View Full Version : Beginners
- silicone and glow fuel?
- Getting Rid Of That Trainer? You Might Reconsider...
- We grow some soft trees up here! LINK FIXED
- Four star build
- Cleaning CA stain???
- I got my Alpha Trainer
- CA Glue
- Help assembling Sig Kadet LT40
- Evo .46 NT question
- transition from stordy bird to Arrow trainer ?
- 46AX break in
- WM Intruder-90 w/retracts
- stiff aileron on sturdy birdy wing
- Converting to Tail Dragger?
- Radio frequencies. Buddy box
- Push rod flex
- Do you know of such a place?
- First flight on tower trainer and balance issues
- fuel line setup in a cowled airplane
- Biulding questions
- First Flight
- advice on which trainer plane needed
- Tail Heavy Foam Wing plane
- Oops...
- aerobird challenger
- Servo Chatter?
- First spin in the new plane
- starting over?
- Are RTF Glow Airplanes the Future of Our Hobby?
- Trim Stripe Question Kadet Senior
- wind?
- battery charging ?
- Park Zone Decathlon and J-3 Cub
- Engine Cutting Out
- Sig Senior ARF engine selection?
- Third Plane Looking
- Nice old guy and $1.09 worth of parts
- Help
- easy star multiplex
- landing gear problems with NEXstar
- SOLOED my PT-40 Trainer!
- Repairing Sheeting
- Need pic of 7c
- Cowl butchering
- Newb radio question
- Side mounting engines
- A very interesting Maiden of Alpha 2
- Power supply question
- Has anyone delt with RCM RCModels.com
- aileron rolls with a trainer
- Kadet Senior ARF assembly questions -
- Hangar 9 Mechanical Retracts - Lock Plate Help
- Ordered the Fourstar
- Engine break-in without wing?
- Maiden of the Tower trainer
- cg ?
- 3 Channel Flying?
- Arrow Semi-Semetrical
- Why only 2 prop?not 4 or 3?
- Metal Clevis
- Four Star 40 instructions
- Kill switch
- Precedent Hi-Boy
- Alpha Trainer / JR Quattro with Hitec?
- Servo jitter
- The strangest thing just happened!
- 3 channel radio setups
- tips for first time build
- Beginner Question
- Alpha Trainer I think I Found What I Want
- advice.
- K&B 61
- Stick question
- I'm in a pickle! please help me dicide!
- Ultra Stick and JR XP6102
- Fuel tank with no foam
- Beginner's Question For You Guys
- Firewall and blind nuts...
- Hobbico VoltWatch Receiver Battery Monitor
- first time flyer
- Beginner Could Use Some Help!
- Wattage P-51
- SERVO QUESTION for Futaba 7CAP
- Mechanical retract question
- K&B .40
- Tracker radio transmitter
- Quick prop question
- Want a little more power - Prop Question.
- Prop size with the .46LA
- Elevons..uh I think..
- ASP Super 52, plug eater???
- How much extra weight can I add to my plane????
- rc plane virgin
- Reinforcing Stab and Fin, Part 2
- first flight today ! woohoo !
- MOVED: Little Toni
- about to trash a o.s. 40 PF
- What Radio "FEELS" the best/not Features
- First Plane
- SSE CG
- HOW TO GET STARTED?
- Engine starting
- ASP engine
- range : 2 feet
- Tower Hobbies .46 Idle mixture setting
- Hobbico SuperStar EP Select RTF w/Ailerons Newby
- Manual for Irvine ABC 40.
- Question: Flight time
- Help me help a special six year old...
- Crashed my trainer today
- OS .46 FXi problem (from NexStar)
- Quick Servo Question
- Hobbico Superstar...Stronger than Dirt
- Im back!!
- Micro motor identification
- I did it! I did it! I did it!
- GP Patty, need help.......programing
- Car charger killed alternator?
- Putting balance weights on the tail
- Where can you fly?
- Does anyone log there flights?
- Pet Peeves (Don't hold it inside anymore!)
