- Aurora 9 issue
- No Head Tracking on Aurora 9???
- Help!How to prevent engine running with radio off!!!
- Rate control mix support
- X-1 Charger
- HITEC AURORA 9 TX CHARGE PLUG REPLACEMENT
- 5645's and A123's or do I need 5685MH's for safe operation and long life
- HS-85mg screw
- Old Multiplex 2010 programming information
- Can Hitec 7.4v servos take 8.4v
- Optic 6 loses comms with airplane when Tx is close to plane...
- Eclipse 7 trims
- 7980 Servo
- 7980 slow to return to center
- Problems continues with Hitec 5485 servos-BEWARE
- Updates?
- Optima rx voltage?
- HPP 22 programming
- RECIEVER BINDING
- Twitching Servos
- Problems with the tail t-rex 600 nitro and aurora 9
- Hitec Modules
- Aurora 9 with Dual Elevator Servos
- Any reported issues with Hitec H5485 servos?
- Hitec hours
- Aurora9 ashamed for supporting Hitec
- wiring spc and ubec?
- Hitec RTF airplanes shown at WRAM show
- pc interface
- PC Interface
- voice module
- Spectra 2.4 Module Blinking Blue
- HS-65MG/HS-5065MG Gear Set Question
- Hitec HFP-25 Digital Servo Programmer
- Optima 6 BEC/throttle
- Optic 6 Throttle Setup
- HSR-5995TG
- Prism 7X upgrade to 2.4 ?
- Eclipse 7,not modulating rf output??
- Low voltage warning using LIFE batterys
- 2.4 Module Lights
- gps & voice module
- 2.4 Module Beeping Twice
- Centering Accuracy
- hpp 22
- Minima 6E range
- program hitec aurora 9 for delta vortex
- HS-5085MG: What is a proper power supply?
- HS985MG servo issue
- New HS-65MG Mighty Feathers ?
- Multiplex Profi 16
- problem getting throttle to activate in idle up on aurora 9
- software versions
- Gear sets for 7955 and 7985 Wher can I get em.
- RPM sensor
- HS-985MG Question?
- Eclipse 7 Pro
- A9 free receiver
- WHAT ARE NUMBERED STICKERS ON HITEC SERVOS??
- Hitec Eclipse 7 2.4GHz
- Optima 9 reverse polarity damage
- Aurora 9 Screen going blank
- Servo programmer/tester
- Brand new HV Hitecs, loose arms
- HV servo installation
- Aurora 9 screen sensitivity
- Optima 7 Receiver
- Aurora (Scan vs Normal confusion)
- IPD Reciever
- Hitec Aurora 9 keeps shutting off by itself Help!!!
- servos true power?
- extreme problem binding optic 7 reciever to hitec aurora 9
- eprom not saving my trims in Optic 6 perpotional
- Problem Futaba9Z and Hitec 2.4 module
- HS-5585/5565 mg servos
- 40% setup
- PROGRAMING ECLIPSE 7
- X2 Multi Charger
- Engine kill devices
- Bind the rec
- arm hold down screw
- OPTIC 6 SPORT 2.4 - Firmware update V1.02(0)
- HPP-22 program file V1.12(0) now available.
- Hitec 555 receiver-no range
- Spectra module for JR9303 (PCM9x)
- Optic 6 2.4 Sport question
- Hitec Aurora - problem with mixes
- Service question
- Telemetry for iphone
- Optic 6 Sport error indication
- How to fix broken / cut servo connectors
- HS-5955TG burn and smoke
- Programming Aurora 9 - Elevon mode
- OLD/NEW/UPDATED VERSIONS OF HITEC SERVOS
- Minima 6E Channel 2 and 4 swapped
- Hitec aurora 9 version 06 and glider application
- New eclipse update?
- Convert Optic 6 BACK to 72 Mhz
- Module Beeps When Elevator stick is moved
- scan mode/function
- programming aurora for delta vortex
- Any Current or Near Future Promos?
- Programming a Servo for a slower speed
- Hitec servos with Futaba receivers
- 645mg's getting interference
- Telemetry w/ Eagle Tree EGT Probe
- Aurora VS Eclipse 7 pro
- Optima 9 - Fuel Level Sensor + Gas & Glow
- Hitec
- Telemetry User Manual
- replacement gear sets. 5985
- dual elev on eclipse 7
- power down out put too high??
- Optima 6's & 7's
- Hitec Optima 9 LOCKOUT
- Lock out problem? Two planes lost
- Hitec 2.4 JR Module "PROBLEMS"
- Optima 7 receiver almost lost my plane
- Aurora 9 data to pc back-up
- 2.4J module for a 11X????
- 2.4 receiver antenna
- Aurora 9 updating help
- RCD 3500 receiver
- trex 500 problem
- Hitec hs 985mg servo noise
- telemetry
- 79XX servos, resolution programming?
