PDA
View Full Version : Beginners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 [53] 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
  1. Lipo Batteries and balance charger
  2. Drilling straight cntrl horns
  3. +6v rx battery
  4. nexstar diving problems
  5. Better Propeller?
  6. Storing your Planes @ Home
  7. what happened
  8. I'm new
  9. Snap??????
  10. Which is the most durable 4 channel plane?
  11. Ouch! That hurt!
  12. which 2nd plane?
  13. Motor w/pinion
  14. Stall strip
  15. Tiger 60 changes
  16. JR XP7202 w/ JR s400 buddy box
  17. .25 trainer arf
  18. Need help with JR 7202 radio
  19. What is a blog exactly ?
  20. Setting throws
  21. had a good find today!
  22. Problems with ailerons
  23. fill valve question
  24. Why does it screech like that?
  25. Senior Telemaster ARF or not to ARF
  26. ahh please help - NEXSTAR
  27. RX battery question
  28. Monokote
  29. tail trouble
  30. 3 1/4 TRU Spinner
  31. multiplex easystar help
  32. Nexstar Prop
  33. SDM Piper Cub
  34. Parkzones WWII Fighters?
  35. Covering question and sealing it to
  36. Can anyone tell me truthfully if it is difficult to fly a rc plane?
  37. Hanger 9 Arrow semi sym. trainer wing flutter..?
  38. Has anyone converted a Sig Rascal 40 -Glow to Electric?
  39. Hitec RCD Supreme Receiver - Anyone know anything about these?
  40. Well I did it today.
  41. Rx Upside-down - bad idea? Mounting small servos?
  42. low vs mid wing?
  43. Prop for Saito 91?
  44. J-3 Cub 25 ARF
  45. First low wing / Tail dragger, which do I buy?
  46. Flying with skis - trike or taildragger?
  47. Plane for 4-year-old?
  48. Have to plug a catalog
  49. slow throttle response?
  50. Trainer and Servo selection
  51. Possible?
  52. 2nd plane?
  53. How do they do that????
  54. first flight help?
  55. new futaba radio stopped working
  56. Single / Dual conversion receivers
  57. Need help with setting up
  58. Second plane... need help
  59. 2nd high wing
  60. Monitoring RX batteries
  61. Winter flying
  62. Engine cut???
  63. Gas 2 Glow
  64. CESSENA 182 by Hanger 9
  65. Calling ALL owners who own The Sundowner Fuormula One
  66. Newbie problem with engine
  67. Futaba Digital Servos
  68. take-off with a taildragger
  69. Second airplane best option for intermediate
  70. good p 51 trainer?
  71. trainer box questions
  72. Identify this plane?
  73. Soloed today!
  74. 2nd Flight, good and a little opps.-Now with Video-
  75. switch 3 blade prop to 2 blade?
  76. New engine starting problems
  77. I Need help with Dual rates and expo...
  78. Servo Help
  79. what to look for in a transmiter
  80. Need a starter plane
  81. need a good start
  82. New transmitter requires new receiver, esc, servos?
  83. Radios ?????
  84. 40 trainer: foam or wood?
  85. Weird Electrical Problem
  86. THE NEXT LEVEL
  87. sig 4* 40
  88. Is this a good plane
  89. Modified Trainer Shots
  90. I'm totally hooked :)
  91. CRASHED IT
  92. New pilot
  93. I just bought a new hitec eclipse 7
  94. new to rc, need help with avistar
  95. Idea for ENgine stand?
  96. Cedar Hobbies Stick 40
  97. 2nd plane -- Pulse XT or 4 Star?
  98. Rehinging new ARF
  99. First plane
  100. looking for sig 1/6 scale piper plans
  101. Just Wondering
  102. alpha 40 wing twist help..
  103. what is better ?
