PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Prop
  2. Needle Extenders for Walbro Carb?
  3. 50cc-ish reasonable $ twin? ISO engine for 12' Tele
  4. Reqt: Pics of AW YAK 120 with DLE30
  5. Plane for DLE 30..nonaerobatic...ARF?
  6. DJ80 from sds hobby or amr hobby
  7. Please help, tuning question
  8. Went cheap. bought a DLE 20 and got burnt!!! UPDATE!
  9. Da 85 or adz 90
  10. Da 85 or zdz 90
  11. Stihl HP Ultra-Must be good stuff.......
  12. DLE 20 or 30 on 90 size Joss Stick
  13. Ignition battery choice CRRC 26 engine
  14. us engine 41 electronic ignition conv.
  15. NGH GT9 Yellow Heli Head ?
  16. Mounting DA-50 washer type, size and grade?
  17. 3W-75i Canister Help
  18. DA100-Spitting problem-Is this normal???
  19. G-38 crank needed!!
  20. DA or Us engines?
  21. DLE 30 won't run after 2 flights HELP!
  22. Gas Kill switch
  23. Melody 70cc twin (MLD70) prototype maiden!
  24. DA-60 Tuning Issues
  25. Venting Gas tank
  26. DLE 20 or DLE30?
  27. Starting Gasoline Engines - Safely
  28. Fuel Filters
  29. DA100 spinner bolt size???
  30. Is this the correct spark plug
  31. SV TROY BUILT 17 CC GAS ENGINE
  32. anybody else had this problem?
  33. For Spectrum/DX-8 users
  34. Evolution 35GT to RCexl ignition
  35. DLA 112 3d prop
  36. DLE 40cc or 60cc twin?
  37. DLE20 or DLE 30
  38. dle 20 or 30cc for hangar 9 cessna 182
  39. DLE 30 Mounting
  40. Engine operating temperature
  41. June 6, 1944
  42. Richer or leaner with cowl on?
  43. Tuning the DA-60
  44. Is DA100 worth the extra $ over DLE111 ?
  45. HeliCoil for CM-6 spark plug
  46. dle 55 Ingition Problems
  47. jc 28 v2 pitts
  48. Zenoah Drill Jig?
  49. DLE-111 first start... warranty used, but things are looking good.
  50. DLE-20 issue
  51. Tygon Tubing...what brand and where..?
  52. Exhaust screws.
  53. quadra 65 or 75?
  54. Touch up carb. tuning
  55. Prop pitch speed, static rpms, and actual flight speed?
  56. DA-100 Ignition Hardware Problem.
  57. DA 100-Is 6.0 volts too much?
  58. Neoprene v/s Tygon tubing
  59. SE Engines 32cc GAS
  60. Hitec A9 Warning-Ignition Kills
  61. DLE 20 compared to Zenoah G20ei
  62. storing gasser long term
  63. New Patent Pending Propeller Available for Purchase!!
  64. RCG 20cc Gas engine
  65. i need help on prop issue for 50cc
  66. twin headers - single canaster
  67. Bent prop shaft DA50R
  68. Best for a Fuji 32
  69. Evolution 58 GX??
  70. Desert Aircraft Packaging ???
  71. Soft mounting gasser
  72. DLE 30 Prop Mount
  73. Replacement Spark Plug
  74. For all you vets...Happy Memorial Day
  75. Engine for Lanier 30% Edge
  76. Walbro carb linkage v nipple problem
  77. Taurus TT 107
  78. Fox 4.2 running very erratic
  79. getting close to wits end with my motor
  80. Spark plug for older Zenoah G23
  81. 2/4 problem?
  82. What Size Gas Engine
  83. FG14 in an RV-8
  84. Right Zenoah gas engine for CMP Corsair?
  85. Need CM6 Spark Plugs?
  86. RCGF 55 Wont start !
  87. Upright DLE 55 Problem?
  88. question-more weight or engine downthrust
  89. Can you make your own reed valves?
  90. Rcexl mini tach
  91. Can You Over Rev a 2 stroke Gas Motor?
  92. BH Model 120 Corsair
  93. NGH 17cc gasoline engine
  94. Fuji 64, Anyone have good luck with them? its heavy but can I trust it?
  95. Fuji 64, its heavy which is ok, but can I trust it?
  96. Mag on the Fuji 32A
  97. DLE-30 Wrap-Around Muffler for ESM P-51
  98. Carb throttle connections on a small gasser
  99. 250cc Briggs & Stratton for large scale planes?
