View Full Version : Beginners
- vinyl coating?????
- Rebuilding
- I need help for my OS LA 46
- fuel lines - help!
- Anybody who owns a Futaba T6XAs radio, help!.
- Nose gear strearing
- Sig Kadet Sr. Arf
- Lt-40 W/ .46fx ???
- OS 52 vs magnum 52 vs saito 50 Help!
- New guy with an Avistar
- Where to learn this stuff...
- Flight sim cable wiring diagram
- beginner help??
- First Powered Plane
- When do you Solo?
- ggrrr....weather!
- firewall problem. need help!
- First RC: uni assignment: has to be scratch built! help!
- Motor mount angle
- Anyone have links for learning about engines?
- Finger Postion
- Solo... sort of
- break-in procedure (Am i rich or lean)
- What engine for U Can Do 3D?
- Gyros
- Still need help :(
- Good Flying Scale Plane
- Question about "Pinch Test"
- Stupid Question BHP?
- Wich aircraft next??
- Any tips for building (finishing) a Tower Trainer .60 ARF?
- Is this a smart thing to do?
- Hobbico Quick Field Charger MKII and JR Rx Batteries
- Hello from a Heli pilot! Shoping for starter plane.
- Sport bipe for second plane
- GP Cessna 182, any comments?
- what kind of field charger gives you alot for your money?
- Good lesson today (My first taste of windy flying)
- Help
- beginner / Trainer... First SLAM DUNK OUCH...
- What tools for your fieldbox?
- Trickle Charger?
- Patching holes?
- My plane does a roll to the right but not to the left, why?
- On-board video..........
- maximize battery life
- Fighterbird
- Crosswind approach...
- engine choice
- What kind of fuel?
- Hobbico SuperStar .40 Select CH 44
- New Beginner Plane
- How do you loosen your prop nut?
- Glow igniter battery life down or glow plug ?
- flaps?
- Does anyone know of a club in Brisbane, Queensland, Australia?
- Prop size on TF Nobler with OS46FX
- prop sizes
- os la 40 engine cuts out after five mins of fly need help please
- ReFueling
- Reverse Servo
- What next after a trainer?
- Balancing the Aircraft
- Can you put a .61 size engine in a .46 size plane?
- First Low Wing
- Good next step from WM Super Stunts
- Sweet First Flight On Glow !!! :)
- Hinge question
- 1st nitro plane
- Electric Flyer Converting To Nitro Needs HELP!
- Trainer planes?
- Larger wheels on the Superstar
- my 1st low wing...
- Wood Types
- Second Plane
- secure fuel tank, battery & receiver
- need good beginners package for cheap
- Wing Bolts verses Rubber Bands
- Wot's monokote for?
- Finally have made a start!
- Field Box Contents
- Is it nose or tail heavy??
- OS MAX 91 vs Saito or YS 4 strokers
- Strange engine problem (Piston Jammed)
- I dumped my plane on the first day
- Poly Glue Removing
- Took the first steps today!
- Prop Size
- What's a Frise aileron?
- I want to buy this plane!
- Got my first flight(s) in today
- What is Balsa rite used for?
- Newbies...... here is a great combo.
- Unabashed pitch for BalsaUSA Stik
- "built In" Right Thrusts
- Need Radio Equipment
- Happy Birthday MinnFlyer
- super stick 40
- adding right thrust
- lithium ion battery for a slow stick
- Help with flying my Zagi SI
- UK trainer choice
- Ok, add me to the list..... :)
- instruction
- Any secrets to landing on windy day?
- Norvel BigMig Engine Help Please
- Orientation question
- Check out this beauty!. my new plane.
- 2nd Plane
- Fuel Dot on Plane with a COWL (Not sure of Setup)
- Solo Completion
- Putting a TG PRO.61 in .40 - .50 size plane... Anyone done it??
- prop size
- Glow Plug Issue
- newby needs input
- after run oil, is it neccessary?
- Help me out here
- Prop / breaking in the engine
- Engine Tower .75
- Rudder
- two basic building questions from a newbie
- I have a plane, now what?
