PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Satio Question
  2. LiFePO4 batteries
  3. Hubsan FPV spy hawk with auto pilot
  4. li-po batteries
  5. 4 channel beginner planes?
  6. prop choice
  7. Need just a little bit of help,,ya right!!
  8. You Pre flight the plane. But what about You?
  9. How to secure batt and rx in plane?
  10. what next?
  11. Gas RC was a mistake !!!!
  12. Where Will RC Be In 10 Years?
  13. Pre Noob first plane
  14. To simulator or not to simulator?
  15. Cutting tail weight
  16. eflite retracts 60-120 size
  17. Scale KITS AH-1Z Cober
  18. Saito 56 or 62
  19. hobby zone mini super cub - flys right turn
  20. Broke in a new field today
  21. What's with this weather???
  22. which glue for aero-cell foam?
  23. Reaming a Prop
  24. Beginner RTF Park Flier
  25. Happy New Year to all!
  26. Phoenix Extra 330S 60" setup issues
  27. Witch Lipo Connector is best?
  28. Wanting to change from 4S to 5S lipo - Will my motor and ESC like it?
  29. Reducing weight 4*60 tail
  30. Old avistar 40 ARF new in box
  31. building boards
  32. Is Gas Engines a Fad?
  33. Repair is on the bench, And I am not In to it.
  34. Valley View Rc profile yak
  35. can I mix ar6200 RXs?
  36. airplane suggestion
  37. What is the best charger?
  38. How many volts for a hobbico 90 torqmaster starter
  39. Hobby Zone Supercub power issues
  40. LiFe charge question
  41. Lipo charge question
  42. Merry Christmas to all my rowdy RCU friends
  43. Red Sleigh Down
  44. Santa has been clearded!
  45. Futaba T6XHS Retract Gear setup help!!
  46. Need Help building Beriev Be-4 model
  47. Zenoah Engine
  48. Receiver question
  49. What size StiK?
  50. Space Walker and PT-19 similar?
  51. What Engine do i have?
  52. Profile foamy
  53. Repairing a Airplane wing
  54. Saito Engine Problem
  55. Some advice for a less than noob
  56. Balsa Airplane HELP
  57. landing gear wobbles
  58. super cub
  59. 1st pull pull setup?
  60. Batteries and props
  61. First plane, which servos?
  62. AirAge took care of me
  63. Need Help cutting grass on field fly free . Calhoun ga.
  64. Pitts ARF outfitting
  65. PT 19 crash pic
  66. new to airplanes but not helicopters
  67. PJS 3D 500
  68. Big Stick 60 vs Super Stunts 60
  69. Need a former profile for a giant scale super sportster
  70. aileron basic set-up (centering , trim question)
  71. ARF RQ-1-B Predator build *NEED HELP*
  72. Imax B6 charger question...
  73. Estimate flight time given RX battery size and servos
  74. Just a question
  75. Hole size for robart pin hinges?
  76. 1st. build electric
  77. Motor just Beeps ???????
  78. Epoxy strengths
  79. Fly RC Magazine Question
  80. QPCM
  81. 2.4 recievers
  82. Champ help
  83. park flyer advice needed...
  84. Learning
  85. Battery Size
  86. New plane for Newb.
  87. Training with Parkflyer
  88. fireproofing?
  89. Gas Motor installation help
  90. FRUSTRATED!!!!!
  91. AirAge in California
  92. Newbie Introduction!
  93. Nitromodels Yak-54 120
  94. correct Antenna orientation
  95. One of those days
  96. set time on 4 stroke
  97. Electric pump
  98. Need some ideas on putting balsa on foam wings.
  99. Replacement for Spektrum AR500 Receiver
  100. Bubble canopy for a hydro
  101. AirField parts?
  102. P-51D BL DSMX RTF
  103. CF landing gear issues
  104. Spektrum DX7 Programming Question
  105. Radio Update and other ?
  106. How to pick up the crash and move on
  107. nitro engines
  108. trainer cord
  109. How's "ya'all" doing
  110. Slowing down after landing
  111. Camera harness...
  112. AT40 Low Wing Trainer with Flame Decals powered by OS 55 Max AX
  113. What is a good engine for a Tower Kaos?
  114. help with air hogs
  115. Where to start oever?
  116. Batteries
  117. New Guy Intro
  118. are different brand receivers and servos compatible?
