View Full Version : Beginners
- prep work
- iron sock
- Happy Mardi Gras
- Futaba 7c 2.4 GHz
- What To Expect From A 4-Stroke
- Need help on a buy..
- Converting a planed designed for electric to nitro
- More than one RX for JR 2.4?????
- Rate my R/C Airplane pics!
- Where's the epoxy at Wal-mart??
- DSM technology
- how to set/check engine thrust angle
- What part of the build do you like the least?
- AMA, MAAW
- I think the hz super cub was a curse
- Longer servo arm for airtronics 94162 servo
- Is it a crime flying R/E only?
- GMS 1.20 good engine?
- MS composit P51 balance
- servos
- FASST rx mounting question.
- retract servo
- RCKen, Minnflyer
- Getting rid of toxic materials
- Beginner's resources - Links to useful information on RCU.
- Altimeter and Air Speed Indicator???
- Electrafun XP
- IT keeps getting BETTER!!!!
- Mounting an OS 55 inverted
- What amp to field charge Nicd batteries?
- Cherokee to good to be true?
- Top Flite Piper Arrow Maiden
- FINALLT THE WILD BLUE YONDER!!!!
- Mixture Setting
- CA glue in the torque rods
- Are thunder tiger 4 stroke engine good?
- buddy box
- Well no more F22 Raptor
- covering
- minnflyer videos
- Cherokee Flap Help
- Noobiest of Noobie Noob Question
- If you can fly this, you can fly ANYTHING!
- Which would you choose?
- Spektrum DX6i setup
- Tite bond glue? fuel proof
- Anybody getting the free rx from tower?
- Surging motor
- How good are the magnum/TT 4 strokes?
- Tiger 60 - trike or Tail dragger?
- SSE Aeleron horn position HELP plz
- Pre-flight
- seems like a good deal?
- prop for hobbyzone supercub
- Low Speed Needle on Maganum 180 4 stroke
- Pilot for my pulse 40?
- Looking for a prop washer for GMS .61 engine
- airtronics to simulator option
- The "slot machine" tool really is GREAT!
- rpm vs HP ?
- Spektrum Resolution?
- New to these forums and Exceed EDF
- Help New Plane Wont Fly?
- camera on airplane
- Need a bigger starter for my Mag 180 4 stroke
- These servos any good?
- What Did Your Valentines Day Bring You?
- servo qustion
- In Need Of Your Expert Advise
- Prop shape question.
- JR XP783 reciever help
- What a difference a prop makes!
- how much power does a tune pipe really give?
- Anyone know of a Machine Gun Sounds Kit For Airplane?
- longer deflector
- Electric "Flat out"
- Saito FA-82 glow plug
- mounting bigger engine on F22 raptor
- Nose Wheel linkage
- saito FA91S help
- Hinges
- All Charged up and
- Is this a good engine to use.
- Servo size
- JR Reciever question!!
- New to planes
- nylon hinges
- Is this a good price
- Acros with my plane
- set up rx
- Teaching to Build
- Headaches with Glue
- Li-Po question
- TXSERVO
- Monocote question
- Hobbico battery help
- My next plane
- what prop do i need
- Charging a LiPo
- Joining AMA
- AK - models, j3 cub
- Modeltech fun fighters P-51?
- Question on Futaba 2.4GHZ Module Add
- fly zones
- Newbie looking for good charger and battery questions
- RC fuel question
- Minnesota Frozen Float Fly (Part 2)
- Rx battery questions
- EXTRA 300S 60 115.99
- wing struts
- First Kit Build (4*40) Prep
- Transparent covering
- Overcharging batteries?
- Newbie Question about plane weight
- ultracoat
- balsa wood glider
- Micro Telemaster setup
- Elevator use during landing approachs
- from a newbie, to newbie's
- Hobby City no good. Anyone else?
- Sheeting a wing
- Determining 3-Blade prop Size
- Refueling System
- Anyone Flying a Goldberg Falcon 56 ARF?
- HS55 servos
- Well,..............It finally happened
- Newbie Plane ?
