View Full Version : Gas Engines
- DA 100 Break in ???
- New G-62 question
- 3W 100 runs rough after 5 or 10 minutes
- Engine surging at idle, looking for suggestions why!!
- Free BME 50 engine
- 3w-28
- 100cc engine choices
- Questions about rear mounted carburators?
- Fuel line size for 80-100cc engine
- This AMSOIL OK?
- Another stupid question, Tank hookup on gas Engines.
- fuel proofing?
- US Engines 41cc - your opinion needed ?
- Newbie to gas question
- HELP ! Slop in crankshaft.
- 2.4 Gasser
- G23 prop size?
- Fuel Tank for the 32B
- Smoke Muffler ?
- WOW !!,,, got my MVVS
- Desert Aircraft - Best in Service!!!!
- G-62 carb parts
- 3.2 Sachs A&M problem
- 3.2 Sachs starts & then runs backward
- ZDZ80 synthetic oil recomendations.
- K & S CANNISTER
- Amsoil 2000 carbon build up?
- BME owners, help.
- What engine is this???
- RCS 1.80...ANYONE USING THIS ENGINE
- smoke and G23
- 3w-70i ...cylinder rotation..help
- MTW or KS Tuned cans for DA 100?
- Zenoah G-38
- z
- Big mess with MVVS 2.15!!!!
- Brison 3.2 shaking bad !!!
- 3W 106b2 Carb linkage question
- more power in 3w 42cc?
- Quadra Identification
- Phone number for ralph Cunningham R/c ignitions
- Exhaust for RCS 1.4
- More power out of a Mac 85 twin??
- "Home" for the 3W-684-B4
- Covering G-62 diaphram vent ? ? ?
- DA-100 Throttle Curve ?
- NGK CM6 Spark Plugs
- Zenoah GT-80 info
- ZDZ 80 Plug. What do you use?
- DA 50 do not idle down in flight. Help.
- Quadra Q52 Quiet Muffler
- DA-100 Mid Range
- RCS In-Fuselage Silencers
- BEST oil for mixing....your opinion
- BME/Mejslick help
- ZDZ 50, Awesome engine!
- MVVS 1.60 Maintainance schedule
- ZDZ 80 SINGLE EXHAUST
- What is the best muffler for ZDZ 80?
- Klotz RC Model lube KL 308
- ZDZ 40 ignition curve/advance?
- RCIGN1 - G62?
- Kris^ and/or Dick Hanson
- ZDZ-40 engine component failure
- New or old ZDZ 80, are they the same?
- Geeezz, so you don't want me as a customer,,,
- RCS 140 Problem!
- YW24 whith MVVS 1.60 - no comparison
- P47 gasser selection
- Sachs engine clarification
- Z-26 going on H-9 Cub
- GP Christen Eagle II + Fuji BT-50SA + Prop???
- RCS 180 or G26 ???
- Question for tkg, Ch Ignition
- New G38 won't run
- Quiet as possible (ZDZ60)
- Quick DA100 question
- BME 110Xtreme
- BME Crashed pretty hard
- Need Help With US Gas Engine RPM
- RC Showcase Roto 35/performance reports?
- ZDZ 160 HELP!!!!!
- Zenoah G-26 and B&B SUPER SMOKE PUMPER
- FPE 3.2...Compared to zdz 50??
- BT-50SA Carburetor Leak?
- DA 150 Prop?
- ZDZ 40 RE
- Headers and Cans for BME 110
- FPE 4.2 Not throttling up after downline
- ZDZ40 with bing carb
- zdz 40 and brison 2.4 weight comparison
- Quadra identification...
- 3W150 Bearing Replacement
- Taurus Website
- Bolt thread: 5mm X .8 and 10-32
- 3W 75 gas newbie???
- Smoke muffler holes
- MVVS 2.15 Gasser performance?????
- how far should I install the trottle servo from the ignition system?
- P-tip Props
- MVVS 35cc gasser motor ???????
- my Zenoah G26 dies when I come into land why??
- DA 50 Weight?
- Rascal 110 gas engine?
- Any one using a YW-48?
- Walbro Pump vent modification-anyone have a photo?
- Why my DA 50 is so quiet???
- what is more powerfull
- leaded fuel or unleaded for gas engin
- O&R GAsoline engine
- BME-44 backfiring (FIXED)
- What size is the bolt on a DA 50 that holds the head on???
- Going to get my first gaser Zenoah G-26
- Ignition battery placement.
- Whic is a more efficient prop?
- Ignition Batteries
- YW-Engines
- SM gas engine
- zenoha g26 or 38 or fuji 32
- where to get spark plugs for g38
- zdz80 throttle linkage question
- BME 50
- DA RPM problem?
