PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 [56] 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Confusion on RF interference and battery location.
  2. Moki 1.8 gas engine
  3. 3W-75US ignition module setup
  4. ZDZ super 80
  5. DA 50 Ignition troubles
  6. What a good airframe for G62. Must at least unlimited with good 3d power.
  7. Carb bolt tightening problem
  8. old engines
  9. Thanks to Tod Blose, and DR Hobbies
  10. Brison 2.4 Throttle transition problem
  11. *Brillelli 40cc & Prop Adapter*
  12. G62 Horizon Hobby vs Ebay
  13. prop for 3w 41i
  14. please delete.
  15. Gas/Oil ratio
  16. How to make smoke?
  17. Brillelli 60cc
  18. MVVS 45 new type ingnition
  19. MOVED: pleae help!!
  20. New - DA 50 Breakin
  21. Sachs Dolmar
  22. Carb ajusting Help
  23. Need Carb Spacer For G-26, Where to Buy??
  24. Evolution 58gx2 won't start
  25. Smoke with DA50
  26. Mineral based run in, then only Synthetic: Myth or fact?
  27. Brison parts?
  28. Please help. Carb trouble (I think)
  29. carb question walbro upgrade
  30. Evolution 1.60GT I or II?
  31. EI for Weedie motor
  32. G-62 Won't Run Right--Whats Wrong w/This Picture?
  33. The "NEW" Brison. What's the Verdict?
  34. 3w41 back carb
  35. Fuji 43- Down on revs?
  36. How do you reach the needle valves on rear intake gasser?
  37. Electronic ignition module placement ?
  38. Help, Gas Plumbing
  39. G62 - Spark Plug Coming Loose
  40. CH Ignition Coil resistance needed.
  41. Test props
  42. HIDE THE CARB
  43. Krill Group Sky-Line Aviation
  44. Airframe for G26
  45. New to Gas
  46. Plane Restriant
  47. Fuji 43EI vs. Fuji 43EI-2
  48. DA50: Idle Too Rich?
  49. Weedie won't fire
  50. which alluminium spinner ( 3 " ) fit for MVVS 45 whit 22X10 prop
  51. G26 vs G38 for GP Super Stearman, or other 40cc engine???
  52. Home Made Canister Mufflers?
  53. Gas Engine Performance Tricks?
  54. need a crank
  55. Micro pulse fuel pump
  56. Is it easy to flood a G26?
  57. Zenoah "Twister" carb adapter
  58. Evolution 26GT Ignition Problem.
  59. BT-43EI-2 vs BT-43EI: ? differences?
  60. RCS 215 Help!!!!
  61. please explain gasoline ignition timing???
  62. Prop Shaft length with DA-100
  63. Which small Gas Engine??
  64. zenoah G-23
  65. zenoah G-23 parts
  66. DA50 stalls in spin ???
  67. g26 prop hub
  68. 3W 85cc RPM varies.
  69. Not Your Common Interference Problem
  70. Good Bearings?
  71. K&B 35 Stallion
  72. Need to know about Fuji BT-32b
  73. question regarding the fuel line in the tank
  74. Fugi- Zenoah which one
  75. BME 50 RFI????
  76. *Brillelli Site Shutting Down*
  77. Homelite mods
  78. Newbie needs help with Gasser
  79. Fuji 43EI & smoke system
  80. DA 150 and 100 Ignitions
  81. RF interference using 42cc Petrol Engine:HELP?!?
  82. Smoke question...
  83. *CH EI Wire Connector*
  84. electic starters for big gas engines
  85. Evolution 26 GT
  86. Fuel Draw/ Evolution 45
  87. Evoltion 45 Ignition
  88. How to do an ignition test
  89. Best way to ~30lbs thrust
  90. SPE40
  91. G-38 flywheel bent?
  92. BT 32B Prop Driver
  93. Where to get Engine standoofs.
  94. 3W 75 Tach Numbers
  95. Sullivan Fuel filler valve part # 750
  96. Best first gas engine?
  97. Can I run my new G-26 without the velocity stack?
  98. propping the G38
  99. Walbro carb question.
  100. Horner engines?
  101. Any experience with the Zenoah G20?
  102. ZDZ problem resolved
  103. Red max engines
  104. zdz80rv gas tank
  105. Spark plug for Webra 60
  106. switching over to synthetic to soon
  107. Just started my G26, now I have a couple questions
  108. Questions about smart switch and failsafe
  109. GN2 Oil - Ashless?
  110. Plastic ARF engine mount ok for MVVS 1.6 Gas???
  111. 3W 106 sagging
  112. G26-Problems
  113. Frustrating Fuji 43
  114. Frustrating Fuji 43
  115. Item's needed for a DA-50
  116. Webra Bully gas replacement engine?
  117. Quiet a G-62?
  118. Best DA 100 prop: 27X10 Or 28X10 (Flying IMAC)
  119. Mejzlik 26x10x2 vs 26x10x2 Narrow
  120. problems with my DA50????
