View Full Version : Engine Conversions
Pages :
1
2
3
4]
5
6
7
8
9
10
11
12
13
14
15
16
17
18
- Planning ahead is important
- wackerengines.com shut down temporarily
- Weird Walbro problem...
- Stihl 25.4cc - Looks like a good one...
- small engine shops
- Mounting the engine
- Walbro's with accelerator pumps.
- EI Timing for conversion engine
- Optimum carbs by CC
- converting Saito 180 to gas
- removing flywheel
- dr1 with a poulan 42cc (pics)
- Glow glop... or why we are here...
- too bad these weren't more popular back in the day
- STARTERS....
- Stihl trimmer worth messing with?
- WHAT TYPE OF CHAIN SAW IS IT???????????????????
- How should I approach
- FOUR STROKE GAS ENGINES FOR SALE!!!!!!!!!
- Weedeater 24 cc conversion candidate
- My new project: Tecumseh
- Echo 650 update, and finally
- BME twin cylinder blocks...
- wasn't 2010 the year for the ban on 2 cycles?
- Been quiet on the ole conversion board..
- Carbs for different sized engines
- OS BGX-1 CH conversion questions
- Need help Identifying this engine
- General Homie Forum
- Homie 25 pinned
- Engine Mount Patterns
- Ryobi Conrod
- Honda GX copy?
- My first conversion
- Poulan 25cc Featherlite needs help
- Poulan 42cc installing EI need help!
- Spark advance question
- Gas to glow conversions
- Rope a Dope
- Engine performance calc
- Prop size for Homelite gas conversion
- homelite\ryobi 30cc bearing seal
- Ryobi performance?
- saito fg-20 well kinda
- Gas engine conversion from Saitos?
- Super Tigre ST 3000 Gas Conversion
- 26cc 4 cycle ryobi conversion to CDI help
- saito 80 conversion to gas
- McCulloch Titan 57 conversion
- Poulan 25cc Differences
- EFI on honda gx35
- Kill circuit for 25cc Homelite
- Nitro to Gas Conversions
- What's on everyone's workbench?
- Conversion weight
- Ryobi 28 or 31.How do I know?
- ECHO SB1080 runs great!
- Newer Ryobi Parts?
- ASP Radial to Gas
- Strato Charged Zenoah?
- Sensor installation suggestions
- After market bearings and seals...
- Stihl four stroke models....
- Echo 650 runs
- weedeater-pouland fl 1500
- Micro Mill
- O.S. fs 200s gas conversion
- How to convert weedwacker motor to RC
- WHAT IS BETTER ENGINE FOR MY PROJECT?????????????
- enlarging spark plug hole
- Conversion info thread, lost it
- Unsticking rings?
- Dammitall ! Lost the stupid little magnet
- Smoke pump idea
- Magnet installation for Ie how to?
- Ryobi, convert to IE?
- WEIRD MAGNETO PROBLEM SOLVED-Take note.
- Covert Drone Diesel to Glow?
- Shindaiwa t270
- source for short blocks for conversions
- MOVED: Old Power Plants
- Prop nut size for larger engines
- MOVED: 2.5 to 3.3
- Ryobi sensor help
- Spun bearings
- Free Degree Wheel
- A very interesting engine site
- power differences between maggie and cdi
- craftsman 29cc 4-cycle trimmer conversion
- New projects
- Nitro to Gas Conversions STM
- Source for odd size bolts?
- converting from glow to gas
- converting a zenoah g38 to cdi ignition
- ryobi 25cc
- SuperTigre 90 Gasser New Home
- Where to get manifold for Homelite 30cc?
- How to do EI
- Gas Weed Eater to Glow Conversion-What is this?
- MERRY CHRISTMAS TO ALL
- Stihl Conversion
- ECHO chainsaw engines
- Homelite 25cc wacker engine
- Small V 8
- Echo/Shindaiwa four stroke info??
- Homelite weedeaters?
- Building a crank case from scratch
- SMALL DISPLACEMENT FOUR STROKE GLOW TO GAS CONVERSION
- Which Engine Size???
- Homelite needle bearing conversion?
- Ryobi 31cc on a Giant big stick?
- Prep cylinder for new rings
- Bernzomatic al3 rod
- Do I have phenolitic material?
- engine converstion help. need real tech help
- 87cc toro 4 cycle
- glow to steam conversion?
- Can I replace Gasoline with Kerosene, just like that ?
