View Full Version : Engine Conversions
Pages :
1
2
3
4
5
6
7
8
9
10
11]
12
13
14
15
16
17
18
- wonder if this yard trimmer could be adapted the price is right 49 bucks
- 50CC saw engine
- Echo/Kioritz 21cc magneto mount
- Harbor Freight Save 20%
- Removing Clutch on HomeLite ST-385
- Ryobi 26cc 4-stroke info here
- Echo clutch tapped for propeller??
- 23.9cc Stihl
- Ryobi conversion parts question.
- Plane for Ryobi?
- Mac 32 conversion for sale
- ryobi 31cc/dynaflite chipmunk combo
- makita 4-stroke questions
- engine cleaning
- Ryobi 26cc Four-Stroke
- Poulan 46cc help/parts
- Echo/Kioritz Coil Question
- Pulse hole question
- Anyone seen a Swindawa?
- 26CC COMING
- new plane
- Ryobi woes
- 26cc 4cycle what plane
- homelite 30cc with CH ignition
- 26CC 4 cycle $90.00
- Honda GX Series -- Which Engine? What Plane?
- Featherlite 21 + Twist 3D ????
- Will a small gasser work?
- New to coverts/ engine advice
- Homelite 45cc
- Cessna 182 looking for power
- idle adjustment ?
- C&H Ignitions
- Carb Question
- Homelite 33cc saws on sale at Home Depot for $80
- Max RPM @ 3/4 , lower RPM @ WOT
- weedie and cheap plane
- new troy-bilt trimmer, 22.5cc pro engine?
- RYOBI INSIDE A STIHL?
- Kioritz 21cc crank adapter
- walbro cleaning, paint thinner ,poliuretanic thinner is sure?
- 70cc conversion?
- Figuring out mount location
- Mac 28, first run
- McCulloch/Ryobi Weedy
- Attempting gas conversion
- Homie starts...won't run!
- Dynaflite Decathlon needs and engine
- Bargin Carb Buy or Not?
- Ryobi RPMs ?
- 21cc Trimmer Power
- MOVED: Ducted Fan 0.91R BVM
- need a walbro link
- 11mm carb for Ryobi 31
- 25.4cc engines
- walbro carbs with accelrator pumps
- Would the ryobi 31cc work in this plane?
- Homelite 30cc blower
- Ryobi Powered RV-6
- poulan 42 with ch ignition wont run
- Freebe engines
- best conversion engine?
- TORO 25cc gas conversions???
- Echo/Kioritz 58cc engine??
- starter question
- Fun Fly Roadrunner and Ryobi Conversion
- YTD725 Information needed
- McCulloch 31cc w/ Rear Exaust and Carb, is it better?
- QUESTION FOR WELDERS...
- Model Engine Building Website
- Homelite HK-16?????
- honda gx31 prop
- engine volume ?
- Poulan 42cc
- Stihl 041 AV
- zenoah G62 conversion by Melody RC
- weedeater engine round exhaust port with springs on muffler
- New Hub Keyway
- 80 cc fourstroke backpack blower
- stock mufflers
- Side Port Ryobi? 30cc
- maybe the lightest 45-50cc engine conversion? 38 oz.
- Conversion of McCulloch 28cc, can someone help?
- MAC 35cc Chain saw
- compression range for weedie/chainsaw engines
- What engine is this?
- King Kong
- Glow and Gas
- Reverse rotation
- Weight vs. displacement
- Zama Remote Primer bulb?
- HomeLite 25cc assorted issues
- Poulan engine parts, where to get them?
- Can anyone identify this engine?
- Is a McCullough 31cc easy to convert?
- My first Homelite conversion
- Toro won't rev
- Weedeater porting question
- Poulan 3400 chain saw engine?
- Mac 38cc on a Giant Big Stik
- Walbro carburetor pressure nipple
- Fuel Tank and stopper for Gas???
- CAM GROUND PISTONS
- recognise my engine please
- Homelite Magnum III 3.55 ci power issues
- Yak 71" & Brillelli 25cc gas , How well they match?
- SCORE! Mitusbishi 42.7cc... Anyone know it?
- DIY STEEL MUFFLER
- Have 2 carbs, need info,Walbro& ZAMA
- Deals
- 55cc Poulan pro
- Honda GX35
- MOVED: Tunning an os 46 fx
- Anyone have experience with these conversion engines
- MOVED: new 40cc enter level gas engine from China
- Mcculloch 32cc Weedwacker
- gas plug conversion for .40
- Mag vs. electronic ignition?
- Mac 38cc - What do you think about this engine?