- Got aerobird, now what?
- SSE Way 2 Fast, Help
- bad aerobird crash! need help fast!
- Engine
- Electrafun XP Landing Gear Help!
- Radios? which are the best?
- SSE RX Batter Location
- propeller comparison
- Engine for a four Star
- what should i do before heading to the field for the fist time?
- Going from RC car to RC gas plane... which one?
- thunder tiger 42
- Can you make any $$ with RC Airplanes?
- OS .46 LA or .46AX
- Flair is BUST!
- Opinion on cheap RC plane to buzz around the house and playground.
- Freebies, Orange County, CA
- sub micro servo on dominator 500
- PROP SIZES
- Trainer to carry extra weight
- Field box need painting...need help.
- MOVED: A little off topic.......
- SSE Filling The Fuel Tank Pain
- Please Critque my Order.
- What radio? New or Old ?
- Broken rudder
- wing hold down rods(need help quick!)
- Help
- 14 months from sticks to covered
- First Flight!
- Finally happened, finger in prop.
- what size wheels?
- Need help with engine
- no aileron control=confusion?
- Buzzard Bombshell Engine
- Wing Joiner
- Damage Repair Questions
- School project budget plane
- which plane!
- first plane?
- My wing won't balance!!
- F-16 thunderbird (NEED RTR)
- odd motor troubles
- Question on Nexstar select issue.
- SSE Tank Help
- Searching for new plane
- The Rascal
- RC Flight schools?
- Feeling severe newbie dollar pain - need advise
- After lerning to Fly
- any tips for uproar 40 kit
- MDS .48
- its just so sad
- Hanger 9 XtraEasy2 engine size
- Engine mounting problem
- Low Rates Radio Problem
- Soloed this Weekend :-)
- Cracked wing mount
- Tower Voyager will not fly
- have i got a dodgy trainer plane?
- nebie needs advice
- Homemade Smoke System WORKED.. Thanks MinnFlyer..
- Flight Write up with pics
- Did you ever hear of such a thing?
- Unwanted items required
- Hanger 9 P-51 .60
- Pull pull or push pull
- engine upside down
- flying solo
- NEW Magnum 1.2 Four Stroke will NOT start - I'm going insane with this one
- NexStar Select Engine Issue - NuBee
- Newbie strikes again
- Plane #2 ordered.
- Newbie needs help
- All for Fun
- Radio choices...
- Question
- Q&A first micro plane
- "Funk" on the Muffler eewwwwwww
- Engine Will Not Stop!!!!
- brushed Vs. brushless
- US Plus Four Stroke Question
- Another Nexstar Post !
- adding ailerons
- Annual first flight
- Old OS Max S35 and a great garage sale find!
- Prop selection
- Wing Incidence Angle Adjuster's
- CG on Hangar 9 Solo Sport
- anybody flown ultra sport 40
- Glow plug size
- Outline of 4*
- anybody help me to buy Engines for
- Been sidetracked
- Everybody run and hide!!!
- What's the Best age to start RC flying
- which plane?
- Aileron connection
- Wrinkles on covering
- Avistar 40 w/ .46AX
- 6V Battery packs?
- Is Expo and Mixing essential for basic 3D
- Uni-Flow Tanks
- first flight success
- Looking for a first/second airplane
- Probably basic, but I'm stumped
- muffler gasket
- Flying sites
- Help a new guy
- Bad Fuel - how?
- WHY is this thing so TAIL HEAVY??
- How's this for a second plane
- Tx...Rx...Crystal???
- New to this need help
- What, ME?.... Land??
- NexStar crash and burn, what went wrong?
- Woodruff pin...a little help please.
- Total newbie needs advice.
- Flexible epoxy system
- Another twist question
- WING FAILURE PROBLEMS
- Crosswind Landing
- Quick Engine Question
- Have you broke your transmitter antenna in the prop yet?
- New Kid Needs Reality Check Please!
- Okay, all set.
- Man! I'm pumped!
