PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Pusher eagle
  2. Dowel joiner seems weak.
  3. Have an Enya .90 need plane, suggestions?
  4. Happy New Year
  5. Tissue Vs. Monokote?
  6. landing gear piano wire angle
  7. Black horse super air C of G needed
  8. Need trike gear second plane for son
  9. Which would be best
  10. Engines
  11. Thoughts?
  12. Stick 75 problem
  13. Inherited Hobby (Newbie!!)
  14. Need some guidance on fuel
  15. Newbie!
  16. Introduction to Glow Engines
  17. Help with motor mount choice
  18. Is this tubing Tygon or silicone?
  19. Meet a Newbie
  20. Newbie park zone 300
  21. Wish you all a Merry Christmas
  22. COG question
  23. Tri Gear versus Tail Dragger
  24. Tip for posting pictures here.
  25. Battery Basics
  26. What size spinner to use?
  27. ElectriFly LiPo battery packs
  28. O.S. 46LA ABN Frozen
  29. Maiden flight
  30. First trainer kit
  31. Controlling a Brushless Motor without a Radio System?
  32. 1st plane thoughts
  33. John Buckner
  34. taildragger astro hog
  35. dumb me/electric
  36. Engine mounting question??
  37. OS .46 la problems
  38. How good is this landing gear?
  39. How many mAh can I increase to?
  40. What size receiver battery
  41. Hyperion EOS SENTRY V2 Battery Checker
  42. nitro foam trainer?
  43. Need info on a replacement motor
  44. Dried Epoxy on Ultracote?
  45. Saito 4 stroke
  46. Wing Dragon Sportster
  47. BEWARE .. GENERAL HOBY
  48. Will a OS 120 run well inverted?
  49. FPS System Suggestions?
  50. Are there any good props made in the US?
  51. Best tips for DX7s
  52. LiPo battery low voltage
  53. Breaking-in New NiMH Batteries
  54. Battery converter connector cables
  55. best 4 channel trainer
  56. RC Flight Timer Phone App - I found a free one
  57. O.S. FS-120S Water Damage
  58. How to bend brass fuel line
  59. "Toys" thread moved to "The Clubhouse"
  60. Electric or Glow Trainer
  61. Futaba 6xa troubleshooting
  62. dynatron starter with makita power supply
  63. Cutting carbon fibre sheet
  64. Trouble Binding DX5e with Spektrum AR500
  65. Brand New T-28 Wasted
  66. What size servos for a 120 size plane
  67. Attaching a 10mm prop to a 8mm motor shaft.
  68. Electric Model for Beginner?
  69. Nitroplanes Black Friday/Cyber-Monday Wish-List
  70. .40 GP Piper J3 Model Kit
  71. watt meter reading questions
  72. The Physics of Flying
  73. Slow fly prop or not?
  74. Switch For Du-Bro 207
  75. How do I slow down?
  76. Hank Williams Jr
  77. Next plane after HZ Mini super cub
  78. Ok, I'm a hooked newbie.
  79. How can I fly my Vapor slow?
  80. Futaba S3152 servo rotation
  81. flying With the wind..
  82. First flight of my Avistar Elite
  83. Ultra Stick Lite 120 ARF by Hangar 9
  84. Need help making a body for these parts
  85. EASYSTAR 2 help
  86. Thunder Power Charger HELP!!
  87. need help in avatar design
  88. Best way to transport plane
  89. Balancing a Trainer
  90. First Eletric Trainer
  91. Flying to the clouds
  92. Battery Balance / Charger
  93. weights and balance in a Big Stik
  94. Wing Ribs & Covering
  95. Which ARF Trainer ?
  96. CA Kicker Home Brew?
  97. hitec servo voltage
  98. Futaba Receiver Question
  99. Aleron Problems
  100. Hot gluing a wing servo ?
  101. Suggestions for first kit for 13 year old
  102. T-28 or Super Cub
  103. soldering problem
  104. Engine for Tiger 2 Kit
  105. Pull pull setup ?
  106. Trim Covering ?
  107. Is Hobbyking foam low quality? 1000mm Corsair Electric
  108. How to build Tiger 2 with Titebond III
  109. Engine, back plate troubles
  110. wiring help?
  111. How much trim is to much?
  112. Second plane?
  113. Choosing Servos
  114. Pushrod Clevis Solder ?
  115. Too many to choose from! First Ultra Micro help!
  116. Help needed!
  117. Need aerial photos, where do I start?
  118. very first airplane-where do i start?
