View Full Version : Engine Conversions
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17]
18
- Echo 58cc
- Poulan 46 or US 41 ?
- Craftsman Engine ????
- Poulan 46-Raw fuel spraying out carb throat HELP
- Homie 25 Throttle spring????????/
- Ofna Hyper .21 P/S to E/S conversion ??
- Homelite 150 conversion
- newbie conversion questions
- Homelite 25 screw sizes???
- Ryobi ?'s
- What size Ryobi
- How do you balance the Ryobi Flywheel?
- Jag engines & 4 Stars
- Engine ID help part 2
- Engine ID help needed
- Craftsman 32.....I think it's dead
- Homelite 25 cc on alky
- Weedy events
- Stihl 4MIX
- Saito 4 stroke anyone tried this?
- Flywheel fin drag
- Poulan 46- What plane you flying it in?
- Converting a Craftsman 32 Blower. Please Comment
- Ryobi 26cc 4-cycle
- Weedeater xt40t??
- McCulloch 32 cc disassembly??
- Ryobi31--Harbor Freight $49.99
- husqvarna help
- CEN MT2 Fun Factor
- Kioritz PB-400 questions
- Poulan 46 won't richen
- Spark plug for G-62?
- Make my own prop hub
- Who makes a big engine for conversion?
- spitfire spark plugs or what?
- World P51 Engine Suggestion
- McCulloch32 or Ryobi 31?
- 25 cc Homies
- Flywheel machining on a Homey
- echo weed eater engine
- Four Stroke Carb Position
- Ryobi RCT2800B
- craftsman
- Gas to glow converstion
- 28cc
- Engine noise check ?
- Ryobi 4 stroker, whos flying them and what do ya think.
- big bore carb, for RYOBI
- Which Engine is which
- craftsman/poulan 3.0ci conversion-whos done it?
- Glow to Electric conversion?
- Weed-Eater Conversion
- Polan 36...wont draw fuel??
- 30cc homelite engines
- Ryobi conversion.
- what is the thread size
- prop shaft need help
- homelite super xl-12
- engine ID help freely given
- Anyone for a 185cc two stroke?
- Carb Insulator
- Poulan 42cc help needed...
- Efco 8420
- Kioritz 1.3
- which company mofidies Poulon?
- Parts for Echo needed
- Ryobi conversion kits
- 28cc craftsman
- NiSL - Chrome liners
- Jobu Chainsaw, any info?
- Older 28cc ryobi on 1/4 scale Fokker DVIII
- And It Was Flying So Well... :(
- reed valve material
- Ryobi 31cc Car
- Poulan 46cc mods
- Honda GX31
- Green Machine 7700 chainsaw
- McCulloch 32 cc
- Husqvarna 39r (weedeater)
- throttle lag on 45cc conversion?
- WA 199 and WA 214 what are the #s of bigger Walbro carbs?
- New Ryobi?
- Any help out there for a OS .61 V
- Ignition Coils
- Weedwacker identification and disassembly/conversion help.
- Older Chainsaws
- After reading: "Don't Forget Echo" (got me one, have ???)
- O.S. 40 LA bearings?
- Setting engine timing
- Homie 25 carb linkage ideas needed
- Alternative to mounting plate Homie 25 Pro/Cons
- Weed Eater 18cc
- mcculloch line of engines
- Light weight G23
- RPM on 54cc conversion??
- Ryobi 31: How much does it weight?
- craftsman saw 2.4 not needed
- Who makes a 19x6 prop???
- Which Aircraft?
- What brand of saw engines are best to convert??
- 25-31cc Reccomendation for 3 or 4 blade props
- What Engine do I have??
- Throttle connections/sensor mounts?
- muffler convertion
- Rcign1
- John Deere
- K&B 3.5 Outboard
- weed eater conversion
- Flywheel fins - what is the limit?
- Weedeater Conversion
- Ryobi questions
- Long or Short shaft Ryobi ?
- Suggestions
- Diesel's
- Ryobi
- Ryobi Again
- looking for a Ryobi spinner nut
- 2 cyl ideas
- Kioritz SRM-302 ADX
- RS engines
- "OLD" Walbro carbs.
