- R5014DPS reciever and Whip antenas
- 9CAP synthesizer module
- 14MZ Slooow Screen
- Triple Rates on A & B (9CAP)????
- Help! 7C Dual Elevator Mix
- Digital S9451 servo in Heli?
- Dead receiver
- 14MZ Mode change
- MOVED: FP-6FG???
- Need help on aileron dual rates 9zap
- RX TX crystals
- G190 for Nosegear Steering?
- 14MZ Conditions or Triple Rates #2
- Latest MZ Update question.
- How does it work??
- Throttle fail safe?
- 8U
- Futaba Conquest No Xtal
- FF9 chrome finish flaking off.
- five cell battery on Futaba 9255 digital servos
- Ultra Stick 60/7CAP
- 149 RX locks out
- 9C ailvator setup? One elev only
- 9CAPS: Elevon D/R on one switch
- 8U series flap question
- 14MZ Binder and other accessories
- 14MZ mode 2 to mode 1
- Strange Problems with new 9CAPS
- 14Mz Update
- 14Mz Update
- broken antena lead
- 14MZ Conditions or Triple rates ??
- Futaba 9C
- Futaba 9C
- T12 stick mode Change
- Servo Arms for 9154
- 14mz Expo help!!!!!
- 14 MZ stick spring
- 9C Super Trim Steps
- 6exas question
- Futaba 4EXA
- Dual Function/Task on Single Switch
- Futaba T6XAs spoilerons vs flaperons
- Is this equipment too old?
- Futaba 9C
- 12Z to 14MZ Model Transfer
- 14 MZ Dsc
- 9C with synthesizer v/v Berg-5*DSP II
- Channel change
- Futaba S9203 servo and Futaba's website
- Bad 611?
- need futaba TX CH 53 crystal yesterday
- 5 Cell Nicad Kill my 149DP?
- 14MZ Flyers Club activation needed!!
- 14MZ changing battery in transmitter
- elevator channel not working
- dual throttle control (part two)
- 7cap dual elevator servo programing
- 3010 servo stripping
- 14mz update has shift select and adds extra channel to old 9channel receivers.
- 14MZ Flapperon Function
- Software Release Question
- 6EAXP No spoilers
- 14mz update for dummies
- Charge Jack/DSC Fuselage Mount
- 14MZ VIRTUAL CHANNELS
- 9Z WC1
- micro recievers below channel 16
- T14 and different PCM protocols...
- 9Z Case Foam
- 14 MZ
- Charge jack housing
- 14mz from 72Mhz to 50Mhz and back?
- 9Z conditions
- Glitches in the plane from Hades.
- T9Z WC2 Help!
- TP-FSM Module
- 12Z sliders?
- 9CAP switch B part number
- Question about T12Z
- Switch guard
- S2008 MONSTER GT SERVO ARM HELP
- 6EXAS
- 9C Super Synthisized question???
- 7C Fault
- 12Z and 14MZ Mode 1
- 12Z pdf manual
- 6exh help...
- Question about R127DF being discontinued
- Problems with the Futaba 7CHP transmitter...
- New 14mz Single Case ?
- 9C finish wrinkling
- 14MZ stick recalibration problem
- R148 DF antenna routing?
- Problem with 9CHP Super
- 14MZ Set-up on a 35% Extra HELP!
- RX Antenna Length - FP-R113 i P
- Dual Throttle control on 9CAPs
- 8U?
- 14MZ Setting up for Elevons?
- 9C Elevator problems with flightmodes
- 1
- Why 9C radio face oxidized so easily?
- MOVED: New R/C Radios Using Cell Phone Technology
- GY611 gyro voltage requirements
- futaba servo lead
- small rx with large servo?
- GH-1 Glow driver setup
- New 6EXH Rx battery/switch defective?
- Futaba radio parts
- Failures with Futaba G3 2048 Receiver
- correct receiver band for 35.900 crystal
- MSA-10 Help!
- AM vs. FM
- 9c to 9c super compatibility - another question
- 8UAFS turning off in the air
- Flap set up on 9c
- More power for my 9C
- transmitter spring
- 7CAP 2 Elevator Servos
- )CAP / 9CAPS campac incompatible
- How to mix flaperons with ailerons?
- Why no talk about the ?? STM ??
- 9C to 9Z compatibility?
- 6EXA Upgrade
- Going up in 9C battery capacity
- Super 8 Chrome face
- Futaba 8UAFS turns off in the air??
