View Full Version : Beginners
- What .90 size plane?
- Starter Plug-in
- Futaba 9CAPS?
- First plane, 3rd maiden
- G3cotroller as buddy box, is ti possible?
- Mini Ventura
- First Flight of the Season
- firebird scout
- Fuel on reciever and battery
- Higher clunk science
- Balancing Question
- 9C Programming Problem
- Fixed the warped aileron...
- Covering Shemes.....Help!
- Quick question on glow plugs...
- How to align control horn plates
- Cheaper Fuel?
- A little lesson in the physical laws of nature
- rc flying terms/lingo
- good 2nd plane???
- What are the setups for mode1 and mode 2 ??
- props
- Awesome Day at the Field
- First Airplane
- Help me diagnose a problem
- receiver compatibility
- New plane hauler
- I need a good 3rd plane
- slow stick
- good electric begginer plane
- Parkfliers?
- vertical tail wing
- Morris BalsaNova as 3rd power plane?
- Broken tail, what to do?
- Bummer:(
- four star 40 engine mount problem
- Finding Torque for Flaperons
- Epoxy Paint for touchup/trim?
- Eagle II trainer Plastic wing Tips?
- engine for prop jet???
- Interesting...
- Battery cycling?
- Pumping gas before starting engine (weird question)
- Prop holder (white plastic thing?..)
- Servo needs extra power
- Problems with my Edge.
- Cowl fueling question
- Biplane Aileron Set-up (Please Help!)
- Flying Field Protocol
- need help with great planes cap 21
- Engine getting messed up?
- Saito 82 Break-in Help/ UCD .46
- CofG Pattern Plane?
- CA on Covering
- Nexstar Repairs
- Done!!!
- Covering Tension
- glow v elec./ ford v chevy??
- How long did you keep your model airplane in one piece?
- Art Grabow passed away.
- Store airplanes in a Garage
- Places to fly - How do you pick? Anyone in Ohio?
- relocating the servos rearward.
- RTF Kits
- Radio Setup Help(please)?
- succesfull first flights
- Trying to Identify a trainer
- JR radio with hitec reciever?
- crystals
- Best 2nd Plane if I have the Following...
- balance
- Cline Regulator
- Uh OH!! Newbie to TD
- GWS Be Found
- Hangar 9 PTS P-51
- Throttle Servo Hookup Question
- Battery help
- software for making decals
- Convetring a Ripmax eletric spitfire to ic
- Robart hinges
- Tygon for Nitro?
- alfa trainer 60 i cant get it to start its brand new and everythings charged
- Choice for 1st plane
- Are Thunder Tiger/Super Tiger 2 Strokes Any Good?
- ANYONE OWN A ALPHA 60 TRAINER?JUST GOT MINE TOGETHER ON CHARGE.AND WAS IT A GOOD PLANE TO LEARN ON.
- Jumped In The Deep End!
- Took the bait
- MRC 989 PRO CHARGER. IS IT OUT?? WHAT EXACTLY IT DOES???
- Enya 60 Info needed
- Needle valve through cowel
- Duracraft Durabat
- Beginner Radio question
- FailSafe
- Believe it or not this is the culprit that got me started.
- HOW TO PROTECT OUR EXPENSIVE RADIO?? DID ANYONE THOUGHT OF IT????
- full house sailplane servo setup?
- 4 Stroke spinner adapter?
- Nexstar taildrager
- gas plane
- Determining Max Payload
- need some measurments, and or the horiz stab plns for a 4*
- Electric trainer and acrobat?
- Trainer to Warbird: IT CAN BE DONE!
- Prop sizes for G23
- Reverse Elevons
- O.S. 91 Surpass, what prop should i use?
- Twist Hardware
- superstar help
- first victim
- whats the difference between gas and electric air planes?
- Does longer fuel line make a difference?
- Setting throws
- Fuel Proofing?
- Funtana 40 VS CAP 580 ...few questions
- Whats the diff between 3d and reg flying
- Hobbico Hobbistar 60 Select RTF Beginner Thread.
- I WROTE TO TOWERHOBBIES, AND I AM WAITING FOR THEIR REPLY!! MEANWHILE PLEASE HELP IF U CAN.
- Different between 4 cycle prop an 2 cycle props??
