View Full Version : Engine Conversions
Pages :
1
2
3
4
5]
6
7
8
9
10
11
12
13
14
15
16
17
18
- Understanding wife....
- converting ????
- Poulan 42 vs. 46
- xyz cdi
- electric leaf blower conversion
- Homelite down on power
- 30cc Ryobi Firing but won't run
- hobby city EI unit
- Evro (ryobi) 150
- mcculloch 32cc in a TT 140size Giles 202
- Coming back in to hobby
- crank taper
- Ryobi 31 CC
- Can't get my conversion to start properly, what am I doing wrong?
- Ryobi engine mount
- Help identify engine
- Tuning question?
- Gas engine starter
- Converting big glow to gas?
- Hey guys, I have a comparison question Quadra 35 = ?
- muffler question
- Tilting a lawnmower motor 90 degrees.
- Saito 125 to gas conversion
- Yellow Aircraft Cap 10 B-Ryobi Engine
- OS 160 conversion
- Fuel tank size?
- New chainsaw break-in
- gas glow in a supertigre 40
- anyone convert 32cc craftsman
- Chainsaw Engine for 1/4 Scale Dragster
- plane for 25cc homelite
- My newest Ryobi 31 Sukhoi!!!!
- walbro HDC carb question
- Ryobi conversion running poorly
- Stihl quits in a dive
- Know a good way to choke a ryobi?
- poulan 46 wont start
- Best prop for ryobi 31?
- Need number(s)=15mm dual needle carb with accelerator pump
- Engine stall on change of attitude?
- Ryobi wont restart after hot
- Best Chainsaw
- Crankshaft balancing
- Ryobi cc ?
- Walbro WT-324
- Who manufactures Rimfire spark plugs?
- which engine is this....?
- An apology to the forum
- Whacker Identification
- I need a homlite 25 ring
- Shop safety tip
- Reviving a weak magnet.
- fuel question
- Two stroke hop-up reading material
- Zenoah 62cc blower?
- Header for Poulan 46
- Stihl 32cc 4-stroke
- Pump nipples for Walbro Carbs?
- Ryobi prop adapter threads
- Unneeded PTO shaft
- Partner chain saw
- Zenoah 41 cc performance?
- Zama - Walbro Exchange - Homelite 30cc
- super tiger 2300 on gas
- Stupid question !
- Source for good knurling tool?
- GLOW ENGINES ON GASOLINE
- New oddies
- Homelite 25cc carb
- How much oil do i need?
- toro manifolds
- sears brand Weedeater 25cc rpm #s with 16X8 mas
- another darn ryobi post (ryobi performance modification, analysis and comparison)
- Glow to gas conversions pros and cons?
- Scored a bunch of engines, opinions?
- Mcculloch 38cc chainsaw motor mount
- RPM numbers?
- Best engine to convert?
- New idea for Gas AND Gas/Glow engine care...
- RYOBI HOMELITE
- Homelite ran perfect last week, now runs rough???
- Can't tach converted Homelite. Why?
- Ryobi spark plug
- TT pro 46 to EI?
- Super Tiger 3250 on gas
- Poulan 24cc conversion carb?
- ryopi 31cc converted
- Moki 210 +ignition
- Ryobi flying upside down
- What kind??
- Homelite Plumbing Question
- Homelite 25cc cylinder hole.
- Deere S1400 wacker engine
- weedwacker ultralight 21cc vibration problem
- My Ebay Engine, $30 Ryobi 31cc
- 32 cc duropower engine
- Spark Plug to fit Glow Plug
- Glow Driver Problem
- backing plate question
- 32cc craftsman weedeater
- WT-324 on Homy 25cc?
- G23 to EI Conversion
- Big Tiger Moth/Ryobi combo..
- MOVED: Glow engine diesel conversions?
- Who has extra echo parts around?
- OSH sale
- stihl engine quits
- 21cc gas/glow troubles?
- Eager Beaver engine
- glow driver
- Weedie motor
- 45cc chainsaw China
- AVGAS... Anyone with experience???
- Ryobi side carb
- Timing advance
- best chainsaw for converting
- extra 260 w .90 gas
- engine conversion
- Kioritz / Deere 30.8 cc
- ECHO SRM 200CE, 21.2 cc Trimmer
- Airframe for conversion motors-what works?