  121. Need engine suggestions...
  122. RCIGN - you back ?
  123. DA50r crankshaft
  124. Fuel Line
  125. Evolution 58 Lessons Learned
  126. 26cc Engine Choice
  127. DA-100 Tuning
  128. 160 mvvs, 8600 rpm on menz s 18-6
  129. DA50 POP?
  130. HELP!! Flexible Pipe??
  131. revo engine cuts out
  132. Johnson Mufflers Website ???
  133. DA-50 broken prop screw
  134. Swapping ignition with different sensor, issues?
  135. Anyone uses G26 Abell muffler for G20?
  136. G62 Three Blade Prop
  137. torch engines
  138. New CH-Ignition prob.
  139. Evolution 35 GT
  140. CMpro giles 202 1.40, suitbale for gas?
  141. Weight of RC Ignition G26?
  142. I need help What Ignition is this???
  143. electronic ignition
  144. Engine suggestion...newbie help !!!
  145. CHARGING IGNITION BATTERY???
  146. 73" yak54 on super tiger 2300 or Gas??
  147. HELP finding a honda gx35 high output cam
  148. ZDZ80
  149. Gasser Throttle Linkage
  150. Getting ready to start my G26
  151. Realistic Gas Engine for 1/3 scale J-3 Cub
  152. How to reach Kieth at BME??
  153. Is a US41 good enough for a 1/4 patty Wagstaff
  154. Brillelli 40cc Performance?
  155. Ralph Cunningham
  156. Gas engine for a 54" Ultimate Biplane?
  157. BME 50
  158. Post-break in oil for Fuji 43 EI
  159. BCMAEngines Website is moving!
  160. CANISTER - mfgr's, types, where
  161. Engine Stress Test
  162. Zama Carburetor Adjustment
  163. Fuji 25 cc 4-stroke
  164. Choke servo question on Brillelli 366GT 60cc
  165. GLOW OR GAS???
  166. BME 115 is Shipping and Flying
  167. US 35cc - Carb continually going rich... need advice
  168. Brillelli 366GT on a GSP 80" Cap-232
  169. DA 50 first run.
  170. Quadra 35cc Muffler
  171. G62 vs. G45 in Bates Bearcat
  172. walboro carbs
  173. Evolution Ignition Question
  174. AeroWorks 33% ultimate
  175. DA50 Running hot
  176. the best
  177. MVVS Ignition
  178. ANY LUCK WITH V-TACH ON BOARD TACHOMETER?
  179. Any sub-50cc gas twins?
  180. Ohlsson and Rice Compact III (Type 133?)
  181. 3w-56b2 Competition
  182. Vess props
  183. C&H ignition Ground???
  184. 58 Pro vibration
  185. ZG45SL & GP kill switch
  186. Crankshaft Size?
  187. DA 50- best 3 blade props
  188. Re-drilling CF Props?
  189. 3W 75 will not go to idle on final
  190. Need Prop Opinions for DA-50
  191. need info about venom 45 gas
  192. Quadra 35 to EI
  193. 3W Ignition RPM OUTPUT
  194. Break in a New G23
  195. fuji 64ie
  196. ignition wire wrap to reduce interference..
  197. MVVS vs. Zenoah
  198. time for a new engine, but must fit in thin cowl. . .
  199. Leaking Spark Plug?
  200. Evolution 26GT/35GT
  201. G-62 sags rich when inverted
  202. MVVS 35 with a 3W 20x8, shwoo
  203. Evolution 58GX - what RPM's should it turn?
  204. 3W 24 gas engine thrust
  205. BME 50 help
  206. Does plastic spinner suit 45 cc gas engine?
  207. RCS 215
  208. KING 100CC CARB TRUMPET
  209. ZDZ Super 80
  210. Comparing gas to glow
  211. Zenoah G26 installation??????????
  212. Need Help Bax
  213. Walbro Part needed
  214. 100cc twin
  215. BME G90 - Latest opinion/reviews???
  216. Installing Zenoah G-38 with carb pushrod
  217. 3W 75i TS Misfire
  218. g 62 on ch ingnition problems
  219. New Zenoah EI
  220. In-line twin 105cc tuning questions
  221. Zenoah 23 Fuel?
  222. G-38 CARBURATOR NIPPLE
  223. Anyone uses GP kill switch? How do you set it up?
  224. NEW Fuji 50EI Help!
  225. Fuji 43 EIS won't start!
  226. Walbro Problem
  227. Strange response from RC Showcase, super 80
  228. cooling problem maybe??
  229. FUJI BT64IE - reverse cylinder?
  230. lite 50cc yak
  231. Avg running temperatures for gasoline engines
  232. my g20ccEI needs help!
  233. DR. EVIL and MINI ME
  234. Evolution 58 reeds?
  235. What you all use for gasket or gasket sealer?
  236. Prop speed, Help me with the math
  237. Overweight Yak 54
  238. Evolution Engines -Gasoline
  239. Question about an oil change?
  240. ZDZ 80rv Template??
  241. FPE 3.2
  242. 33% CAP 232 Set Up Question
  243. Brillelli 46cc
  244. 3W 106QS keeps blowing out canisters.
  245. DA 100 stock exhaust
  246. tune them there spark plugs guys,,
  247. BME 100 Parts and preformance
  248. hiteck 805BS servoes
  249. How About A Fuel Injected Gasser?
  250. A change in the 3W80xi wrap-around header?
