PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 [91] 92 93 94 95 96 97 98 99
  1. HP and BHP?
  2. zdz and AvGas?
  3. servos
  4. What's the crank diameter on a G26 ?
  5. ZDZ 40 Sport?
  6. Glow Alky Outboard- Good News, Bad News
  7. What RPM on 3W70i
  8. Ignition data
  9. ZDZ40 and Oil
  10. How long before a rebuild on a gasser?
  11. Goldberg Ultimate/ RCS 140???????
  12. Ziroli b-25 engine help wanted
  13. what muffler is this???
  14. zdz80 order
  15. Need muffer screws for OS 1.60
  16. Electronic Ignition Interference issues (worries)... Help!
  17. 3W Ignition (Need help identifying the wires)
  18. Lawn-boy oil.... Is this the right one?
  19. Engine carb. filters
  20. Hyde soft mounts
  21. What are you doing?
  22. Good props- zdz60
  23. Amazing new engines!
  24. Prop and Engine For H9 Edge 540
  25. 3-blade prop for 3W????
  26. Byron 2 blade prop hub
  27. Bme
  28. MDS 148-miserable midrange
  29. HP rating on ZDZ 60
  30. st3000 twin 60cc
  31. G26 Hairline Crack in Phenolic Block
  32. Prop for ZDZ80
  33. ZDZ80 prop drill jig
  34. Used D&B 3.7
  35. What size gas engine on WM G.S. P-51 (Zenoah or Fuji)...I know you guys will know!
  36. What is a suitable gas engine for the 73" H9 Cap 232?
  37. Tank size for a Q35?
  38. ZDZ40RVL dies when going verticle
  39. 3w-75 w/canister muffler -- HELP
  40. First Gasser w g23 giving me glitch fits
  41. test post
  42. 3W 75 Prop Reopened 26 Jan
  43. A great idea to increase power
  44. prop performance
  45. ZDZ 40 Sport and Joss Stick?
  46. Stihl 56.5 cc /3.45 ci information
  47. Glow conversion question- rpm drop w/o battery
  48. Fuel Tubing for G-38, which size???
  49. rcs engine
  50. Webra 1.20 and Dave Patrick Ultimate
  51. Quadra 35 questions...
  52. FUJI 86cc Thrust???HELP!!!!
  53. ryobi vibration mount?
  54. DA 100 Ignition
  55. Glow engine to Gasser sizing question.
  56. supertiger 4500 for GP PITTS ARF?
  57. Propeller Info needed
  58. 3 Blade prop on ZDZ 50
  59. CH Jump Start? V Toni Clarks Easy Start?
  60. Which 3 blade prop for a Brison 3.2 ?
  61. Gas to Glow?
  62. zenoah g-62 alternatives?
  63. RCS 180 engine
  64. DA-100 Nice Engine
  65. Moki 2.1 engine mount for GP 1/3 Pitts
  66. ZDZ 60 silencer options???
  67. Da 50 Arrives...
  68. Big carb help needed, please.
  69. Smoke Problem... Help!
  70. sachs dolmar weed whacker--worth the time to convert?
  71. plug gap
  72. moki 2.1 muffler HELP!!
  73. 4-stroke from 3W
  74. Supersonic vs. J & A muffler ZDZ80
  75. Zdz60 Muffler
  76. bme muffler - can I use a weedwacker muffler?
  77. Propellor Pitch
  78. Prop Selection
  79. ZDZ 210 question
  80. 3w
  81. FPE 2.4 internal noises...
  82. G-38 Wrong carb?
  83. BME5.8/102 headers
  84. fuji ingnition on byron mustang 50?
  85. Chainsaw Engine
  86. Tuned pipe on ZDZ 60?
  87. OS 160FX low end needle setting question, lost my book
  88. Moki 1.35 best prop size????
  89. Quadra 50 and Stinger 120 ?
  90. Zdz 80
  91. Best muffler- ZDZ80
  92. Bme 44 - Vibration ??
  93. Alcohol Carb for G-62
  94. Help! Need to see photos of throttle linkage setup for 3W engines
  95. Stupid Philosophy Question
  96. Vibration dampening
  97. Motor size reccomendation?
  98. quadra 50?
  99. ZDZ 60 props.
  100. ZDZ 60 props.PLEASE DELETE THIS ONE!!!
  101. Perry pumps
  102. problem with 3w100b2
  103. Quadra 42 prop / RPM experience?
  104. 3w-140 Problem Update
  105. Need help Sachs 4.2 throttle coupled spark advance
  106. Taurus 52 kicks while being started
  107. ZDZ 50 header adapter
  108. Calling Ryobi gurus !
  109. Cutting DA mufflers
  110. byron mustang 50
  111. G23/26 Zenoah Inverted Bisson Mufflers
  112. rcs 140 what weight can plane be and still 3d
  113. Giant Scale Prop Reamer ??
  114. Air Hobbies (A&H) Muff mount
  115. Glowplug For Moki 2.1?
  116. Need help cutting the header on 3W150QS??
  117. What is it??????
  118. 3W Ignition
  119. New FPE 1.3 gasser
  120. US Distributers for KS or PeFa Mufflers
  121. question about oil for gas motors
  122. RC Showcase 215cc gas radial
  123. Moki 180 + Hanger 9 1/4-scale Cap 232
  124. would like to find a used C&H ignition
  125. ZDZ 80 Single Vs GT-80
  126. ZDZ or FPE 2.4?
  127. ECHO 25.4cc
  128. Can Some One Give Me A Hand With This One???
  129. Broken crank
  130. ZDZ 60 Horsepower Inaccurate Description
  131. Supertiger 3000 prop hub?
  132. Muffler for sachs 3.2
  133. Prop hub adapter sizing?
  134. Ignition set
  135. Tired of helping newbies????
  136. G-62 spark problem...
  137. Giant Glow engine
  138. porp size for ZDZ 100 B2 ????
