View Full Version : Gas Engines
- so whats the smallest gas engine now?
- FPE 2.4 prop
- MOVED: Homelite 45cc & Walbro HDB-6B
- 52 cc tuning pros!!!
- Is this possible?? G--62 9000 rpm?
- New To RC's
- MOVED: What to do with this?
- Need Help : H9 Ultra Stick 60 + BME G.90
- Evolution 26GT VS BCME SPE 26
- What size scale warbird for Quadra 35?
- Anyone running the new Zenoah G20EI?
- Brison 3.2 fuel consumption?
- bcma spe26
- Crank work G-62
- 3W106 Running Rich Inverted
- gas vs. nitro
- Is anyone here familiar with the New Zenoah's G20ei engine with electronic ignition?
- Zenoah G20EI
- Byron Originals Mustang 50
- 3W50i - Getting the most out of it
- New gas owner needs some help.
- McCollough or ????????? Can anyone identify?
- KIORITZ GP-21 ???? Can you identify!
- Low tank, High Carb
- Sound levels - 100cc DA 3w cans no
- Question for Ralph, or anyone who knows.
- 3W106 BLUES FINALLY FIXED
- Is there an Evolution .61 gas engine
- Gasser for 1/3 scale Dr.1
- GT80 by RCIGN
- Propeller washer - BT-43EIS w/10mm spinner bolt
- glow fuel pump for gas?
- (HELP) Zenoah G-38 Carb
- What is up With Brison Aircraft now ?
- Field Gas Can & pump setup?
- which engine to use
- Center Mark Engines
- Throttle curve Futaba 8U
- us engine,gas
- Evolution 45GX
- Brushless starter for Vario gas
- Odd behavior with DA-50
- Roto 70 V2 Questions
- Idle adjustment for fuji 64 EI
- DA 50 QUESTIONS & ANSWERS
- Where can I buy U.S Engines?
- Brison 2.4 Spark Plug
- MVVS 58 Where to buy?
- pcm vs standard FM
- Throttle response question - 3W 106
- why do rings stick with Amsoil 64:1?
- Help with throttle hook up
- zdz 60rv or 3w60 any suggestions
- Fuel tubing size - what size do I use?
- How big
- DA100 in-cowl muffler options
- DA-50 All-Up Weight?
- 3w 42 on hanger 9 cap 232
- DA 100 Low Throttle Power Sag
- Piston to Cylinder Clearance
- G26
- velocity stack
- what motor for Goldberg Pitts Model 12
- G-26 idle problem
- G23 Walbro
- DA-50R new side mount muffler
- Large prop advice
- Fuji 50 SA Electric start Video Clip
- MVVS Engines Where to Buy?
- What sealant to use on leaking 3W carb blocks
- 3W-80xi and ZDZ 80super
- engine suggestion NEW 3w 55i US?
- moved thread ?
- THOR 45
- gas engines and composite pipe
- Six Bolt to Single Bolt Adapter for Sachs-Dolmar
- Marvel Mystery Oil used--???
- Online Sources for Big Props
- wierdness 3W 75US
- Where do you buy your Amsoil?
- tuning gas motors
- DA-50R Carb kit needed,,,Where?
- Evolution Propellers???
- Quadra 42 for Giant Super Sportster
- Zenoa G26 Noise
- 4-stroke gassers
- DA 50r Problem!!!
- 5 gallons... why?
- Here the initial rpm nos/pics on Zenoah G20EI
- Da 50 Loading up
- "Hard Solder" for Aluminium
- Gas Engine 1/4 Scale Dilemma
- What Plane for the Zen. G-38
- zdz60 and 50
- what plane did you put your Evolution-26-gt in
- Props For 106CS?
- Prop for 3W 80
- I want to know more.
- Quick math check
- Which engine ZDZ80rv or ZDZ100 B2
- Adjusting the high speed needle when....
- chip hyde's vision and zdz50
- Static thrust of Da 50
- G26 and kill switch
- Brillelli review
- MOVED: 25 to 30 cc engines will they fly a plane
- Smoke residue on white covering how to…
- Help setting up G45
- does changing oil mix change tune on DA-50?
- Smoke Muff for Fuji 50 EI
- advice on a engine
- BME44 & BME50, do they use the same stock muffler?
- Carb Stack Question
- Zenoah 62 wont go!!!!! HELP!!!!!
- Hanger 9 Edge 540 "S"ZDZ80 Chief Mount
- ZDZ80 and three blade prop?
- BME email address
- MOVED: why does every 1 hate xbgs?
- Exhaust Insulation
- Car stops at half tank
- Mystery Gas Engine (Can you ID it?)
