View Full Version : Beginners
- Spinner & CG Question !!!!!!!
- Trainer or SIM ??
- Fiberglass Cowl
- smoke system colors?
- what type of Zurich sunglasses are best?
- visiblity
- OH NO-Not another trainer question
- needle valve
- engine...
- Need instructions for Q-Tee
- Super Kraft's Astro Trainer H_40
- Nylon Tape
- engine difference?
- power panel help
- Plane I'm buying
- tricks
- Is there a way?
- 1 Week to solo!
- First flight!!
- wilson feild
- JR 600 mah battery
- question for those with a NEXstar
- overflow line...is it necessary?
- How to clean an engine
- First Solo!!
- Redrilling the engine mount
- Engine mount question?????
- Flaperons on an Eagle 2 by Carl Goldberg
- Biplane as second plane
- PLEASE HELP!!!!!! W/ 0S /46FX
- Speed reducing maneuvers
- Spinner nut question
- Got To Say,If There`s A Better Trainer...
- just about done
- backyard flying?
- ARF Kit for first time built
- What Should My Second Plane Be?!?!?!
- Four Star 40 with OS .25FX engine!
- Glow Plug Tutorial Please...
- Mayday!
- ESM F1 Trainer
- Transmitter Question...Channels?
- engine
- HELP!!! I broke the needle valve on my OS 46
- Help Finding A New Plane!!!
- TTPegasus 40
- trainer repair
- How effective are Flight Simulators...
- Choosing the right density Balsa for a build
- Dose more Amps mean more power or time?
- Propeller questions!
- Can I store my planes in my outdoor workshop?
- So what's in your field box?
- Winter Flyer
- Logbooks
- Glow engines Right side up or upsidedown ?
- Waiting!
- Will Hobby People ship internationally?
- Would you join a club that drinks alcohol while flying?
- My P-38L
- I want to get a Plane..Completly Lost.. Help?
- How to store arfs new in box ?
- Fuel tank w/engine rotated
- Access hatches
- Can a expert please become my freind?
- Anybody fly at cobb county rc club in GA
- sanwa rd 6000
- Engine tuning problems
- What can't my trainer do?
- Giles 4 stroke
- antenna length
- What Radio to go for ? FM or PCM ?
- Help if you do you get a beer!
- Over reinforced planes?
- GP PT-40.....46 OS MAX FX engine ok???
- What to use 10% or 15% fuel?
- Elmers white glue?
- how do you tune your engin?
- My Tiger II is flukey, should I ask for a refund or replacement?
- Second Plane
- WHAT SHOULD I DO MY MAIN GEAR IS CROOKED (Dbl Post BUT I REALLY NEED HELP!!!!!!!)
- Nexstar Wing Mount on Avistar?
- Will stick on lead weights near servo tray cause any interference?
- Free flight lessons
- 40 vs 60
- picture of a plane
- i fixed it
- Solo'd my trainer for first time today!
- AMA?
- The TRUE cure time of epoxy...
- Saito 100 mounting
- ESM F4U Corsair?
- SHOOT MY STUPID TIGER II is 9 LBS and I need to add 1 lbs of NOSE WEIGHT TO BALANCE!!!
- Uh-Oh! Tiger II won't stand on Landing Gear Minn, DB, HELP!!!
- Tiger II Finished!! er well almost
- it's not working!!!!! Pico Cub
- What radio to begin with
- Flap Programming
- Thunder Tiger Classic Trainer 40 ARF
- Permanent fuel tank installation?
- plans needed
- GP Extra 300S .40 kit engine dilemma
- Spage walker 2
- Propeller + Ground = Engine Damage?
- My engine recommends 10x6 break in prop, will it really screw up with a 10x7 APC?
- Hmm How do I make my Tiger II ARF easier to see in air?
- Acrylic Plastic model paint : Fuel resistant? Suitable for Prop Painting?
- If my pushrod is rubbing against sth, is it ok?
- Hmm will Home Depot Socket Screws work?
- Tiger II Canopy Gluing Messup + RC Z 56 wont Dry
- Avistar nose gear stress
- Electric Fuel pump
- Thunder Tiger Trainer 60
- Would you really use a weed eater motor?