- Homelite 30CC carb
- A PISTON QUESTION
- 180FS Glow to Gas
- Stihl MS 250
- Ryobi backfire problems
- TCI-ignition
- Pilot 1 aeronca conversion
- Engine conversion give away..
- 25cc toro on telemaster
- Homebrew ignition?
- 85cc Tecumseh, conversion?
- Electrical Systems
- walbro nitro diaphram
- Please help identify this engine
- Anyone had a successful Stihl 020 conversion?
- Stihl TS-350
- 77cc Chrysler ?
- MOVED: rustler
- Shindiawa t-25
- 4 stroke weedeater?
- troy bilt 4 cycle
- toro 25cc problems
- EFCO 39cc project
- Custom Piston Rings
- toro 25cc
- Carb Gasket Material
- Saw engines seperate from the case?
- Stihl engine help needed
- Favorite larger engines?
- Clueless in J Ville
- NITRO TO GAS QUESTIONS
- Gas to Ethenol conversion
- PULAN 26ccm EI Conversion
- Briggs 34cc
- Prop Position
- Craftsman 32cc Powered Giant Super Sportster
- Homelite 42cc Chain Saw
- new guy. need help!
- Backplate idea for conversion?
- Compression ratio mods?
- Saito FG20 - why is it so powerful?
- YS160DZ glow CDI conversion
- Engines with two rings???
- Tanaka 16cc
- Engine Parts
- Do dimensional drawings exist for any of these sm. 4stroke engines?
- MAC 28, Sithl FS 56 or Weed eater feather light
- could someone help me find some information on an engine?
- Stihl 92cc With Stuck Rings - Prognosis?
- Strange problem with Homie 30cc on gas/glow...
- Homie differences
- poulan 42cc intake
- Help identifying echo engine.
- Poulan25 longshaft
- John Deere 110G????
- engine parts
- Timing for Glow CDI
- diy cdi
- Super Tigre .61 with CH Ignition
- Walbro WT-353
- ECHO two stroke engine conversion for rc trainer
- Featherlite 26cc deal
- EI Magnet Installation
- Ryobi weedie engine - what's it worth??
- Newbie help
- what about Jonsered
- Weedeater GTI 15t displacement?
- WALBRO CARB INFO NEEDED
- Prop Shaft Adapter Design suggestions
- Walbro Carb and RPM's
- Conversion Photos
- Project poulan
- Idle speed problems
- hall sensor for RC Ignition ignition?
- Always a latecomer, I have need for rebuild help
- Walbro Questions
- Poulan 25cc on Four Star 120 questions
- ASP.91 glow to gas?
- small engine conversions?
- Fuel cooking..is this normal?
- Echo 50cc Short Block Conversion - Seeking Advice
- Homelite 25cc conversion
- CH Ignition
- Homelite 45 Ignition Help
- 28 degree magnet placement?
- Finding top dead center and timing engines Video
- Radial Engine
- how small can gas/glow go?
- Help with engine ID
- Modifying Crank Pin SC 1.20
- no spark hand proping
- Homelite 33cc
- Connecting rod Bushing
- Ryobi question
- echo 16cc carb?
- walbro carbs
- Stihl MS250 saw engine
- homelite 45 with reverse threads
- Old Briggs 2 cycle 3.5 hp, need parts help.
- Homelite weedie with electric starter, need info.
- EI modules
- New Refurb 40cc (42?) Poulan Saw $109
- Ryobi 30CC Max safe RPM
- what size pipe for header
- Need a little Ryobi help
- ryobi mount?
- Need help with Walbro Anatomy
- POULAN 42 cc CONVERSION HELP
- small gasser
- My score of the day
- Ingition Box
- Homelite 33cc EI help
- Quadras, roller main bearings, questions...
- boost bottle - work or not?
- Boost bottle- work or not?
- WinPic800
- Lucas fuel treatment
- RCEXL IGNITION FOR 1/4X32 PLUG?
- My ST G2300 conversion
- Poulan Micro Super XXV: worth it? how big?
- Honda GX31
- Echo engines cut crank, plug block.
- First post and questions
- Echo SRM-311 weedie, 30.5 cc is it a good canidate?
- gas to glow
- Duct Fan to prop?
- ryobi pulse port
- working on a poulan 32
- fireslot head on 34cc fource?
- EI prop adapter for Homelite 33cc
- Timing question
- Installing magnet in hub