- Ryobi not sold in California
- is there hope?Can this engine be converted?
- Husquvarna 88cc, need muffler?
- Help I need a wt499 glow carb
- Homelite 25cc mods and rpm numbers...
- Elect. Ignition
- engine convert
- perry carb mod
- Webra 120 Pumped As A Pusher??
- Irvine 39
- glo to gas
- Soft or Hard mounting a weed eater ?
- Need some 3/16" magneto for a electronic ignition
- cheap gasser plane?
- Ryobi Four Stroke on Glow
- What size Electric Starter
- poulan 54cc
- exhaust system sealer OEM
- is this a sky ranger or a WW2 JAP WARBIRD
- Ryobi as a pusher canard ??
- Hanger 9 mount
- 45 or 46 cc
- stuffing
- Os 160 & Tuned Pipe
- what is up with ch ignitions website??
- plane,thrust??????????
- Overheating?
- PowderCoating engine parts
- Craftsman 31cc weedeater conversion?
- Poulan 46cc
- Is this homey convertable?
- Weed Eater: Rear Carby....which is it?
- O.S. Max conversion
- Saito 120s
- Ryobi Four Stroke Questions
- muffelators
- replacement parts for ryobi.
- Learning to convert
- irvine 40 diesel head fix
- taplin twin diesel 0.30
- 60B carb on an OS 50SX-H
- silent spark
- What is this?
- Spinner size for a Ryobi
- Weight of Homey engines
- Bucket O' Engines
- loosing the airfield because of the noise. Help!
- Glowplug XXL
- Ryobi parts
- stihl 017 on glow conversion
- Good links!
- Seeking True Diesel Engine
- Poulan 34cc
- davis diesel conversion kit
- Need Kawasaki info
- Ryobi Carb question
- homey pics
- I need 16+ lbs thrust, which engine?
- Ryobi engine mounting
- Ryobi Fuel line question
- OS 61FX Diesel?
- Husqvarna engine
- What Is This???
- What a deal!
- Stihl chainsaw conv.
- pulsating sound, @ full throttle no rpm change per tach??
- Part # for Homelite Carb Rotator???
- Where to buy spark plugs i the EU?
- Como/italian Engine/principles>2-s
- Montgomery Ward Chainsaw engine
- Big Motor!!!!
- Prop Adapter...?
- Mac conversion questions
- toro weedplane engine??
- What oil mix ratio is reccommended for Homelite 25cc?
- Convet to Gas from Glow
- after run oil
- Which prop for a Ryobi
- Ryobi Four Stroke Fuel economy
- A Tip, And A Question...
- I just picked up a bunch of engines.
- 18cc poulan
- Poulan 46 prop sizes/brands?
- poulan 46 good first gasser??
- Homelite 25cc carb
- Cheaper Fuel Solution for O.S. 61??
- Sensitivity on hall effect sensor...
- CD ignition coils...
- Norvel 061 diesel conversion
- Poulan 33cc chainsaw conversion
- Good 3.7-4.2 conversion?
- Ryobi 4 cycle
- Poulan 46 vs 54
- Homelite SX-135 Bandit Trimmer Engine
- Kawasaki info??
- Poulan 46 for 80"
- Crankcase volume
- Poulan Mounts??
- Poulan parts info???
- Performance Silencers
- Poulan Pro
- Ryobi question
- what has more power ryobi or homelite?
- Lawnboy Engines?
- Echo 23.6 prop help
- What type and size engine is this?
- What is it?
- Check It Out...
- RE: Go kart engine
- Go Kart engine
- McCulloch 28cc weedwacker engine,good conversion or not?
- Power sprayer for aircraft engine
- MDS 1.48 Deisel convertion
- Saito 150s
- Buy a weedwacker-Make an engine?
- Discovery!!??
- Tig Welders??
- Info on smaller Poulans??
- NOS for RC?
- Ch Ignition "kit"... Please Help??!!
- RYOBI Testing
- stihl question?
- Formula for calculating carb size
- Jato Tube!
- McCulloch 2.0 or 2.1
- giant spad website
- JEH Ignition
- O.S. 16 boat engine temp