  119. tower hobbies glow engines
  120. Assistance please.
  121. Rich-Model Yak-54-380 ????
  122. Unsure about reinforcing
  123. I think I made a good buy
  124. Antenna Exit
  125. supercub foamie
  126. Winter Build Giveaway O.S. MAX .40 FP Motor! (Open Till November 25 2010) TheDaveyht3
  127. Elevator and Stabilizer Spacing?
  128. More Push Rod ?
  129. Foam Padding Alternatives
  130. Glow driver servo frenzy! :)
  131. Did I pay too much? Ultimate Biplane
  132. To the Wind, I LAUGH in your face!
  133. Thicken Epoxy?
  134. Minnflyers witch
  135. robbe futura gold
  136. Gold N Rod tips?
  137. Propeller Installation Question
  138. Servo Arms?
  139. a 2nd plane for me
  140. my first 2 flights
  141. what is it?
  142. 1st Part Covered ( Go IU ! )
  143. Advice for Newbie
  144. kit building, tail vs nose weight
  145. Rudder Pushrod Grommet
  146. Erotic idling
  147. Alkaline Rx batteries
  148. Beginning Covering
  149. RC newbie with a unique problem
  150. programing futaba 7c 2.4
  151. Throttle Linkage ?'s
  152. futaba 7 c
  153. Long time member just inherited engines what to do?
  154. 20~35cc gas trainer
  155. silly question, what does it mean by "brake function?"
  156. Greetings from NC
  157. Good foam plane for indoor
  158. Just getting started
  159. SERVO RETRACTS
  160. What size motor for my plane??
  161. Having trouble on first start. Need some help
  162. Sharp New Prop
  163. Sig 4*20EP Build
  164. Rcexcell optikill and Rcexcel tach
  165. NiCd vs. NiMH Transmitter Battery?
  166. Film Coverings
  167. Looking for and 80" ARF for .91 4 stroke
  168. What happened to RC superhero?
  169. weedeater plane idea scrapped next idea
  170. Ca hing
  171. help cycling RX pack
  172. I need some new batteries
  173. weedeater powered coroplast cub beginner
  174. Collapsed wing rib.
  175. Stick plane
  176. What plane has similar flying charistics as Spacewalker
  177. Second plane
  178. Chargers
  179. Fixing Foamies
  180. New teacher from South America !!
  181. Help with first plane choices!
  182. Motor Mount Size?
  183. How to bend 1/4 X 1/2 balsa
  184. engine stalling problem
  185. Getting back into the hobby
  186. Guanli pby throws
  187. Second plane after Champ?
  188. I want to try 3 blade prop. Am I getting the right size?
  189. First flight with the HZ super cub
  190. Noob needs some help lol
  191. Installing icing on the cake
  192. Don't buy from this company
  193. H9 1/4 Cub ARF
  194. Explain this please
  195. Transmitter operated kill switch ( toks
  196. Lanyu trainer
  197. Tip of the Hat to Horizon Hobby
  198. Building a large foam plane
  199. Mufflers for gas engines
  200. Can I use Epoxy on A Foamie?
  201. BEC 5amp enoguh for 6 servos
  202. What plane (brand new to hobby)
  203. 1st time airborne with my HZ Super Cub
  204. CG Help With 1/4 scale extra 300
  205. Pusher star
  206. manual for fliton inspire 60
  207. Super Sport 40s
  208. Battery choice
  209. Are Pattern Planes Good 2nd Planes?
  210. Omega 15% non 4 cycle blend
  211. HK Orders
  212. What do you think of my trainer upgrade
  213. Which RC Plane to purchase as a gift??
  214. Radio Equip. Needs Question
  215. Twin .61 prop question
  216. Tail wheel steering fixture
  217. Almost Sod-Rocketed Her Today
  218. Lustercote Dove Grey
  219. Setting up control thows
  220. Running brushless at less than rated volts?
  221. How many MA are these batteries
  222. can 800mah lipo be used with twisted hobbys crack yak
  223. A.R.C Ready 2 plane help
  224. Spektrum DX6i Rudder Issue
  225. Need a project for OS.15LA
  226. Cox Sky Cruiser RTF Review - A Beginner's Tale of Learning to Fly RC Plane and Glider
  227. 3 ch to 4ch.??????
  228. What's the proper method of a barrel roll?
  229. Looking for a set of plans
  230. Which is lighter CA or Titebond?
  231. Good parkflyer
  232. What to use to hold screws in?
  233. Anyone Near Bigfoot IL?
  234. Got my wings, what now?
  235. What's the Difference in these Airtronics Tx?
  236. discussion: gas power trainer
  237. Free fighter jet plans
  238. Alpha Trainer Problems
  239. To all who recomended the 4*120 for my DLE20
  240. 4 Stroke Throttle Linkage
  241. aging receiver failures....
  242. Motor replacement
  243. How to Fiberglass ?
  244. Rc su29 onboard camera maiden Evening flight :D
  245. How to get your plane outta of a tree ?
  246. Glow Tank Stopper Leaks
  247. Pre-Maiden Jitters
  248. How to send On/OFF to aircraft
  249. Which Iron ?
  250. Deals on Transmitter/Receiver
