PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. GP Ultimate 40S bipe full build kit help
  2. Flight time?
  3. How Do I Stop Shaking
  4. what is the better motor
  5. Spare LiPo for Parkzone P51BL
  6. Idle while breaking in Magnum .70 4-Stroke
  7. Super Tigre Engines
  8. First Flight.
  9. rx's
  10. Max RPM Too Low?
  11. How do you choose the prop size?
  12. A good solid Tx
  13. Automatic starters on Gas airplanes?
  14. Rc receivers-questions about airplanes vs. helis?
  15. Who is a beginner ?
  16. CA hinge is toast
  17. Why are Airplane Batteries Male Plugs??
  18. Needle Valve Initial Settings?
  19. What Servo?
  20. How often do you get to fly?
  21. Hobbyzone Mini Super Cub Opinions?
  22. GAS ENGINES
  23. 6 V. NiMh care
  24. Looking for Fellow Flyers on Oahu, Hawaii
  25. Rebuild of Funtana X100
  26. Air Bubbles between High needle and carb.
  27. t Greetings from the Sea
  28. What would you guys do?
  29. 6v reciever batt
  30. TCRC Auction this weekend.. who will be there? And what you looking to buy/sell?
  31. Biplanes
  32. Taildragger Landing Technique
  33. RX Battery Chemistry
  34. Heating the Shop
  35. Eflight p47D ARF issue
  36. To Paint or Not to Paint Foam
  37. problems with e-flite esc?
  38. Receiver question
  39. Is there a quick fix for this?
  40. Frugal servo question
  41. ASP 75
  42. All I Wanted Was a Flap mix !
  43. os 46sf
  44. digital servos
  45. hot wire cutting stuff
  46. Could not do my maiden flight
  47. SSE rebuild photos
  48. glow plug question!
  49. Buddy Box Question.
  50. I'm pulling my hair out; I can't find batteries.
  51. os engine tuneing
  52. LiFe packs
  53. Airplane scales: where?
  54. More Nitro PNP??
  55. spring Hurry please
  56. Hanger 9 p51 pts
  57. My new fourth plane
  58. Futaba 7/B channel on reciever
  59. Fuel resistant spray paint
  60. Has anyone ever used hobbyking?
  61. New to the site
  62. Good all around plane
  63. where to buy
  64. O.S engine help please
  65. sUPPORT CABLE ON TAIL FEATHERS OF A sse
  66. Big stick
  67. Looking for first flyer, HobbyZone Super Cub LP RTF good option??
  68. Muffler baffles
  69. trainner cord and transmitter compatability
  70. adhesive for Lowes blue foam wing?
  71. has anyone built a cmp spitfire 50?
  72. Hangar 9 P 51 D Mustang Sport 40
  73. RPM for Magnum XLS 46
  74. Motor identification?!
  75. OS91FX with BCM Pitts
  76. Available full build kits: where?
  77. More questions about fuel
  78. Nirtoplanes and Banana Hobby
  79. How to convert a weedwacker motor to RC?
  80. How to choose propeller?
  81. Best fuel for trainer?
  82. Throttle reversing questions
  83. GLUE?
  84. nylon gear bolts
  85. Ugly stick 60 size
  86. Adding side and down thrust when the engine is on stand offs
  87. how to dry fuel from balsa?
  88. What's wrong with this picture?
  89. Stylus 40/ Sig Four Star
  90. PT 19 decal application
  91. Motor Help
  92. Three questions about trainer biplanes: How? When? Which?
  93. Begining out (again)
  94. first hot wire results
  95. Made a choice and hope that i don't regret it.
  96. Problem with Starting
  97. Sucess!!!
  98. Duraplane Trainer 40 vs. a standard PT40
  99. Fabric covering over foam?
  100. Battery/Charging question
  101. Frozen Fuel
  102. Split Elevator with One Servo
  103. MOST REALISTIC RC SIM???
  104. Airmadillo Kombat 40
  105. I'm new,...again. Need help
  106. learn to fly
  107. Why use Depron when EPP is so much more durable?
  108. Control Throws Adjustment
  109. My Wife Dont Understand
  110. hangar 9 ultra stick 60
  111. Help buying a 3d foamie + radio for under $200
  112. Engine Trouble
  113. R/C enjoyment rising
  114. Any of you NC guys coming to the swap meet
  115. Soldering clevises
  116. what are the different of the 2 stroke and 4 stroke engine?
  117. determining spinner size
  118. 2 year old fuel with hole in cap ?