  139. US engines.
  140. Engine for a 26% Steen Skybolt
  141. Taurus 3.2 final set up. I Did a great job guys?
  142. Engine Sugg for H9 New 95 W/S cessna!
  143. G 23 On A Tf Cessna 182 Skylane
  144. Help me justify a DA 100
  145. Recommend a Gas Engine
  146. Zenoha G23 no spark
  147. Need help,starter info.
  148. Brison Web Site
  149. What size fuel line for Gas Engines?
  150. Homebuild Muffler For Gas Engine
  151. setting needles w/cowls
  152. zdz 60
  153. Trying to go gass but need help
  154. Da-100 Or Bme Extreme 106
  155. when is an engine worn out?
  156. Walbro info needed
  157. Engine for T Craft
  158. Prop for Sachs 3.8 or 3.7
  159. Header tank
  160. Please help Taurus 3.2 stall when put to vertical.
  161. Gt80
  162. muffler for ys
  163. 3W 70us prop
  164. help, first time gas user
  165. BME44 / prop shaft size???????
  166. Proper Engine Break-in
  167. Sachs 2.4 Performance
  168. Where Can You Get Parts For This Engine American Power Equipment Co 70cc
  169. Zdz 40rvl Hard Starting
  170. ST needle bearing conversion?
  171. G-23 to FPE 2.4 ??? or ZDZ
  172. Mousse can muffler - 1.8 size?
  173. 3W prop adapter?
  174. Engine Gurus, I need help
  175. Spring Starter For Ryobis And Macs
  176. Help with 3w60 ignition
  177. engine performance - ZDZ vs 3W: Help me build this database.
  178. Falkon VS C&H Ignitions
  179. ryobi flywheel heavy point
  180. anyone know what engine this is?
  181. Run in NEW ZDZ 40**WOW**
  182. Engines What Else!!!
  183. bme muffler-how to quiet
  184. poulan 46 muffler, what will bolt on?
  185. Help - 3W or ZDZ ????
  186. Mid Range problem, BME 100
  187. Ign update on fpe2.4 from R/C ignitions
  188. OS 160FX and Jett Muffler?
  189. How much rpms does a pitts muffler cause you to loose.
  190. Homelite 2.5?
  191. Brison engines
  192. Webra Bully 35cc - Any for sale?
  193. 3w-140 problem
  194. OS 1.60 High End Question
  195. Need Help Black Goo In G 23 Muffler
  196. tuning us engines
  197. ZDZ 40 question
  198. Pitts Stlye Exhausts Brison 5.8/4.2 and g62
  199. G-38 in a Sig CAP 231
  200. G
  201. Zdz 210
  202. 3w shaft/nut bent
  203. Velocity Stack for Brisson 5.8?
  204. Does ZDZ have the same bolt pattern as DA/3W?
  205. 100cc Partner Conv.-What stock muffler will fit?
  206. 3W 75i idle
  207. Sachs 4.2 Thread size
  208. Lawnboy ashless leaving black residue..how do I get it off?
  209. Opinions on the U.S. 35cc engine......
  210. HELP 5.0 chainsaw converted to glow
  211. 3W 70 vs ZDZ 60
  212. Sachs 4.2ci Engine with 6 Bolt Hub
  213. Which Muffler for OS 1.60FX??
  214. Home Made Canisters
  215. bme 50
  216. small gas engine?
  217. 2 Taurus 52 just in for christmas.
  218. G-62 ignition conversion ?
  219. Need engine recommendations please!
  220. 3Bladed props
  221. 3w-50qs "quiqie somzini special"
  222. Homemade muffler for Moki 2.10 ?
  223. Your preference ?
  224. YS Engine differences
  225. ZDZ or 3W?
  226. ys 120 fs opinion
  227. ?? about us 2.5 engine
  228. Need some more advice
  229. Plug and gap for elec. ignition
  230. 3W 100 Warped intake spacer!
  231. More Engine for Edge 540
  232. bme 3.5?
  233. velocity stacks
  234. 3W 75iUS. Are these good motors?
  235. Need Helping finding short spark plugs.
  236. want to buy 2 giant engines, 20hp each if possible
  237. 3w100 dies, plane dies, vicious cycle
  238. ZDZ contact info????
  239. Has anyone received their ZDZ or DA 50?
  240. Need help on Engine ID
  241. G62 or ZDZ 60
  242. NEW G26 Zenoah
  243. What size fuel tubing for the Moki 180?
  244. O.S. 160FX vs Moki 1.80 #'s vs Exp.
  245. tuned pipe design for Honda GX31
  246. Servo for throttle/choke
  247. Need engine decision advice
  248. Ram Igniter 1300 Driver - On Board Glow - Happy Ending - Gone Bad.
  249. Looking for muffler advice.
