updated as of 1/21/07
stats:
3 channels, A, B, C - 27mhz
130mah lipo
45mm counter rotating props
motors:
thrust 8-10g
5.3 ohm 6mm coreless
390mA draw per motor
6-10 ohm motors possible replacement
weight:
stock weight:
biplane 19.68g - monoplane 17.02g
breakdown:
receiver including antenna but w/o charging socket and switch 1.35 grams.
Motor with leads and prop weighs 1.83 grams
Cell weighs 3.8 grams
Fuselage pod 1.4 grams
Wing 3.42 grams
Stab/rudder 0.71 grams
Tailboom assy 1.8 grams
Motor mounts 0.42 grams
replacement parts:
lipo - 130mah-225mah range
motors - 4.5ohm-10ohm
foam - meat trays, insulating foam, foam dinner plates
props - Aero-X
upgrade/mod sites:
AA Toolbox -
http://aatoolbox.no-ip.org/
AA RX parts -
http://www.falcon1.net/~ars/rcmodels.html
Australia vendor -
http://www.eagle-hobbies.com
AA group:
http://www.rcuniverse.com/forum/m_4540834/tm.htm
TX battery options:
2300mah Nimh rechargeables
electronic mods
RX wiring diagram:
post #1451
http://www.rcuniverse.com/forum/m_33...59/key_/tm.htm
post #1603
http://www.rcuniverse.com/forum/m_33...65/key_/tm.htm
post #3192
http://www.rcuniverse.com/forum/m_33...28/key_/tm.htm
channel changing:
post #432
http://www.rcuniverse.com/forum/m_33...18/key_/tm.htm
post # 3558:
http://www.rcuniverse.com/forum/m_33...43/key_/tm.htm
extending antenna:
post #450
post # 520
http://www.rcuniverse.com/forum/m_33...21/key_/tm.htm
LEDs:
post #26
http://www.rcuniverse.com/forum/m_33..._2/key_/tm.htm
post #106
http://www.rcuniverse.com/forum/m_33..._5/key_/tm.htm
post #3136
http://www.rcuniverse.com/forum/m_33...26/key_/tm.htm
post #3196
post #3684
http://www.rcuniverse.com/forum/m_33...48/key_/tm.htm
post #3940
http://www.rcuniverse.com/forum/m_33...58/key_/tm.htm
post #3975
turn without throttle:
post #190
http://www.rcuniverse.com/forum/m_33..._8/key_/tm.htm
post #391
http://www.rcuniverse.com/forum/m_33...16/key_/tm.htm
post #3558
adding lipo connectors:
post #421
http://www.rcuniverse.com/forum/m_33...17/key_/tm.htm
lipo info:
post #2462
http://www.rcuniverse.com/forum/m_33...99/key_/tm.htm
solar power:
post #3202
http://www.rcuniverse.com/forum/m_33...29/key_/tm.htm
airframe mods:
wing extentions:
post #26,#35
post #419, #424
post #1689
http://www.rcuniverse.com/forum/m_33...68/key_/tm.htm
post #2878, 2884
easy motor adjustment:
post #1463, #1466
post #2412
http://www.rcuniverse.com/forum/m_33...97/key_/tm.htm
moving the lipo/CG:
post #473, #475
http://www.rcuniverse.com/forum/m_33...19/key_/tm.htm
post #1371
http://www.rcuniverse.com/forum/m_33...55/key_/tm.htm
canard winglets:
post #1014
http://www.rcuniverse.com/forum/m_33...41/key_/tm.htm
post #1067
post #1234
http://www.rcuniverse.com/forum/m_33...50/key_/tm.htm
post #2674
http://www.rcuniverse.com/forum/m_33...07/key_/tm.htm
post #2679
http://www.rcuniverse.com/forum/m_33...08/key_/tm.htm
post #3088, 3099
http://www.rcuniverse.com/forum/m_33...24/key_/tm.htm
no fuselage:
post #2900
mid wing AA:
post #1091
http://www.rcuniverse.com/forum/m_33...44/key_/tm.htm
clipped lower wing:
post #1828
http://www.rcuniverse.com/forum/m_33...74/key_/tm.htm
post #2163
http://www.rcuniverse.com/forum/m_33...87/key_/tm.htm
post #2886
AA Triplane:
post #395
post #1119, #1120
http://www.rcuniverse.com/forum/m_33...45/key_/tm.htm
replacement tail feathers:
post #121
W wing mod:
post #2038
http://www.rcuniverse.com/forum/m_33...82/key_/tm.htm
post #2078, #2079
http://www.rcuniverse.com/forum/m_33...84/key_/tm.htm
landing gear:
post #79, #86
http://www.rcuniverse.com/forum/m_33..._4/key_/tm.htm
post #299
http://www.rcuniverse.com/forum/m_33...12/key_/tm.htm
post #339
http://www.rcuniverse.com/forum/m_33...14/key_/tm.htm
post #804
http://www.rcuniverse.com/forum/m_33...33/key_/tm.htm
post #841, #844
http://www.rcuniverse.com/forum/m_33...34/key_/tm.htm
post #1134
http://www.rcuniverse.com/forum/m_33...46/key_/tm.htm
post #1321, #1325
http://www.rcuniverse.com/forum/m_33...53/key_/tm.htm
post #1336
http://www.rcuniverse.com/forum/m_33...54/key_/tm.htm
post #1708
http://www.rcuniverse.com/forum/m_33...69/key_/tm.htm
post #2871
http://www.rcuniverse.com/forum/m_33...15/key_/tm.htm
