PDA
View Full Version : Engine Conversions
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. Brillelli customs? Marks site
  2. how to attach a magnet to a Webra Prop Hub?
  3. Echo 16cc Gas/Glow
  4. Which Spark Plug for Nitro to Gas Conversion?
  5. carburetors for a Home Light 25cc
  6. New Be needs help tuning or trouble shooting
  7. Walbro Diaphrams
  8. Your Tecumseh 98cc conversions?
  9. My second conversion coming to life!
  10. Converting a 60 glow to gas (with glow plug)
  11. Problems when inverted
  12. Tecumseh TC200 / TC300
  13. Weedeater XT 250 broken bearing
  14. Ignition timing.
  15. Rare saws at my local saw shop
  16. New Electronic fuel mix
  17. WHAT ENGINE IS THIS??
  18. asp 108 glow 2 stroke engine to petrol
  19. Small air-cooled engine repair manual
  20. prop hub for cy engine
  21. Tanaka 21cc conversion ?
  22. Nitrous Oxide for a gas engine?
  23. Ryobi will not idle
  24. conversion motors in the buy and sell area
  25. Carr Precision still trading?
  26. Would a Tuned Pipe work for a Conversion 33cc?
  27. CDI conversion for GX 25
  28. Honda GX25 - Self tapping screws?
  29. zenoah dies when inverted
  30. Conversion parts
  31. 25cc mtd
  32. Custom Cox Engine Concern
  33. MOKI 210
  34. Homelite 25cc electronic ignition conversion question.
  35. 2.4 Ghz interference!!
  36. Different fuel pumps available
  37. where to get parts to convert a weeddy
  38. Little Zenoah grey coil??
  39. another conversion thread. just interested
  40. 10th scale buggy big block conversion!
  41. Looking for Stihl mechanic or dealer....
  42. Super Tigre G2300 CDI IGN timing with (glow fuel mix w/o nitro)
  43. Aluminum Bottle Muffler (Pics)
  44. Help with exhaust for a 33cc Mitsubishi.
  45. Help OS GT 33 installing clean in GP 27% Edge 540
  46. Walbro carby hack to make fuel pump
  47. Strange fuel problems...
  48. husqvarna 61 conversion
  49. Kavan MKI to gas
  50. "Hot Rod" Homelite 30cc
  51. Ryobi gas to glow?
  52. Can't recall, any conversion motors that are same as G38 ?
  53. OS 200 engine Mount
  54. RYOBI 31cc flywheel question
  55. Carb dripping fuel when inverted - help
  56. Muffler idea, picture added
  57. Ryobi 31 carb mismatch
  58. Saito 120 prop hub campatability
  59. Antique gasser with modern ignition?
  60. Toro with 15x6 prop @ 8,700 RPM
  61. 31cc Atom Motor
  62. pioneer p-51 engine
  63. four strokes carb systems
  64. 4 stroke conversion.
  65. My New Gasser With Toro 25cc (Pics)
  66. Hovering with 30cc conversion (Video)
  67. Stihl 4 mix engines
  68. Nose weight for large scale slow flyers
  69. Walbro WT-499 carburetor question..
  70. Stihl 046 conversion
  71. Installing bearings
  72. Are scored pistons useable?
  73. Walbro WYK 194-1
  74. Tap 5/16 nf and it was 8mm x 1.0
  75. Handy thread chart
  76. Smoke pump?
  77. Toro 25cc Threaded Shaft 5/16 x 24???
  78. Kyosho GXR 0.18 conversion engine for gas
  79. Ryobi length
  80. Echo Gt2000 engine
  81. Best place to buy Walbro carb kits..
  82. Help for external pulse line
  83. Muffler has an effect on idle and transition?
  84. 26cc Gas Engine
  85. Starter problem
  86. WALBRO on a TORO (Pulse hole line up)
  87. How you do a free flow muffler?
  88. Will it fly?
  89. Need 3 inch aluminum spacers - help
  90. briggs 34cc head gasket
  91. R/C Gas Airplane Engine
  92. Question about Porting
  93. Kawasaki 22cc
  94. Accesory for aluminum grinding
  95. weight to power ratio / which engine
  96. Is a 19x8 to much for a 33cc
  97. IMPORTANT - MODERATORS HELP!!
  98. Moki 1.80 & 2.10 conversion to gas
  99. Echo 58cc
  100. Homelite 25cc to 30cc conversion.
  101. Schumacher Raptor conversion PLS HELP
  102. weed wacker engines
  103. Need more power which 42 -46cc to convert
  104. Walbro midrange adjustment
  105. Header parts for home made??
  106. Decision: New Poulan 25 or Hommie 26
  107. Porting work on a 20cc.
  108. Question regarding magneto locating pin on Homie 33
  109. 26cc Mightylite Homelite - Motormount?
  110. MDS 148 conversion
  111. Stihl 62cc challenge....
  112. G38 carb
  113. oil secrets for gas converted engines
  114. Help needed tuning gas glow carb setting
  115. An Echo in the Market Place....
  116. Stihl Engine
  117. Bike engine for my 1/3 scale Sopwith pup
  118. 25cc Homelite short-shaft
  119. STENGINES SUPPORT
  120. Homelite 25cc gs/glow mounting plate question
  121. CDI Summary (The New, New CDI Thread)
  122. Stengines, Anyone Ever Had Any Success W/Them?
  123. Craftsman 25cc Conversion
  124. Interference problem HELP please
  125. gas/glow conversion fuel mix question.