- Odd frustrating US-41 problem.
- Amsoil & glass beads
- ZDZ 80 B2 carb settings please.
- Air filter for walbro carb
- g 38.
- This whole oil thing is driving me batty
- Can this engine be converted for airplanes?
- G-26 problems
- Head Temp on Twins?
- Aft Cannister Mounts
- Insulate in-fuselage canisters instead of airflow?
- prop size on g45
- Snake drive on gasser?
- 3W 78 twin
- 3w140 ???
- why was my post deleted?
- ignition battery for a MVVS?
- Slimline Muffler for DA50
- Really stupid question here!
- BME
- Which 100:1 Amsoil?
- Tecumseh TCII TC300 clutch question
- What's happened to RC Showcase
- MVVS 35CC muffler recommendations??
- Price question
- Pitts ~ 64cc ~ Electric Start
- DA-100 Target Idle?
- pop off pressure
- Throttle servo for Brison 3.2?
- DA150 - header length?
- MA 16x8 versus APC 17x6 for most thrust
- Just an Observation
- Liquid Cooling
- Echo 21cc
- DA-50 snag and need some help
- Engine guru, please help me to find why my engine flamed out...
- Zenoah G-38 tank size
- new carden 35% extra, engine choice help!!
- Welcome US Engines
- FPE 2.4 good, bad, or indifferent?
- gas engine for chief katana 72"
- ignition experts (help)
- Exhaust Leak?
- Smoke shut off problem DA 50 TME pump
- Position of the Hall sensor on ZDZ-40
- 4-stroke gas
- ZDZ 80 RV Muffler
- Best throttle linkage??
- G45 problem please help
- Needle Valve Extensions
- G26 Problem - Help Please
- Coleman or gas
- Weed Wacker Conversion!!!
- us engin 41 is it good
- Tank Positioning on Patty Wagstaff Extra
- ZDZ 100NG on JMB cans.....you out there Dick?
- Extremely rich mid-range, G-62
- Ignition wiring for a DA-50-R
- Precicion Eagle 4.2
- fuji 50 sb or zenoah 62 or45
- Tillotson needles
- anyone run 6V on ignition?
- G23 vs. G26 and Quadra 42 vs. US engine 41
- Fuji 50SB, idle RPM
- 3W 90-degree intake manifold - experiences?
- 3w-55b2...any updates?
- Fuji 50-SB....First Gas Engine..Questions.
- G26 Problem
- Biela Propellors
- What size tygon fule tubing for 3W 150?
- ZDZ 50 NG starting question , help....
- Old ZDZ 50 and new ZDZ 50NG differences? (Dick?)
- DA-50 on a K&S Pipe
- Prop for ZDZ 80 RV
- MVVS 58cc Gas
- Muffler on DA 50
- what to use to clean off black exhaust residue?
- Fuel Line Question
- BT-64 Smoke system
- Sullivan tank for gas use
- ZDZ 100 NG (Help Dick)
- ZDZ 80 IGNITION BATTERY
- Help with G-38 Zenoah
- Closing in on problem... Walbro question. Engine surging & cutting out
- 3w 106 AI problem...
- 3w 106QS
- Zenoah G-62 Help/Suggestions please...
- Trouble With Midrange on Fox 3.2
- Help: G26 Throttle/Carb problem
- RC showcase-manufacturer's support forum
- ZDZ 40 bubble in fuel line SOLVED
- 3W-106 QS Crank breaking
- Muffs for G26
- Propeller for ZDZ 50NG
- DA-50 Exhuast Manifold
- 3W-50 Manual needed!
- Broken cranks on gassers
- fuji 32
- Gas engine for a hanger 9 edge 540
- 3W 80 B2 Spares?
- ZDZ 40 & 72 in. Hangar 9 CAP 232
- 3W140 trouble, flat spots in low range
- prop reamer
- G-38 Carb. Upside Down
- 1.5 oz pouches of Amsoil 100:1
- Break in on Synthetic vs Minerals
- My DA-50 does it too!!!!
- Q42
- ZDZ 100 NG
- which 3w engine for 1/3 scale champ?
- DA 50 for dummies
- Falcon igntion G62?
- DA150 VIBRATION
- Amsoil 100-1
- ZDZ 80 Question ?? Dick Hanson ??
- ZENOAH G26 VENTING
- 6 Bolt adapter for BME 110?
- Which ZDZ 40 do I have?
- and with DA 50, 3W 50 or DA50?
- DA50 battery capacity for ignition
- Gas Engines
- Ignition
- Is there a gas engine for GB Extra 300?
- Having trouble starting a new G-62
- G62 CARB QUESTION
- GasZenoah 26 engine in plane causing rf glitching HELP!!!
- I'm new to the DA's and need some info
