PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 [96] 97 98 99
  1. thanks for the useful info
  2. Evaluation Of Webra 1.45 Aero X Rearexhuast
  3. Electronic Engine spark module info
  4. giant engine starters
  5. Huskey Challenger
  6. CH Ignitions
  7. 150 Rpm
  8. ZDZ Prop Shaft size and drill guide
  9. CH Jump Start… How does it work and how is it installed
  10. Mds 2.18????
  11. HELP: need ST 3000 muffler part
  12. Sacks engine question
  13. Lanier 80" cap and G-45
  14. Dubro tank stopper--mine melted
  15. Replacement suggestions for A&M 3.2?
  16. Drilling Props
  17. Swedish made Partner engines
  18. Menz Ultra props
  19. Calling All Motorheads
  20. Horner Repair question for Ralph
  21. Tuned Pipes On Os160fx & Ys 140dz
  22. Summer Sale
  23. What gas engine for H9 cap ?
  24. BME 44 What ratio using synthetic?
  25. quadra 50 rpm?
  26. 3w 24 CARB QUESTION
  27. Zenoah Engines and Amsoil 100:1
  28. S.T.2300... where to get parts.
  29. 70cc engines
  30. ZDZ 80 rough Idle
  31. 40cc Gas in a Cermark Pitts
  32. great planes extra 330l and bme 102 with canisters from rcs
  33. ZDZ 40 Prop test data as promised
  34. New verison of MVVS 1.60 gasser
  35. Brison 4.2 help
  36. saito 180 fuel consumption
  37. Anybody using an RCS engine
  38. 3W 100\40lb. Focke Wulf?
  39. FUGI 86 TWIN wanted input from those that own them
  40. Need a decent fuel filler valve, giant scale
  41. g-38 or us-41
  42. 3W-80 B2 one cyl.dropping out
  43. os 1.60 fx what plugs os8,a5,a3,typef what do u guys run
  44. Prop for Taurus TS72
  45. O.s. Bgx 3500 Question
  46. Home made boxer engine?
  47. Pk Props?
  48. Ch Ignition Problem
  49. torque vs rpm vs horsepower
  50. quadra 42 question
  51. Displacement ST 3000??
  52. ZDZ 40 and biela prop on H9 T-craft
  53. How Hot Does Your Gasser Run?
  54. Byron Corsair, A&M 4.2, Need fuel mix and prop size.
  55. MDS 1.48 carbs/Horizon Service
  56. Spinner for a ST 3000
  57. First Place or YW engines
  58. I got it !
  59. os160 fuel injection how good is it.
  60. Us 41 Velocity Stack
  61. Carb Breather hole?
  62. ZDZ 40 Spark Plug
  63. 26x10 3 Blade prop?
  64. Taurus 2.6 Hub Depth - Tru-Turn Spinner
  65. engine mounting
  66. Reamer for ST 3000 Props
  67. ZDZ 120 B2: Anyone using this twin
  68. Best mufflers for 3W 100
  69. Velocity stack
  70. Muffler for SACHS 5.2
  71. Soft Mount: is it needed for Saito 180 and 150 ?
  72. Boxer motors
  73. BME50 and starting
  74. How often to lube?
  75. Us41 Cc Not Running Right...help!!!!!
  76. Husky 80
  77. 3W Muffler size question
  78. Quadra 42 Case broken for muff bolt. Any fix possible?Help?
  79. Prop for Brison 2.4
  80. Where's Brison ?
  81. Giant Gas Engine Kill Switches
  82. Zenoah Z-445 engine question
  83. engine-plans-project-drawings
  84. Moki 1.80 Throttle arm Nut - What size & thread?
  85. How do I keep this CF prop from spinning?
  86. APC prop for Zenoah G-45
  87. Magneto automatic timing module
  88. Q-42 vs. US 41 - HELP!
  89. Ignition Questions
  90. Trimming DA Mufflers
  91. I have gas also SEE the viper pic... but I still like the big ST's.
  92. Do I go gas or big ST on this stick plane
  93. boat anchor ST.. yea right I put them in all my planes.. look
  94. Inteligent or "stupid" glow drivers?
  95. US Engines....need your feedback
  96. Proper Prop ST 3000
  97. Brison 2.4 mid range
  98. SOLO 61cc
  99. How to start a G45 Engine ?????
  100. glow plug question
  101. semi of the sky!!!!
  102. What's a SuperTigre G-4500 good for?
  103. us engine no spark
  104. Brison 5.8 HELP!!!
  105. Breaking in new MVVS 1.6 gasser?
  106. ZDZ 60 muffler size
  107. electronic advance vs mechanical advance?
  108. Patrick Power
  109. Life of a gasser?
  110. 21cc gasser
  111. Engine prices
  112. throttle cable where to get ?
