PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 [88] 89 90 91 92 93 94 95 96 97 98 99
  1. What's the best gasser to use in place of a Saito 180?
  2. Ignition on 6 volts ?
  3. DA-100 Ignition Battery
  4. can't find Ralph Cunningham @RC Ignition
  5. help a newbe (zdz40rlv
  6. US 41 & Pitts
  7. Tell us about your RCS 140 Powered Warbird
  8. comparison ZDZ vs others
  9. 3W-75 Carden 30% Cap Cowl???????
  10. Best BME Prop and Oil after break in?
  11. RCS180 ignition flamouts
  12. beginner looking into gassers
  13. torque wrenches ?
  14. Pumper carb not pumping?
  15. 80" h9 cap & zdz or g45
  16. 3w-100 ... if you own this please have a Look
  17. Ford or Chevy
  18. Are you flying a 40% with a 150-3W above 5000 ft?
  19. Conversions Sub-forums have arrived
  20. This looks verrrry interesting!!!
  21. moki 135 engine instruction manual
  22. ZDZ 50 Problem
  23. Source for Fuel Tank Nipples
  24. US 41 replacement HELP
  25. gasser going dead
  26. Prop for G23/Hanger 9 Taylorcraft
  27. Trouble starting my 3w 50i
  28. 3W140 running on one cylinder
  29. OPS 60 Twin Maxi RCA engine info?
  30. What starter are you using?
  31. Ultimate .90
  32. rcign et al have a look at my A&M Sachs
  33. Pitts Muffler for ZDZ 80RV
  34. zdz80 break-in oil, synthetic or not?
  35. Slimline F1 fueling system for giant scale: BEWARE
  36. Poll on Engine Conversion Sub-Forum
  37. Blocking 1 pipe on FPE 2.4
  38. Why does it rip???
  39. What Motor mount for for OS 160?
  40. Prop for DA 100
  41. da 50 for 2m ekstra
  42. My Saito FA-60T has problems that I cannot solve, Please help.
  43. zdz 80 drill guide
  44. Walbro question
  45. What can go wrong..
  46. Super Hustler 2.6
  47. Featherlite 25 RPM???
  48. Are you flying a 40% with a 150-3W above 5000 ft?
  49. Ryobi 31cc Starves When Inverted
  50. timing a zdz80
  51. Engine for 1/4 Cub.
  52. Mounting ZDZ80 in GP Extra
  53. Fuel Tank?
  54. Cheap 22-25cc Gasser.
  55. zdz 50 or 3W-50i
  56. Us25
  57. A & M Sachs 4.2
  58. Poulan 2.0
  59. Fuji BT 32??
  60. Cannister/Muffler
  61. Me and my G23
  62. Ryobi 31cc Converted. Need Help to finish.
  63. Best smaller gas engine to replace 1.2 4 stroke
  64. how to start a 3W 38
  65. Thrust Measurement
  66. Please help ID this gasser
  67. New ZDZ carb fuel leak......Help?
  68. DA100 Exhaust
  69. New Brison Rear Intake / Rear Exhaust
  70. rf interference and battery placement
  71. Prop adapter for 28cc 'wacker' motor.
  72. RCS 1.4 Setting up linkages?
  73. Plane for RCS 140
  74. Zenoah G-23 or G-26
  75. G38 throttle
  76. ryan idc trimmer
  77. How long will my 3W 70 twin run on 32oz tank??
  78. HELP!! RCIGN? anyone? Sachs 4.2
  79. Tartan Twin or Q-35?
  80. Tiny Gas Engine
  81. Ryobi wont start
  82. Walbro glow conversion
  83. Sachs 3.0 twin opinions please!
  84. Fuji 64
  85. RCIgn1
  86. Bme 50
  87. Newbie needs best large engine to start with
  88. Zenoah G38 mounting
  89. Engine Conversion Sub-forum???
  90. why do you like gas?
  91. Mustang 50 info needed..
  92. Stihl size?
  93. Poulan featherlite 25 ports
  94. BME prop selection
  95. Right airplane for Seidel st770 radial
  96. 3W Intake Manifold / Air Horn
  97. Poulan 36
  98. G-38 won't idle down. Why?
  99. ZDZ 50 rpm Figures??
  100. adapter spinner nut
  101. Fuel filter for DA 100 ?
  102. US25 fuel hookup?
  103. Da-50 & Mufflers
  104. g-62 not priming ????