post #2996
http://www.rcuniverse.com/forum/m_33...20/key_/tm.htm
post #3136
post #3202
post #3559, 3563
pontoons:
post #2217
http://www.rcuniverse.com/forum/m_33...89/key_/tm.htm
post #2242, #2234
http://www.rcuniverse.com/forum/m_33...90/key_/tm.htm
AA single wing with AA Jet parts:
post #2670
http://www.rcuniverse.com/forum/m_33...7/key_/tm.htma
ribbon mod:
post # 3396
http://www.rcuniverse.com/forum/m_33...36/key_/tm.htm
lightweight AA:
post #3494
http://www.rcuniverse.com/forum/m_33...40/key_/tm.htm
pico-38:
post #2782
shorter tail boom:
post #2695, 2698
toothpic/stir stick mod:
post #2886
post #2940
post #2894
post #3048
http://www.rcuniverse.com/forum/m_33...22/key_/tm.htm
post #3240
http://www.rcuniverse.com/forum/m_33...30/key_/tm.htm
post #3515
post #3723
http://www.rcuniverse.com/forum/m_33...49/key_/tm.htm
round wings:
post #3809
VARIOUS:
prop puller:
post #864
http://www.rcuniverse.com/forum/m_33...35/key_/tm.htm
post #4035
http://www.rcuniverse.com/forum/m_33...62/key_/tm.htm
removing throttle spring:
post #496
post #3002
interior pics:
post #1357, #1369, #1370
post #1648
http://www.rcuniverse.com/forum/m_33...66/key_/tm.htm
post #2744
http://www.rcuniverse.com/forum/m_33...10/key_/tm.htm
changing motors/props from pusher to puller:
post #129
http://www.rcuniverse.com/forum/m_33..._6/key_/tm.htm
coin mod:
post #561
http://www.rcuniverse.com/forum/m_33...23/key_/tm.htm
CG locator:
post #2381
http://www.rcuniverse.com/forum/m_33...96/key_/tm.htm
post #2727
easy trim knob adjustment:
post #3492
DIY AA powered planes:
various AA powered planes and plans:
http://www.rcuniverse.com/forum/m_3773941/tm.htm
build your own AA powered plane:
http://www.rcuniverse.com/forum/m_4401704/tm.htm
white wings paper plane conversions:
http://www.rcuniverse.com/forum/m_4549324/tm.htm
AA gallery (please post your creations too!):
http://www.rcuniverse.com/forum/m_5244036/tm.htm
AA slow flyer thread:
http://www.rcuniverse.com/forum/m_4447072/tm.htm
6" AA Cube:
http://www.rcuniverse.com/forum/m_4535280/tm.htm
post #103
post #258
http://www.rcuniverse.com/forum/m_33...11/key_/tm.htm
post #287
post #611
http://www.rcuniverse.com/forum/m_33...25/key_/tm.htm
post #627
post #671
http://www.rcuniverse.com/forum/m_33...27/key_/tm.htm
post #831
post #856, #859, #860, 863, 866
post #979
post #1011
post #1093
post #1118
post #1140
post #1284
http://www.rcuniverse.com/forum/m_33...52/key_/tm.htm
post #1475
post #1672
http://www.rcuniverse.com/forum/m_33...67/key_/tm.htm
post #2240
post #2401, #2414, #2415
post #2432
http://www.rcuniverse.com/forum/m_33...98/key_/tm.htm
post #2493
http://www.rcuniverse.com/forum/m_33...00/key_/tm.htm
post #2516, 2519
http://www.rcuniverse.com/forum/m_33...01/key_/tm.htm
post #2549
http://www.rcuniverse.com/forum/m_33...02/key_/tm.htm
post #2552
http://www.rcuniverse.com/forum/m_33...03/key_/tm.htm
post #2561
post #2568
post #2647, 2649
http://www.rcuniverse.com/forum/m_33...06/key_/tm.htm
post #2663, 2664, 2666
post #2771, 2773
post #2898
post #2977, 2982
post #3042
post #3070
post #3109
post #3197, 3198
post #3215
post #3226
post #3318
post #3333
post #3371
post #3389
post #3564, 3570
post #3579
post #3629
post #3688
post #3711
-post #3732, 3746
post #3751, 3771, 3772
http://www.rcuniverse.com/forum/m_33...51/key_/tm.htm
post #3778, 3780, 3796, 3798
post #3836, 3839
post #3854, 3870
post #3894
http://www.rcuniverse.com/forum/m_33...56/key_/tm.htm
post #3952, 3960
post #3984, 3998
http://www.rcuniverse.com/forum/m_33...60/key_/tm.htm
post #4002
http://www.rcuniverse.com/forum/m_33...61/key_/tm.htm
post #4067
http://www.rcuniverse.com/forum/m_33...63/key_/tm.htm
other AA powered craft:
airboat:
http://www.rcuniverse.com/forum/m_4334711/tm.htm
http://www.rcuniverse.com/forum/m_4232934/tm.htm
hovercraft:
post #2236
quad mod:
http://www.rcuniverse.com/forum/m_3968433/tm.htm
post #2298
http://www.rcuniverse.com/forum/m_33...92/key_/tm.htm
post #3107
single motor + actuator
post #615
post #2414
3 channel AA
post # 1895
http://www.rcuniverse.com/forum/m_33...76/key_/tm.htm
AA powered Tank:
http://www.rcuniverse.com/forum/m_4367803/tm.htm
updated 1/21/07
nick
