View Full Version : Engine Conversions
Pages :
1
2
3]
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
- Zenoah G23L - Any Experience?
- ASP 180 FS gas conversion
- Garolite G-10 substitute??
- Engine Firewall Material
- Need thread size and pitch for the prop nut on a Ryobi 31cc engine
- Here is a engine you will like
- Frank Bowman Piston Rings
- Homelite 30cc gas/glow prospect..
- XYZ igniton compatability?
- walbro or tillotson carb on ST 3000
- DLE 30 carb for 4 st ? an replacement for walbro wt-456-1
- CH Synro Spark?
- Pleasantly surprised with an old Kalt 22
- Homelite Rings
- cc of Homelite
- Some unique conversions
- MAC 610 Chainsaw conversion 60cc
- Saito 120 gas conversion (and repair??)
- Another Homelite 30cc
- Straight line speed.
- Echo 21cc in marketplace....
- eem to be getting any gas i put a carb on it from a burnetup hamelight chainsaW MOTORAND DOES NOT SE
- Muffler fabrication question
- extra post, sorry
- Zenoah 80 twin Converted to electronic Ignition
- 4-stroke design idea
- MOKI XL 35cc
- solvent tank/parts washer?
- RYOBI 4CYCLE ENG
- Echo 65cc?
- Converting to Alcohol
- My latest Homelite 30cc.
- Hey, it's dismal here!!
- Repair aluminum...build exhausts
- St g90 gas conversion tuning issues
- Now HERE'S a conversion engine!
- Need to find.....
- xyz cdi
- OS FS40 ignition conversion
- 120 Webra speed conversion
- I thought some of you might enjoy this conversion boat project.
- How sensitive is intake mani length on a little 4 stroke?
- convertion
- deja vu
- Poulan 46 cc EI help.
- 30cc POPE Pusher.
- Looking for photos of G-26 LITE, help!
- BGX 35CC GAS CONVERTION
- Ryobi 26CC
- SUPERTIGRE 3000 SPECIAL TUNED CONVERSION
- Is a "Green Machine" chainsaw Zenoah
- McCulloch 21cc
- chainsaw/trimmer conversions
- Running a 2-stroke backwards
- More Carb Questions
- NEW RADIAL BI ROTARY ENGINE
- Any News on how BCCHI is doing?
- WYK Walbros, 40cc Briggs
- Carb linkage
- Balancing a crank/con-rod/ piston???
- air power tech ignitions
- OS FT series Glow to Spark conversion
- Methanol
- PROPANE FUEL 4 STROKE
- carburetor problem revealed
- OS -160 conversion
- Remove bearing oils seals?
- Engines for conversion
- HomeLite z625cd?
- saito .56 gas conversion
- Honda GX31/35 wrist pin diameter?
- Zama with strange choke system
- Dynamic balancing of an engine?
- MTD 25cc power heads
- I got bored and beat up on a blower
- tuned straight pipe for Ryobi conversions
- Wt 38 or 367 Wanted
- Prop balancing
- interesting find at Sears
- GRASS CUTTER HOMELITE STE CONVERSION
- Grounding a electronic ignition
- Bennett Built
- Inline twin
- Electronic ignition
- YS 140 to gas ?
- Need Help Tuning a Carb
- Rich midrange fixes?
- Carbs.
- FTL CDI UNIT
- Suitable walbro-Aviastar 1.50 conversion
- Sorry guys... couldn't help myself...
- Bill Carpenter
- Ryobi crankshaft bearings
- Gas/Glow adapter
- Carb for a Ryobi
- Want To Build A 100cc 4-Cylinder Conversion For Me?
- Engine Conversion Chart ??????
- Cutting a Flywheel
- Briggs 40cc 4-stroke compression release?
- An interesting sighting
- 42cc Poulan port work?
- Happy Holidays!!
- Smoke Muffler
- Aluminum Prop Adaptor
- POULAN Engines
- Magnum 52 gas is ABC?
- Ryobi long shaft
- Ryobi bearings
- Four Stroke Short Blocks
- 20CC WEEDEATER ENGINE IN CMP T-34 MENTOR ?
- 1/4-32 Taps
- Large conversion engine source?
- walbro carb pump diaphram colors
- So why is it that.....
- That Mac 60cc IS worthwhile!
- Successful aluminium brazing
- Convert OS/Magnum 91 to gas?
- Need muffler with 37mm bolt spacing
- WT 458 Pics/Use
- MacCulloch 101cc conversion pieces
- need parts to convert my Mac 101cc
- Muffler bolt spaceing resource?