  105. Super Tigre 2500
  106. SPAM can muffler
  107. Help 3W-75 Ignition
  108. New BME site !!
  109. US Engines - Any Info Appreciated
  110. Poulin 25cc PowerUp
  111. Poulan Pro 330
  112. Brison 3.2 or DA 50
  113. Moki Manual
  114. Engine data wanted
  115. Help.. 3W in Carden 330 power problems
  116. Chainsaw Engines?
  117. FUEL LINE ?'s
  118. Carb govenor?
  119. G-26
  120. Detailed Fuel Consumption Data
  121. DA 100 Muffler bolts
  122. FPE 2.4 on Texas Hurricane
  123. Lighter, Faster, Stronger, pick one!!
  124. Zenoa G26 dimensions???
  125. zenoah G-62
  126. What is this engine?
  127. os 3500
  128. DA 50 choke access problem....
  129. G38 Prop Suggestions
  130. Centermark Twin Question
  131. new 3W 106 is here
  132. ZDZ 80 - A little different approach
  133. Prop Hubs
  134. bme 102 quits downline
  135. How to select a prop?
  136. are spark plugs generic? (ZDZ)
  137. Zdz 80 Heavy Prop WASHER
  138. Desert Aircraft, No answer
  139. Pecking order - Thanks & specifics
  140. Enya from Japan???
  141. How do you install the linkages on a gas engine?
  142. question on gas /oil mix
  143. Bolt size for MVVS muffler?
  144. Homelite 25 and 30cc
  145. Which engine
  146. Mejzlik prop on ts42?
  147. Brison 5.8 vibration?
  148. ZDZ 80 RPM's?
  149. Help - need small spark plugs
  150. No Bs Rpm Numbers Pls
  151. Quadra Q75 RSS
  152. G-38 help
  153. loose muffler US41
  154. gas engine spraying fuel out of carb
  155. What Oil To Use
  156. How do I tell if it is a Quadra 50?
  157. Quadra 35 V/S Ryobi 31?
  158. G-45 Zenoah new "EZ carb" watch out!
  159. Husqvarna 162
  160. Prop for 4.2 Brisson
  161. Pecking order - Gas engines
  162. ZDZ 80 Single prop bolt size?
  163. G26 - Ultra Stick 120 crash
  164. Which Prop bolt design do you prefer?
  165. delete
  166. DA50 with a cannister
  167. Engine Mount
  168. Fuji BT-50SB vs Fuji BT-50SA
  169. Mystery Engine
  170. Engine conversion how-to?
  171. GP plastic mount for RCS 140?
  172. How much pull??
  173. BME 50 best lightweight engine mount ?
  174. fuel t's and zdz engine
  175. How to improve our engines (pick all applicable)
  176. Addicted to this Forum...
  177. ElectroDynamics Kill Switch
  178. Ryobi 31cc Linkage?
  179. HELP!!! Adapter for 3 1/2" Spinner with ZDZ 40
  180. Mac Minarelli 70cc Twin Muffler
  181. Zenoah G38 carb settings?
  182. Zenoah G26 / ultra stick 120
  183. muffler hole measurements
  184. Tilixon carb on the 3W 70 Twin??
  185. Another electronic ign question
  186. PPM with big petrols/gassers
  187. How much smoke fluid is too much?
  188. What size tank for 50 size GAS ?
  189. 3W 100 Throttle Linkage Idea's ???
  190. Zenoah G-38 ?
  191. bme 50 idle?
  192. Fuel Tank Size for Ryobi 31cc?
  193. Best Prop Fuji 50
  194. 3W-35, How is it??
  195. Any Ideals on Husqvarna 98 cc saw convertion?
  196. What 3 Blade Prop for BME 50?
  197. DA50R Shaking Bad!!!
  198. High Temp Hose
  199. Quadra 65 coil lead
  200. 3w 100 lite
  201. zenoah or what?
  202. Electronic ignition input
  203. Flywheel/Mag vs CDI? Running habits?
  204. Zenoah G23 Prop Bolt Torque
  205. Mixing Fuel, What Are You Measuring With
  206. Where to buy a ZDZ 40
  207. Prop bolt holes on 3W 70, same as ZDZ 60???????
  208. Muffler for a ZDZ 60rv
  209. the lightest 56cc gas engine is only 51cc
  210. Jug rotation on chainsaw engines?
  211. DA ignition voltage
  212. 3w70 in a 88in by wing
  213. Quiet Muffler
  214. Moki 180 + Cline Regulator ?????
  215. HT lead screening
  216. Average engine temps
  217. Brison 3.2 @ 103 dB-HelP!
  218. HP 120 Twin Engine Experience??
  219. 3W24-Super Cub
  220. 3W-100 to 3w-106
  221. walbro speed governer?
  222. walbro website ?
  223. Mvvs 1.60 Gas-- 1/4 Scale Cap 232
  224. on/ off switch
  225. Break in prop for DA 100?
  226. homelite 25 help?
  227. high temp. silicon tubing
  228. ryobi flywheel departs on 1st start!
  229. Sachs 2.6 gas engine
  230. Electronic Ig. G74 Con.
  231. How to size a US engine?????
  232. Where can I find larger gassers to convert
  233. Gas engine for a PILOT 1/3.7 Christen Eagle
  234. Hobby Services and my US41
  235. Smoke question
  236. Zenoah Engine Question
  237. ZDZ 60 vibes and idle RPM
  238. Starter for Saito 1.80 / OS 1.60
  239. us41
  240. Zenoah GT-80 for H9 Sukhoi?
  241. Fuji BT64A
  242. DA 50 :o) Anyone seen one of these Beauties
  243. Easy link
  244. Mma 60 Twin
  245. 3W Prop Bolts
  246. DA 150 mid range throttle problem
  247. Another 4 cycle engine on market
  248. Da-100
  249. Brison 5.8 - 2 questions
  250. weedeater 21 for 1/4 scale cub?
