PDA
View Full Version : Engine Conversions
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18
  1. Chain Saw oil pump could it be used for a smoke system pump ?
  2. ys 110 head conversion
  3. RYOBI 31cc questions
  4. re-aligning supply/return nipples Walbro
  5. 30 cc homelite
  6. Engine experts, what is it ?
  7. 52cc 4-stroke opposed twin...any interest???..pictures...
  8. Homelite Versus Poulan
  9. Engine mounted starting system
  10. Best 50 (ish) engine for tuned pipe?
  11. gasket removal???
  12. Homelite electric start
  13. Trim the fins???
  14. Homelite 45cc parts
  15. Homelite Gas Engine Conversion
  16. Homelite 2.0 chain saw engine? How good is it?
  17. Plugging Ryobi decompression slots
  18. Homelite "ZipStart" ???
  19. jb weld coil to case??
  20. looking for a source to get a new 28cc maculloch
  21. Ryobi VS. Poulan
  22. She Flies!!!!!!! Pic's of Stingray with Ryobi
  23. about my new and rare 22cc engine!!!
  24. short shaft or long
  25. CH Ignition - Extra Resistor
  26. Which engine could I use
  27. Poulan 60
  28. Poulan model 2375 chain saw enigine ?
  29. Remington PL-5
  30. Making a prop hub
  31. Glow to gas conversion
  32. Prop Hub for Ryobie 31 conversion.
  33. i need to convert a weed eater engine into a rc plane engine, about a 35-45cc engine i need
  34. Homelite 45cc ????"s
  35. Homelite 25cc -> 30cc, vibes part2
  36. Widing venturi to 12mm
  37. Homie 33 engine mount
  38. Poulan 42 question
  39. Ryobi w/ electronic ignition?
  40. Thrust Rating & Wing Loading
  41. It is finished - Stingray 120 & Ryobi
  42. prop for 54cc husqvarna
  43. Homelite 45cc Problems
  44. My cast aluminum Homelite mount
  45. What size prop on a Balsa USA Stinray 120 with Ryobi
  46. Horsepower ?
  47. 33cc homelite
  48. Winter Project for 25cc Homelite
  49. Original carb Weedeater 25 widening throat
  50. Poulan 42cc dies out
  51. 32cc Craftsman/Poulan convert experience
  52. Glow to Gas
  53. Ryobi jug
  54. Running on alcohol?
  55. Diaphragm kit for a Ryobi
  56. Converting MOKI 2.10 to GAS...
  57. Echo conversion engine
  58. Coleman fuel instead of gasoline.........
  59. converting homelite 45cc
  60. Remington chain saws
  61. Will they fly well
  62. Attention E-bay Shoppers
  63. Ryobi flywheel balance........
  64. inverted with vent opened
  65. Electric starter
  66. Homelite 45
  67. Stihl Model 2621 Gas Drill engine?
  68. What is this engine?
  69. Ryobi 31 in 1/7 Zirolli P-47
  70. Homelite compression
  71. Homelite 240 conversion
  72. Poulan 40cc info
  73. Homelite 45 Pulse Port ??????
  74. Correction: Any mods to increase power on Weedeater 18?
  75. Wraparound muffler for Homelite 45?
  76. Homelite 45cc conversion questions
  77. 1.8 engine / hop ups / max airplane weight
  78. Ryobi 31cc- Dynaflite Decathlon ??
  79. Poulan conversion questions
  80. Why worth the time and money?
  81. I want a 9-cylinder made from Cox .049's
  82. Homelite 45cc Idle
  83. RYOBI trouble need help as soon as possible to fly again!!!
  84. Adjusting Reed Value on Ryobi?
  85. look what yall made me do!!!
  86. Home Made Ryobi 31cc Engine Mount
  87. Engine Identify/Upgrade
  88. Just acquired a strange one!
  89. Prop adapter for Kioritz 21CC
  90. Ryobi 4stroke running
  91. ignition problem on ryobi
  92. Help With Homelite 45cc
  93. Painting Ryobi
  94. spring starter?
  95. Husquvarna flies!
  96. Ryobi mods.
  97. Gasser for a 8-9 lb Bipe
  98. California Ryobi's?
  99. Kioritz Ignition System
  100. Can you ID this engine?
  101. Homelite 30 cc conversion
  102. 32cc Mac.
  103. Homelite 45cc
  104. electronic ignition on Stihl 051
  105. Big Bore Carb
  106. carb problem
  107. ZDZ 80 boxer port timings
  108. Information about the Homelite Ranger and Bandit
  109. Ryobi Tune Pipe (to do) or (not to do) how
  110. Zen G23LH Modify ???
  111. Thread Size for a ryobi 31
  112. OK, So I screwed up!
  113. Prop hub designs and Procedures
  114. Craftsman 37.7 cc, Convertable ??
  115. Dwell question
  116. Where's The "Points"?
  117. Kioritz shaft and carb questions.
  118. 38 cc poulan
  119. Walbro carb mounting
  120. I might be crazy, but....
  121. Homie flywheel removal?
  122. Any large engine conversions? 70-100cc?
  123. McCulloh Eager Beaver
  124. Homelite 25cc -> 30cc
  125. Homelite XL Engine
  126. Hinges?
  127. Starting a Homelite Conversion
  128. Is this a Ryobi?
  129. 45cc homelight carb
  130. Carb Of Choice for 22cc Weedeater
  131. McCulloch.. What size?
  132. Walbro Carb
  133. Prop recomendation/rpm range for 88cc husky?
  134. homie
  135. crankshaft balancing.?.?.?......