- HPP-22 download function
- HPP-22 Upgrades
- Optima RX and HV servos
- throttle lock
- Optima 6 Lite won't bind
- hobbyking 15A Ubec. TR-UBEC15
- Hitec
- Multiplex Servo TITAN SHV Digi 5 Torque
- NiMH battery for Aurora 9
- what size model for 6T
- Individual throttle control Optic 6
- Instructions Questions
- Response time
- Hitec DIY sensorstation - Open Source the A9 -
- HP-20 Servo Programer
- Hitec 5 channel Micro Receiver use
- New Aurora 9 owner... 3 quick questions
- hpp-22 - Run-time error 13: Type Mismatch
- Competitive priced Hitec 2.4GHz receivers ???
- 2-positions switch G not working as expected
- Blue light when linking.
- Download site down?
- HPP-22 Runtime error (Answer from Hitec)
- HiTec Modules
- Aurora 9 Receiver Battery Voltage Not Displaying on Transmitter
- Aurora-9 Transmmiter Battery
- optima 9 reciver battery
- Hitec Supreme IIS channel assignments
- AURORA 9 RX BATTERY ALARM.
- Aurora 9 - Minima 6E will not bind
- Multiple Hitec 5645 Servos
- Aurora 9 - Ability to use seperate channel to change another?
- Optical kill and AFHSS - any advice?
- Hitec Focus 3
- FMA USB interface and HPP-22
- Aurora is driving me NUT'S
- 5496mh servo problem
- AURORA 9 DATA TRANSFER WITH PMIX
- high voltage servos question
- Aurora 9 "AUX"
- I have problem in my Hitec Aurora 9ch 2.4ghz(SOLVED)
- 5625s sub trims don't line up
- Hitec Optima 9 Receiver
- channel 7
- HS5945HS test
- Eclipse7 conversion to 2.4
- Aurora Tx.Password.
- early Multiplex geared prop unit
- Flaps
- Hitec Aurora 9 - Throttle to elevator downline mix question
- Hitec Eclipse 7
- Hitec Focus 4
- 3 Position Flaps
- Hitec HS-985MG Problem
- Aurora 9 + Left Slider + Flaps
- Touch Screen pressure
- Where to buy a module for JR
- Aurora 9 + Futaba Trainer Box Compatibility?
- Aurora 9 Landing Flight Condition
- Aurora-9 question
- Naming Models
- Spectra module in Futaba 8UAPS
- Aurora 9 v1.08 Update
- Aurora update to v1.08
- Aurora-9 throttle state
- retractable tailwheel lockout?
- hitec servos and orbit power jack
- Change from Scan mode to Normal mode - Optima Receiver?
- HS225MG question
- SPECTRA PRO and SPCM!!!!!!!!!!!
- Hitec A9 Warning-Ignition Kills
- PROBLEMS WITH HITEC's HIGH VOLTAGE SERVOs
- A9/Optical Ign. Switch Bulletin?
- optima rx batt warning
- Hitec 7955TG problem
- Aurora 9 touch screen stoped working
- Throttle limiter Royal Evo 9
- hitec 2.4 module for JR 10X
- Hitec X4 help needed!
- Quivering 7950 servo
- Eclipse 7 three way switch
- Which are the important direreces between optima and minima rx
- Need Help Linking New Rcvrs to Aurora 9
- Optima 6 antenna location
- Aurora Mode change problem
- Reciver problem
- Receiver Selection
- How to receive training Aurora 9 2,4 radio from Futaba or Jr 2,4 masters?
- Aurora 9 telemetry fuel sensor
- What's up with the spectra pro module?
- Aurora 9 relinking problem
- Question on Aurora 9 Curve point
- Thw best !
- Kevlar fuse and 2,4 ghz
- Help with Hitec & Corona
- Programing ? on 5645
- flaperons
- Hitec Optical RPM sensor range...
- Replacement for Hitec 5945 Servos
- Freedom 9S & ID
- optic 6 has stoped working
- Optima 9 antenna
- Disassembling Hitec HS-7955TG, how?
- Aurora 9 Update issue
- Optima6 receiver problem
- Telemetry GPS
- power reccomendations for A9 setup
- New A9 Screen Issues
- Spectra Mod (pn 28315) w/ Futaba 9C ???
- HS-985MG behavior - Is this Normal or need to be fixed?
- Question about aurora update
- y harness on channel 7
- telmetry hitec
- HPP-21 ????
- Servo Programer software link no good?
- Jr module- Built in Antenna
- Hitec HTS-Voice Telemetry Voice Announcing System, anybody have one..??
- Aurora 9 Delta Wing programming
- Flaps
- Pico transmitter
- Programming Question 7955