  113. Tecumseh engines
  114. Customer service at Cactus Aviation
  115. Is it broken in yet?
  116. Carb adjust - ZDZ 40
  117. Ryobi 31cc question
  118. G38- Okay,i Give Up !!!
  119. 3-bladed Prop suggestion, ZDZ80
  120. Fuji BT86 twin...problems starting with spring starter?
  121. Scale/Static Props
  122. Mounting Servo on engine box
  123. question for Flipflop 33cc homelite conversion
  124. US41 Muffler
  125. Trd ??????
  126. ZDZ 40 Tank Size
  127. G23 bolt on hop ups
  128. ZDZ 80 Muffler
  129. Fuji BT-50S-A gasser
  130. 3W 24i silencer
  131. Engine Kill Switches???
  132. Smoke System on Saito 182TD?
  133. all new 3W 100
  134. ZDZ 40 NEW--- Pits in cyl wall
  135. Brison 3.2 Which Prop?
  136. Opti-2 Oil. Has anyone had any experience with it?
  137. moki 2.1 prop size??
  138. C.H. syncro spark?
  139. Is a NIMH Battery fine for my 3W Ignition ?
  140. Best gasser
  141. Sears Weed Wacker Engine
  142. Mac Minarelli 70cc Twin?
  143. Zdz 80
  144. Modified US41
  145. ZDZ 40 RE Muffler
  146. Mods for converting H9 Edge 540 to gasser (BME 44?)
  147. Ultimate Combo with DA-50
  148. Redline Oil: What do you think?
  149. "Tiny bubbles in my fuel lines"
  150. Us 41
  151. How do you measure thrust
  152. Fox engines!!
  153. G38 Muffler
  154. Oil question for BME50....
  155. Smaller prop than recommended
  156. Need Advice on Horner 4ci Twin
  157. Anyone converted Poulan 46cc?
  158. zenoah g38 problems
  159. Fuel tank question re Zenoah G38
  160. Fuel tube/fittings size for Zenoah G38?
  161. Horner 4 ci Twin
  162. ZDZ 80 Single, prop #'s and noise
  163. Fuji BT86- Share Info......
  164. how can I tell what Brison I have?
  165. Saito 1.80 Starts Backwards
  166. ZDZ80 twin just died, Help please.
  167. D/A 100 breakin procedure
  168. Opions on Klotz R50 Syn Oil
  169. Shorter spark plugs to fit in cowl???
  170. I think I've finally made up my mind......3W24
  171. Best Prop for 300 twin 4 stroke
  172. rcs 1.40?
  173. ZDZ40 what rpms are you guys getting ?
  174. G 62
  175. Questions re ignitions on gas engines
  176. Super Tigre 3000 Non "K" Carb
  177. Just thinking about one of these
  178. Spark Plug for ZDZ80
  179. MVVS 1.44 Twin in H9 Cap
  180. My prop don't work
  181. Steel Cable throttle linkage, taboo on gasser?
  182. Quadra 42 Stalling
  183. Zenoah G-45
  184. Tartin Twin 50
  185. Taurus,Taurus,Taurus...PART II....
  186. Saito 1.50 with Perry pump.
  187. Z38 Mystery Mod.
  188. Bme 3.2
  189. first time gasoline engine user
  190. Radio Glitches at Full Throttle
  191. G38 noise at TDC
  192. Precision Eagle 4.2
  193. FourStar120...G-38
  194. Ryobi tuning
  195. 3W 42 - what will it drive
  196. flip starting a g23
  197. does anyone have a good smoke recipe???
  198. Ryobi repair
  199. Tach suggestions
  200. Rcs 140
  201. another question for RCIGN
  202. What RPM should I expect out of a 3w-78 Twin
  203. Just Fired Up The Tarten Twin!
  204. prefered engine kill ? ? ?
  205. Setting Ignition Timing SyncrSpark Quad
  206. setting the time on Q52
  207. US-41 Muffler
  208. What Ignition Battery for my 3W ?
  209. BME 44 and 50 carb mounting
  210. Gas for Beginners!
  211. MVVS 1.60 Gas and DP Ultimate
  212. Thin Muffler?????
  213. ZDZ 40 gas consumption
  214. OS BGX 3500 Questions
  215. Saito 450R3 Fuel Consumption
  216. Brison 6.4 owners
  217. Fuji Engines?Anybody seen one run?
  218. Name that engine!
  219. Can't kill RCS 1.4 with throttle??
  220. help: gas or glow
  221. Best prop for 3W-70 ?
  222. Need help, Mejzlik prop wont fit in alum. spinner
  223. Cowl baffles for Zenoah GT-80
  224. BME 44 Carb Number,Walbro carbs
  225. Mac Minarelli Engines, any info
  226. Tartan Twin 77 questions
  227. Carrs Website for gas conversion???
  228. Spring Starter Problems
  229. What's the best way to start a 3w-twin?
  230. G74 lack of revs
  231. Where do you get "R" sparkplugs.
  232. Question for RCIGN
  233. Carbon Fiber Props
  234. 5.8 issues
  235. What do you use for fuel line anchors?
  236. What size threads on the shaft?
  237. Ops 30 Maxi
  238. CAN I GET SOME HELP HERE? Mw Cap 232 What Engine?
  239. Homelite Piston Rings?
  240. Onboard Starter
  241. G 38 Prop?
  242. Will Muffler for Sachs fit Brison?
  243. RF noise new 3W-75
  244. US 41 CH Ignition upgrade
  245. Kavan 50 Twin (anyone know history of them)
  246. Brison Service
  247. G62
  248. Props by Roger
  249. Bme 102 Help
  250. Brison 4.2