  100. Mrs Gasket fuel pumps
  101. MVVS/EVO 26GT Fuel draw question
  102. DLE-111 carb questions...
  103. Poll... for avistar Photo of Jody at VVRC
  104. Quieten a muffler
  105. Walbro Throttle Arm Screw
  106. Kalt 22 Twins
  107. How to repair Zenoah G20EI after a crash ?
  108. MLD-28 to Rxexcell Ignition
  109. DLE GAS ENGINE -dependability
  110. Engine won't run beyond idle
  111. DLE technical specification info?
  112. New plane & new engine-is this a good idea?
  113. wot 4 XL what servo do i use
  114. Prop for 3W60 side carb
  115. DLE 111 ?
  116. A canister conundrum
  117. Best way to mount 30cc engine
  118. Saito Claims the only Gas Twin Engine 4-Stroke in the market 57cc
  119. Prop Clocking a Gasser
  120. crrc 26R-dle20
  121. vibrating 3W 106
  122. Dose Gas = Slow?
  123. Moki 75
  124. AW Yak 120QB- 120AX or 160FX or DLE30
  125. probly a dumb question i'm new to gassers
  126. RCEXL Ignition power requirements...
  127. dla 112 3 blade prop
  128. OS CM6 spark plug on DLE?
  129. Huge Kudos To Troy Built Models
  130. RCS SV26
  131. OS 30cc engine
  132. prop type for 30cc gas engine
  133. se 32cc
  134. Zenoah G38 coil
  135. glo to gas
  136. Improving a G20's performance
  137. How to make a Slimline smoke?
  138. Igniton Timing at Idle
  139. RCG 26cc Gas engine does not shut down
  140. Head porting for Gas Motors
  141. Pulg connector replacement
  142. Engine for 1/7 scale TF P-51?
  143. DA 60 or 3W 55xi
  144. What's gone wrong with carburetor/engine?
  145. which ignition Jodi?
  146. Zenoah GT-80 Frustration
  147. checking for spark
  148. Crank thread size on 150 3W
  149. Trouble Shooting DLE Ignition Modules
  150. ZDZ 40RE...good engine?.
  151. Byron Sachs upgrade
  152. Older unused carburetors
  153. Mcculloch Eager Beaver 3.4
  154. Brisson 3.2 Carb
  155. 3W 140 in-line twin
  156. Are there any tune pipes for Gas Motors ie:DLE 30?
  157. IGNITIONS FOR GASOLINE ENGINES
  158. Power Curve of a gas motor (DLE 30)
  159. What RPM is idle screw not in effect
  160. Can this be done to my RCATS ignition kill switch
  161. New to Gas - What to do
  162. Height difference with change to CM-6 plug??
  163. Carburetor Problems?
  164. RCG 26 SPINNER
  165. Zenoah G20 Help??
  166. DLE 30 broken bolt in hub
  167. Which gas engine for Lancair120
  168. HELP! Need replacement ingition for G-38 with C&H module
  169. Prop and Spinner Balancing
  170. Spinner Nut/"Heavy Hub" for DLE 20???
  171. What size fuel tank for a DLE30?
  172. Source for engine standoffs?
  173. Fuji-imvac 24EI
  174. What size gas engine for Husky?
  175. Gas engine for a Seagull Nemesis 80" ?...
  176. 30 year old Q35
  177. DA / DL observation
  178. Repairing aluminun parts...ect
  179. zenoah GT80 on H-9 Sukhoi 33% HELP
  180. DA 50 - Periodic Hard Start
  181. SV-26 CC Anyone using this engine?
  182. fuel inlet fitting
  183. Help Please RCGF 65cc
  184. Gasser for a H9 Ultra Stick 120 Lite?
  185. walbra carb rebuild
  186. MVVS ignition problem.
  187. DL50 "wear" problem
  188. DA 50 Question
  189. DLE55 stalling on high G manuver
  190. New to Gas EnginesWhat is the "safest" MFG to go With
  191. Evolution Gas GT vs GX?
  192. Best Fueling System For Gas??
  193. which gas motor to choose
  194. IBEC or Remote Kill Switch or nothing ?
  195. Gasser for a 70 size sport plane?
  196. Cylinder Gasket Thickness
  197. DLE-20 Gas/Oil Ratio ?
  198. G62 90 degree intake
  199. which gas engine do i need
  200. Zenoah GT80 Who stiil does electronic ign.?
  201. Smoke muffler for a Zenoah G-62
  202. A little ignition 101 please?
  203. DLE 30 V1 Black Gummy Exhaust
  204. DLE-30 Fuel Tank Size?
  205. ign switch location?
  206. DLE 55 vs OS GT55
  207. sku gas engine
  208. Do I have a bad ignition?
  209. Southeast R/C Engines is closing it's doors
  210. Ignition Battery Voltage Question
  211. evolution 26gt ignition
  212. Sachs 52 w/ CH ignition found in dark place.
  213. Zenoah GT80 starting help PLEASE!!!
  214. DLE Plastic Wire Loom
  215. 3W problems gone?
  216. Throttle servo glitching
  217. Being taken over
  218. Gas Wannabe
  219. Zenoah GT80-Prop Drilling question
  220. DLE 111
  221. Spark Plug Bushing
  222. Dle 50 to dle 55
  223. OS GT55 Gas Engine Vibration Help!
  224. MDL 35cc Engine Ques.
  225. DLE-30 Spark Plug Torque
  226. DL 50 exhaust bolt holes stripped
  227. DLE-20 Spark Plug Gap ?
  228. Thank you USA!
  229. DLE-20 Spark Plug Cap does not stay on !
  230. DLE 30 engine timing
  231. Battery up front of a gasser
  232. G26
  233. What 3 blade prop for DLE111??
  234. 3W 75i Question
  235. Throttle Response on DLE30
  236. DLE 30 Back firing
  237. FTL26 Replacement Spark Plug
  238. JB Weld to seal a muffler crack?
  239. DLE20 Muffler
  240. 3W Video
  241. DLE111 Needing lot of throttle on startup
  242. Gas to Glow Conversion????
  243. What's the latest on Bill (Bcchi) of CH Ignitionss
  244. DLE 55 Spark Plug Cap Does Not Stay On. Anyone Know What To Do?
  245. CH-Ignitions Jump Start
  246. Gas Engine opinions
  247. DLE-30 Firewall to Prop Dimension?
  248. MLD 70 twin
  249. Powering Gas Ignition?
  250. MLD 35