  126. Stihl 65cc "Four Mix" four stroke engine
  127. ECHO CS-360 Short Block
  128. My Engine Conversion Plane (Mitsubishi 33cc)
  129. Off Topic but maybe you guys can help...
  130. How can I delete an old post!
  131. Inverted 4-stroke?
  132. troy built/mcculloch 25cc engine stalls
  133. Primer bulb???
  134. Is it worth taking flywheel fins off?
  135. Metal working...tips
  136. Poulan 46cc
  137. help on identifing engine
  138. Moki 180 gas conversion
  139. Cool four stroke engine!
  140. Echo 16cc conversion results
  141. saito 300 twin con kit
  142. Balance/harmonic issue
  143. Walbro WT456 conversion to 4-stroke
  144. Engine mounting idea...
  145. Conv Kit Saito 150-180 important Update
  146. rear carb
  147. Poulan 306- 245
  148. New Mount for 32cc Gasser.
  149. DL 100
  150. Anyone figure out how to mount a Homelite 26cc?
  151. Securing a spinner backplate?
  152. Need a good engine??
  153. Is a Poulan 25cc a weaker engine?
  154. Converting an OS 1.60 FX
  155. Ryobi 30cc is equivalent to old 31cc?
  156. Echo 28CC engine
  157. Converting OS 1.08 BX1 from Glow to Gas?
  158. Still the best
  159. Weedeater Brand Ignition Module
  160. Ryobi 31 Prop shaft
  161. can you say good bye walbro??
  162. RPM higher when cold?
  163. The Ultimate question - when does it make sense to go gas from glow???
  164. Bearing removal
  165. long coupling hex nut as prop adaptor??
  166. Spark Plugs RIMFIRE Vs. RCExcel.
  167. Walbro Carb chart
  168. 32cc McCulloch Chainsaw carb question.
  169. Bud Light can with Macs header on 30cc Homelite...How to mount?
  170. 20mm Walbro for MITSUBISHI 33cc?
  171. 20mm Walbro for MITSUBISHI 33cc?
  172. Musee SAFRAN SNECMA Motor Gnome & Rhone
  173. Walbro experts needed
  174. Shipping STENGINES important.
  175. Zama needle settings
  176. Mitsubishi 33cc Conversion
  177. OPS Maxi "conversion"
  178. Any other conversion engine forums???
  179. Squish bands?
  180. New kind of conversion for weed whackers
  181. Mokie 180 conversion?
  182. Carb on 31 ryobi
  183. How to look for a garage sale weedwacker to convert
  184. Macculloch 32cc parts
  185. Possible project/conversion: Stihl FS50E
  186. E85 in the OS Bio-Ethanol engines
  187. engine conversion help
  188. where do I buy the connecting rod needle bearings?
  189. Mac 2815 Weedie Conversion
  190. Craftsman 2.4 ci conversion
  191. Eliminate ignition battery?
  192. Os55hz to gas E85
  193. Walboro fuel inlet
  194. need help
  195. more muffler fun
  196. Is it normal...
  197. Flywheel center as part of a prop hub.
  198. Poulan Pro PP033
  199. av8tor1977
  200. Glow to gas conversion on an OS BGX 3500
  201. G38 crank extension
  202. Question engine/plane
  203. Who does Engine Conversions
  204. carb swap ?
  205. Craftsman/Snapper 25cc and MAC 2815
  206. mcculloch 32cc timing ?
  207. Big Chaos on gas?
  208. Props Matter!
  209. BX1 1.08 making new conrod
  210. John Deere Trimmer?
  211. McCulloch 835AV any good?
  212. I made this muffler, now much better!
  213. 24cc Echo conversion
  214. Ryobi 31 converstion sputtering...
  215. Tank Plumbing
  216. Tillotson Carb Problem
  217. Poulan Pro 25cc Engine Conversion
  218. G38 prop hub-out with the old?
  219. Ryob1 31cc
  220. What kinds of planes are guys using converted engines in?
  221. Tuning guide for Walbro carbs.
  222. 4-mix 65cc got me stumped
  223. Timing for Electronic Ignition
  224. Saito 180-150 conversion Kit
  225. 30cc homelite sparkplug
  226. NEW CONVERSION
  227. smallest size but reliable glow to gas conversion?
  228. Honda GX25 and Briggs 40cc RPM and Thrust Data
  229. Troy Bilt 4-Cycle Engines?
  230. Prop Hub Problem ??
  231. cdi onboard tacho on magneto ?
  232. brushcutter engines
  233. rare 50 cc engine
  234. Stihl 4-mix 65cc questions
  235. How do I pump a glow carb for gas?
  236. My 3 Point Airboat Motor!
  237. 4 strokes gas os 120 Special Tuned Engine
  238. non ringed ABC liner on gas ??
  239. OS BGX-1 Glow to Gas Conversion (Yeah!) Thanks Max
  240. Honda GX25 flies on Kangke Monocoupe... High performance parts anyone?
  241. MOVED: DLE 30 Prop Shaft Conversion
  242. Stihl fs74 cc?
  243. Pioneer 66cc
  244. CDI gr8flyer55
  245. Como S .61 with 1/4x32
  246. Delrin for carb adapter??
  247. Echo ES302 saw
  248. Robin/Subaru EHO25 deal?
  249. Sato FA 220 Converted to GAS?
  250. Melody ignition - who knew?