  119. Prop/flywheel Evo .46 questions
  120. Foam Aircraft repair for painting
  121. A good starter plane?
  122. My Odds Of Shot Down With F M Radio
  123. Evolution .52 Issues
  124. Mount carb backwards?
  125. How do I apply monokote?!
  126. Need simple electric motor advice
  127. Rossi 65 with UTSM65
  128. How to drill straight without a drill press ?
  129. Fuel Tank Size ?
  130. My $50.00 SSE is now a pile of sticks PART 2 rebuild
  131. Two Stroke vs Four stroke?
  132. Hey,Guys,I am new and please give me some suggestions about planes
  133. Pete N'Poke First time build
  134. Looking for good inexpensive 3d stunt plane.
  135. inches to degrees
  136. Buying a New Futaba 14MZ from Tower Hobbies
  137. Increasing tank pressure when using a pitts style muffler
  138. about E-Props
  139. flycamone2 help??
  140. Which servos
  141. TailWheel Bracket Question?
  142. WRAM 2010
  143. My first Swap Meet
  144. DLE-30 and MPI Spinner
  145. Looking for a radio?
  146. low power in FMS ???
  147. Poor Man Setup- U Can Do 60 ?
  148. could It be the Fuel Tank?
  149. Propeller options
  150. Against everybody's suggestions and my own good judgement I maidened my Edge today
  151. Gnat - I'm running out of props!
  152. Best Electric Plane? for novice
  153. Away From the Cold in N. Carolina!
  154. new flyer
  155. 4.8 V to 6.0 V
  156. what is the best carger for its price
  157. tee in fuel line question
  158. Receiver for DX6i
  159. charging rate
  160. Ways to transport My planes to Field
  161. i just bought an engine and was wondering...
  162. help me im lost again, brushless ufo
  163. Instructors Forum
  164. need simple answer to carburator needles
  165. Futaba S3004 servos
  166. Mode 1 vs. Mode 2
  167. Electric Motor Specifications
  168. Hot wire cutting tips?
  169. Sig Seniorita ARF
  170. removing the limiters on EVO engines
  171. Flew today, Rebuild tomorrow
  172. Accessability?
  173. Car guys and plane guys unite!
  174. Magnum XLS 46 manual incorrect?
  175. Any thoughts on a Senior Telemaster?
  176. Nose Heavy Avistar
  177. Some Questions
  178. My $50.00 SSE is now a pile of sticks
  179. A wheeled cradle for a seaplane?
  180. Balancing a Bi-Plane
  181. Nosewheel set-up
  182. Hangar 9 Alpha 60
  183. Winter Flying?
  184. Have you ever destroyed a Slow Stick?
  185. looking for ways to store my planes
  186. PARAGOULD ARKANSAS
  187. OS .61FX Prop size.
  188. Minnesota Frozen Float Fly (Part 2)
  189. Newb, Got my first crash out of the way...
  190. New to Building, What Tools do I need
  191. Receiver installation
  192. retract servo equivalent
  193. Engine size for Telemaster 70 ???
  194. differnce betwwen RRTF and BnF?
  195. Newbi here looking for advice
  196. GWS Pico Stick CG
  197. Radio Help
  198. How wide a hot wire cutter?
  199. Evolution 45 PTS engine issues
  200. Looking for parts
  201. Parrot AR.Drone - Fly w/your iPhone
  202. Maiden flight Dynam super cub
  203. Couple questions
  204. Looking for a good Airplane online Store
  205. Engine tuning?
  206. 2.4Ghz F/A-18C Blue Angel EDF Jet w/ Brushless Power
  207. I'm Hooked!
  208. Just bought first plane, need battery help
  209. A late Christmas!!
  210. how to fiberglass
  211. How many times on the club trainer
  212. Engine suggestions
  213. dig servo prog
  214. Help Stylus Sport 40 ARF
  215. Reciever Will not charge on Field Charger
  216. HELP - Battery chargin/discharing figures!!
  217. joining wing halves
  218. HELP!!!!
  219. How to make this connect to that
  220. Program DX6i T-28 Trojan with FLAPS
  221. Question on Controllers and receivers
  222. need a good starter motor for my plane
  223. free plan for motor and prop
  224. Couldnt get motors to start
  225. How to drill straight for control horns
  226. Newb, getting into electric
  227. Paint on Monokote
  228. exceed slope diver
  229. Converting electric to glow airframe
  230. What size engine do I need?
  231. Alpha 40 Prop/Glow plug suggestions
  232. first 4 channel
  233. Will Futuba servos work in a JR reciever?
  234. Broke of pin on needle on ASP(Magnum) .91 four stroke
  235. Battery weight help
  236. New Magnum XLS 46 settings
  237. Ripmax Pro Peak Prodigy II - manual?
  238. Alpha 40 (RTF) Engine placement angle?
  239. C.G. Airplanes
  240. Help Setting up servos
  241. New Magnum XLS 46 won't start
  242. Transmitter battery upgrade
  243. Did anyone fly on New Years Day?
  244. Any Fun Fly pics of videos?
  245. Where do you buy your fuel?
  246. Having Problems with Servos Geting in a Bind
  247. Rc foam glider conversion
  248. Just Bought A Used Dynaflite Butterfly...NEED HELP
  249. Help! Need to add weights. Where?
  250. I want to wish all my RCU Friends a Happy New Year