- cox 049 low speed
- Some battery questions
- Battery Charger advise/basic: 1650nimh
- I need a new weather channel, mine's a liar!
- Prop nut on 4 stroke
- Plane Goes Crazy!
- Servo on my Hobbistar buzzing??
- Got my Old plane out of the Attic NEED SOME HELP
- installing blind nuts
- 2ND BEG BUILD " THE VENTURE 60"
- Charging receiver battery help
- Licensed pilots vs No experience
- Prop Balancing
- A good .61 engine
- Futaba and BlueBird
- To Old
- Bigger Prop = black oil?
- Are all servos created equal?
- Engine Question...
- Problem with my super tigre 90
- Second plane maiden flight will be today!
- Amnesty Friday
- Phoenix Tucano maybe?
- Live-Stick???......whew that was close...
- Computer Radio
- 4 channel planes
- Tx Interface need help!!!
- Made my FIRST FLIGHT!!!
- cowl for Kadet Sr.
- Pull-Pull woes
- Opinions on these parts?
- What is a good engine for a four star 40?
- Free Rc Simulator
- WHAT CLEANER TO USE
- Installing Robart hinges
- Brand new, rookie, newbie - free flight maybe?
- Beginners FAQ?? We need your help!!!
- MOVED: site?
- electricflight.co.uk
- Crash Sale
- Venture 60 engine advice
- Triple Prop versus Reg prop
- WHAT WOULD BE A GOOD SECOND PLANE?
- Where to buy Saito motors (and other R/C stuff)?
- Sticky?
- STILL A BEGINNER . . . New problem . . . stabilizer struts??
- where to start??? help!!
- Hobbico Superstar EP RTF for only $140?
- CG - Hobbico "Superstar 60"
- What's it called?
- Cap Castrol Avaitor
- Old Radio Control Manufacturers
- Radio Question??
- Looking for suggestions on aileron throws
- Trainer suggestions
- prop nut problem
- covering...
- Thrilljunkies.com jp3 piper cub
- Engine mounts
- Four planes from the 80-90's
- OS 40 LA thing
- Need the help of an expert
- FIRST FLIGHT DISASTER
- Ideas ! Can I have suspension on my plane "funtana 40
- 3D planes
- Stupid Nose Cone!
- Second Plane........
- four star 40
- blind nuts
- LT-40 training - first landing
- Funny thing during engine break in...
- thunder tiger .91 4stroke
- 12V Power Supply
- HET Typhoon Micro 6
- Found a used nexstar setup
- engine quit when verticle
- danger, 4 stroke prop coming off
- Batteries
- Instruction video
- ESC question
- Are engine mounts universal?
- easy fueler valve
- Servo Specs
- AXI numbering
- should i????
- how do you post a pic
- kadet LT-25 build!
- Vacation Planning
- Need another KIT???
- Another 2nd plane question
- Looking for advice on a radio
- transmitters
- It's official
- Are Flight Sims Worth it?
- 4 Stroke with Funtana 40 ...What do I buy ?
- Is the Sky Raider Mach II worth it?
- DONT LAUGH__ need help!! beginner
- Dynaflight Butterfly
- HELP with learning rudder control
- 4* 60 wheel pants
- Taking the dihedral out of the nexstar...
- 4*120 Kit Build
- Is this a good plane?
- Installing pushrod guides in Tiger 2 Kit
- tail question
- are rd planes hard 2 fly
- alierons to flaperons ?
- Looking for an instructor in Houston
- anyone wanna fly today around memphis tn are?
- Wing dihedral
- alfa trainer 40 size eng 6 lbs.
- Pick on "MinnFlyer" This Evening!
- 4d foamy???
- new to flaperons
- posting some pics of my "trainer plane"
- i just finished
- need someone and somewhere to fly
- IS flying expensive? And other newbie questions
- (In reply to WHOM)
- Nexstar covering
- Club dues
- Han Solo School of flying please!!
- Need advice from Instructors
- BUBBA DAY!!!
- HELP NEED DEFINITIONS!!!!!!
- Kadet MkII - back in the air!
- exhaust deflector
- {Question} - GMS .61 BB Ringed w/Muffler
- Solo ... w00t!!!
- whats a servo?
- another "fly without an instructor" question
- Membership Finally