  104. Prop Selection
  105. Mixing Futaba and Hitec rc gear
  106. A safer way to start your plane
  107. Pull/Pull cable dependable
  108. FM Vs. PCM
  109. Brushless upgrade
  110. Skyhawk's Nimh 8.4v 7AAA 600mAh for 1100mAh
  111. Hitec RX/ Futaba TX
  112. Servo Reversing
  113. MOVED: R/C Research Paper
  114. Pointy props
  115. Bent / Warped canopy
  116. What do you experienced guys do.....
  117. Sig Mid Star dihedral
  118. why not c a
  119. Where to get Blind nut
  120. ca and epoxy
  121. sig kadet ARF antenna
  122. Saito 82 vent line
  123. 2.4Ghz
  124. DX7 v JRx9303
  125. Hitec servos
  126. Carl Goldberg Gone
  127. Another New Member With Plane/Engine Question
  128. Indestructable PRANGSTER for beginers and dearing arobaics
  129. AR7000 issues
  130. Saito 82 & 260cc fuel tank
  131. A LITTLE OIL
  132. Water landing
  133. Wot 4 or Spacewalker 2
  134. Sundowner and Beginers don't mix.....
  135. Power Panel II question
  136. Warped pieces in kit
  137. NEED HELP...PLEASE!
  138. My incredible new RTF (somegeek jr)
  139. Umm why did my spinner and prop fly off?
  140. nexstar mowin grass
  141. Servo's for Ailerons
  142. I recommend the Great Planes RV-4
  143. need help with my 2nd airplane
  144. Strokes
  145. Charger for this battery pack
  146. Os engine, 0.65LA fuel consumption
  147. different engine types
  148. anything bad about the dx7?
  149. Need help on picking radios
  150. OS .40 FX need info
  151. New transmitter choices...
  152. 12v lead calcium battery questions
  153. Propellers 101. Help/info needed.
  154. Golden Knight Saitos??????
  155. Ironing Board
  156. ABS cowl in kit
  157. Great Planes Easy Sport vs. Sig Mid Star
  158. e-flite mini pulse question
  159. flaps?
  160. gms motor
  161. clear Lacquer
  162. FP-T7UAF and FP-R127DF compatible?
  163. 3rd plane
  164. U Can Do 60 size with YS 120
  165. What do you think? Too big a leap?
  166. Ballance
  167. Anyone?
  168. super coverite
  169. World Models CAP232R CofG
  170. Just my opinion
  171. Fuel Plumbing question.. help plz
  172. Is it possible to be in this hobby and have a normal life?
  173. Zenoah G-26
  174. Tryin somethin new - Electric flying
  175. Converting gas to electric ?
  176. fueling up nexstar
  177. Shutting fields down / experiences?
  178. Maiden flight...how do you trim
  179. Better Off-the-shelf Cleaner Than Windex?
  180. Plans for SeaMaster
  181. p-51 pts setup
  182. My SUNDOWNER FORMULA ONE
  183. JR 2610
  184. throttle adjustment
  185. How about a NexSTAR 46 Select 4-Channel RTF 68.75" as a trainer
  186. 3rd plane; 1st kit; Suggestions?
  187. Pls suggest a nice Electric plane - for intermediate /expert level
  188. radio to rec prob.
  189. GMS Engine??
  190. Great Trainer if you can figure out what I made it from!!!!
  191. need radio
  192. Digital Throttle Servo
  193. Servos and Batteries
  194. Replaced Lost Trainer
  195. Which four stoke
  196. Im new to the RC world and was wondering
  197. Bisson vs. Slimline
  198. receiver problem?
  199. nexstar chokeing out
  200. I am new.
  201. New prop and spinner problems...
  202. Falcon HX-213
  203. needle valve adjusting
  204. Pilot to plane orientation
  205. help
  206. Battery
  207. Using pins for building
  208. P-51 prop size
  209. Next engine
  210. This is AWSOME !!!
  211. I just fully discharged my nicads, will they still work?
  212. Balancing
  213. Tower Hobbie Trainer
  214. How does a fuel tank work? help?
  215. Fox Eagle 60 runs hot
  216. Body care questions
  217. Glues
  218. Magnum GP 25
  219. Next step up from trainer
  220. Nexstar Select problem.
  221. CG Eagle II build wing tips
  222. New Pilots and New Planes
  223. Robart Hinges on Extra
  224. Nexstar 12 minutes whith a tank i expect more
  225. Nexstar with flaps should i remove airfoil extensions
  226. Receiver question... need answer FAST :)
  227. Update on the cub (no longer using 40 LA)
  228. Can someone explain Prop numbers(Pitches)
  229. Good Engines ,Bad engines???+
  230. Prop Change
  231. Great Planes Standard Fuel Tubing
  232. Trouble removing prop from .40 Super Tigre
  233. prop balancing
  234. crimp or solder
  235. P-51 Mustang PTS setup
  236. SST Simple Scratch Trainer
  237. More lipo for newbs questions???
  238. Prop Injuries... (link)
  239. Crashed and not exactly sure why
  240. Where I started
  241. lipo chargers
  242. How do you contact a RCU administrator?
  243. Kadet Mark II build - Getting Ready for next flying season
  244. shipping??
  245. Flap question - Futaba® 6EX w/2.4GHz FASST
  246. Hobbico = HiTech
  247. Questions
  248. Dead stick landings
  249. Flying club--How do you contribute
  250. Change Ignition on Gas Engine