- Look at this mans work!He did this years ago.
- effects of nitro on ignition conversion
- Best way to find out displacement?
- whats the difference.
- direction of prop spin?
- Gas/Glow engine icy day start-up
- Wanted - 46cc Poulan or 50cc Echo
- Ryobi differences... Comments??
- How long is straight methanol good for?
- Tuning problems with 30cc Homelite on gas/glow
- giving a stihl 020 AVp a shot
- engine running troubles
- spark plug compression leak
- Echo saw conversion help
- where is the best place to sell off parts
- MERRY CHRISTMAS to all my friends in the forum!
- Can anybody identify this engine
- Is this possible?
- Muffler threating Magnum/ Saito
- Ryobi vibration
- gas reduction gear system
- Almost lost my converted twin, be careful!!
- Air Eengine
- Carbon removal tips?
- Homelite 30cc Problem how to fix?
- almost there now...the elusive prop adapter
- Where to find engines to convert
- 4 stroke Ryobi
- think this Sachs can be converted for a plane
- Walbro WYJ-315A
- half crank or full crank
- ECHO Don't shun the 21
- Engines taken, Free engines for conversions
- Husqvarna R24 conversion 24cc
- Anyone Convert a 27cc Stihl?
- Walbro carb adapters?
- Propeller hub for a Zenoah 38
- Ring seal VS gas/oil mix
- Stihl 22.5cc engine
- Small motorcycle minibike engines?
- Moped coils ?
- Rebuilding a Carb?
- My homey in yak....
- Gas Conversion
- Crafsman chainsaws
- Conversion to Gas?
- Next conversion
- Mounts for Poulan Chainsaw engines?
- Where To Find Poulan 46cc Engine?
- Lets talk about timing...
- ECHO 21cc -FPE 1.3 clone -operating specs
- "Brillelli Machining" website
- CDI
- SCORE Echo 30cc going to be a good one.
- Good planes for conversion engines?
- 2 cycle lawnmower conversions
- Just a Warning....
- Need a Twister Intake Spacer
- How to convert?
- ryobi 28cc? is it worth it?
- ZENOAH G26 CDI ?
- st 40
- McCulloch 21.2 cc engine
- My newest hub...
- Source for Echo 21cc Conversion Parts
- ECHO 1.3 (FPE-Clone) Conversion
- The art of engine ID?
- Question about modifying a jug
- installing hub magnet
- Carb recommendation
- Spring tension on throttle
- running on single lipo
- Echo 25.4
- Walbro HDC carb question
- Stihl 28cc
- who has the cheapest online parts house for our small engines
- Bolt Tapping?
- Electronic Ignition USA supplier.
- Top 10 list of convert-able engines?
- Glow Diesel
- please help ID this engine
- Fuels and Health Issues
- Am I right ?
- old craftsman 2.0
- Marine engine to Air
- Honda GX25 valve size?
- removable head?
- When will we see new improved 4 cycles coming out?
- Porting tips?
- Ryobi
- Any new weed wackers with electronic ignition ?
- poulan 18 cc ?
- Craftsman 32cc Weedeater
- Painting a engine.
- poulan wildthing 40cc
- How are conversion engines in the winter?
- asp fs 180 conversion
- Another brand to convert?
- What engines have beam mount?
- poulan 46 cc weird needle issue
- found some pics of one of my first coversions
- What I got a auction today....
- Four-Star 120 ARF with Homelite Chainsaw conversion (Video)
- Gas/glow fuel
- prop hub for g-38
- GAS/GLOW HOW TO....
- A bit off topic, But....
- Echo 23.6
- os120ax
- Post here if you rn Gas/Glow engines
- Propeller Adaptor for Homelite 26CC
- kawasaki
- Brand New Weedwhacker for $49.99
- My First Conversion!!
- Are you down on power and don't know why??
- Home made pump
- Tig Welders...
- More engines to convert need info please.
- PORTING RYOBI 31
- Homelite 26CC, Low RPM's
- Best Walbro carb for Poulan 25cc ?
- 42cc poulan won't run
- ryobi bottom end
- Engine did run good...But then?
- Need advice on prop hub design....
- First conversion with plane
- My first practice conversion engine.....thought?
- supertiger 3250
- What engine is this