- Glow Powered Park Flyer
- power starter battery clips or panel ready
- fuel pump installation
- What is XX% (i.e. 35%)?
- 2-4 stroke
- Huston we have a problem
- Question on 4-Stroke Thottle Linkage
- Engine fuel line pinch test question
- i need parts
- hello
- First Solo! Certificate?
- Need help with 9C and Aileron
- fuel ? for TT pro 46
- Frequencies
- nexstars realflight transmitter interference
- Should I use Resin & Hardner or Epoxy?
- help wit old Controlair
- did i do good or not...???
- engines
- ? about props
- Vertical Stabilizer re-attachment?
- Modifying battery packs
- Cutting Fiberglass
- Anyone flying the Hobbico Superstar 40
- Is $15 too much for flight lessons
- Evolution 46, the saga comes to an end!
- What do you do with your trainer after you've learned to fly?
- Best .46?
- Good 46 motor to start with
- First Plane
- Second plane
- Tower 46 flameout trouble
- only 7 flights a day? C'Mon
- what size engine for a sig 4* 40
- davis deisel
- Trainer and Harsh Areobatics= CRASH n BURN
- Balancing act
- What is 3D?
- Mariner 40
- props- wood or nylon?
- Lazy Tiger with LA40
- Dragon Lady ok for second plane???
- LT-40 advise
- how hard can you push a Superstar?
- Painting your prop?
- Now this is the Ultra Super Super Sportster!
- Fly w/o Canopy?
- Super Tigre owners BEWARE !
- First Airplane, need advice/comments
- the worlds greatest trainer! is...
- Nexstar Auto System
- MATCHING ENGINE-PROPELLER
- My tower hobbies engine chicken stick
- Retract gear kit
- Fairchild 24 with .049 engine, beginner
- Any advice?
- Question for the Experienced
- I can't start it!! MDS .18
- Need advice on first nitro plane
- Going crazy here, need some advice...
- engines?
- Why are all my controls Backwards?
- engine cowl?
- Radio question
- Park Flyers
- Building a flight box
- I crashed my first plane!!!
- Next plane
- PCM and PPM
- Additions to Real Flight G2 Lite?
- Zagi XT w/Focus 3 FM radio question....
- Talk about a crappy day flying....
- A/C adapter for charger?
- engine for 4*40
- starters
- Engine upside down?
- Advice on right size OS engine for Sig LT-40
- .46 on a sportster 60
- Which stick for the rudder?
- Fuel tank rap
- Flapperon question
- Trade???
- Replacing stock fuel cell
- muffler
- Wing question
- engine mount question
- Any intructor in DALLAS
- Looking for Eagle 2 Plans
- Airtronics transmitter-computerized vs. not? benefits?
- hows this for a trainer
- NexStar's Auto Pilot (ASF) - who's using it????
- Begginer looking for a plane.
- Debond Monokote
- soloed today-- got about 7 flights or more. very excited and hooked
- Nose wheel question
- Beginners view of Multiplex Easy Star
- New .46 FX... Silencer Problems?
- QUALITY field gear
- noob.Please help
- odd question on turning
- Futaba Charger on a Jr Radio !!!
- Alternator for glow engine
- Help with Retracts for Spitfire
- Ask the people who know
- My Trainer
- Chicken wings
- advice on learning to fly on your own
- French Fries
- Water
- Is the field ok?
- Three line tanks require T-thingy?
- Fuel Dot Question ????
- rc videos?? where to find?
- broken parts in new kit
- Latest Mars Photo
- urgent ??
- Trainer Cord
- batterys
- I went to the field today to go it alone
- Trainer cord or not
- My new plane is here!
- Cold Weather Flying !
- Newbie w/ crashing Aerobird
- new guy looking for first plane
- Article for those new to the hobby
- Flight Simulators ?
- Is This Common?
- How to be Senior Member...
- How does covering stick?
- Turn rate not equal in right and left turns
- Reciever Wire Question ?
- not-quite-straight elevator...
- Ultra Stick 60 servo question
- R/C Logbook
- spinners
- Old School Learning
