PDA
View Full Version : Engine Conversions
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18
  1. POULAN VS CRAFTSMAN!!
  2. LIGHTENED FLYWHEEL??
  3. Conversion for carb
  4. Please help, Glow conversions basics?
  5. Honda Gx35 Piston Mod Instructions!!!!
  6. HUSQVARNA trimmer conversions
  7. Engine ID
  8. my engine
  9. Gas/Glow?
  10. Honda 4-Stroke Conversions
  11. Honda 4-Stoke Conversions?
  12. Zenoah G62 EI conversion
  13. Where to buy EI prop hubs?
  14. 4 stroke 29cc Trobilt
  15. Poulan 42cc
  16. homelite in 1/4 scale pup
  17. Weedeater 1400
  18. need a carb I think
  19. mac engine
  20. moki radial mount
  21. Advancing timing?
  22. Poulan 46cc/S&S Electronic Ignition
  23. 26CC 4-Stroke for $75.00!!!!!!
  24. cut too much!!
  25. First conversion pick a engine 5-choices?
  26. Need a new shaft for a homie 25cc (long, from blower not wacker)
  27. Help Name This Engine
  28. Long shaft solution?
  29. Name this gas engine! Win a No-prize!
  30. What cc is Weedeater 1500 engine
  31. 32cc on Ultimate bipe
  32. Anyone flying with E85?
  33. prop position in relation to flywheel..
  34. Alchohol vs gasoline
  35. Crankshaft sizes
  36. Prop hub for Ryobi 31 CC running Glow
  37. Help determing cc size?
  38. Poulan chainsaw with SAS
  39. Homelite
  40. 31 CC Gas vs Glow
  41. Glow to Gas conversion
  42. Engine size recommendations
  43. Homelite piston
  44. Stihl 65cc 4-mix on 30% Edge
  45. Help neede identifying this engine
  46. Poulan 25cc ?
  47. Brillelli 46 prop??
  48. Homelite on Glow
  49. Homelite St-80 trimmer
  50. twister manofold gasket
  51. STIHL 27CC SPECIFICATIONS
  52. Snapper 42cc chainsaw
  53. gas newbie needs tuning advice
  54. twister manifold part #ps04357
  55. Adjust your venturi size larger
  56. honda clutch
  57. More problems...Engine too wet!
  58. BEWARE OF DURO-POWER ENGINES
  59. Carburetor Size? Measure where?
  60. Homelite st-175 model number help?
  61. Sachs Dolmar conversion upgrades
  62. Fuel to oil ratio
  63. Mac 32CC mounting
  64. Boring carb spacer
  65. Fuel tank size for newbie
  66. Opposed Twin conversion material...
  67. Another Homelite 25cc success story...
  68. Need advice for homelite 25cc
  69. MOVED: help with 2.5r in rc10
  70. Echo Engine Left Hand Thread
  71. Engine ID Ideas?
  72. conversion G62 to EI, just for fun
  73. Can you BELIEVE this??
  74. Yard Machines 4-stroke weed whacker...
  75. Power Products Engine
  76. Honda GX35
  77. strange ryobi behavior
  78. Shindaiwa 22CC conversion?
  79. Who uses a tuned pipe on a converted engine?
  80. Crankcase Stuffing
  81. Need to get head examined
  82. Shindaiwa 4 cycle 80cc
  83. Ryobi 26cc 4 stroke - $74.99
  84. Needed your suggestions for senior telemaster
  85. Why do you do conversions?
  86. 4-STROKE RYOBI ANYONE?
  87. No Spark on Homelite 25
  88. Ryobi carb advice needed
  89. need advice for a good engine for 1/4 scale
  90. Ryobi on a diet
  91. can't get rcu site
  92. Dynaflite Decathlon flew today, 33cc homelite not withstanding.....
  93. First gas engine conversion
  94. wHere to buy parts
  95. Falkon Ignitions
  96. 4 STROKE RYOBI ANY GOOD?
  97. New CDI - opensource project JMJ and Bigboat
  98. need advise for ryobi conversion
  99. Repair shops
  100. 18cc featherlite conversion possible?
  101. Stihl 032AV, What next ?
  102. coil problems
  103. What gas motor for .60 size trainer?
  104. 50 cc Beam mount ?
