PDA
View Full Version : Gas Engines
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99
  1. Need a purchase opinion on the RCS SV26
  2. DL 100 Help Needed
  3. Brison 50cc
  4. 40cc rear carb
  5. Saito FG-20
  6. Help finding a G62
  7. dl 50 mounting on a 77in goldberg yak
  8. 1 ring VS 2 ring engines
  9. brillelli engines
  10. Twin ignition GURUs
  11. Fromeco Wolverine help!
  12. cannister question
  13. need info on RCS-SV17 eng
  14. rcs215
  15. What size is my 3W engine?
  16. 20cc gasser engine choices? Help
  17. Smoke connection to 50cc gas engine
  18. Sachs engines
  19. Ralph Cunningham..?
  20. Quadra 75 settings
  21. Sachs 4.2
  22. Oil and gas...
  23. DL-50 Engine Temp
  24. Please help with part info for Brillelli engine
  25. Largest single cylinder engines
  26. prop/reduction drive calculation
  27. Gas Engine for 1/4 Scale Balsa USA J-3 Cub
  28. Which 20cc ???
  29. BEST VESS FOR A BME 105?
  30. Cheap 54-50cc
  31. SV-26 carb problems
  32. Zenoah G-62 spark plug and ignition
  33. 26cc gasser trouble
  34. RSC / Moki 150 information
  35. Saito 125 glow or Saito 20cc gas?
  36. Is this normal on DA-85?
  37. battery for 26cc engine
  38. G-38 Slow acceleration
  39. DA50 or Rev 52?
  40. Da 50 starting trouble
  41. MOVED: 40la
  42. DA50I
  43. G62 Tank Size?
  44. Zenoah G-26Ei
  45. MT 42
  46. Changing to a more efficient ignition on the Zenoah G20
  47. FPE 52cc
  48. Wanting to fly gas instead of glow for my 1/6 scale planes...
  49. Aerovate 50cc twin
  50. Reed valve or Rotary valve ?
  51. NEED 10mm 1.5 thread spin adpter??????
  52. zdz 80 ignition
  53. Zenoah G 23?
  54. MVVS 58 Prosport- Evolution 58 GX
  55. Ralph Cunningham ingition
  56. Moki 250 engine - were to buy
  57. G-62 weight savings ?
  58. G62 Spring Starter Binding
  59. .20 or .36 Saito Gas or 1.50 Glow????????
  60. Getting back in,, throttle linkage ??
  61. BME 140 Engone???
  62. Spring Starter on G38
  63. Precision Eagle 4.2 w/TOC Mods
  64. Prop suggestion for DL50?
  65. NEED GAS ENGINE FOR SIG EXTRA 300 1.2
  66. Where to buy Lawnboy oil?
  67. newby to gassers
  68. help picking a new engine in 25cc range.
  69. BME 110/116
  70. CRRC tuning questions
  71. BEST PROP FOR 50cc
  72. Can you identify this 26 cc gas for me?
  73. Broke one ring..but engine still runs good
  74. taurus 52 muffler
  75. Zenoah G20 Throttle Hookup(How To)
  76. Rear dump Pitts muffler for G20?
  77. Sachs 4.2 engine
  78. DL 50cc/Aeroworks
  79. crrc pro26 quitting
  80. Stupid Zenoah G20 question.
  81. HELP, need plans
  82. 3W80 With MTW-TD 110?
  83. walbro carb numbering
  84. Engine for Comp-Arf Extra300L 2.3m
  85. Hub dimension on a Zinger 18x6
  86. G62 carb question
  87. Which Engine Would You Use
  88. DA 50 engine in 35cc - 45cc 78" kit?
  89. Dl50 H9 extra 260 throttle/choke set-up
  90. Threaded inserts for mounting Engine??
  91. Look What I found!
  92. Glow to Gas...
  93. Zenoah G45 Won't Idle
  94. Pitts mufler maker?
  95. zenoah 26EI
  96. Super Tech Universal 2 cycle oil for air cooled same as Pennzoil air cooled???
  97. mystery engine
  98. AMSOIL RECOMMENDATION CHART
  99. stinger with g-38
  100. DA-85 stand off's?
  101. slight click at bottom dead center
  102. AMSOIL not recommended for RC Use
  103. DA-150 spare parts needed!
  104. Brillelli 46 with Vess 22A prop?
  105. is there a low voltage spark plug?