- mvvs
- DA 50-R
- What's up with Brison??
- DA 50 with smoke
- evolution 26gt
- Ahhh! Where can I buy a spark plug???
- 3W Synthetic Oil
- Spark Plugs, how do you clean them?
- Fuji Imvac BT-32B 32cc for The New Giant Super sportster????
- gasahol maybe?
- Erratic BT 64
- no gas evolution g 26
- DA-100 Low Needle (Forbidden question)
- Tartan (Twin 77)
- No thermometer ? ? ?
- DA50 Popping
- how do you know when the ignition is on?
- Another Scammer!
- Maloney 100
- Fuji 50 BT help
- can anyone id this engine?
- Fuel tubing between cylinder head why?
- plane set up
- MOVED: engine conversion
- DA50 has a very noticeable throttle delay
- Zenoah G45 woes
- Zenoah G20
- Fugi Imavc 32 EI Interference
- Choosing engine
- How close can RX component get to Magneto before problems?
- Anyone running the new Evolution 58 GT?
- DA50 Troubles - Help!
- RCS-75R gas engine
- ZDZ 160 carbon deposit
- looking for a muffler for Evolution 26
- DA-100 Specs.Anyone?
- Ethanol/rpm increase
- gas engines and PCM vs PPM
- zdz80rv sparkplug wrench size.
- BME 110 owners
- US Engine and Qudra w/electronic ignition
- Fuel Tank Fuel Tube Positioning!
- Muffler for a 2.4 First Place Gas Engine
- Tuned pipe for Zenoah 62
- DA150 Bolt Size?
- DA 100 Dimensions??
- magneto problem?
- RCIGN1s Carb adapter
- taurus 52 mufflers
- Is Epoxy Gasoline Proof?
- Zenoah ZG-62 shaft run out
- Wanted, Radial.
- Ignition problems with ZDZ 40
- Home build cannister for MVVS 116
- CRRCPROGF45I Gas engine
- CG Chipmunk - O.S. 91 surpass motor mount
- DA50 Problem
- Removing plugs on a ZDZ
- Gas engine vibrations and throttle servos
- Engine for my Sukhoi 26?
- BME G90 vs Zenoah G20
- ZDZ80 or DA100 HANGER 9 EDGE?
- ZDZ 80 super / center bolt question??
- E85
- 3w 56 twin for 1/3 scale cub?
- Alcohol in Gasoline
- Gas engine mess during breaking in, is this excessive?
- Fuji Imvac EIS 64 sensor problem
- Which Heavy Duty Starter ?????
- Circlips
- how to repair pull starter
- Fuel Pump Suggestion
- Brison 3.2 Change to AutoAdvance
- Brison 3.2 weight
- Greve tuned pipe
- DA 50 and clicking noise..??
- ZDZ Super 80.....EVO 80....weights
- 3W 80 needles
- EVO 150....EVO 80
- Carb inside carb?
- Should I replace carb?
- New ZDZ40RE - Run out of ideas, help if you can !!
- experience with ZDZ 40 BS
- Missing Posts
- G62 Ultra Lite
- BME110 owners
- 3w 50i help
- 3w 80xi rpms?
- us engines 41cc
- Kill Switches
- mvvs 160.mismatch between header and engine
- G45 troubleshooting-- needle adjustments out of whack after storage
- fuel filter question
- no fuel going through fuel lines?!?!
- Brillelli 25GT on a CMP Giles-202
- EVO 58 mixture screws
- 50cc Props
- Thrust to weight ratio ???
- bt-86 hop ups?
- electronic ignition vs Vlach ignition
- DA 100 muffler mounting?
- BCMA-SPE26 engine owners,suggestions?
- Electrodynamics Fiber Optic Kill
- When very hot, engine misses - 3W
- Is Gas Cleaner?
- weight of the fuji 43
- Ethanol/gasoline??
- Which aerobatic plane for Zenoah G-26
- Beginner size ?
- G26 RPM
- G38 engine mount
- Is my engine rich
- Measuring thrust – How?
- Kill switch on eis
- walbro - the mith...
- ZDZ 50
- how about the 3W 28 ????
- Zenoah G62 misses at high idle
- 3W-106 prop bolts sheared again!!!!
- Guys,How much air for cooling twins w/can's
- First Gasser
- A gas engine and a U Can Do 60?
- Gas mix 6 months old?
- head/cylinder temps
- mounting prop question 1,2, 3 O'clock rock
- magnet for timing in a gas engine?
- First run DA50
- Dave Brown spinner on G45..h e l p
- G 26 won't start