- Ryobi 26cc model 2 and model 3
- Engine Selection?
- Conversion newbie with a McCullogh 282
- Poulan 42 muffler
- Starting Poulan 46cc
- help!! my engine's busted
- Great source for engines
- Kioritz Echo Question
- boost bottle
- ignition timing
- WYL Series Walbro Suitable?
- Ryobi 26cc hop ups
- Zama Carb Question
- WHAT A DEAL
- Homelite 25/30 and Spinner Nuts(Safety Spinner)
- mounting upside down
- port timing
- Latest, Best, word on HONDA GX31 carb??
- 30cc Gas = ???? 4 stroke OR 2 stroke ????
- Robin 2 Cylinder Motor
- homebrew dyno
- 55cc Homelite, looks good , don't run
- 3-4 cu. in engine for conversion?
- 26 cc 4 cycle
- mac conversion
- Help with homelite 45
- Velocity stack & walbro craburetor
- 34cc sprayer engine from India
- cdi timing question/
- carb question
- Homelite Headgasket
- briggs and stratton 4 stroke
- Homelite pipe
- Gas Engine mounts? ?
- Walbro Carb w/2 Fuel Taps ???
- Toro 25 prop hub
- Homelite/Ryobi 30cc
- Is this Homelite/Ryobi weed-wacker good for a conversion?
- Lathe
- S/S electronic ignition (Pics Added)
- "CONVERSION GASSERS... Taking over my fleet!!
- Worth the effort?
- shindiawa t230x tach readings
- ECHO carb #
- New engines
- Removing Compression Release on Honda GX25
- Identify this engine!!
- GT-80 Converted to 124cc?
- Poulan 46 with syncro spark
- walbro carbs
- What is this??? said 25cc on tag
- Cox Medallion .15 conversion C/L to R/C
- twin conversions
- TORO HI TECH TERD NEED EXPERT HELP
- where to find engine?
- Engine sizes
- Exhaust question for the experts
- Tanaka Engines
- Ryobi From Harbor Freight--Compression Relief Slots??
- Homelite 25/30 backplate question
- stihl backpack fourstroke
- MOVED: What happened to my subscribed forums?
- Weed eater brand leaf blower Model GBI 22 ??????
- radio interference
- ANOTHER ECHO 23.6 JOB
- hand starting a ryobi
- MOVED: carb for a Saito 120 - 150
- DYI PROP ADAPTER HUBS
- How to convert from Points
- Ducting a weedie? More out of the box thinking.
- Stupid mistake.. Need a new Ryobi Flywheel
- new to this..questions
- Is this a 'standard' short-shaft Ryobi?
- Conversion
- Ryobi 31cc Hop-up question
- Old Stihl 041 Farm Boss
- What magnets for CDI pickup?
- Stihl 023C conversion
- Homelite 54cc Bearings Question
- Online Kioritz parts supply?
- Who makes the engines in Weed Eater brand trimmers?
- 21cc Kioritz: glow or gas?
- Mac 32cc
- Mac Engined ID help (upotate: Kiortz?)
- Video of Honda GX31 on Rascal 110
- Another spring starter question Poulan 55cc
- Stihl 032 success
- Flywheel - is this safe?
- My First Homelite conversion
- Poulan Chainsaw reference need one!!
- 14cc Kioritz, got any?
- Kioritz and other engine conversion parts
- Craftsman Eng.
- Ryobi 33cc Parts (Cyl, Piston and 2 Rings)
- Shorten the stroke. Good idea?
- Spring starter
- IS IT POSSIBLE TO CONVERT A WEED WACKER INTO A PLANE ENGINE?
- exaust modifications or custom pipes?
- Ok, I'm in!
- Opensource CDI ignition
- Ryobi Conversions for the Aussies
- Timing CH Igniton on a McCulloch 38cc question?
- husqvarna 345 conversion
- HomeLite 25CC pistion Question.
- Starboard
- home made coils for CDI and kettering ign's?
- Poulan 46 weight
- craftsman 55cc anyone done one??
- Lawnboy
- Honda GX35 Now Available
- HomeLite 25cc Zama Carb screws
- Stihl FS61
- Please ID this unknown Engine!
- Carb Insulator
- Poulan 46 prop sizes
- Spark Plugs
- Robin Engines
- weedeater XT50
- Weedie convert
- walbro carb
- Cutting prop driver key-way
- shindaiwa t230x conversion (weed eater)
- Ryobi and H9 PT-19
- PRO MAC 610 Conversion
- Stihl 041
- velocity stack
- What to use to seal engines back up
- Ryobi 31cc 3D CAD model
- Stihl 044