- complete noob question
- kitbash fourstar 40 with a p51
- What's A Good Online Source for Xoar Props?
- PIPER CUB ARF
- GMS 2000 47 won't run
- Is there a washout on a 1/4 scale cub wing
- 2.4 mode 1 or mode 2
- Better 3rd plane
- warped fuselage solution..
- battery maintenance
- Help with Extra 300S
- Screw assortment
- Really confusing crash (Added pictures and possible solution)
- Best motor for Micro Telemaster
- Robart hinges: after the fact
- What does ACRO stand for?
- Futaba 2.4 faast rx battery - the right one?
- Maiden Flight
- Flap Hinge Repair Help
- muffler spins
- parts for a tower hobbies engine
- Looking for best floats
- Hex Drivers, Ball Drivers, Nut Drivers, Oh My!
- Wing jig question for friend
- Did I Do Something Wrong....
- Futaba RX question
- Servo problem HS-82MG
- Saiton Fa-82 prop
- What is washout?
- Carbon fiber and RX question.
- CA HINGE INSTALL HELP
- Game experience help at all?
- breaking the sound barrier
- Spektrum Flight Log
- OUTLAW no more...
- Glow plug
- Edge 540 Maiden Flight
- Maiden Flight of rebuild...
- 6v batt. in futaba 4vf
- What do you think
- Carb Help
- DX6I and Slo-V Issues
- Prop/engine question???
- Blade Dancer
- what is size 40 or 60 or 90
- Anybody had a jet as your first RC aircraft?
- Is a 1.20 to big?
- Best beginner aircraft...
- Servo "buzzing" noise...
- Need help with thrust problems
- Tuborix 6Ch FM Futaba Type CCPM Radio - 35/40/72Mhz
- is this possible (help w/ dynaflight butteryfly)
- Newbie Fuel Question...
- cherokee 40 glow/2nd plane.........
- hi-band vs. low band which is better
- Aerobatic Maneuvers
- Power Plant for Falcon 120
- Servo J vs Servo U
- cuting the dihedral
- JR crystals
- what ep for Bird dog
- what is chordwise
- Frozen glue
- OS engine for Phoenix Tiger60
- mounting the tail
- Ernst Charge Receptacle...?
- Sim pratice question
- short term "Intro Pilot" program
- help with fsone
- H9 Hellcat 60 Help
- how well does the super stick 60 fly
- Reciever battery question
- experience with AP Engine
- Cool but Strange Find
- flaps or flaperons
- scouts want to build a plane
- What porp should I use.
- Important Notice: C-5 Galaxy post on this this thread
- Throws for 3D Edge 540 .46
- prop question
- Can a Futaba Changer fry a JR Radio?
- 1st plane ? electric or nitro plus other newbie ?
- banner towing rc plane
- What hapened to the C-5 thread?
- FM 72 mghz question
- now the cowl!
- balsa lenths
- r x question
- FMS Landscape
- JRSX600 or Spektrum DX6i Radio
- help with sim question
- me 109
- Anyone ever fly the Big Bingo
- A week of stupid mistakes
- dumb mistake, now what?
- Thumbs or 2 fingers??
- rebuild with coro
- Problem with a PZ Corsair
- Servo/Receiver Help
- A freak misshap or a problem?
- modified nestar question.
- First time covering
- Pactra primer/sealer
- Hangar 9 F22 Raptor question
- What wheel collars?
- MIXING RECEIVER & CRYSTAL BRAND
- What is the proper way to shorten servo leads?
- fuelproof firewall
- aileron to main wing gap
- What is a good slow flying scratch build
- ok.nojets. so any warbirds?
- Help! Skyartec Cessna brushed 290
- Great Planes Extra 300 40 Size
- Beginner but not scared
- Will a Flight Leader power panel work with a H9 battery
- Parkzone T-28 Trojan center of gravity
- Buddy Box ???
- Video - Maidened my first airplane outside yesterday.
- oracover
- Bubbles in Fuel Line
- HELP! think I screwed up my kit
- Warped wood
- Newbie to airplane..