  106. G62 throttle connection HELP
  107. RCS SV 26, Peak 26, HH26H, GRPro 26
  108. How do you stop fuel starvation on long down lines?
  109. Needle valve setting
  110. ZDZ 40 or Evolution 40GX!
  111. Gas Engine Kit?
  112. Drill Guide for old-style G38 prop hub
  113. G62 Carb elbow
  114. Running temps of gas v. glow
  115. is there a tiny 3oz ignition with Tx controlled advance and mounting tabs
  116. Venom 45cc parts
  117. B&B Speciailties muffler on Zenoah G20 EI?
  118. ENGINE OFFSET ??
  119. MOVED: ryopi 31cc converted
  120. g-38 conversion
  121. Zenoah backfires
  122. Who sells 1/4-32 spark plugs?
  123. MOVED: Moki 210
  124. Inverted pitts muffler for MLD-28?
  125. G-62 Spring Starter Slipping
  126. Prop mounting pattern
  127. G-62 props and starters
  128. Dang!!!
  129. Zenoah 45 linkage
  130. Evolution 58GX2
  131. Questions about selling an engine
  132. DA-50 carb
  133. MOVED: Ryobi flying upside down
  134. Open or shielded bearings for a DA 85???
  135. MOVED: What kind??
  136. Any engines smaller than 20cc (1.2)?
  137. Gas/Petrol newbie questions
  138. 28.5cc and WYK-194
  139. Dave Brown 5" spinner on a DL 50
  140. Magnum XL61 ringed - how to insert
  141. A123 batteries??
  142. G20 in a Hangar 9 Corsair
  143. Zenoah G-20ei
  144. On board starter system anyone?
  145. DL50 Standoffs
  146. DL-50, XYZ-50HP VS. DA, ZDZ AND 3-W ENGINES
  147. Rcexl Spark Plug Boot - Does it go over the Hex flats?
  148. where to buy "banjo" muffler 3W60
  149. New 3W 110iB2 inline
  150. Byro-drive with Quadra 35
  151. weedie ultralight 21cc vibration problem
  152. 3W-80ix CS Quits on Taxi & Low Octane Gas??
  153. one carb or two
  154. Pennzoil Users Only
  155. super sportster & xyz
  156. DL50 carb
  157. Aerovate 26cc from Kondor models
  158. MOVED: Tuning specs
  159. DL50 Muffler gasket question
  160. Zenoah gt80 needle settings...
  161. DL50 problem (might be the user!!)
  162. Need help with carb ID for 3w60
  163. Fuji 43-EI interference with Spektrum 2.4Ghz
  164. DA-50R flameout
  165. G-38 Throttle Spring
  166. NGK CM6 Similar but Diferent???
  167. RCEXl Ign on DL50
  168. By The Numbers...
  169. Six bolt prop on single bolt hub
  170. New CRRC Pro GP50R prototype 50cc
  171. Premium Gasoline in a DA-50
  172. brillelli 46 spark plug question
  173. RXcell Question
  174. XYZ 26 Engine
  175. Zenoah 20 ei keeps quitting in flight at idle
  176. Walbro carb numbering system
  177. RCS SV 26 in a Goldberg Ultimate
  178. We put a DA 150 into hangar 9 35% extra
  179. ?? Walbro HDA 77b
  180. Throttle noise
  181. G23 to EI
  182. ZDZ 80RV BEST PROP???
  183. two props on a single shaft
  184. Brillelli 46 question
  185. Pennzoil 2-cycle Air-Cooled oil
  186. Saito FG-20 or 21
  187. MOVED: Mount 4 stroke upside down
  188. E-85 anyone?
  189. Could you describe the symptoms of carbonization?
  190. engines
  191. Engine Repair Company
  192. SEARCH FOR SUPERMANII
  193. g20 carb kit #
  194. MT-62
  195. Three needle carb.
  196. Aerovate EnginesAnyone?
  197. I need some canister education
  198. Y.G.B.S.M.
  199. FPE 2.4 with a 4 blade prop
  200. muffler for CRRC 26cc
  201. Small cracks found in prop under LED light ???
  202. rear carb.
  203. Sig 4* 120
  204. Manufacturers cost?
  205. Filter For Vent Line
  206. Warm up your engine before tuning but .... ?
  207. Need advise on a propeller
  208. NGK CM6 Where the @#$ & to buy?
  209. Crankcase Goo
  210. SPE 26cc
  211. ?? How to remove the plug???
  212. ?? How to remove the plug???
  213. Prop problem on 3W 106 and 157
  214. MOVED: Weedie motor
  215. Evolution 58gx2
  216. TMM-106 twin is now in production
  217. Replacement Walbro Carb source
  218. Muffler Placement to Cooling Fins
  219. DA 50 maintenance
  220. Dubro belt reduction drive. Durable? Power comparison?
  221. AVGAS... Anyone with experience???
  222. throttle linkage
  223. Does anyone know this engine? Eagerbeaver 200A Mcculloch
  224. Help with Poulan 42cc
  225. fuel burn rate/tank size for DA 50
  226. Which 80-85cc engine
  227. 50cc fuji electronic ig engine
  228. CRRC-Pro 26i
  229. Twin or single
  230. Area 51 or DL-50?
  231. have you seen this little baby,,
  232. SY Props where can I find them?
  233. 2 attractive 26 cc engines, but which one ?
  234. zdz100 kinda too quiet
  235. zdz 40rv fuel tubing
  236. DA-50 Carby
  237. are ignitions for ftl and dl engines interchangable?
  238. Propeller Pitch
  239. MT 57
  240. CRRC 26pro & 3 Bladed prop?
  241. STOLEN ENGINE & Truck
  242. what is a good size prop for a DL50?
  243. Quadra 75?...need prop hub
  244. DA-50 will not go to full throttle????
  245. Zenoah G20 Dead sticks
  246. stumped by Zenoah G38
  247. Testing a Magneto system ?
  248. Identify this gas engine
  249. Will not idle at end of flite
  250. Zenoah G-26 Newbie.