- A solo certificate please
- CG..Superstar 40 Help!!
- Starter Zipedtied to a gell cell battery
- GWS Pico stick indoor flyer
- Painting plastic?
- Checklist
- Engine mounts
- Help with OS engine
- What is pylon racing???
- what i need for...
- Something is wrng with my Mini Piper!!!!!!!
- Hobbico Accu-Cycle Tx/Rx Battery Cycler
- Hobbico Trainer 40 question
- Looking for an Aileron Trainer
- radio control layouts whats correct
- I Flew On Sunday!!
- First time solo
- Engine Problems!!!!
- First Solo
- flip starting a 4 stroker
- FMS Simulator & PFN
- Props
- Disappointed
- Is there a good way seal Monokote seams?
- Got to Fly,but...never have
- Took the plunge
- Starters
- Flew today !!!!
- Engine
- Aerobatics help ....
- Made my big order
- Finally got to fly my Superstar
- Real flight g2 vs real flying, how similar are they and can I advance using a sim?
- Sig Kadet ARF vs Kit Engine Size
- First time flyer
- Somethin' Exrta finished
- First flight with Avistar! Good and bad
- How do you break in an engine??
- Engine Questions? Tower .61
- which plane to fly (or crash)
- Wing balance problem... help please.
- just got a first plane HELP
- what skill level would you rate a Modeltech Extra 300s ARF w/Magnum .28 at??
- More Pull Pull help.
- Small field boxes
- Tower Trainer 60
- Engine Mount
- Which kit
- US 40 retracts
- Got Planes, what Know?
- Hobbico Avistar Complete Construction Manual
- Which is better
- Scooter vs Schoolboy
- OS Valve needle
- OS Engine QUESTION
- External Fuel tank on Profile
- What TX?
- Plane bounces too much on take off
- Easy Sport .40 Maiden
- Plz help, beginner, Plane not flying straight?
- Instructors?
- Something to feel proud about!.
- Kaos 40 arf
- Ailerons on a Slow Stick
- Towers Hobbys Kaos 40 ARF
- refueling help please
- Gyro or Co-Pilot?
- Tipsy as a first plane?
- tail control surfaces -Firebird
- Back from Club and LHS
- Another newbie
- I Need a Tachometer, suggestions?
- I need help getting started
- MAS vs. APC Props
- My first crash
- Saga of a newbie
- soled
- Making my first step
- This is what I had in mind, suggestions?
- Covering over covering
- tail heavy-nose drops
- New and YES Addicted... Loving that RUSH!
- JR 537 servo vs hitec 425bb are JR worth extra cash?
- need some help on wire connections
- 60 size trainers
- Father Son outings
- Recommendations for a kit
- Crash and Burn?
- Soloed! Soloed! soloed! today
- Hanger 9 cap 232 Sport
- Engine wont start
- Weather
- Expanded scale voltmeter, which one?
- Kyosho trainer cover??
- Futaba car servos in a plane?
- New here, hello
- Guillows Vought F4U-4 Corsair modification 'help'
- Trying to select your first airplane? Read This
- Problem with inverted flight?
- How do I fly a low winger?
- Goldberg Tiger 2 60 Kit
- engine for dp 120 ultimate
- Does anybody know of any good sites with videos?
- CG Freedom 20 Help
- Engine from EBAY question
- newbie in albany, NY
- Balancing my LT-40
- Crosswind approach to landing.
- Starting out again in Baton Rouge
- Removing Decals / Stickers .........help
- building basics help
- Balsa cowl for 4*40
- What kind of Plane is this
- trying to fly my cub
- First Flight, My Plane!!!
- VMAR 540T edge Build it or Sell it ? HELP
- Quick update as to my progress :)
- Newbie Again Wondering if this would be a alright set up to start
- Soloed today!
- Newbie Needs Help
- What is the difference between mode 1 and mode 2??
- Looking for a good deal
- 2 stroke vs 4 stroke size comparison ????
- Overflow Bottle?
- help with begginer engine
- Do i need to use a glow starter (Glow Clip) if i have a 12v engine starter?
- Second Plane
- 4 blade prop??