- need assistance with this engine project
- Ryobi 30cc 4 stroke
- Home made CDI question
- making decent mufflers
- home depot
- OS GPEGASUS 320 GAS CONVERTION
- General port timing guidelines?
- ZAMA carb warning....
- bulk fuel line size and source
- 9.5 to 10mm WT Carbs
- Access to Stihl bone yard this week,what to look for?
- Ryobi Compression
- IDENTIFY THESE 26cc FOUR STROKE GAS ENGINES
- IDENTIFY THESE FOUR STROKE GAS ENGINES
- newer homelite chain saw conversion
- Ryobi long shaft,short shaft??
- Zenoah CDI
- A Typical Weed Whacker Conversion
- converting a .21 nitro to spark ignition
- OT- Tailwheel for Fokker D-7
- metric sized plugs converted to standard size.
- "Favorite" plug to use with Ryobi
- Walbro carb venturi specs
- Best carb for my Ryobi gasser
- cox 140 gas engine
- Saito 25cc Gas engine
- Needle roller bearing conversion on super tiger s2000
- Loss of cheap
- XYZ IGNITION FAILURES
- Ryobi/Homelite 30cc duration numbers???
- McCulloch 32cc prop
- looking for homie 33 parts
- Honda lawnmower engine & Extra 330S
- A spark plug question.
- Which engines to look for?
- Installing magnet for CDI
- converting zenoha 23 to electronic ignition
- OS91 Cspec pumped, Gas/ignition candidate?
- Moding Homelite 25cc - Input Appreciated
- Engine Tuning???
- Gear reduced starter insert????
- Sachs 4.2
- Please help me think this through
- OS BGX and Enya 1.80 to spark ignition
- PLEASE HELP ME which petrol 4 stroke engine for yt internotianla spitfire 73
- A place to put a conversion engine
- Mac 85-SX 21cc
- 25cc toro on a diet
- Clicking Ryobi
- A favor....
- 25cc 2 bolt Weed Eater
- Echo and Stihl
- Ryobi tuning problem
- briggs 4 stroke prop?
- Carb Setup Help! (WT-739)
- crankcase sealing on gas/glow conversions
- Engine I.D
- looking for large scale coro-cub build thread
- Briggs 40 4-stroke
- Ryobi Conversion Questions
- engine question
- Briggs Craftsman 40cc 4-stroke
- carb question
- Cool conversion tool...
- Want a conversion engine?
- Poulan 46cc Intake problem
- INCREASING CC OF A TWO STROKE ENGINE!!!!!!!!!!!
- Kawasaki, Echo, and a Homelite
- Europe / Germany spark ignition manufacturers
- Tanaka 43cc Conversion
- Stihl 19cc (20cc) Conversion
- Need Homelite 30 cc Machined
- craftsman 55
- G90 TO GAS - HIW TI FIT THE CARB?
- A $5 LED stroboscope
- Magnum xl 91 2-stroke is it convertable?
- Ryobi reed plate
- Complete new CDI - website open
- What parts do I need?
- Stihl conversion ignition ID??
- Stihl 77cc Saw, Piston scored.
- Weedeater (brand) XT 40
- what weedeater...
- Short shaft prop adapter installation
- Ryobi Conrod failure
- Honda GX31
- Newer rotary carburetors
- Any potental here? Stihl Saw 77cc
- OS Pegasus 320 to Gasoline
- interesting find...
- Plug gap
- ASP 52FS From Glow to Gas with RCExcel Ignition
- 33cc RYOBI CONVERSION
- Husky won't rev up
- Homelite 25 Problem??
- starter
- WYA CARB/ Craftsman 30 cc 2-stroke
- 4-stroke carbs...educate me!
- YS FZ120 to gas.
- Prop hub help needed.
- Homelite 45cc Questions
- ryobi muffler bolt
- HOMELITE TIMBERMAN 45CC HELP
- B/S 4-strokes
- Harbor Freight super sale (incl. angle grinder)
- jag engine parts
- A boatload of fun
- Ryobi 31cc engine conversion parts
- Stihl 20cc exceeds expectations
- 20cc Stihl in a 60 size f4U?
- Ryobi 31cc flywheel
- Pumped carb and pressurized tank
- Nitro 1.20 to gas carb question
- Homebrew muffler options
- How do you like and prop a poulan 42cc?
- What size plane?
- rcexl ignition test kit
- Dle 30/55 electroinc ignition test kit
- BFM 80 single Cylinder Engine with gear
- One way to make a prop hub
- Planning ahead is important
- wackerengines.com shut down temporarily
- Weird Walbro problem...
- Stihl 25.4cc - Looks like a good one...
- small engine shops
- Mounting the engine
- Walbro's with accelerator pumps.
- EI Timing for conversion engine