  136. Ryobi Mount
  137. Ryobi 26cc 4 stroke carb question
  138. Big Bore Carb.
  139. Homelite 45cc Flywheel and Clutch Removal
  140. Question to Pro's about the props :)
  141. I know there were several web pages on instructions on converting engines from other uses
  142. Ryobi 31 cc what do I put it on
  143. Converting a Homelite Chainsaw engine for Model Aircraft Use
  144. Homelite 45 sensor mount ?
  145. This Long Shaft!
  146. Parts prices
  147. Poulan 305 Pro
  148. RCIGN1
  149. Ryobi big end rattle
  150. Thust to Weight Ratio
  151. slide carb
  152. Poulan 42/46cc mufflers
  153. Husqvarna or Poulan??
  154. Sites for cc's.....
  155. Still TS 760 cut-off saw
  156. RCFAQ SITE??
  157. Husqvarna 254 XP
  158. Shindaiwa four stroke
  159. Homemade prop hubs...
  160. Homelite 360???
  161. "Free" Ryobi Starter
  162. Homelite 25 Vs. Weedeater 25
  163. HOMIE IN A PITT,S
  164. 33cc Kawasaki
  165. Electronic Ignitions
  166. Phaeton 90 and 25cc Homey.
  167. Kioritz 23.6cc vs. Homey 25cc
  168. Horsepower
  169. Hall Effect IC PART NUMBER
  170. John Deer Chain Saw engine
  171. Gas 4 stroke
  172. Got any ideas as to what plane for 40 cc Kioritz?
  173. coolest thing EVAR!
  174. Stinger 120+weedie 25cc?
  175. what company made this chainsaw motor?
  176. echo 25cc conversion....
  177. Weedeater 25
  178. McCulloch muffler
  179. Hack city - Four Star 120 into an ME 109
  180. Lowe's has trimmers for.......
  181. Bolens 31cc same as Ryobi 31cc????
  182. Electronic ignition
  183. Which Plane for Homelite 25cc??
  184. Saito 1.80 conversion to gas
  185. Victa engine?
  186. ryobi won't start!
  187. fs40 4stroke for tmaxx
  188. Electronic Ignition on Homey 45 ?
  189. Makita 52cc
  190. Header to muffler connection question. ?
  191. new to gas, ready to start
  192. Ryobi short shaft prop hub keeps slipping
  193. Stihl 2.2
  194. Homey conversion
  195. gas fuel with glo plug no ignition
  196. Anyone used a gas conversion on Ultra Lite Stik?
  197. Direction of rotation?
  198. RYOBI 31 CC - Am I Missing KEYWAY?
  199. ryobi 31cc won't idle
  200. Will CH sensor & pickup fit in starter area of Echo 23-26 case?
  201. homelite flywheel
  202. CH ignitions...please forgive me
  203. Walbro carb help
  204. WA-197 No longer available new???
  205. homelite question
  206. Balsa USA Stingray & Ryobi Pic's
  207. large APC props for gas..
  208. What do you think of this combo?
  209. Ryobi 4 Stroke Engine Mount
  210. What size of Homelite? Free parts motor..
  211. Something interesting...
  212. Walbro Parts Diagram
  213. Taking the dust off of a 80cc
  214. Walbro ID
  215. INFO on convert 4 stoke to gas?
  216. Is it plated inside?
  217. alternate throttle shaft linkage for walbro carbs
  218. mufflers
  219. John Deere Leafblower?
  220. What type of Fuel tank do I use?
  221. homelite sputter
  222. What would be a good 3d kinda plane.....
  223. 28cc McCulloch
  224. homey 25 mufflers
  225. Ryobi 26cc four stroke carb return spring question
  226. Ryobi 31
  227. weedy questions
  228. ID this engine - what is it?
  229. Stihl FS80 brushcutter engine
  230. Homelite question for the experts
  231. I feel sorry for a chainsaw :(
  232. New Poulan Wildcat Leaf Blower
  233. Featherlite Weedeater carb
  234. Stihl 039 64cc engine conversion
  235. RPM reading of 25cc homelite conversion.
  236. homey
  237. Where did you get your engines from?
  238. What do you have your conversion in???
  239. McCulloch, Homelite, etc. on Ebay
  240. Dynaflite Decathlon/Ryobi 31cc conversion combo?
  241. Chain saw conversion smoke pump??
  242. Ignition Coil
  243. Hand Starting
  244. mac 60
  245. Any Twins Out There?
  246. Post Your Poulan Saw Conversion Pics with muffler, carb and mount ideas
  247. Shindaiwa c4??
  248. difference between ryobi 28 and 31
  249. Snapper & Poulan trimmer engines - Worth converting?
  250. TIM-6 ignition - - - like or dislike?