  105. What to do with this?
  106. 1/4 Fokker Triplane with Honda power
  107. Stihl 4 stroke lubrication
  108. Rear Carb, Okay?
  109. Homelite 45cc & Walbro HDB-6B
  110. list of planes suitable for 25cc conversion
  111. Choise of carburettor
  112. MOVED: Diesel COnverstions.......
  113. MORE POWER!
  114. echo 33cc chainsaw
  115. Echo 33cc chainsaw
  116. A Machining Question
  117. Ryobi 31cc conversion help
  118. a mystery of a ryobi that won's start
  119. Source of Briggs 34cc Four Stroke for Conversion
  120. Good Coversion engine?
  121. Sear's 21 CC weedy motor with pics
  122. Online Source For Husqvarna 2-Stroke Oil--Quarts or Gallons?
  123. McCuloch 28 cc vibrating like CRAZY
  124. Honda 25 vs. 31
  125. Zenaoh 23cc Trimmer engine question
  126. GOT MY STIHL BACK FROM BRILLELLI ENGINE
  127. jump starter
  128. Converting a Poulan 25cc engine
  129. 80 cc to 100cc conversion engines
  130. Exhaust Insulation
  131. McCulloch 32cc on a 85" 14.5lb Extra 330?
  132. need hub for short shaft 31cc ryobi with cdi ignition
  133. honda gx31 throttle linkage
  134. Poulan 46--Post Your Pics Please
  135. MOVED: Brillelli review
  136. 25 to 30 cc engines will they fly a plane
  137. MS880 MAGNUM
  138. Ryobi ignition timing
  139. building on a budget-best bang for the buck
  140. MOVED: Tartan (Twin 77)
  141. Wich Walbro Carb is best??
  142. Ryobi 31cc crossflow vs 25cc homey
  143. Converted Homelite, what firewall thickness?
  144. Ignition spark
  145. 25CC engine question?
  146. GMC Branded 25cc, any good?
  147. Need suggestion on conv. engine for 1/4 scale Gilmore "Red Lion"
  148. Craftsman 32cc Weedeater Motor
  149. COMPRESION RATIO CALC HELP??
  150. engine conversion
  151. Gas engine vibrations and throttle servos
  152. cc to flying weight? & what prop?
  153. WALBRO WITH ALCOHOL
  154. Homelite 33cc chainsaw no start and plumbing sanity check?
  155. Homelite 25cc Plumbing??
  156. McCullough 38cc Question
  157. What is it really?
  158. Max Carb Size On Stock Ryobi?
  159. fuel tanks
  160. Propeller size for 31cc RyobiWhat is the
  161. does ryobi have to be converted to electronic ignition?
  162. what are you putting your 31cc ryobi's in?
  163. bore
  164. Engine with bolt on plates on transfer ports.
  165. Throttle linkage help
  166. Gas/Glow fuel line choice
  167. Ryobi crossflow is it or not ?
  168. Homelite 150
  169. first time nitro burner
  170. 40cc Briggs & Stratton 4-cycle in Craftsman Line Trimmer
  171. convert this ! question?
  172. Fuel tank plumbing
  173. reed petal replacement
  174. Poulan 42/46 compression figures/values?
  175. four stroke weight?
  176. Durapower 50cc 4 stroke
  177. 31 cc for $59.99
  178. Featherlite versions
  179. Need some engine choice advise please
  180. Briggs&Stratton 34 cc 4 stroke mounting
  181. What is this Port for on the Carb/Engine intake?
  182. Identify This Weedie Conversion Please
  183. 32.6 duropower pictures and info
  184. Twin ring Ryobi
  185. Help ID this engine please ?
  186. Ryobi tuning
  187. Super Teger 32500 to gas?
  188. *Brillelli 25cc GT Engines Arrived*
  189. TOC Super Chipmunk with Ryobi
  190. bearing question
  191. crankshaft question...
  192. 50-75 cc conversion ?
  193. Frank Bowman
  194. Help identifying an engine....
  195. Redmax trimmer engine question
  196. Ryobi full-crank 25cc at Cummins Tools
  197. Tack & Safety
  198. Poulan 42cc rpm numbers please?
  199. What is this ??
  200. Carb size vs.Prop R.P.M Homie 25 & 30
  201. Ryobi 31cc
  202. Small Conversion Engines For This Twin?
  203. 1st conversion, tips and help?
  204. 16lb of thrust on 42cc
  205. Need a conversion to substitute a G62???
  206. Opinions
  207. Which Poulan do I have
  208. stihl ms 250
  209. engine conversion
  210. Servo for 78" Chipmunk
  211. Homelight 25
  212. NITROPLANES Big Tiger Moth...
  213. 38cc McCulloch
  214. GeeBee
  215. stihl conversion
  216. Engine Conversion
  217. MTD 31cc with Electronic solid-state ignition
  218. 4 strokes at Harbor Freight
  219. Montgomery wards chain saw
  220. homelite conversion
  221. Brillelli 25GT on CMP Spitfire
  222. ?Candidate for converted engine H9 Funtana90?
  223. Not sure where to post... Saito 100 to gas conversion?
  224. 1/4 scale Fokker triplane with Honda GX35 4 stroke nearing completion
  225. Guess what this is?
  226. More Ryobi questions
  227. PICS ADDED 1/9 scale B17 with 4 4stroke gassers
  228. Which is What???
  229. Tom Perry, NEED EMAIL
  230. 25cc weedy port timing.
  231. My new 4.5 oz.flywheel
  232. Need quick answer!
  233. *25cc Conversion & Plane Combo*
  234. Finally got a video of the Honda 4 stroke flying
  235. Poulan 42cc questions....
  236. RYOBI CONFUSION
  237. OPS30 Glow to Gas
  238. Interference from ignition?
  239. Nice Poulan mount for Giant Big Stik...
  240. homelite identification question
  241. 18 cc and up $45.00
  242. Ryoby 26cc 4 c motor mount
  243. Distributor for Kioritz 23.6cc short block?
  244. Weedie 25cc ID ?
  245. GX35 Pics and one homelite (pic of completed engine added)
  246. Shindawa 4 cycle
  247. Gas to FAI conversion
  248. MCCulloch Clutch Remove
  249. Inexpensive options for an ARF w/ conversion engine.
  250. mufflers for converted engines?