  119. Servo
  120. New to electric power
  121. Pushrod binding - help!
  122. brushless motor C-20-155
  123. Buddy Box
  124. PT-20 washout
  125. Pushrod Geometry
  126. First Low Wing
  127. Looking to upgrade to a faster more agile rc plane
  128. HELP!! Cannot start OS max 25LA engine.
  129. Applying Skis to The Electrifly Sopwith Camel
  130. Flight Simulator
  131. lights on an aircraft carrier
  132. Need help with measuring voltage and amps in brushless motor
  133. Warbirds Over the Rockies Pictures
  134. HobbyZone SuperCub turning problems
  135. Is it my Radio?
  136. Receivers
  137. Futaba receiver antenna
  138. Servos
  139. reiews
  140. VIDEO - Need help determining if my new motor is running right...
  141. alternative ways to heat the glo plug?
  142. Omega fuel question
  143. Very large trainer
  144. Throttle servo question
  145. Radio Choice
  146. Vertical Stab Slightly Canted
  147. Buddy box compatibility
  148. question about mixing my own fuel
  149. First Gasser ?
  150. RX batteries
  151. Airplanes!!!!
  152. Alpha .40 Stall on Throttle up...
  153. Conversion???
  154. Propeller Fit on O.S. .61FX Crankshaft
  155. DX7 with Lipo battery
  156. DX7 fail-safe
  157. Smoke on my super tiger60
  158. Which on would you choose
  159. new plane
  160. HobbyZone Super Cub DX8 Settings
  161. Am I Ready to be called INSTRUCTOR?
  162. Jr nes-513 retract servos
  163. Fiberglass wings' leading edges with Duck drywall seam tape?
  164. crystal?
  165. I was going to fly today but ...
  166. buzzing servo
  167. binding my remote
  168. My flying buddy is now a Marine
  169. Good Ol' LT-25
  170. Engine mounting bolt question
  171. O.S. 55AX dying
  172. AR600 Spektrum
  173. Sig Seniorita and Mini Telemaster about the same?
  174. Fuel tank mounting question...
  175. Four Stroke Engine in Tower Trainer .60
  176. Avistar
  177. d/R and expo question
  178. Servo suggestion
  179. Aeronca Champ ARF?
  180. should i get a sig somethin' extra?
  181. Best small scale flyer
  182. Need help picking plane for my power system
  183. Electro Stik Battery
  184. WRAM Relocated
  185. whats rong with my easystar?
  186. Suhkoi SU-26 scratch build
  187. best battery for motor?
  188. Buddy Boxs
  189. which motor?
  190. Learning Progress to more manuvers , planes?
  191. Log Book
  192. Hot wire foam cutter
  193. Gws slow stick
  194. Balance Point of Sig Kadet Seniorita
  195. need suggestions for a new plane.
  196. Few questions before I buy my first plane. (New pics added!)
  197. what is this?
  198. New pilot, need a suggestion.
  199. Nexstar or Easy Star?
  200. I guess I'm getting better
  201. magnum 46 vs. OS 46
  202. Question about wing joining...
  203. out of the ordinary
  204. Lucky day
  205. Is Active Powersports for real?
  206. want to copy some plans to a disc
  207. simulators?
  208. Amazing !
  209. Here is the dummy with another dumb question
  210. Older Equipment
  211. Battery question
  212. RX battery for Escapade 60?
  213. Mounts
  214. Put hands together to condemn it strongly!
  215. engine noise
  216. Anone familiar with this engine
  217. Trainer X or Trainer Y?????? Opinions please
  218. Glider ESC set up, brake question...
  219. How to paint instead of monokote
  220. Hawksky not flying
  221. Rimfire 400 mounting screw size?
  222. A question about ASP 52a and OS 46fx mufflers
  223. Unequal Aileron Travel
  224. Radio
  225. dx6i and parkzone stryker f27q
  226. 4* 60 4 stroke.
  227. Newbie who is ready to jump in
  228. One servo shaking like crazy
  229. Evolution .36 won't suck fuel. Compression problem? (Video included)
  230. Best hinge tape?
  231. OS32 SX muffler replacement...
  232. O.S Max 25
  233. This isn't going to work... Is it?
  234. What is a "Reversed Servo?"
  235. Sea Cruiser 11 plans
  236. Unmatched aileron servos ?
  237. Unmatched aer
  238. fiberglassing
  239. Won't roll!
  240. Electric beginer plane that has both top and under wind mount.
  241. Geared to Direct Drive
  242. motor issues
  243. Phoenix simulator PC cord.
  244. DX6i- Not happy!
  245. Senior Telemaster ARF Assembly Problem
  246. Helping Hand!! Soldering! WOW!
  247. Gorilla Glue and Milled Fiberglass
  248. Beginner Setup Issues
  249. How ? Remove old covering from Airframe
  250. Atlanta Hobbies.