- 3PK Setups
- Futaba 7CAP, dual elevator setup problem
- s3108 replacement gears
- MOVED: T 12Z new pictures
- Campac
- Futaba 9C
- Futaba digital servos and Hitec Radio
- 9C Super question
- R127df case
- R5014 DPS Aerial
- 14 MZ backlight
- PMIX ..9C ...What am i doing wrong..!
- 14MZ software upgrade version 1.05
- FP-R5014-DPS Aerial
- Futaba 9C battery question
- switching thr/cut switch to right side on a 9c super
- What is the Best Way?
- What Fm or Am receiver for Futaba AM
- Futaba Conquest 4 ch Tx Buddy Box Issue...
- 9C - Trims stop working
- Futaba servos...what's the difference between these
- 7CAP "Big Problem"
- 9C Airbrake programing
- 14MZAP... 14MZHP what's the difference?
- driving 2 servos on a Y
- How Much Current?
- Nine Cell Battery for Gold Case TX
- T12Z & 14MZ Mode1 on 50MHz
- 9C - Need help with "Complex" setup
- PCM and FM rx
- 9C flaperon help
- Digital Servo Programmer
- Servo question w/ my 9C
- 127DF week signal
- Futaba 6EXH vs 6XHS & FM Vs PCM
- Positive shift vs negative shift
- 9C Questions
- New Futaba black NeckStrap
- Futaba 8UA Super with Ultra Stik
- When do I need a power expander?
- 6EXAS
- MC114H w/LiPo 3S question.
- futaba 6exas radio
- 35Mhz Synthesized TX module question (UK)
- 9 cap mixing
- Why no futaba servo comparable to the JR 8611?
- 9CAP will not change model
- Motor for the Futaba 9102
- Reciever FPR127Df Futaba
- Futaba FP-T5NLP use today
- Change low band to high band.
- 9C Rudder Center Positions Different in Norm vs. Idle Up/Hold
- Is there a 149DP PCM receiver available on 29 MHz?
- Questions about checking/repairing Futaba 9C RF module
- 9351 servos
- Power Output, 6EXA
- Spread Spectrum
- 149DP on 29 MHz
- re: the R146iP
- Elevator deflection
- R146iP on a T Rex
- 9Z WCII Question
- 6EXA mixing question
- dual aileron servos w/ 5 channel rx
- is there an upgrade from4ex to 6ex
- FP-R127DF Jitters
- 8UAPS transmitter
- Wc2 tranny and a 3d Plane - config
- "twitchy" servos when TX in PCM mode
- 9 vap
- Flaperon trims, 6XAS,7C,9C?
- 9Z WC2 and dual Rates
- Futaba 7CAP
- 3PK Brake Balance vs. Rate - Confused
- 8u works and 9z doesn't
- Reciever questions
- FUTABA 9C Super
- 7CAP 5chan RX Flaps?
- 9CAP super and 9CHP super.....
- Hi/Low Pitch on 9chp
- can I buy components from futaba for my conquest 6?
- can 7C use synthesized module??
- Futaba 12ZAP Anounced in Tower Hobbies
- 7CAP Broken "B" Switch...Warranty??
- Rx. battery Voltage
- Flaps on Sw G on a 9C
- What's different about the T9CP??
- FP-TF-AM Module... Narrowband???
- Transmiter vs Receiver (PCM 1024)
- rx @ channel 37 verses tx @channel 42 need help
- how to transfer models from WC II to 14MZ
- Is Futaba TX compatible with JR RX
- servo eyelets
- Micro Receiver ???
- FF9
- Skysport 4 modification
- dsc and pc serial connection
- 7CAP Snap Function Inhibited
- Trainer cord?
- 9C Super PCM Mode
- 6EXA CHANNELS MIXED UP...
- Super 7
- Servo question
- troubleshooting radio/receiver prob (1990's futaba)
- Cross mode teacher student link on 14 MZ
- 8UAPS
- Can you use a 6.0V receiver battery w/s3151
- Mode 1 and Mode 2
- type 72-7 & 72-9 crystal application?
- 9Z WC II triple rates and internal battery?
- Futaba fp-t5uap transmitttor mode change
- NiCad Only for S9351??
- 9C super programing question
- Trainer/student with different modes. Possible?
- 3pk wierd problem Pls help
- Sent in receiver for service....
- i think i just blew the mothafukin speed control out!
- Diode in 8UAF Super
- DISPLAY SCREEN T9CHP
- GY401?
- 9ca to 9ch conversion
- Larger Campac Memory available ?
