need a carb adapter plate.
- DLE Engine Mods
- DLE111 crankshaft-propshaft threads?
- Prop drive hub for a v1 DLE-111
- Broken cast!!
- whats the biggest prop for a g-62 in a 1/3 scale champ?
- G 38 convertion to Electronic start
- Prop size and Engine Tunning
- thoughts on a mld 70 in a 1/3 champ?
- Gas/fuel requirments
- What pipe for DLE 35RA
- New walbro ethanol proof diaphragms!!??
- Help identifying this motor
- 15GX 15cc Gas Engine with Pumped Carb Opinions ?
- Iebc single battery system
- Brison 52 leaking fuel from velocity stack
- Yippee, got an early Christmas present. Is gt 15
- Quadra 75
- Carb for G-26
- Zenoah g62 operating advice.
- FG030B Saito
- Power box spark switch
- Remote kill switch for magneto engines - options
- Quadra 52
- Fast prop for DLE 170
- Optical Kill Switch for Twin engines
- 3 blade prop in place of 26X10
- DA 50 Leaks Raw Gas Out of Mufflers Sitting.
- Servo Chatter?
- Question about batteries and switches?
- Taurus ts 52 engines parts and repair
- 5CC gas engine, close to a practical gas engine infinitely...
- compression
- OS--DLE or evolution? which one.
- Aerostar Props
- Lubrication question for Saito FG30B gas 4 stroke engine
- BME 102 Ignition, maker?
- Quadra 35 ignition coil--No spark
- Rcgf engines
- Is Evolution engines about to go out of business?
- Remote Kill for Magneto Engines...
- That funny noise??
- Will the Saito,
- DA 70 question
- Saito FG30B Prop Nut help
- Electronic control x 2 dle 55ra
- Electric starter capability
- DA 100 inlinetwin
- Spark plug question: One Elec Ignition gives one spark ... another EI gives a burst
- Mid range burble
- Electric starter for 50cc Engines
- First Place Engines, FPE Looking For Quality Feedback
- Where is JAG ENGINES
- piper j3 cub
- Walbro in Carby gauze filters
- Problem starting Revolution R50 gas engine
- help
- Zenoah G-45 Toni Clark ?
- Saito FG30B - need flexible exhaust
- Need Ideals to prevent over heating on narrow cowl war Bird
- Engine will not run with over flow fuel line plugged
- G26 prop for WW1 Plane
- Anyone know about this RC motor company?
- DLE 35 missing with any input from the radio
- Fokker D21 powered by Saito FG60R3 engine
- Zenoah G62 Quality engine mount from who?
- Saito FG84 and Tachometer Telemetry question
- flooding
- dle 20 ra high rpm issues
- Anti vibration mounts. - DLE 35
- BME 105 carb adjustment cowl off and cowl on
- Rocker oil starvation (Saito FG84R3)
- Zenoah G45 plane?
- DLE props?
- Saito FG engines "coughs" ?
- surging engine
- Two Stroke Gas Life?
- Need Help looking for Tillotson Carb Kit
- DLE 20RA missing stock throttle arm?
- Airhobbies 3.0 Twin, ignition question
- ASP FS400AR gas conversion help carburetor running rich
- Starter mounting instructions for DLE 35RA
- OS GGT15 Inverted Mount
- Muffler design
- DLE 35ra timing 46??
- Dle 50 rpm
- Motor mount for DLE20 RA
- Is 40:1 GAS/OIL Mix good for both DLE 55RA & 35RA
- Tank Placement on DLE 20
- *ROTO 50CC Twin*
- BME 105 and spinner compatability
- Breaking in a Saito FG30B
- Crrc pro help!
- idle on dle20
- RCCR26 bearing replacement
- DLE 30 rod big end bearings?
- sig kadet senior kit
- Saito FG-40 problem(s)
- Pennzoil air cooled not available, what is the Pennzoil equivalent?
- Where to buy 3w engines
- 3w-150 Has not ben run in a couple years
- Setting for metering lever WJ57 carb required.
- Saito FG-36 Carb Rebuild KIt
- Timing of the gas model engine single and twin.
- chinese engines
- How to install kill switch on G38?
- Saito FG21 or Saito FG30B for H9 1/4 J-3 cub??
- Parts help
- Avistar 30 cc
- rainbow 2000 gas engine
- Help identifying Walbro carburetor number
- Zdz90 rv-j ignition timing
- Saito FG30 Break in
- Walbro rebuilding kit, where is the best place to get one?
- Using The OS GG5 Plug on an RCGF 15
- Super morton m5 engine manufacturer vernal engineering up and running!
- Frustrated with two DLE 111s
- What rc plane gas engine is this????
- 15 cc gas
- 10 cc gas engine
- Zenoah G38 Repair
- RPM too low?
- old never used Walbro need service?
- 2 inch (50mm) dia rubber (not plastic) insert for an rc starter.
- Tuning Problem
- Spark plug failure
